BM23PF0.8-42DS-0.35V(51)
    HRS(广濑)
    SMD,P=0.35mm
    板对板连接器 立贴 针脚数:42Pin 间距:0.35mm 排数:2
BM23PF0.8-42DS-0.35V(51) 数据手册
0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A BM23PF Series High current applicable Conventional product (P=0.35mm, 34pos.) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM23PF-24pos. (+2pos. for power) Power lines are concentrated into 2 power contacts (Up to 5A/line) instead of conventional multiple signal contacts. Fig.1 ■Features Space-saving Dimension Example : 24 Pos. 1. Rated current : 5A Receptacle Equipped with power contacts capable of handling up to 5A current. (See Fig.1) Rated current : 5A (Power contact), 0.3A (Signal contact) Header ● 2. Space saving design Compact design ideal for mobile devices. (See Fig.2) Pitch : 0.35mm, Width : 1.98mm, Stacking height : 0.8mm ● 3. Robust [Breaking Strength : 90N] Metal guides prevent housing damage due to incorrect mating. (See Fig.3) 4. Highly reliable contact design 2-point contact design for both power and signal contact ensures high reliability. (See Fig.4) 5. Good mating operation Wide self alignment range with metal guides offers enhanced mating operation. (0.4mm in pitch direction, 0.35mm in width direction) Furthermore, a clear tactile click generated by the unique locking contact design insures complete mating. The narrower and shorter, yet flexible design allows tight installation ( Pitch : 0.35mm, Width : 1.98mm ) Fig.2 Robust design Metal guide prevents connector damage even if mated incorrectly. Metal guide 6. Supports USB 3.1 Gen.2 (10Gbps) transmission Breaking Strength Actually Measured Signal contacts support USB3.1 Gen.2 transmission speed. ■Environmental ● Halogen-free* As defined by IEC 61249-2-21 Br : 900ppm max., Cl : 900ppm max. Br+Cl :1,500ppm max. 90 N Fig.3 Cross-sectional view of mated contacts Power contact Signal contact Fig.4 In cases where the application will demand a high level of reliavility, such as automotive, please contact a company representative for further information. 2022.03 ③ 1 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A ■Product Specifications Ratings Rated current Signal contact : 0.3A (Note1) Power contact : 5A Operating temperature range -55°C to 85°C (Note2) Storage temperature range -10°C to 60°C (Note3) Rated voltage 30V AC/DC Operating humidity range 20% to 80% Storage humidity range 40% to 70% (Note3) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions 1. Contact resistance Signal contact : 90mΩ max. Power contact : 30mΩ max. Measured at 20mV AC, 1kHz, and 1mA 2. Insulation resistance 50MΩ min. Measured at 100V DC 3. Withstanding voltage No flashover or insulation breakdown 100V AC for 1 minute 4. Durability Contact resistance : Signal contact : 90mΩ max. Power contact : 30mΩ max. 10 mating cycles 5. Vibration No electrical discontinuity for more than 1μs. Frequency: 10 to 55Hz, single amplitude : 0.75mm in 3 axis directions for 5 minutes, 10 cycles 6. Shock resistance No electrical discontinuity of 1µs or more. Acceleration : 490m/s2, duration of pulse: 11ms at 3 times for 3 directions. 7. Humidity Contact resistance : Signal contact : 90mΩ max. Power contact : 30mΩ max. Insulation resistance : 25MΩ min. 96 hours at temperature of 40±2°C and a humidity range from 90 to 95% 8. Temperature cycle Contact resistance : Signal contact : 90mΩ max. Power contact: 30mΩ max. Insulation resistance : 50MΩ min. -55°C for 30minutes ➝ 85°C for 30minutes, 5 cycles 9. Soldering heat resistance No dissolution or melting of the resin that will affect the performance. Reflow : with recommended temperature profile; Hand soldering at soldering iron temperature of 350°C for 3 seconds max. Note 1 : The total current capacity for the connector with 40 or more signal contacts is 12A for all contacts.(Signal contact only) Note 2 : Includes temperature rise caused by current flow. Note 3 : Storage refers to long-term-storage of unused items before they are mounted on the PCB. Operating temperature/humidity range applies to the state of temporary storage such as non-powered after mounting on the PCB, and during transportation, etc. ■Materials / Finish Product Receptacle Header Part Material Finish UL Regulation Insulator LCP Black UL94V-0 Signal Contact Copper alloy Gold plating ____ Power Contact Copper alloy Gold plating ____ ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle / Header BM 23 PF 0.8 1 2 4 * DS - 0.35 V (***) 5 6 7 9 8 Series Name: BM Connector Type DS: Receptacle DP: Header Series No. : 23 Contact Pitch : 0.35mm Shape Symbols PF: Power contact type Terminal type V : Straight SMT Stacking Height : 0.8mm Gold plated specification and packaging status (51) : Gold plate thickness 0.05µm Embossed tape packaging(10,000pcs/reel) (895) : Gold plate thickness 0.05µm Embossed tape packaging (1,000pcs/reel) Number of Contacts 2 3 - BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A ■Receptacle A B 1.98 P=0.35 0.8 0.12 0.29 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D Recommended PCB layout Recommended metal mask dimensions (mask thickness : 100µm) Unit : mm Part No. HRS No. No. of contacts A B C D BM23PF0.8-10DS-0.35V(***) 480-0312-0 ** 10 4.25 1.40 2.81 2.84 BM23PF0.8-14DS-0.35V(***) 480-0367-0 ** 14 4.95 2.10 3.51 3.54 BM23PF0.8-20DS-0.35V(***) 480-0434-0 ** 20 6.00 3.15 4.56 4.59 BM23PF0.8-24DS-0.35V(***) 480-0368-0 ** 24 6.70 3.85 5.26 5.29 BM23PF0.8-30DS-0.35V(***) 480-0472-0 ** 30 7.75 4.90 6.31 6.34 BM23PF0.8-40DS-0.35V(***) 480-0369-0 ** 40 9.50 6.65 8.06 8.09 BM23PF0.8-42DS-0.35V(***) 480-0436-0 ** 42 9.85 7.00 8.41 8.44 BM23PF0.8-46DS-0.35V(***) 480-0402-0 ** 46 10.55 7.70 9.11 9.14 BM23PF0.8-54DS-0.35V(***) 480-0370-0 ** 54 11.95 9.10 10.51 10.54 Note 1 : Please place orders in full reel quantities. Note 2 : This connector has no polarity. Note 3 : The specification number(895) in the Part No. changes to(95) in the HRS No. 3 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header Recommended PCB layout Recommended metal mask dimensions (mask thickness : 100µm) Unit : mm Part No. HRS No. No. of contacts A B C D E F BM23PF0.8-10DP-0.35V(***) 480-0306-0 ** 10 3.49 1.40 2.70 2.11 3.41 4.25 BM23PF0.8-14DP-0.35V(***) 480-0366-0 ** 14 4.19 2.10 3.40 2.81 4.11 4.95 BM23PF0.8-20DP-0.35V(***) 480-0433-0 ** 20 5.24 3.15 4.45 3.86 5.16 6.00 BM23PF0.8-24DP-0.35V(***) 480-0291-0 ** 24 5.94 3.85 5.15 4.56 5.86 6.70 BM23PF0.8-30DP-0.35V(***) 480-0426-0 ** 30 6.99 4.90 6.20 5.61 6.91 7.75 BM23PF0.8-40DP-0.35V(***) 480-0317-0 ** 40 8.74 6.65 7.95 7.36 8.66 9.50 BM23PF0.8-42DP-0.35V(***) 480-0435-0 ** 42 9.09 7.00 8.30 7.71 9.01 9.85 BM23PF0.8-46DP-0.35V(***) 480-0401-0 ** 46 9.79 7.70 9.00 8.41 9.71 10.55 BM23PF0.8-54DP-0.35V(***) 480-0303-0 ** 54 11.19 9.10 10.40 9.81 11.11 11.95 Note 1 : Please place orders in full reel quantities. Note 2 : This connector has no polarity. Note 3 : The specification number(895) in the Part No. changes to(95) in the HRS No. 4 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Embossed Tape Dimensions (IEC 602286-3, with JIC C 0806) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Receptacle Un-reeling direction ●Reel Dimensions 10,000pcs/reel 1,000pcs/reel ▶ ▶ Unit : mm Part No. HRS No. No. of contacts A B C G H I BM23PF0.8-10DS-0.35V(***) 480-0312-0 ** 10 16 7.5 4.36 17.5 21.5 330 BM23PF0.8-14DS-0.35V(***) 480-0367-0 ** 14 16 7.5 5.06 17.5 21.5 330 BM23PF0.8-20DS-0.35V(***) 480-0434-0 ** 20 16 7.5 6.11 17.5 21.5 330 BM23PF0.8-24DS-0.35V(***) 480-0368-0 ** 24 16 7.5 6.81 17.5 21.5 330 BM23PF0.8-30DS-0.35V(***) 480-0472-0 ** 30 16 7.5 7.86 17.5 21.5 330 BM23PF0.8-40DS-0.35V(***) 480-0369-0 ** 40 24 11.5 9.61 25.5 29.5 330 BM23PF0.8-42DS-0.35V(***) 480-0436-0 ** 42 24 11.5 9.96 25.5 29.5 330 BM23PF0.8-46DS-0.35V(***) 480-0402-0 ** 46 24 11.5 10.66 25.5 29.5 330 BM23PF0.8-54DS-0.35V(***) 480-0370-0 ** 54 24 11.5 12.06 25.5 29.5 330 Note 1 : The specification number(895) in the Part No. changes to(95) in the HRS No. 5 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Embossed Tape Dimensions (IEC 602286-3, with JIC C 0806) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Header Un-reeling direction ●Reel Dimensions 10,000pcs/reel 1,000pcs/reel ▶ ▶ Unit : mm Part No. HRS No. No. of contacts A B C G H I BM23PF0.8-10DP-0.35V(***) 480-0306-0 ** 10 12 5.5 3.65 13.5 17.5 330 BM23PF0.8-14DP-0.35V(***) 480-0366-0 ** 14 16 7.5 4.35 17.5 21.5 330 BM23PF0.8-20DP-0.35V(***) 480-0433-0 ** 20 16 7.5 5.4 17.5 21.5 330 BM23PF0.8-24DP-0.35V(***) 480-0291-0 ** 24 16 7.5 6.10 17.5 21.5 330 BM23PF0.8-30DP-0.35V(***) 480-0426-0 ** 30 16 7.5 7.15 17.5 21.5 330 BM23PF0.8-40DP-0.35V(***) 480-0317-0 ** 40 24 11.5 8.90 25.5 29.5 330 BM23PF0.8-42DP-0.35V(***) 480-0435-0 ** 42 24 11.5 9.25 25.5 29.5 330 BM23PF0.8-46DP-0.35V(***) 480-0401-0 ** 46 24 11.5 9.95 25.5 29.5 330 BM23PF0.8-54DP-0.35V(***) 480-0303-0 ** 54 24 11.5 11.35 25.5 29.5 330 Note 1: The specification number(895) in the Part No. changes to(95) in the HRS No. 6 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A BM29 Series Ultra-small, power/signal contact design for Board-to-Board/FPC-to-Board providing 3A max current Precautions Precautions 1.Recommended 1.temperature Recommended solder profi le MAX 250℃ temperature profile 250 220℃ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Jul.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature ( ℃) 220 200 180 180℃ 150℃ 150 100 50 25 25℃ (60 sec onds) 0 90 to 120 seconds Preheating time Max. 60 seconds Soldering time Start Time (seconds) [Conditions] [Conditions] 1. Peak temperature 1. Peak temperature 2. Heating unit 2. Heat section unit 3. Preheating 3. Preheat section 4. Number of times : 250ç : Maximum of 250℃ : No less than 220ç for no more than 60 seconds : 220℃ min., : 150 to 180çwithin for 9060 to seconds 120 seconds : 150 to 180℃, 90 to 120 seconds : No more than 2 times 4. Number of reflow cycles : Maximum of 2 cycles Note 1 :The temperature is the surface temperature of the PCB in the vicinity of the connector Note 1 lead : Thepart. temperature is the surface temperature of the PCB in the vicinity of the Note 2 :When you use refl ow, please mount the product with the oxygen concentration connector leadnitrogen part. Note 2 at : When using nitrogen reflow process, please mount the product with the oxygen a minimum of 1,000 [ppm]. concentration minimum of 1,000[ppm]. Please contactatusa if the concentration is below 1,000 [ppm]. Please contact Hirose if the concentration is below 1,000[ppm] 2. Recommended hand soldering conditions 2. Recommended manual Soldering iron temperature : 340 ± 10°C, Soldering time within 3 seconds Soldering iron: temperature: 340±10℃ 3. Recommended screen thickness/aperture ratio 3. Recommended screen (pattern area ratio) Thickness : 0.1mm Aperture ratio : 100% on the DS side ; 80% on the DP side soldering conditions thickness and open area 4. ratio Warpage the PCB to PCBofpattern area 5. Cleaning 4. Warpage of the PCB 6. Notes 5. Cleaning 6. Notes Soldering time : within 3 seconds Thickness : 0.1mm Aperture ratio 100% onat thethe DScenter side, 100% side A maximum of :0.02mm part on of the the DP connector based on both ends of the connector. Not recommended. If you clean this product, please evaluate the performance before using it. (Cleaning may cause a change in the mating/unmating property and its resistance to A maximum of 0.02mm at the center part of the connector on both ends of the connector. environment) Care should be taken that mating/unmating operation when the product is not mounted on the Not recommended. If this product is cleaned, please evaluate the performance before using PCB could cause damage or deformation, etc. of the contact. it. Cleaning may cause a change in the mating/unmating properties as well as environmental Avoid supporting the PCB only by connectors, and support it by other means than connectors. resistance. Care should be taken that excessive prying mating/unmating could cause damage. During do not apply fl ux which will causeand fl ux oozing on mounted connector. sholudsoldering, be taken when mating/unmating the connector when it is not on the ■Carehand This product may differ in hue due to production PCB. Damage or deformation of the contacts may occur. lot variability, but it doesn’t have any infl uencesupporting on the performance. the PCB only with the connectors. Support it by other means such as bolts, ■Avoid screws, posts, etc.next page for the precautions for mating/unmating. Please refer to the taken to avoid thatcaused could cause damage. ■Care should Considering thebepossibility of sengagement diexcessive prying duemating/unmating to the counterfor ce by the drop, impact manual soldering, do not state apply by fluxthe which flux oozing on connector. ■During and routing of FPC, xfi the mated usewill ofcause housings and cushion materials, etc. may have color differences due to production lot variability, butrated this does not rated ■This product Caution! Do not use theslight connector in non-recommended conditions (i.e., current, have any effect on the performance. voltage, PCB design and operating environment, etc.). Such usage could lead to material ■Please refer to the next page for precautions regarding mating/unmating. outgassing, ignition, or short-circuit, etc. ■Because the product can disengage if dropped (or other impact), and by FPC routing, it is Refer to the specifi cations and the guidelines for board pattern dimensions, board cautions, advised to secure the mated connectors to the board with housings and cushioning materials. and connector treatment. ■Caution! Do not use the connector in non-recommended conditions (i.e., rated current, rated Pleasae contact Hirose if operating using theenvironment, connector etc.). underSuch conditions other than those described in voltage, PCB design and usage could lead to material the outgassing, specifi cations andorthe guidelines is being considered. ignition, short-circuit, etc. Refer to the specifications and the guidelines for board pattern dimensions, board cautions, and connector treatment. Please contact Hirose if using the connector under conditions other than those described in the specifications and the guidelines is being considered. 7 5 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A ●Handle with care when mating a connector BM23PF0.8-*DP-0.35V BM23PF0.8-*DS-0.35V Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Alignment method OK When aligning, look for the guide port without applying excessive force. Caution! If excessive force is applied, the connector could crack or be shaved which could lead to a defect in contact resistance. NG Guiding condition Mated condition 8 When guided, the connectors are aligned parallel to each other with longitudinal and lateral movements restricted. Mate them parallel to each other. BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Handle with care when un-mating connectors OK Un-mate connectors parallel to each other. OK If the connector cannot be un-mated parallel, it can be removed diagonally from the pitch direction, as shown in the left figure. However, the connector can be broken if the FPC is not rigid. Please confirm rigidity of the FPC at the time of trial production. Pitch direction Do not pull from the corner. If it is pulled from the corner as shown in the left figure, the contact and connector could be damaged. NG Corner direction NG Please provide a reinforcing plate for the FPC. If the rigidity of the FPC is not sufficient, the connector may break as shown in the left figure. Please check the action of the FPC to be used repeatedly. A reinforcing plate of 0.3mm or thicker made of glass epoxy material, or 0.2mm or thicker stainless steel is recommended 9 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO 10 BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO 11 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Aug.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BM23PF Series●to 0.35mm Pitch,SCREW 0.8mm TM Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A EF2 Series●Up 400A ZERO Terminal Block USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ INDIA: SINGAPORE: HIROSE ELECTRIC SINGAPORE PTE. LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Singapore 079909 Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +65-6324-6113 Phone : +91-12-660-8018 Fax : +65-6324-6123 Fax : +91-120-4804949 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: MALAYSIA: BANGKOK OFFICE (REPRESENTATIVE OFFICE) PENANG REPRESENTATIVE OFFICE 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Lepas Penang, 11950, Malaysia Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +604-648-5536 Phone : +66-2-686-1255 http://www.hirose.com/sg/ Fax : +66-2-686-3433 http://www.hirose.com/sg/ ® 12 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com Thecharacteristics characteristicsand andthe thespecifications specificationscontained containedherein hereinare arefor forreference referencepurpose. purpose.Please Pleaserefer refertotothe thelatest latestcustomer customerdrawings drawingsprior priortotouse. use. The The contents catalog current of date of 08/2017. Contents subject to change without notice purpose of improvements. The contents of of thisthis catalog areare current as as of date of 03/2022. Contents areare subject to change without notice for for thethe purpose of improvements.
BM23PF0.8-42DS-0.35V(51) 价格&库存
很抱歉,暂时无法提供与“BM23PF0.8-42DS-0.35V(51)”相匹配的价格&库存,您可以联系我们找货
  • 10000+5.7927110000+0.74871
