HR08D-12WLPB-10SC(31) 数据手册
Small, Waterproof, Push-On Bayonet Lock Connectors
HR08D Series
Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Mating is completed simply
by pushing the plug onto the
receptacle.
To unmate this connector,
rotate the locking collar to
release the lock, then pull
them apart.
■Features
Fig.q
1. Simplified mating operations
•To mate the connector, simply push it onto the
receptacle. To unmate, rotate the locking collar
and pull the plug back from the receptacle.
(Fig. q)
•Simplified mating is enabled by the alignment
markings
•Mating guide keys are provided at 3 points to
prevent contact damage. They also provide the
ability to blind mate these connectors when needed.
Plug connector does not damage the receptacle
contacts.
Cable exit directions
2. Waterproof structure
Supports IP67 and IP68 ratings while in the mated
condition. (Ratings explained below*)
*IP67: Submerged in 1 m for 30 minutes
*IP68: Submerged in 2 m for 14 days
Fig.w
3. Adjustable cable direction
The right angle plug can be adjusted to mount in
any of the 8 different directions (adjustable in 45°
increments). (Fig. w)
4. Variations available
Items
No. of Contacts
2 or 10 positions available
Connector Type
Straight Plug, Right Angle Plug, Receptacle (10 pos. only)
Plug Termination
Crimp, solder
Receptacle Termination
Solder
Cord Tube Material
Cable Diameter Range
(Reference)
Plastic, metal
(Ø5.7 to 6.5)(Ø6.5 to 7.3)(Ø8.0 to 9.0)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.7②
1
HR08D Series●Small, Waterproof, Push-On Bayonet Lock Connectors
■Product Specifications
Rated Current
Rated Voltage
Ratings
Operating Temperature Range
Storage Temperature Range
-20ç to +85ç
-10ç to +60ç
Items
Specifications
Conditions
1. Contact Resistance
2.Insulation Resistance
3. Withstanding Voltage
6. Durability
20mø or below
Minimum of 1,000Mø
No flashover or breakdown
No electrical discontinuity of 10µs or
greater
greater
Contact Resistance : Maximum of 30mø
7. Temperature Cycles
Insulation Resistance : Minimum of 500Mø
Measured with DC 1A
Measured with DC 500V
10 pos. AC 900V for 1 minute 2 pos. AC 1,500V for 1 minute
Tested in 3 directions with 10 to 500Hz /cycle, total
vibration width of 0.75mm, and 98m/s2, 3 hours each.
Tested in 3 directions with the acceleration of 490m/s2,
and a duration of 11ms, 3 times each
500 mating cycles
Left at -55ç : 30 minutes ⇒ Ordinary temperature : 2 to 3
minutes ⇒ 85ç : 30 minutes ⇒ Ordinary temperature : 2 to
3 minutes, 2 to 3 minutes, Total of 5 cycles
Left at temperature 71ç and humidity 95% for 336 hours.
Left at the temperature of 71ç and 95% humidity for 336
hours.
Left submerged in water at the depth of 1m, for 0.5 hours,
in the mated condition.
4. Vibration Resistance
5. Shock
3A
AC200V, DC250V
8. Humidity Resistance
9. Waterproof Structure
Insulation resistance
Minimum of 50Mø (high humidity)
Minimum of 500Mø (dry)
Should be no water leakage inside the
connector
■Materials / Finish
●Plug
Component
Outer Shell
Insulator
Female Contact
O Ring, Gasket
Materials
Zinc Alloy, aluminum alloy and polyamide resin (black)
PPS resin (black)
Phosphorous bronze
NBR, Nitrile hydride rubber
Finish
Nickel under plating
---------------------Gold plating
Remarks
---------------------UL94V-0
Materials
Zinc alloy
PPS resin (black)
Brass
NBR
Finish
Remarks
●Receptacle
Component
Outer Shell
Insulator
Male Contact 10 position
O Ring
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Plug
● Receptacle
HR08D 12 WP A - 10 S (**) HR08D 12 WR - 10 P (**)
❶
❷
❸
❹
❺
❻
❼
❶ Model Name : HR08D series
❷ Shell Size : Diameter (mm) of the mating interface of the plug
❸ Shell Type
WP : Straight plug, WLP: Right angle plug
❹ Cord Tube and Cable Range Type
A : Material of cord tube : Metal, with cable dia. range of (Ø 5.7 to 6.5)
B : Material of cord tube : Metal, with cable dia. range of (Ø 6.5 to 7.3)
M : Material of cord tube : Plastic, with cable dia. range of (Ø5.7 to 6.5)
N : Material of cord tube : Plastic, with cable dia. range of (Ø6.5 to 7.3)
K : Material of cord tube : Metal, with cable dia. range of (Ø8.0 to 9.0)
❺ Number of Contacts : Contacts available (2 or 10)
❻ Contact Shape
S : Female contact for solder termination
SC : Female contact for crimping termination
❼ Other specifications :
A two-digit character is added to indicate other
specifications as needed.
2
❶
❷
❸
❹
❺
❻
❸ Shell Type WR:Receptacle
❹ Number of Contacts : Contacts available (10 only)
❺ Contact Shape P : Male contact for solder termination
❻ Other specifications :
●Crimp contact
HR34B - SC1 - 2 1 1
❶
❷
❸
❹
❺
❶ Model Name : HR34B series (Shares the same contacts
as the HR34B series)
❷ Contact Type SC1 : Female contact
❸ Contact Shape 1 : Single contact 2 : Reel contact
❹ Barrel Shape : 1 : 20 to 25 AWG
❺ Plating Type 1 : Gold plating
■Straight plug
●Regular version ( Cord tube material : Plastic)
49.1
4
3
A
φ20
1
8
7
10
(example)
◆Solder termination version
Part No.
HRS No.
A
HR08D-12WPM-10S(31)
108-0274-5 31
Ø7.4
Applicable cable
diameter range
(Reference)
(Ø5.7 to 6.5)
HR08D-12WPN-10S(31)
108-0275-8 31
Ø8.5
(Ø6.5 to 7.3)
HR08D-12WPM-2S(31)
108-0272-0 31
Ø7.4
(Ø5.7 to 6.5)
HR08D-12WPN-2S(31)
108-0266-7 31
Ø8.5
(Ø6.5 to 7.3)
Contact solder cup inner
diameter
Ø1
Ø1.8
◆ Crimp termination version
Part No.
HRS No.
A
Applicable cable
diameter range
(Reference)
HR08D-12WPM-10SC(31)
108-0268-2 31
Ø7.4
(Ø5.7 to 6.5)
HR08D-12WPN-10SC(31)
108-0269-5 31
Ø8.5
(Ø6.5 to 7.3)
●Robust version (Cord tube material: Metal)
Part No.
HRS No.
A
HR08D-12WPA-10S(31)
108-0219-7 31
Ø7.4
Applicable cable
diameter range
(Reference)
(Ø5.7 to 6.5)
HR08D-12WPB-10S(31)
108-0231-2 31
Ø8.5
(Ø6.5 to 7.3)
HR08D-12WPK-10S(31)
108-0262-6 31
Ø9.5
(Ø8.0 to 9.0)
HR08D-12WPA-2S(31)
108-0279-9 31
Ø7.4
(Ø5.7 to 6.5)
HR08D-12WPB-2S(31)
108-0280-8 31
Ø8.5
(Ø6.5 to 7.3)
HR08D-12WPK-2S(31)
108-0281-0 31
Ø9.5
(Ø8.0 to 9.0)
diameter
Ø1
Ø1.8
◆Crimp termination version
Part No.
HRS No.
A
Applicable cable
diameter range
(Reference)
HR08D-12WPA-10SC(31)
108-0220-6 31
Ø7.4
(Ø5.7 to 6.5)
HR08D-12WPB-10SC(31)
108-0232-5 31
Ø8.5
(Ø6.5 to 7.3)
HR08D-12WPK-10SC(31)
108-0263-9 31
Ø9.5
(Ø8.0 to 9.0)
3
■Right angle plug
3
7
10
8
33.5
φ20
1
4
B
A
(example)
HRS No.
A
HR08D-12WLPM-10S(31)
108-0276-0 31
Ø7.4
Applicable cable
diameter range
(Reference)
(Ø5.7 to 6.5)
HR08D-12WLPN-10S(31)
108-0277-3 31
Ø8.5
(Ø6.5 to 7.3)
HR08D-12WLPM-2S(31)
108-0273-2 31
Ø7.4
HR08D-12WLPN-2S(31)
108-0267-0 31
Ø8.5
Part No.
B
30.85
(Ø5.7 to 6.5)
(Ø6.5 to 7.3)
Contact solder cup
inner diameter
Ø1
Ø1.8
Part No.
HRS No.
A
HR08D-12WLPM-10SC(31)
108-0270-4 31
Ø7.4
HR08D-12WLPN-10SC(31)
108-0271-7 31
Ø8.5
B
30.85
Applicable cable
diameter range
(Reference)
(Ø5.7 to 6.5)
(Ø6.5 to 7.3)
Part No.
HRS No.
A
HR08D-12WLPA-10S(31)
108-0221-9 31
Ø7.4
HR08D-12WLPB-10S(31)
108-0233-8 31
Ø8.5
B
30.5
HR08D-12WLPK-10S(31)
108-0264-1 31
Ø9.5
HR08D-12WLPA-2S(31)
108-0282-3 31
Ø7.4
31.5
HR08D-12WLPB-2S(31)
108-0283-6 31
Ø8.5
HR08D-12WLPK-2S(31)
108-0284-9 31
Ø9.5
31.5
HRS No.
A
B
HR08D-12WLPA-10SC(31)
108-0222-1 31
Ø7.4
108-0234-0 31
Ø8.5
HR08D-12WLPK-10SC(31)
108-0265-4 31
Ø9.5
30.5
Applicable cable
diameter range
(Reference)
Contact solder cup
inner diameter
(Ø5.7 to 6.5)
(Ø6.5 to 7.3)
Ø1
(Ø8.0 to 9.0)
(Ø5.7 to 6.5)
(Ø6.5 to 7.3)
Ø1.8
(Ø8.0 to 9.0)
Part No.
30.5
31.5
Applicable cable
diameter range
(Reference)
(Ø5.7 to 6.5)
(Ø6.5 to 7.3)
(Ø8.0 to 9.0)
4
■Receptacle
4×
(R
2
3.
φ
4×
8)
A
B
2.
B
Part No.
HRS No.
A
B
HR08D-12WR-10P(31)
108-0218-4 31
17.26
23.4
diameter
Ø1.1
Note : The number 10 contact is connected to the outer shell, which provides the ground connection.
BPanel Mount Hole Dimensions
Dimension
HR08D-12WR-10P(31)
A
17.26±0.05
B
M3×0.5
A
B
4−
C
1 0/ ー 0.1
D
12.2 +0.1/0
E
16.2 +0.1/0
C
A
φD
φE
■Crimp contact
●Female contact
15
1.2
A
Type
Part No.
HRS No.
Loose piece contact
HR34B-SC1-111
134-0051-7
Reel contact
HR34B-SC1-211
134-0050-4
Applicable electric
wires
20 to 25 AWG
Note : The loose piece contacts are sold in packs of 100. Reel contacts are sold in full reel quantities
of 10,000 pieces per reel.
5
BPlug Contact Diagram
2 position version
10 position version
1
3 2 1
7 6 5 4
10 9 8
2
Note : The numbering of the contact is from the
plug termination side.
Powered by TCPDF (www.tcpdf.org)
BApplicable Tools
Tools
Manual Crimping Tool
Automatic Crimping Press
Automatic Crimping
Applicator
Part No.
HT304/HR34B-1
CM-105C
HRS No.
150-0107-9
901-0001-0
AP105-HR34B-1
901-2051-2
RP6-SC-TP
150-0039-0
Contact Extraction Tool
BManual Crimping Tool
Applicable contacts
Applicable wire size
HR34B-SC1-111 20 AWG、23 AWG、25 AWG
HR34B-SC1-211
20 to 25 AWG
HR34B-SC1-111
HR34B-SC1-211
BAutomatic Crimping Press CM-105C Model
(applicator sold separately)
BContact Extraction Tool
BOperating Precautions
1.Prior to inserting or extracting this connector, make sure that the connector is not energized and the power is in the OFF position.
2.There may be some resistance when inserting the cables into this connector, even if the cables are within the applicable cable range.
This is to be expected due to the connector’s waterproof ability. The waterproof performance and clamp force is dependant on the cable
specification. Please check the cable specifications before using as they can cause a difference in performance in the waterproof
protection and cable clamp force.
3.Please contact your local Hirose Sales Representative for any inquiries regarding the assembly procedures of this connector.
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
