ISOLATED
POWER SYSTEMS
FEATURES & BENEFITS
• Individually shrouded contacts for electrical and
mechanical protection
• .100" (2.54 mm) and .165" (4.19 mm) pitch
• Surface mount or through-hole
• Vertical and right-angle for parallel, perpendicular
and coplanar applications
• Locking clip, key polarization and guide post options
• Discrete wire assemblies with 16-30 AWG PVC or
Teflon™ fluoropolymer wire (see pages 243-245).
• Metal or plastic rugged latching system
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec
Selectively loading
contacts achieves customer
specific creepage and
clearance requrements.
CREEPAGE & CLEARANCE
Flexible standard or
high-power stacking systems
with Power Eye three-finger
BeCu contacts for reliable
connection. For available series,
visit samtec.com/flexiblestrips
CREEPAGE
CLEARANCE
IPT1/IPS1
MMSS(T)/MMSD(T)
2.54 mm
1.91 mm
IPBT/IPBS
PMSS(T)/PMSD(T)
4.27 mm
3.05 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
PITCH
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
IPT1/IPS1
.100"
(2.54 mm)
Black LCP
Phosphor Bronze
Sn or Au over
50 µ" (1.27 µm) Nickel
-55 °C to +125 °C
5.9 A
(1 pin powerd)
775 VAC
Yes
IPBT/IPBS
.165"
(4.19 mm)
Black LCP
High Copper Alloy (IPBT)
Phospher Bronze (IPBS)
Sn over 50 µ"
(1.27 µm) Nickel
-55 °C to +105 °C
10.3 A
(2 pins powerd)
400 VAC
Yes
F-224
VOLTAGE LEAD-FREE
RATING SOLDERABLE
samtec.com/minimate or samtec.com/powermate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
5.9
A
m
p
s
(2.54 mm) .100" PITCH • SHROUDED POWER CONNECTOR SET
IPT1
NO. PINS
PER ROW
1
05
LEAD
STYLE
15
D
–L
Specify
LEAD
STYLE
from chart
10
PLATING
OPTION
TAIL
OPTION
OTHER OPTIONS
–A
Requires -01
Lead Style
(Leave blank for
Through-hole)
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Alignment Pin
(–VS only) (N/A with –LC)
–LC
–RA
= Locking Clip
(Manual placement required)
(–VS only) (N/A with –A)
= Right-angle
–VS
25
–K
= Surface Mount
(Standard Sizes)
= (6.00 mm) .236" DIA
Polyimide film
Pick & Place Pad
(–VS only)
–TR
= Tape & Reel
(–VS only)
IPT1
Board Mates:
IPS1
Through-hole
IPT1/IPS1
PINS
CURRENT RATING
(PER CONTACT)
1
2
3
4
50
5.9 A
4.8 A
4.1 A
3.6 A
2.3 A
IPS1
-VS
Surface Mount
NO. PINS
PER ROW
LEAD
STYLE
01
05
PLATING
OPTION
D
–L
15
B
(2.16) .085
(11.05) .435
(6.35) .250
(13.59) .535
(6.35) .250
N/A
–02
(14.00) .551
(9.30) .366
(2.64) .104
–03
(16.00) .630
(11.30) .445
(2.16) .085
–04
(17.00) .669
(12.30) .484
(2.69) .106
–05
(19.00) .748
(14.30) .563
(2.46) .097
–06
(20.00) .787
(15.30) .602
(2.35) .093
–07
(25.00) .984
(20.30) .799
(2.31) .091
–08
(30.00) 1.181
(25.30) .996
(2.39) .094
–09
(35.00) 1.378
(30.30) 1.193
(2.46) .097
TAIL
OPTION
= Locking Clip
(Manual placement
required)
(–VS only)
–RA
= Right-angle
–VS
1RRISRVLWLRQV[
25
(Standard Sizes)
–K
= Surface Mount
= (5.50 mm) .217" DIA
Polyimide film
Pick & Place Pad
(–VS only)
IPS1
Board Mates:
IPT1
Through-hole
–TR
= Tape & Reel
(–VS only)
Surface Mount
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OTHER
OPTIONS
–LC
Leave blank for
Through-hole
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
10
A
–01
-RA
MATED
HEIGHT
-01-VS
1
–FR
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
(-VS only)
1RRISRVLWLRQV[
-VS
–FR
(-VS only)
-RA
View complete specifications at: samtec.com?IPT1 & samtec.com?IPS1
samtec.com/minimate
F-224
很抱歉,暂时无法提供与“IPS1-109-01-L-D”相匹配的价格&库存,您可以联系我们找货
