F-224 WEB
MTMS–130–02–G–D–100
MTMS–110–02–G–D–100
MTMS–125–51–G–S–200
(1.27 mm) .050"
MTMS, HMTMS SERIES
MODIFIED MICRO TERMINAL
SPECIFICATIONS
For complete specifications
see www.samtec.com?MTMS
or www.samtec.com?HMTMS
Mates with:
SMS, SLM, RSM
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin
-55 °C to +125 °C with Gold
RoHS Compliant:
Yes
Position anywhere
in the body with
(3.05 mm) .120"
minimum tail
PROCESSING
Lead-Free Solderable:
Yes
Ideal for board
stacking
applications
Single row
and double row
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
TYPE
STRIP
1
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
01
thru
50
Specify
LEAD
STYLE
from
chart
–L
ROW
OPTION
POST
HEIGHT
OPTION
–S
–“XXX”
–“XXX”
FILE NO. E111594
ALSO AVAILABLE
(MOQ Required)
• Other platings
MTMS
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
–G
= Modified Standard
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
HMTMS
= Modified High Temp
(1.27) .050 x No. of Positions
(2.48)
.098
50
01
02
100
(2.54)
.100
HMTMS –D
BODY DESIGN
99
(1.27) .050 TYP
(0.46) .018 SQ
B
(0.00) .000
MIN
(2.54)
.100
OAL
(3.05)
C .120
MIN*
(0.51)
.020
(0.51) .020 DIA
SINGLE ROW
Note:
This Series is non-standard,
non-returnable.
–D
= Double
Row
DOUBLE ROW
Tail DIA is .020" (0.51 mm) for min .120" (3.05 mm).
Balance of tail is .018" (0.46 mm) SQ.
= “B”
Dimension
(Specify
Post Height
in inches
(0.13 mm)
.005"
increments)
LEAD
STYLE
OAL
–01
= Polarized
Position
(Specify
position of
omitted pin)
B
(Maximum
when C =
(3.05 mm) .120")
(11.43) .450
(5.84) .230
–02
(8.13) .320
(2.54) .100
(8.38) .330
(3.18) .125
–51
(10.41) .410
(4.83) .190
–52
(10.80) .425
(5.21) .205
–53
(12.83) .505
(7.24) .285
–54
(14.10) .555
(8.51) .335
–55
(15.49) .610
(9.91) .390
–56
(15.88) .625
(10.29) .405
–57
(16.51) .650
(10.92) .430
–58
(17.91) .705
(12.32) .485
–59
(19.18) .755
(13.59) .535
–60
(20.96) .825
(15.37) .605
–25*
(4.98)
.196
01
= Single
Row
*Style -25 tail C = (1.02 mm) .040" min
is available.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MTMS-105-01-G-S-230 价格&库存
很抱歉,暂时无法提供与“MTMS-105-01-G-S-230”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15.464731+1.86483
- 50+12.0010150+1.44715
- 100+9.64985100+1.16364
