QFSS-078-04.25-L-D-A 数据手册
F-217
QFSS–078–04.25–L–D–A
QFSS–052–04.25–L–D–PC4
QFSS–026–04.25–L–D–A
(0.635 mm) .025"
QFSS SERIES
SHIELDED GROUND PLANE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QFSS
Board Mates:
QMSS
PROCESSING
RECOGNITIONS
Increased insertion
depth for rugged applications
Standoffs:
SO
11 mm
Stack Height
Insulator Material:
Liquid Crystal Polymer
Contact, Ground
Plane & Shield Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
(Tin on Ground Plane tails)
Voltage Rating:
300 VAC mated with QMSS
Operating Temp:
-55 °C to +125 °C
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (026-078)
Board Stacking:
For applications requiring more
than two connectors per board,
contact ipg@samtec.com
Standard shield grounding
is GSSSSG. Application
Specific options available.
• Increased
insertion depth
• Integral guide post
(1.30 mm)
.051"
NOMINAL
WIPE
HIGH-SPEED CHANNEL PERFORMANCE
17
QMSS-DP/QFSS-DP @ 11 mm Mated Stack Height
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
QFSS
Single-Ended
Signal routing
G b p s
PINS PER ROW
NO. OF PAIRS
PLATING
OPTION
04.25
A
TYPE
For complete scope of
recognitions see
www.samtec.com/quality
–L
–026, –052, –078
ALSO AVAILABLE
–016, –032, –048
(MOQ Required)
• Headers without
Alignment Pins
• 8 Power Pins/End
• 4 or 8 Power Pins/End for
(2.36 mm) .093" thick board
• Guide Holes
• 64 (-DP) and 104 pins per row
Contact Samtec.
(16 pairs per bank = –D–DP)
APPLICATION
QMSS
Some lengths, styles and
options are non-standard,
non-returnable.
OTHER
SOLUTIONS
01
(0.89)
.035
(0.10)
.004
(7.06)
.278
–D
(1.02) .040 DIA
02
No. of Banks x (21.34) .840 + (12.87) .507
(7.44)
.293
(8.13)
.320
–D–DP
(2.00) .07874
Notes:
Patented
–D–DP
= Differential Pair
(8.13)
.320
(0.23)
.009
= 4 Power
Pins/End
(N/A with –A)
(Tin on Signal Pin
tails, and Ground
Plane tails)
QFSS
(11.00)
.433
= Single-Ended
No. of Banks x (21.34) .840 + (1.02) .040
(2.10) .083
(21.34) .840
02
(0.635)
.025
–PC4
–D
= 10 µ" (0.25 µm)
Gold on Signal
Pins, Shield and
Ground Plane
(52 total pins per bank
40 signals + 12 grounds to shield = –D)
FILE NO. E111594
OTHER
OPTION
01
(2.54)
.100
See SO Series for precision
machined standoffs.
(1.78)
.070
(2.54)
.100
–PC4 OPTION
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
QFSS-078-04.25-L-D-A 价格&库存
很抱歉,暂时无法提供与“QFSS-078-04.25-L-D-A”相匹配的价格&库存,您可以联系我们找货
