SCRUS-17-G-01.00-AMS-AM 数据手册
IP68 SEALED
USB & ETHERNET
SCRUS/SCRES SERIES
SCRUS
Mates wtih:
SCPU
SCRUS
SHELL
SIZE
–17
SPECIFICATIONS
–G
(Standard
USB only)
Insulator Material:
PBT
Contact Material:
Phosphor Bronze
Wire:
20 AWG (Power)
25 AWG (Signal)
28 AWG (Drain)
O-Ring:
Silicone
Operating Temp Range:
-20 °C to +75 °C
PLATING
= 30 µ"
(0.76 µm)
Gold on
Contact,
Nickel
on Shell
WIRE LENGTH
END 1
OPTION
–00.25
–AMS
= (0.25 m) 9.84"
Cable
–AM
= USB A Type,
Sealed
–00.50
= USB A Type,
Not Sealed
–BMS
= (0.50 m) 19.68"
Cable
END 2
OPTION
–BM
= USB B Type,
Sealed
= USB B Type,
Not Sealed
–MB
Standard lengths
= Mini USB B Type,
Not Sealed
(Assembled Length
= Wire Length
+ (37.9 mm) 1.50")
–BC
= Blunt Cut
(48.45)
1.907
(39.50)
1.55
DIA
–BMS
SCRES
Mates with:
SCPE
SPECIFICATIONS
Insulator Material:
PBT
Contact Material:
Phosphor Bronze
Shield Material:
Phosphor Bronze
Wire:
24 AWG
O-Ring:
Silicone
Overmold:
PA66
Current Rating:
3.8 A per pin
(1 pin powered)
-40 °C to +70 °C
SCRES
DUST CAP
–AMS
PLATING
–G
= 50 µ" (1.27 µm)
Gold on Contact,
Nickel on Shell)
WIRE LENGTH
–00.25
= (0.25 m) 9.84" Cable
–00.50
END OPTION
–D
= Double Ended
= (0.50 m) 19.68" Cable
C5E
–C5E
= Cat 5e rating
–BC
= Blunt Cut
Standard lengths
Assembled Length = Wire Length + (12.70) .50
(48.45)
1.907
–D SHOWN
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Dust cap: DCA-17-03
(USB Flash Drive Cover)
–AMS
END NO. 1
END NO. 2
DUST CAP & PANEL PLUG
Dust cap: DCA-17-01
Panel Plug: SCPPA-17-01
samtec.com?SCRUS
or samtec.com?SCRES
samtec.com/AccliMate
F-224225
WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SCRUS-17-G-01.00-AMS-AM 价格&库存
很抱歉,暂时无法提供与“SCRUS-17-G-01.00-AMS-AM”相匹配的价格&库存,您可以联系我们找货
