SDK-9BNS-K13-GS-TB(LF)(SN)1 数据手册
Emboss Tape
SDK CONNECTOR
Specifications –––––––––––––––––––
This connector is designed for SD Card &
MMC (Multi media card), complying with
the SD Card Association standard, and is
with the switch for Write-protection & Carddetection. And due to Push-push
mechanism design, its card can be easily
ejected by push-push operation.
• Space saving design
• The amount of card ejection
• Outstanding durability
• Prevention of reverse card insertion
• Current rating: 0.5A AC, DC
• Voltage rating: 5V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Recommendatory PC board thickness:0.6mm to 1.0mm
[When it is mounted on the FPC,
recommendable reinforcing layer thickness is 0.6mm min.]
• Contact resistance:
(Signal part) Initial value/30m Ω max.
After environmental testing/60m Ω max.
(Switch part) Initial value/100m Ω max.
After environmental testing/100m Ω max.
• Insulation resistance:
1,000M Ω min. at 500V DC
• Withstanding voltage: 500V AC/minute
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
13.195±0.05
11.355±0.05
9.75±0.05
8.05±0.05
1.4±0.05
7.55min
Terminal
(GND)
0.9±0.05
13.395±0.05
1.2min
0.9±0.05
Shell
GND
28.1±0.05
1.2±0.05
(1.45)
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
Note: 2. The dimensions above should serve as a guideline. Contact JST for details.
Shell
GND
1.35±0.05
Shell
GND
Connector outline
2.8±0.05
13.195±0.05
(1.45)
5.6±0.1
±0.15
2.8
1.8
5.6±0.1
Card center
Write protect switch
1.8
23.4±0.05
1.2±0.05
No.1
No.9
No.2
No.3
No.4
No.8
No.7
No.6
Shell
GND
8.05min
1±0.05
0.45
7.3
9-1.1±0.05
1.2±0.05
1±0.05
24.35
1.2±0.05
27.15
21.4±0.05
23.4±0.05
9.75±0.05
7.15±0.05
PC board layout (viewed from component
side) and Assembly layout
No.5
6×P2.5=15±0.05
5.625±0.05
Card detection switch
7.75±0.05
9.85min
1±0.05
27.7
±0.05
PC board layout (for reference)
Pattern prohibition area
Connector
27.1
Circuit No.8
12.895
11.355
Circuit No.1
1
Circuit No.2
30
(33.6) when pushing in a card
(34.6) when putting in a card
(8.4)
2.8
(43) when releasing a card
20.95
24.35
27.15
9.3
6.7
6xP2.5=15
5.625
Circuit No.9
Model No.
SDK-9BNS-K13-GS-TB
450
Material and Finish
Housing, Guide: Heat resisting resin, UL94V-0
Contact: Copper alloy, nickel-undercoated,
selective gold-plated, selective tin-plated (reflow treatment)
Terminal: Copper alloy, nickel-undercoated, gold-plated
Card detection switch: Copper alloy, nickel-undercoated, gold-plated
Write protect switch: Copper alloy, nickel-undercoated,
Card lock: Copper alloy, tin-plated
Joint rod, Spring: SUS
Shell: SUS, Solder tail/ selective nickel-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Note: This products listed above are supplied on embossed-tape.
Card centor
Q'ty / reel
SDK-9BNS-K13-GS-TB(LF)(SN)1 价格&库存
很抱歉,暂时无法提供与“SDK-9BNS-K13-GS-TB(LF)(SN)1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15.389001+1.99671
- 10+14.6278310+1.89795
- 30+11.1611730+1.44816
- 50+10.4744550+1.35905
- 100+9.95321100+1.29142
- 300+9.60572300+1.24634
- 500+9.53126500+1.23668
- 国内价格
- 1+24.59083
- 20+21.04535
- 100+17.59568
- 450+14.15800
- 国内价格 香港价格
- 1+20.919291+2.71426
- 10+15.4586810+2.00575
- 50+11.7921450+1.53002
- 100+11.06058100+1.43510
- 500+10.51190500+1.36391
- 1000+10.146121000+1.31645
- 2000+10.076452000+1.30741
- 国内价格 香港价格
- 1+26.301521+3.41260
- 20+22.5566020+2.92670
- 100+18.81168100+2.44080
- 450+15.15386450+1.96620
