ONE-PIECE
INTERFACES
(2.54 mm) .100" PITCH • SIB/SIR1 SERIES
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.6 A per pin
(1 pin powered)
Operating Temp Range:
-55 °C to +125 °C
SIB
-1
NO. OF
POSITIONS
02
02 thru 30
S
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Weld Tab:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.8 A per pin
(1 pin powered)
–LC
1RRISRVLWLRQV[
—LC
SIR1
NO. OF
POSITIONS
–03, –05, –10, –15
(Per Row)
PLATING
OPTION
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–S
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
PROCESSING
OPTION
–A
= Alignment Pin
–K
= (4.00 mm) .157"
DIA Polyimide
Film Pick &
Place Pad
–TR
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
S
= Tape & Reel
1RRISRVLWLRQV[
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OPTION
= Locking
Clip
(Manual
placement
required)
non-returnable.
SPECIFICATIONS
= Gold flash
on contact,
Matte Tin on tail
Yes
(0.10 mm) .004" max (02-19)
(0.15 mm) .005" max (20-30)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Notes:
The SIB Series
is intended for vertical
mating only.
PLATING
OPTION
–F
(Per Row)
PROCESSING
samtec.com?SIB or samtec.com?SIR1
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“SIB-112-02-F-S”相匹配的价格&库存,您可以联系我们找货
