0916 072 3101
0916 072 3101
    HARTING(浩亭)
    HARTING - 0916 072 3101 - Heavy Duty Connector, 72+PE, Less Contacts, Han DD, Insert, 73 Contacts, 1...
0916 072 3101 数据手册
Han® 72 DD Size  16 B 250  V 10  A Number of contacts 72 + Han D / DD Inserts Identification Crimp terminal rder crimp contacts O separately (see Technical characteristics on page 02.06) Series Part number Male insert (M) Female insert (F) Drawing Dimensions in mm Han DD® 09 16 072 3001 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 16 072 3101 " 1) Distance for contact max. 21 mm Contact arrangement view from termination side Panel cut out for inserts for use without hoods/housings Coding pin Coding pin 09 33 000 9915 "https://b2b.harting.com/ebusiness/en/ " Use of the coding pin prevents incorrect mating to other connectors of the same type. The male pin should be omitted from the opposing cavity in the male insert. Stock items in bold type 02 . 15
0916 072 3101 价格&库存
很抱歉,暂时无法提供与“0916 072 3101”相匹配的价格&库存,您可以联系我们找货
  • 1+311.779161+40.46325
  • 10+264.9653310+34.38767
  • 25+248.3800825+32.23520
  • 50+236.5302150+30.69731
  • 100+225.25030100+29.23338
  • 250+211.16627250+27.40553
库存:36
