Recommended layout
har-flex straight male connector
Pole number
006
008
010
012
014
016
018
020
022
024
026
028
030
032
034
036
038
040
042
044
046
048
050
052
054
056
058
060
062
064
066
068
070
072
074
076
078
080
082
084
086
088
090
092
094
096
098
100
General information
Design
Mezzanine connector
No. of contacts
from 6 to 100poles
Contact spacing
1,27mm x 1,27mm [0,050"x0,050"]
Test voltage
500 V
Contact resistance
< 25 mOhm
Insulation resistance
> 1x107 Ohm
6 poles : 1,2A
68poles
32 poles : 0,8A
100 poles : 0,7A
Working current acc. to IEC 60512, @70°C, 80% derating
Temperature range
: 0,75A
-55°C … +125°C
Termination technology
SMT
Reflow processing temperature
2min. @ 220°C
Clearance & creepage distance
0,4mm min.
Insertion force
(depending on mating PCB)
approximately 0,5N/contact
Withdrawal force
Mating cycles
PL1 : 500 mating cycles
PL2 : 250 mating cycles
RoHS - compliant
Yes
Leadfree
Yes
Insulator material
Material
LCP (liquid crystalline polymer)
Color
black
UL classification
UL 94-V0
Material group acc. IEC 60664-1
IIIa (175 < CTI < 400)
Contact material
Contact material
Copper alloy
Plating termination zone
Sn
Plating contact zone
Au over PdNi (acc.to Perforamnce Level)
The current carrying capacity is limited by maximum
temperature of materials for inserts and contacts including
terminals.
The current capacity curve is valid for continuous, non
interrupted current loaded contacts of connectors when
simultaneous power on all contacts is given, without exceeding
the maximum temperature.
Control and test procedures according to DIN IEC 60512-5
Electrical load [A]
Derating diagram acc. to IEC 60512-5 (Current carrying capacity)
derating curve at Imax*0,8 (IEC 60512-5-2)
Temperature [°C]
Name
29aou11
JA
Inspec.
30aou11
JMV
Stand.
Mod.
Subject to change without prior notice, all rights reserved
Date
Detail.
Date
Name
HARTING Electronics GmbH & Co. KG
A
2,54
3,81
5,08
6,35
7,62
8,89
10,16
11,43
12,70
13,97
15,24
16,51
17,78
19,05
20,32
21,59
22,86
24,13
25,40
26,67
27,94
29,21
30,48
31,75
33,02
34,29
35,56
36,83
38,10
39,37
40,64
41,91
43,18
44,45
45,72
46,99
48,26
49,53
50,80
52,07
53,34
54,61
55,88
57,15
58,42
59,69
60,96
62,23
B
6,96
8,23
9,50
10,77
12,04
13,31
14,58
15,85
17,12
18,39
19,66
20,93
22,20
23,47
24,74
26,01
27,28
28,55
29,82
31,09
32,36
33,63
34,90
36,17
37,44
38,71
39,98
41,25
42,52
43,79
45,06
46,33
47,60
48,87
50,14
51,41
52,68
53,95
55,22
56,49
57,76
59,03
60,30
61,57
62,84
64,11
65,38
66,65
Technical data sheet
har flex male stacking height 1,75 and 3,25 mm
DS 15 11 110 03 01
Page 1 of 2
Application information
Tape layout & packaging
Tape acc. to IEC 60286-3
a1 pin
Reel off direction
S
X&Y
S
Pick & place pad 6,4 ± 0,1 x 4,5 ± 0,1
Tape dimensions:
poles 06 to 12
poles 14 to 20
poles 22 to 40
poles 42 to 56
poles 58 to 80
poles 82 to 100
A
24,0
32,0
44,0
56,0
72,0
88,0
Admissible inclination
Admissible mismating
Reel dimensions
Tape dimensions:
poles 06 to 12
poles 14 to 20
poles 22 to 40
poles 42 to 56
poles 58 to 80
poles 82 to 100
E
24,4
32,4
44,4
56,4
72,4
88,4
Name
29aou11
JA
Inspec.
30aou11
JMV
Stand.
Mod.
Date
Detail.
Date
Name
DS 15 11 110 03 01
Page 2 of 2
