19 40 006 0411
19 40 006 0411
    HARTING(浩亭)
    HARTING - 19 40 006 0411 - HOOD, HPR 6B, M25, ALUMINIUM
19 40 006 0411 数据手册
Han® HC Modular 350 Modular High Current Connector System Identification 2000/4000 V 350 A     Part number Male contact Female contact Wire gauge Drawing Dimensions in mm Contacts with Screw terminal for housing bulkhead mounting 09 11 001 2655 09 11 001 2755 for cable lug up to max. 120 mm² 09 11 001 2651 09 11 001 2652 09 11 001 2751 09 11 001 2752 35 ... 70 mm² 95 ... 120 mm² with Axial screw termination PE contact Han HC Modular with Axial screw termination 09 11 000 6156 09 11 000 6256 35 ... 70 mm² Hexagonal driver Adapter (SW 5) 09 99 000 0371 Identification Hexagonal adapter metal version with O-Ring Part number M SW 19 36 000 5134 19 36 000 5135 25 32 30 40 Drawing Dimensions in mm Stock items in bold type 14 . 13 Han® HC Modular 350  Frame Part number 2000 V Hoods/Housings M Part number 25 32 19 40 006 0411 19 40 006 0412 – 09 40 006 0311 4 x 25 19 37 048 0401 – 09 37 048 0301 Hoods Han® HPR 6 B 1 pole 09 11 000 9951 Housings, bulkhead mounting Han® HPR 6 B Hoods Han® M 48 B 4 poles Han HC Modular 09 11 000 9954 Housings, bulkhead mounting Han® M 48 B 4 poles 09 11 000 9955 14 . 16 Stock items in bold type Han® HC Modular 350  Frame Part number 4000 V* Hoods/Housings Part number 2 x 25 19 40 016 0431 – 09 40 016 0311 Hoods Han® HPR 16 B 2 poles 09 11 000 9952 enclosed separately Housings, bulkhead mounting Han® HPR 16 B Hoods Han® HPR 24 B 2 poles 09 11 000 9956 enclosed separately M Han HC Modular 2 x 32 19 40 024 0432 – 09 40 024 0311 Housings, bulkhead mounting Han® HPR 24 B * A working voltage of 4000 V is only possible to realize by using a hexagonal adapter and the HARTING cable gland, in order to realize the clearance and creepage distance according to DIN EN 60 664-1. Stock items in bold type 14 . 17 Han® HC Modular 350  Frame Part number  4000 V* Hoods/Housings 09 11 000 9963 3 x 25 19 40 024 0461 3 x 32 19 40 024 0467 – 09 40 024 0311 3 x 25 19 40 024 0931 3 x 25 19 40 024 1231 Hoods Han® HPR 24 B Housings, bulkhead mounting Han® HPR 24 B Han HC Modular Part number Hoods Han® HPR 24 B 3 poles enclosed separately M Drawing see page 14.17 Housings, surface mounting Han® HPR 24 B horizontal version Housings, surface mounting Han® HPR 24 B straight version 14 . 18 * A working voltage of 4000 V is only possible to realize by using a hexagonal adapter and the HARTING cable gland, in order to realize the clearance and creepage distance according to DIN EN 60 664-1. Stock items in bold type
19 40 006 0411 价格&库存
很抱歉,暂时无法提供与“19 40 006 0411”相匹配的价格&库存,您可以联系我们找货
  • 1+360.41249
  • 12+342.39655
库存:26
19400060411
  • 1+657.59220
  • 10+458.09861
  • 50+435.84349
  • 100+426.51262
