Data sheet | Item number: 231-433/001-000
THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5 mm; 3-pole;
gray
www.wago.com/231-433_001-000
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
L = (pole no. – 1) x pin spacing + 8.2 mm
L1 = L + 5 mm
L2 = L1 + 7.4 mm
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
Pin cross-section: 1 x 1 mm
With coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
320 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
Subject to changes.
Hansastr. 27
32423 Minden
320 V
29.12.2019 Page 2/7
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
12 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per UL 1977
Rated voltage per UL 1977 (factory wiring only)
600 V
Rated current per UL 1977 (factory wiring only)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
No. of poles
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
5 mm / 0.197 inch
Width
18.2 mm / 0.717 inch
Height
12.2 mm / 0.48 inch
Height from the surface
8.4 mm / 0.331 inch
Depth
12 mm / 0.472 inch
Solder pin length
3.8 mm
Solder pin dimensions
Subject to changes.
Hansastr. 27
32423 Minden
1 x 1 mm
29.12.2019 Page 3/7
1 x 1 mm
Drilled hole diameter (tolerance)
1.4(- … +0.1) mm
Plug connection
Contact type (pluggable connector)
Male connector/plug
Connector connection type
for PCBs
Mismating protection
No
Mating direction to the PCB
0 °
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire male connector, in line
Number of solder pins per potential
1
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.021 MJ
Weight
1.1 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918866095
Customs Tariff No.
85366990990
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/7
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
1466354
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Certificate
name
Approval
UL
Underwriters Laboratories Inc.
UL 1059
E4517219911118
UR
UL International Germany GmbH
UL 1977
E45171
Compatible products
Marking accessories
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Item no.: 231-129
Coding key; snap-on type; light gray
www.wago.com/231-129
Item no.: 231-500
Spacer; for formation of groups; light gray
www.wago.com/231-500
Coding
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 231-433/001-000
CAE data
EPLAN Data Portal 231-433/001-000
Download
PCB Design
Symbol and Footprint 231-433/001-000
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Coding
Coding a male header – fitting coding key(s).
Product family
MCS MIDI Classic
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
很抱歉,暂时无法提供与“231-433/001-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.33520
- 10+4.21200
- 30+3.66120
