24034060000
24034060000
    HARTING(浩亭)
24034060000 数据手册
Ha-VIS eCon 3000 Full Gigabit Ethernet Basic 2 to 7 Ethernet ports RJ45 and FOC English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0°C ... +55°C / Industrial ­­ temp.: -40°C ... +70°C Energy Efficient Ethernet ■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3 ■ Support of jumbo frames (10 kB) ■ Variants with industrial temperature range of -40°C ... +70°C ■ Wide range power supply 24/48 VDC ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet ■ Optimised DIN rail bracket Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 3000 Full Gigabit family of unmanaged Ethernet switches is equipped with up to 7 gigabit Ethernet ports and allows for cost-efficient and quick expansion and/or reconstruction of network infrastructures with high bandwidth requirements. In this, all switches support extra-long Ethernet frames (jumbo frames). The slender design of the switches enables an extremely high packing density on the DIN rail. The selection includes various combinations of variants with RJ45 and fibre optic cables. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch Features Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE Enclosure width 25 mm Type of connection RJ45 Number of ports 2, 5, 6, 7 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame Size Auto-MDI(X) 10 kBytes MAC table size Transfer conditions 8k entries Transfer speed 10 / 100 / 1000 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size 1 Mbit Non-blocking Yes Quality of Service Yes Energy Efficient Ethernet Yes PROFINET compatible Yes EthernetIP compatible Yes Yes Twisted pair Ethernet ports 1000BASE-SX / 1000BASE-LX Type of fibre Multi-mode (MM) Type of connection Transfer conditions Wavelength Power supply FOC 850 nm Transfer speed Nominal voltage 24 VDC Permissible voltage range 48 VDC Surge protection Yes Reverse polarity proof Yes Starting current 1.60 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout Input sensitivity 3.20 A Yes (12 A) 2.21 W ... 4.73 W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screwed contact +/-/ Supply circuit (according to 60950) Transfer length Output power 9 VDC ... 60 VDC SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches Single-mode (SM) SC Duplex 1310 nm 1000 Mbit/s 0.55 km 10 km -9.5 dBm ... -4 dBm -9.5 dBm ... -3 dBm ≤ -17 dBm ≤ -21 dBm SFP ports Transfer standard Depending on used SFP Type of connection Depending on used SFP, RJ45 or LC Transfer conditions Depending on used SFP, TP or FOC Transfer speed Transfer length Depending on used SFP, 100 or 1000 Mbit/s Depending on used SFP Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. Enclosures Ambient conditions Enclosure width 25 mm Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) Commercial temperature range 142 mm x 25 mm x 107.5 mm Weight 428 g ... 490 g Type of installation 35 mm DIN acc. to EN 60 715 Material enclosures Anodised aluminium / powder-coated steel sheet Protection class (with pluggable screw type terminal block) III Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green -40 °C ... +70 °C Storage temperature range -40 °C ... +85 °C Relative humidity (operation) 0 % ... 95 % (non-condensing) Relative humidity (storage and transport) 0 % ... 95 % (non-condensing) Air pressure 2000 m (795 hPa) Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT IP30 Protection class 0 °C ... +55 °C Industrial temperature range Link is active Link is active and data is transferred EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 Link speed ("Spd") off 10 Mbit/s EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Link speed ("Spd") illuminated yellow 100 Mbit/s Link speed ("Spd") illuminated green 1000 Mbit/s Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C RJ45 SFP SC Enclosure width Power consumption @ 24 VDC MTBF in million h Switch Part no. Switch Part no. 1 - 1x MM (0.55 km) 25 mm 92 mA 2.13 Ha-VIS eCon 3011GB-AD 24 03 401 1110 Ha-VIS eCon 3011GBT-AD 24 03 401 1100 1 - 1x SM (10 km) 25 mm 92 mA 2.13 Ha-VIS eCon 3011GB-AF 24 03 401 1210 Ha-VIS eCon 3011GBT-AF 24 03 401 1200 1 1 - 25 mm 90 mA 0.95 Ha-VIS eCon 3011GB-AC 24 03 401 1310 Ha-VIS eCon 3011GBT-AC 24 03 401 1300 4 - 1x MM (0.55 km) 25 mm 155 mA 2.15 Ha-VIS eCon 3041GB-AD 24 03 404 1110 Ha-VIS eCon 3041GBT-AD 24 03 404 1100 4 - 1x SM (10 km) 25 mm 155 mA 2.15 Ha-VIS eCon 3041GB-AF 24 03 404 1210 Ha-VIS eCon 3041GBT-AF 24 03 404 1200 4 - 2x MM (0.55 km) 25 mm 182 mA 2.08 Ha-VIS eCon 3042GB-AD 24 03 404 2110 Ha-VIS eCon 3042GBT-AD 24 03 404 2100 4 - 2x SM (10 km) 25 mm 182 mA 2.08 Ha-VIS eCon 3042GB-AF 24 03 404 2210 Ha-VIS eCon 3042GBT-AF 24 03 404 2200 4 3 - 25 mm 172 mA 0.99 Ha-VIS eCon 3043GB-AC 24 03 404 3310 Ha-VIS eCon 3043GBT-AC 24 03 404 3300 5 - - 25 mm 149 mA 1.97 Ha-VIS eCon 3050GB-A 24 03 405 0010 Ha-VIS eCon 3050GBT-A 24 03 405 0000 5 - 1x MM (0.55 km) 25 mm 177 mA 1.91 Ha-VIS eCon 3051GB-AD 24 03 405 1110 Ha-VIS eCon 3051GBT-AD 24 03 405 1100 5 - 1x SM (10 km) 25 mm 177 mA 1.91 Ha-VIS eCon 3051GB-AF 24 03 405 1210 Ha-VIS eCon 3051GBT-AF 24 03 405 1200 5 2 - 25 mm 175 mA 0.94 Ha-VIS eCon 3052GB-AC 24 03 405 2310 Ha-VIS eCon 3052GBT-AC 24 03 405 2300 6 - - 25 mm 172 mA 1.76 Ha-VIS eCon 3060GB-A 24 03 006 0010 Ha-VIS eCon 3060GBT-A 24 03 006 0000 6 1 - 25 mm 178 mA 0.89 Ha-VIS eCon 3061GB-AC 24 03 406 1310 Ha-VIS eCon 3061GBT-AC 24 03 406 1300 7 - - 25 mm 182 mA 0.85 Ha-VIS eCon 3070GB-A 24 03 407 0010 Ha-VIS eCon 3070GBT-A 24 03 407 0000 Copyright© 2014 HARTING Technology Group Date of issue 02.2015 All rights reserved ICPN Datasheet 0848/01
24034060000 价格&库存
很抱歉,暂时无法提供与“24034060000”相匹配的价格&库存,您可以联系我们找货
  • 1+3447.641471+432.50750
  • 5+3240.287575+406.49490
