FFMD-13-S-02.00-01-RW 数据手册
TIGER
IDC
EYE
TIGER EYE™ FLAT
IDC WIRE CABLES
(1.27 mm) .050" PITCH • FFMD SERIES
FFMD
Mates:
FLE*, SFMC*
TRANSFER END
Mates:
FTS, FTSH, EHF,
SHF, ESHF
SERIES
NO. PINS
PER ROW
FFMD
–04, –05,
–08, –10,
–13, –17,
–20, –25
= Terminal
Strip
–S
= Single End
–D
OVERALL
LENGTH
- 01 -
–“XX.XX”
–N
= Notch
Polarization
on socket
(-T end only)
(Not available
with -04
position)
–T
= Transfer End
Insulator Material:
PBT
Terminal:
Phosphor Bronze
Contact:
BeCu (-T)
Plating:
Sn over 50 µ" (1.27 µm) Ni
Wire:
30 AWG
Current Rating:
2.5 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
Voltage Rating:
215 VAC / 304 VDC
TRANSFER
OPTION
Leave blank for
–S and –D End
Options.
= Assembled
Length
= Double End
(Standard sizes)
SPECIFICATIONS
END
OPTION
OTHER
OPTION
–RW
= Reverse Wiring
(Red wire opposite
position #1)
–D “XX”
= Daisy Chain
–SR
= Strain Relief
(Mates only with
ESHF Series)
(Not available with
–O, –M, –R or –DXX)
–R
01
= Reversed
(3.05)
.120
–M
= Middle Reversed
(Requires –DXX)
No. of positions x
(1.27) .050 + (4.19) .165
–O
= Outside Reversed
(Requires –DXX)
(5.08)
.200
Assembled Length
in INCHES (± .130")
2 inches minimum
ALSO AVAILABLE
MOQ Required
Other sizes
Assemble Length (–“XX.XX”)
Single End (—S)
Double End (—D)
(50.8 mm)
2.00
min.
Transfer End (—T)
“XX”
± 1/8"
No. of positions x
(1.27) .050 + (8.00) .315
01
02
*Note:
Standard FFMD callout will
not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates with Pin 1, etc.
Note:
This Series is non-standard,
non-returnable.
(101.60 mm) 4.00 min.
Reverse Wiring (—RW)
Reversed (—R)
Daisy Chain (—D “XX”)
Middle Reversed (—M)
Strain Relief (—SR)
Outside Reversed (—O)
samtec.com?FFMD
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
FFMD-13-S-02.00-01-RW 价格&库存
很抱歉,暂时无法提供与“FFMD-13-S-02.00-01-RW”相匹配的价格&库存,您可以联系我们找货
