FH65-8S-0.5SH
FH65-8S-0.5SH
    HRS(广濑)
    HIROSE(HRS) - FH65-8S-0.5SH - FFC / FPC Board Connector, R/A, 0.5 mm, 8 Contacts, Receptacle, FH65, ...
FH65-8S-0.5SH 数据手册
NEW 0.5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector FH65 Series Low profile and space-saving are achieved. 18.8 mm (34 p os.) Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.2mm 3.57mm Fig.1 ■Features Connection using the FPC/FFC temporary holding mechanism 1. 125°C heat resistant 125°C heat resistance makes it suitable for applications requiring heat resistance such as automotive components. 2. Low profile, space-saving design Space-saving with 1.2mm height and 3.57mm depth. (Fig.1) 3. Satisfies severe requirements for various automotive applications This space saving design satisfies severe requirements for various automotive applications. (Ex. Temperature cycles) Temperature -55 → +15 to +35 → +125 → +15 to 35°C Time 30 → 2 to 3 → 30 → 2 to 3 minutes 1000 cycles under the above conditions 4. Excellent workability enabled by fliplock mechanism The tabbed FPC/FFC provides a high FPC/ FFC holding force in horizontal direction. Fig.2 Visual inspection after mating FPC/FFC The flip-lock (one-touch rotation) ZIF design enables easy and reliable FPC/FFC connecting operation. In addition, the firm and clear tactile click prevents incomplete lock. 5. High FPC/FFC retention force The tabbed FPC/FFC provides a high FPC/FFC holding force in horizontal direction. (Fig.2) 6. FPC/FFC can be inserted easily. The FPC/FFC positioning mechanism enables the FPC/ FFC to be temporary held in place in the correct mating position. (Fig.2) 7. Easy visual inspection after mating FPC/FFC Easy to visually check if FPC/FFC is correctly mated by the FPC/FFC positioning mechanism. (Fig.3) 8. Supports FPC/FFC thickness of 0.3mm Visual inspection possible after mating FPC/FFC (prevents incomplete mating) Supports the thickness of 0.3mm, which eases manufacturing and insertion. Fig.3 9. Environment · Halogen free *AS defined by IEC 61249-2-21. Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm max In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.1 1 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector ■Product Specifications Current rating 0.5A Operating Temperature Range -40 to +125°C (Note 1) Storage Temperature Range -10 to +50°C (Note 2) AC Relative humidity 90% RH Relative humidity 90% RH Voltage rating Operating Humidity Range Storage Humidity Range 50Vrms or less (no condensation) or less (no condensation) Rating Recommended FPC/FFC SPC Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items 1. Insulation Resistance 2. Withstanding Voltage t=0.3±0.05 Gold plated 125°C resistant FPC/FFC Specifications Conditions 500Mø min 100V DC No flashover or insulation breakdown 150Vrms AC 3. Contact Resistance 50mø max *Including FPC conductor resistance 1mA AC 4. Mechanical Operation Contact resistance : 50mø max No damages, cracks and looseness of parts 20 times insertions and extractions. 5. Vibration Resistance No electrical discontinuity of 1µs or longer Contact resistance : 50mø max No damages, cracks and looseness of parts Frequency : 10 to 55Hz, half amplitude : 0.75mm, for 10 cycles in 3 axial directions. 6. Shock Resistance No electrical discontinuity of 1µs or longer Contact resistance : 50mø max No damages, cracks and looseness of parts Acceleration : 981m/s2, duration 6ms, half-sine wave, at 3 times in 3 axial directions 7. High temperature and high humidity environment Contact resistance : 50mø max Insulation resistance : 50Mø min No damages, cracks and looseness of parts 1000 hours at 85ç and humidity of 90 to 95% 8. Temperature Cycles Contact resistance : 50mø max Insulation resistance : 50Mø min No damages, cracks and looseness of parts Temperature : -55→+15 to +35→+125→+15 to +35ç Time : 30 → 2 to 3 → 30 → 2 to 3 minutes 5 cycles with above conditions 9. Resistance to Soldering Heat No deformation of case or excessive looseness of the terminals Reflow : See recommended temperature profile (page 6) Manual soldering : 400±10°C, 5 seconds Note 1 : Including temperature rise caused by current flow. Note 2 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. For no-electrification state after PCB mounting, the operating temperature and humidity are applied. ■Materials / Finish Parts Insulator Contact Metal fitting Material Finish LCP PPS Coper Alloy Brass Gray Black Nickel barrier gold plated Pure tin reflow plated UL Regulation ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 65 − 34S − 0.5 SH (99) ❹ ❶ Series Name : FH ❻ ❷ Series No. : 65 ❺ Terminal Type SH…SMT horizontal mounting type ❸ No. of Contacts : 34 ❻ Specifications ❹ Contact Pitch : 0.5mm 2 ❺ None : Regular (5000 pcs/reel) (99) : 500 pcs/reel UL94V-0 ーーー FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector ■Connector Dimensions A±0.15 B Q n× (0.12) 0.15 Q (3.27) 0.5 R A ** R Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.28) (3.49) (0.15) (C) (1 (2.5) (2.59) Cavity No. Number of contacts HRS mark Polarization mark FPC : t0.3 (9 0° ) °) 20 1.2±0.1 Contact No.1 1±0.1 1.08±0.1 D±0.1 (1.13) (2.8) 0.3±0.1 3.57±0.2 Note 1 : The dimension in parentheses are for reference. 2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max. 3 : To be delivered with tape and reel packages. See the packaging specifications for details. 4 : Note that preventive hole for sink mark or slit could be added for improvement. 5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic. 6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. 7 : ‘n’ shows the number of contacts. Units : mm HRS No. No. of Contacts A B C D FH65-4S-0.5SH (**) Part No. Under planning (Note 1) 4 3.8 1.5 2.57 3.18 FH65-6S-0.5SH (**) Under planning (Note 1) 6 4.8 2.5 3.57 4.18 FH65-8S-0.5SH (**) Under planning (Note 1) 8 5.8 3.5 4.57 5.18 FH65-10S-0.5SH (**) Under planning (Note 1) 10 6.8 4.5 5.57 6.18 FH65-12S-0.5SH (**) Under planning (Note 1) 12 7.8 5.5 6.57 7.18 FH65-14S-0.5SH (**) Under planning (Note 1) 14 8.8 6.5 7.57 8.18 FH65-15S-0.5SH (**) Under planning (Note 1) 15 9.3 7.0 8.07 8.68 FH65-16S-0.5SH (**) Under planning (Note 1) 16 9.8 7.5 8.57 9.18 FH65-18S-0.5SH (**) Under planning (Note 1) 18 10.8 8.5 9.57 10.18 FH65-20S-0.5SH (**) Under planning (Note 1) 20 11.8 9.5 10.57 11.18 FH65-22S-0.5SH (**) Under planning (Note 1) 22 12.8 10.5 11.57 12.18 FH65-24S-0.5SH (**) Under planning (Note 1) 24 13.8 11.5 12.57 13.18 FH65-26S-0.5SH (**) Under planning (Note 1) 26 14.8 12.5 13.57 14.18 FH65-28S-0.5SH (**) Under planning (Note 1) 28 15.8 13.5 14.57 15.18 FH65-30S-0.5SH (**) Under planning (Note 1) 30 16.8 14.5 15.57 16.18 FH65-32S-0.5SH (**) Under planning (Note 1) 32 17.8 15.5 16.57 17.18 FH65-34S-0.5SH (**) 580-4700-0 ** 34 18.8 16.5 17.57 18.18 FH65-36S-0.5SH (**) Under planning (Note 1) 36 19.8 17.5 18.57 19.18 FH65-40S-0.5SH (**) Under planning (Note 1) 40 21.8 19.5 20.57 21.18 FH65-45S-0.5SH (**) Under planning (Note 1) 45 24.3 22.0 23.07 23.68 FH65-50S-0.5SH (**) Under planning (Note 1) 50 26.8 24.5 25.57 26.18 FH65-60S-0.5SH (**) Under planning (Note 1) 60 31.8 29.5 30.57 31.18 FH65-64S-0.5SH (**) Under planning (Note 1) 64 33.8 31.5 32.57 33.18 FH65-68S-0.5SH (**) Under planning (Note 1) 68 35.8 33.5 34.57 35.18 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 3 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Recommended PCB Mounting Pattern Recommended Stencil Pattern Recommended stencil thickness:t=0.1 n× 0.05 X 0.6±0.05 X 0.3±0.03 3.79±0.05 (0.15) 0.6±0.05 0.5 B E±0.05 1.35±0.05 1.35±0.05 (Connector image) 0.5±0.03 Y 0.25±0.03 0.5 n× 0.05 Y 3.79±0.05 B Contact No.1 E±0.05 0.5±0.03 Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended FPC/FFC Dimensions Contact No.1 F±0.1 G±0.05 Z 0.5±0.07 B 0.5±0.07 0.3±0.05 0.5 0.35±0.03(FPC) 0.3±0.03(FFC) 0.03 n× Z 2-R0.2MAX 1.97±0.05 2-R0.2±0.05 4.2MIN 3.2MIN 2-R0.2±0.1 2-R0.2±0.05 (1MIN) 0.5±0.05 2-R0.2MAX H±0.05 Units : mm Part No. HRS No. No. of Contacts B E F G H FH65-4S-0.5SH (**) FH65-6S-0.5SH (**) FH65-8S-0.5SH (**) FH65-10S-0.5SH (**) FH65-12S-0.5SH (**) FH65-14S-0.5SH (**) FH65-15S-0.5SH (**) FH65-16S-0.5SH (**) FH65-18S-0.5SH (**) FH65-20S-0.5SH (**) FH65-22S-0.5SH (**) FH65-24S-0.5SH (**) FH65-26S-0.5SH (**) FH65-28S-0.5SH (**) FH65-30S-0.5SH (**) FH65-32S-0.5SH (**) FH65-34S-0.5SH (**) FH65-36S-0.5SH (**) FH65-40S-0.5SH (**) FH65-45S-0.5SH (**) FH65-50S-0.5SH (**) FH65-60S-0.5SH (**) FH65-64S-0.5SH (**) FH65-68S-0.5SH (**) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) 580-4700-0 ** Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) 4 6 8 10 12 14 15 16 18 20 22 24 26 28 30 32 34 36 40 45 50 60 64 68 1.5 2.5 3.5 4.5 5.5 6.5 7.0 7.5 8.5 9.5 10.5 11.5 12.5 13.5 14.5 15.5 16.5 17.5 19.5 22.0 24.5 29.5 31.5 33.5 2.8 3.8 4.8 5.8 6.8 7.8 8.3 8.8 9.8 10.8 11.8 12.8 13.8 14.8 15.8 16.8 17.8 18.8 20.8 23.3 25.8 30.8 32.8 34.8 3.83 4.83 5.83 6.83 7.83 8.83 9.33 9.83 10.83 11.83 12.83 13.83 14.83 15.83 16.83 17.83 18.83 19.83 21.83 24.33 26.83 31.83 33.83 35.83 2.5 3.5 4.5 5.5 6.5 7.5 8.0 8.5 9.5 10.5 11.5 12.5 13.5 14.5 15.5 16.5 17.5 18.5 20.5 23.0 25.5 30.5 32.5 34.5 2.87 3.87 4.87 5.87 6.87 7.87 8.37 8.87 9.87 10.87 11.87 12.87 13.87 14.87 15.87 16.87 17.87 18.87 20.87 23.37 25.87 30.87 32.87 34.87 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 4 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector BFH65 Series FPC/FFC Construction (Recommended Specifications) 1. Using Single-Sided FPC FPC : Flexible Printed Circuit Material name Covering film layer Material Polyimide Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover adhesive (25) 1/2oz (18) Surface treatment 0.2 µm thick gold plated over 1 to 5 µm thick nickel underplating Copper foil Cu Base adhesive Thermosetting adhesive 25 Base film Polyimide 1mil thick 25 Reinforcement material adhesive Thermosetting adhesive 30 Stiffener Polyimide 7mil thick 35 175 293 FPC : Flexible Printed Circuit Material name Covering film layer Material Polyimide 1mil Cover adhesive Thickness (µm) (25) (25) Surface treatment 0.2 µm thick gold plated over 1 to 5 µm thick nickel underplating Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 Base film Polyimide 25 Base adhesive Thermosetting adhesive Copper foil Cu Cover adhesive Thermosetting adhesive 25 Covering layer film Polyimide 1mil thick 25 Reinforcement material adhesive Thermosetting adhesive Stiffener Polyimide * To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is not recommended. 3. Using FFC 3 1oz Total 2. Using Double-Sided FPC Thickness (µm) 1mil 3 15 1/2oz 18 1mil thick 1/2oz 4mil thick Total 18 (18) 50 100 297 FFC : Flexible Flat Cable Material name Material Adhesive Thickness (µm) (12) Polyester film Thermoplastic polyester (30) Gold plated annealed copper foil Adhesive 35 Polyester 30 Polyester 12 Adhesive Polyester 30 Stiffener Polyester 188 Total 295 * Typical thickness tolerance is about ±20µm 1. This specification is a recommendation for the construction of the FH65 Series FPC and FFC (t =0.3±0.05mm). 2. For details about the construction, please contact the FPC/FFC manufacturers. 5 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Packaging Specifications 1.75±0.1 4±0.1 2±0.1 1 0. + 0 8±0.1 Ø 5 1. K±0.1 (J) A ** A ** (3.52) (4.27) M±0.1 L±0.3 (J) (1.6) (0.3) K±0.1 L±0.3 + 0. 1 8±0.1 0 4±0.1 2±0.1 Ø1 .5 (1.6) (0.3) 1.75±0.1 ●Embossed Carrier Tape Dimensions 1.7 +0.15 0 Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Direction of unreeling 1.5 (3.52) (4.27) +0.1 0 Direction of unreeling ●Leader, Trailer Dimensions N±1 (Reel outer width) (Ø1 3) ●Reel Dimensions Direction of unreeling 400mm MIN(Leader) Ø380±2 Ø80±1 Direction of unreeling 100mm MIN Top cover tape Embossed carrier tape 160mm MIN (empty components) (Trailer, empty components) P±1 (Reel inner width) Units : mm Part No. HRS No. No. of Contacts J K L M N P FH65-4S-0.5SH (**) FH65-6S-0.5SH (**) FH65-8S-0.5SH (**) FH65-10S-0.5SH (**) FH65-12S-0.5SH (**) FH65-14S-0.5SH (**) FH65-15S-0.5SH (**) FH65-16S-0.5SH (**) FH65-18S-0.5SH (**) FH65-20S-0.5SH (**) FH65-22S-0.5SH (**) FH65-24S-0.5SH (**) FH65-26S-0.5SH (**) FH65-28S-0.5SH (**) FH65-30S-0.5SH (**) FH65-32S-0.5SH (**) FH65-34S-0.5SH (**) FH65-36S-0.5SH (**) FH65-40S-0.5SH (**) FH65-45S-0.5SH (**) FH65-50S-0.5SH (**) FH65-60S-0.5SH (**) FH65-64S-0.5SH (**) FH65-68S-0.5SH (**) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) 580-4700-0 ** Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) Under planning (Note 1) 4 6 8 10 12 14 15 16 18 20 22 24 26 28 30 32 34 36 40 45 50 60 64 68 4.0 5.0 6.0 7.0 8.0 9.0 9.5 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.5 27.0 32.0 34.0 36.0 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 14.2 14.2 20.2 20.2 20.2 20.2 20.2 26.2 26.2 26.2 16.0 16.0 16.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 32.0 32.0 32.0 32.0 44.0 44.0 44.0 44.0 44.0 56.0 56.0 56.0 — — — — — — — — — — — — 28.4 28.4 28.4 28.4 40.4 40.4 40.4 40.4 40.4 52.4 52.4 52.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 37.4 37.4 49.4 49.4 49.4 49.4 49.4 61.4 61.4 61.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 33.4 33.4 45.4 45.4 45.4 45.4 45.4 57.4 57.4 57.4 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 6 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Temperature(℃) Temperature Profile Applicable Conditions MAX 250℃ 245 Reflow method 220℃ Solder 200 : IR/Hot air Reflow environment : Room air 180℃ : Paste type Sn/3.0Ag/0.5Cu (M705-GRN360-K2-V made by Senju Metal Industry Co.) 150 Test PCB 150℃ : PCB material and size Glass epoxy 80×100×1.6mm Land size, per recommended on 100 page 4. Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20 to 40 sec. 50 Peak temperature 25℃ 0 120±5 sec. Preheating time 60 to 90 sec. Soldering time Start Metal mask : Thickness and opening size Per recommended on page 4. This temperature profile is based on the above conditions. It may vastly depending on solder paste type, manufacturer, PCB size and mounting materials. Please Time(sec.) use only after checking the mounting conditions. 7 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions [Operation method] This connector is a small-sized and thin product, care needs to be taken when handling it. In order to prevent damage and contact failure etc. (incorrect mating, disconnection of FPC/FFC pattern) of connectors and FPC/FFC, please use them after following the below instructions. The values described in the cautions vary from the product specifications. 1. Initially delivered state Actuator is locked in the delivered state. [Caution] ・Don't operate the connector while it is not mounted on the board. Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. How to unlock actuator (FPC/FFC not inserted) Actuator rotates around the center rotation axis, as shown in the Figure below. Operate the actuator and slowly rotate it, releasing the lock. [Fig.1] [Caution] ・Operate the actuator about the center. [Fig.2] ・Do not operate the actuator on one side only. [Fig.3] ・Operate the actuator by hand, take care not to allow jigs or claws to get inside the connector . [Fig.4, Fig.5] ・Actuator cannot be opened wider than 120°. Do not open it wider than that angle. [Fig.6] ・Do not apply a strong force in the actuator slide direction. It could prevent the actuator from sliding in, as shown in the Figure. [Fig.7] ・Do not pick and raise the actuator, or hook it. [Fig.8, Fig.9] Actuator rotation axis (Rotation center) PCB PCB [Fig.1] Operate the actuator around the center. [Fig.2] Operate the actuator on one side. [Fig.3] Deformation of the upper arm section of the contact PCB PCB Deformation of the contacting section of the contact [Fig.4] 8 [Fig.5] FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions [Operation method] 0°) (12 [Fig.6] PCB PCB Actuator prevented from sliding in [Fig.7] PCB PCB [Fig.8] [Fig.9] 3. How to insert FPC/FFC This connector uses a bottom contact point. Additionally, this connector is equipped with reinforcing metal tabs for positioning FPC/FFC. Hold FPC/FFC with the conductor side facing down, and insert FPC/FFC from above diagonally at an angle of about 20° to the board. [Fig.10] [Caution] ・Be careful not to insert FPC/FFC with the conductor side facing upwards. ・Be sure to insert FPC/FFC to the end. ・Do not insert FPC/FFC from diagonally above. [Fig.11] ・Insert FPC/FFC while the actuator is open. [Fig.12] ・Do not insert FPC/FFC approaching in a vertical, lateral or diagonal direction. [Fig.13] Reinforcing metal tabs for positioning FPC (20°) Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB PCB PCB FPC conductor side (facing downwards) [Fig.10] 9 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions (45 °) [Operation method] PCB PCB Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Fig.11] Disconnected from FPC pattern FPC/FFC FPC/FFC [Fig.12] [Fig.13] 4. Check the inserted state of FPC/FFC This connector uses reinforcing metal tabs for positioning FPC/FFC. When insertion of FPC/FFC is complete, confirm that the FPC/FFC positioning tab is located at the place shown in the Figure. [Fig.14] [Caution] ・Do not insert FPC/FFC insufficiently deep or from a diagonal direction. [Fig.15, Fig.16] FPC/FFC FPC/FFC positioning tab Reinforcing metal tabs for positioning FPC/FFC ࠉ The FPC/FFC positioning tab goes in the reinforcing metal tabs for positioning FPC/FFC. [Fig.14] 10 FPC/FFC (shallow) FPC/FFC (diagonal) The FPC/FFC positioning tab runs over the reinforcing metal tabs for positioning FPC/FFC. The FPC/FFC positioning tab runs over the reinforcing metal tabs for positioning FPC/FFC. [Fig.15] [Fig.16] FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions [Operation method] 5. Actuator locking mechanism Actuator rotates around the center. After inserting FPC/FFC correctly to the end, operate the actuator by rotating it, and then lock in place. [Fig.17] Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] ・Operate the actuator around the center. [Fig.18] ・Do not operate the actuator on one side only. [Fig.19] ・Operate the actuator by hand, take care not to allow jigs or claws to get inside the connector. ・Do not operate the actuator in the direction opposite to the closing direction. ・Do not pick and raise the actuator, or hook it. ・Please check to insure the actuator is placed horizontal to the board surface when locked. PCB PCB Actuator rotation axis (Rotation center) [Fig.17] Operate the actuator around the center. Operate the actuator on one side. [Fig.18] [Fig.19] 6. Check the mated state of FPC/FFC When the actuator is completely locked, visually inspect the inserted status of FPC/FFC. [Fig.20] [Caution] ・Do not insert FPC/FFC insufficiently deep or from a diagonal direction. [Fig.21, Fig.22] W  hen FPC/FFC is correctly inserted, the FPC/FFC positioning tab sits in the reinforcing metal tabs for positioning FPC/FFC. FPC/FFC Reinforcing metal tabs for positioning FPC/FFC [Fig.20] If FPC/FFC is not correctly inserted (or is not inserted deep enough), the FPC/FFC positioning tab will not sit in the reinforcing metal tabs for positioning FPC/FFC and sticks out of the connector. FPC/FFC (shallow) [Fig.21] If FPC/FFC is not correctly inserted (or is inserted diagonally), part of the FPC/FFC positioning tab does not go in the reinforcing metal tab for positioning FPC/FFC and sticks out of the connector. FPC/FFC (diagonal) [Fig.22] 11 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions [Operation method] 7. How to unlock actuator (FPC/FFC inserted) Push the actuator slowly just above and release the lock. [Fig.23] [Caution] ・Operate the actuator around the center. [Fig.24] ・Do not operate the actuator on one side only. [Fig.25] ・Operate the actuator by hand, take care not to allow jigs or claws to get into the connector. ・Actuator cannot be opened wider than 120°. Do not try to open it wider than that angle. [Fig.26] ・Do not pick and raise the actuator, or hook it. [Fig.27] Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Actuator rotation axis (Rotation center) PCB PCB [Fig.23] Operate the actuator around the center. [Fig.24] Operate the actuator on one side. [Fig.25] 0°) (12 PCB [Fig.26] 12 PCB [Fig.27] FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Operation Methods of Connectors and Precautions [Operation method] 8. How to remove FPC/FFC This connector uses reinforcing metal tabs for positioning FPC/FFC. After unlocking the actuator, pull out the FPC/FFC diagonally at an angle of about 20° to the board. [Fig.28] [Caution] ・Do not remove the FPC/FFC in the horizontal direction. ・Do not remove the FPC/FFC considerably diagonally above. [Fig.29] ・Do not remove the FPC/FFC while the actuator is closed. [Fig.30] Deformation of the upper arm section of the contact (20°) Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Actuator [Closed] PCB PCB PCB [Fig.28] [Fig.29] [Fig.30] [Cautions for PCB layout] Depending on the routing of FPC/FFC to mate, a load may be applied to the connector, which could lead to contact failure. In order to prevent any failure, please consider the following. [Caution] ・Please ensure there is no load applied to the connector in the pulling, inserting or lateral direction. [Fig.31] Please ensure that no extreme tensile force or upward force etc. is applied to the connector in the vertical direction. ・When routing FPC/FFC, please ensure that the FPC/FFC is not pulled and routing is carried out with adequate margin. Please check that the reinforcing film is placed horizontal to the board surface. [Fig.32] ・Do not route the FPC/FFC to bend around the connector. [Fig.33] Please take care with the FPC/FFC so that no direct force is applied to the connector section. ・Please do not place any parts under the FPC/FFC reinforcing film that will interfere with FPC/FFC. [Fig.34] ・Please confirm the recommendations of in this document for the shape of FPC/FFC. In addition, for the flexibility of FPC/FFC, please make adjustments with the FPC/FFC manufacturer. ・When designing, please ensure there is adequate for FPC/FFC insertion so it is not inserted on an extreme diagonally. In addition, a short FPC/FFC will make insertion difficult, please use adequate layout and length for FPC/FFC. ・When designing a board layout, please secure the space required for actuator movement. Reinforcing film (horizontal) FPC/FFC The state where a load is applied to FPC/FFC PCB [Fig.31] [Fig.32] Reinforcing film (diagonal) Reinforcing film (diagonal) FPC/FFC FPC/FFC PCB PCB Mounting parts interfering with FPC/FFC [Fig.33] [Fig.34] 13 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector [Notes for mounting on the board] Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] ・Please confirm recommendations for mount board land shape, metal mask opening shape, and FPC/FFC shape. ・If the land is narrower than recommended, or if the metal mask opening is wider than recommended, solder (flux) wicking is more likely to occur. If there is difference from the recommendation, please use after checking the mounted state. ・The level difference between the bottom surfaces of contact lead and the mold is designed to be small. When there is silk print etc. on the bottom surface of the connector, it could push up the connector bottom surface, and cause non-sticking solder or defective fillet formation. When there is silk print etc. on the bottom surface of the connector, please use it after checking the mounted state. ・Use the reflow conditions within the specification. The mounted status may vary due to external conditions such as the type of cream solder, manufacturer, and board size. Please use after checking the mounted state. ・Please control the board warpage as much as possible. While the coplanarity of this connector is 0.1mm or less, if there is considerable board warpage, defective soldering could occur. ・When mounted on FPC/FFC, be sure to provide a reinforcing plate to make it easier to handle. A reinforcing plate of 0.3mm or thicker made of glass epoxy material is recommended. ・When you remove the emboss from the reel, or when you absorb the connector from the emboss and so on, do not apply any excessive external force to the connector before mounting. (1N or less) [Cautions when handling the board after mounting] Please be careful of the following matters when you handle the board after mounting operation. [Caution] ・Do not apply any load to the board in the assembly process, such as 'dividing a multi-piece board' or Securing the board to the frame. Such an action could apply a load to the connector and damage it. ・Use the board with the deflection of 1mm or less when the board width is 100mm. [Fig.35] If the board has some deflection, it could apply a load to the connector and damage it. 1MAX 100 Connector 1MAX Connector PCB 100 [Fig.35] [Cautions for hand-soldering] Please be careful of the following matters when you carry out hand-soldering such as for repair work etc. [Caution] ・Do not t hand-solder while FPC/FFC is inserted. ・Please be careful not to apply excessive heat, or allow the solder iron to touch any place other than the connector contact lead part. Such an action could cause the connector to be deformed or melted. ・Do not operate the connector while it is not mounted on the board. ・Do not supply an excessive amount of solder (flux). If too much solder (flux) is supplied to the contact, the solder or flux could adhere on the contact point or the rotation section of the actuator. This will cause contact failure or defective rotation of the actuator. Additionally, if too much solder is supplied to the reinforcing metal tabs, the rotational action of the actuator could be damaged . 14 FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 15 Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH65 Series●0 .5mm Pitch, 1.2mm Height, 125°C Heat Resistant, FPC/FFC Connector USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 15083 Phone : +82-31-496-7000 or 7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ INDIA: SINGAPORE: HIROSE ELECTRIC SINGAPORE PTE. LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE 10 Anson Road #26-16, International Plaza Office NO.552, Regus-Green Boulevard, Level5, Tower C, 079903, Singapore Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +65-6324-6113 Phone : +91-12-660-8018 Fax : +65-6324-6123 Fax : +91-120-4804949 http://www.hirose.com/sg/ http://www.hirose.com/sg/ MALAYSIA: PENANG REPRESENTATIVE OFFICE 1-21-01, Suntech @ Penang Cybercity (1164), Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 16 INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 01/2017. Contents are subject to change without notice for the purpose of improvements.
FH65-8S-0.5SH 价格&库存
很抱歉,暂时无法提供与“FH65-8S-0.5SH”相匹配的价格&库存,您可以联系我们找货
FH65-8S-0.5SH
  • 1+12.384411+1.60939
  • 10+10.0827810+1.31029
  • 25+9.2961625+1.20806
  • 50+8.7430150+1.13618
  • 100+8.22034100+1.06826
  • 250+7.57862250+0.98486
  • 500+7.12681500+0.92615
  • 1000+6.702141000+0.87096
  • 2500+6.179632500+0.80306
库存:8828
FH65-8S-0.5SH
  • 1+17.914041+2.32798
  • 10+15.1762510+1.97220
  • 25+14.2262425+1.84874
  • 50+13.5470350+1.76047
  • 100+12.89854100+1.67620
  • 250+12.09086250+1.57124
  • 500+11.51349500+1.49621
  • 1000+10.963981000+1.42480
  • 2500+10.799522500+1.40343
库存:8228
