CA3324L-602P0618-1816H
    BRH(宝仁弘)
    插件
    共模电感 6mH 60mΩ 插件
CA3324L-602P0618-1816H 数据手册
EMI、EMC對策用元件 THIS SPECIFICATION IS APPLIED TO WIRE WOUND INDUCTOR CA3324L-602P0618-1816H Product standard of spec sheet 寶仁弘電子有限公司 Prosperity Electronic Co., Limited EML:brh@baorenhong.com Web:www.baorenhong.com TEL:0755-29687188 FAX:0755-29688152 深圳市寶安區福永鎮立新二路天佑創客產業園 TEL:0512-36878535 FAX:0512-36878435 江蘇省昆山市花橋鎮綠地大道 1325號 CA3324L-602P0618-1816H PRODUCT OVERVIEW ◎Shape&Dimensions 形狀與尺寸: 33max 1 3.5±0.5 44max 24max 1 3 4 1.2± 0.1 18± 0.5 1 16±0.6 3 2 4 NO:CA20230224TP8011 -AY01 Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H TEST DATAS FOR SAMPLES ◎Electrical Diagram 電性圖: Electrical Diagram 1 4 2 3 Winding Sequence Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H TEST DATAS FOR SAMPLES ◎Material List 物料清單: ITEM BOBBIN MATERIAL T375J(G5) T375J(G6) CLASS UL NO. MANUFACTURER 150℃ E59481 CHANG CHUN PLASTICS CO.,LTD CORE SQ3324 12K MINGJI ELETRON CO., LTD WIRE @*FIWx180 180℃ E234867 ZHUHAI SUNTEK WIRE CO LTD VARNISH E962 130℃ E335405 ZHUHAI CHANGXIAN INDUSTRIAL CO., LTD Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H TEST DATAS FOR SAMPLES ◎Winding 产品绕制要求: WINDING MATERIAL START--FINISH REMARK N1 0.8T*1.8mm 扁平线 1-2 32Ts REF. 密绕 N2 0.8T*1.8mm 扁平线 4-3 32Ts REF. 密绕 Test condition ◎Electrical Characteristics 電氣特性: NO Item Spec Test Equipment 1 L(1-2)(4-3) 6.0mH MIN TH2816A/TH2832/ CHENHWA UC2906 2 DC Resistance (1-2)(4-3) 60 mΩ MAX CHENHWA 502A 3 Difference/Inductance/ L(1-2)-L(4-3) 0.3mH MAX TH2816A/TH2832/ CHENHWA UC2906 4 Rated Current (A) Input 220V 10A MAX 5 HI-POT TEST 6 Insulation Resistance.DC 500V COIL TO COIL 1KHz/0.25V/25℃/ 内阻50Ω DC.RESISTANCE AT 25℃ E-SUN 19053 AC 50Hz,3mA, 3Sec,1.5KV 100M OHM MIN In case of doubt: Test the samples after putting it in the room temperature of 25℃~40℃ for 5~6 hours Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H TEST DATAS FOR SAMPLES ◎Test Datas For Samples 樣品測試數據: MEAS.Item DC Resistance 60mΩ MAX 8mH MIN Product Diagram Suggest 1-2 4-3 1-2 4-3 1 9.65 9.63 19.88 19.88 2 9.63 9.65 20.01 20.03 3 9.66 9.65 19.97 19.98 4 10.02 10.01 19.98 19.97 5 9.78 9.79 19.87 19.89 6 9.82 9.83 19.86 19.87 7 8.95 8.99 19.85 19.82 8 9.39 9.39 20.05 20.01 9 9.46 9.46 20.02 20.01 10 9.17 9.17 19.86 19.86 X 9.55 9.56 19.94 19.93 R 1.07 1.02 0.20 0.21 The test data above is only for reference,actual results may differ due to different production batches. Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H TEST DATAS FOR SAMPLES ◎Test Datas For Samples 樣品測試數據: MEAS. Item 33.0 MAX 44.0 MAX 24.0 MAX 18.0±0.5 16.0±0.6 1 29.73 42.20 22.37 18.23 15.88 2 29.75 42.15 22.35 18.21 15.86 3 29.71 42.18 22.39 18.25 15.88 4 29.74 42.17 22.38 18.22 15.91 5 29.77 42.21 22.37 18.23 15.89 6 29.78 42.19 22.39 18.21 15.87 7 29.76 42.23 22.36 18.25 15.85 8 29.77 42.21 22.35 18.23 15.92 9 29.75 42.18 22.37 18.22 15.88 10 29.74 42.18 22.39 18.21 15.87 X 29.75 42.19 22.37 18.23 15.88 R 0.07 0.08 0.04 0.04 0.07 The test data above is only for reference,actual results may differ due to different production batches. Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H PACKING ◎Packing 包裝: A. Quantilty per box :According to customer’s request. B. With PE tapes. C. Package Dimensions (mm): L(mm) W(mm) H(mm) 350 MAX 350 MAX 170 MAX D. Lable Items: * Customer * Quantity * Part. Number * Lot. Number * PROSPERITY ELECTRONICS CO.,LTD E. Storage: * Please be sure to store the package at no more than 35℃and 70%RH , keep the package in the atmosphere free of sulphur and chlorine. Web Site:http://www.baorenhong.com CA3324L-602P0618-1816H RELIABILITY TEST ◎Reliability Test 可靠性測試: STORAGE TEMPERATURE -25℃~85℃ OPERATING TEMPERATURE RANGE : -25℃~+85℃(CONTAIN HEATING COIL) EXTERNAL APPEARANCE NO EXTERNAL DEFECTS CAN BE FOUND IN THE VISUAL INSPECTION. TERMINAL STRENGTH FIXED INDUCTORS,ONE END OF THE ELECTRODE WITH 0.45KG PULLING FORCE,GUIDED THE NEEDLE DOES NOT FALL OFF. INSULATING RESISTANCE THE INSULATION RESISTANCE SHOULD BE OVER 1000MΩ WHEN D.C.100V IS APPLIED TO THE WINDING –CORE. MEANWHILE NO STRUCTURE AND ELECTRIC DEFECTS SHOULD BE FOUND FOR 1 MINUTE. HUMIDITY TEST INDUCTANCE DEVIATION IS WITHIN ±10.0% AND NO STRUCTURE AND ELECTRIC DEFECTS CAN BE FOUND AFTER 96±2hours TEST UNDER THE CONDITIONOF RELATIVE HUMIDITY OF 90~95% AND TEMPERATURE OF 40±5℃. AND 1 HOUR STORAGE UNDER ROOM AMBIENT CONDITIONS AFTER THE DEVICE IS WIPED WITH DRY CLOTH. VIBRATION TEST INDUCTANCE DEVIATION IS WITHIN ±10.0% AFTER 1 HOUR SWEEPING VIBRATION IN EACH THREE DIRECTIONS. NAMELY, FREQUENCY IS10~55Hz ANDTHE AMPLITUDE OF 1MINUTE CYCLE IS 1.5mm . Web Site:http://www.baorenhong.com
CA3324L-602P0618-1816H 价格&库存
很抱歉,暂时无法提供与“CA3324L-602P0618-1816H”相匹配的价格&库存,您可以联系我们找货
