5J2100A
5J2100A
    LANSON(良胜)
    FUSE_D5.2X20MM
    一次性保险丝(熔断) FUSE_D5.2X20MM 250V 10A 无引线
5J2100A 数据手册
产品规格书 PRODUCT SPECIFICATION 客户名称: CUSTOMER: 产品名称: PRODUCT NAME: FUSE 保险丝 型号规格: 5J MODEL DETAIL: 料 F10AL 250V 快断型(FAST-ACTING) 号: 5J2100A PART NO.: 供应商: 深圳市良胜电子有限公司 SUPPLIER: SHENZHEN LANSON ELECTRONICS CO., LTD. 地 深圳市宝安区福永街道富桥第三工业区 A18 栋 址: ADDRESS: A18th Bldg, Fuqiao 3rd Industrial Zone, Fuyong Town. Baoan District,Shenzhen. TEL:0755-29929709 29929711 Http:www.lansonfuse.com 编 制 审 核 PREPARED BY CHECKED BY 批 准 APPROVED BY FAX:0755-29929812 E-mail:lanson@lansonfuse.com 承 认 SIGNATURE 供方签章: 需方签章: SUPPLIER: CUSTOMER: 日期: 日期: DATE:2024.01.18 DATE: 审 核 CHECKED BY 批 准 APPROVED BY SHENZHEN LANSON ELECTRONICS CO.,LTD. PRODUCT EDITION NO. A/8 SPECIFICATION FILE NO. LS/C- 005-17 MODEL:5J PAGE PAGE 1 OF 4 1. 适用范围 Scope of application 本产品适用于各种电子电器内的电路中起过电流保护作用。 This product is suitable for various kinds of electronic machines to work for over current protection. 2. 相关标准及认证 Relevant Standards and Certification 2.1 执行标准 Standards :IEC60127-1 IEC60127-2 GB/T9364.1 2.2 认证 Certification: GB/T9364.7 安规 Certification 认证范围 Scope of Certification 证书编号 Certification No. UL 125mA~6.3A E221465 CCC 自我声明 200mA~6.3A 2020970207000110 CQC 8A~10A CQC09012038370 VDE 200mA~10A 40009306 1A~5A JET5359-31003-1007 6.3A~15A JET5359-31003-1008 200mA~800mA SU05026-7002A 1A~2.5A SU05026-7003A 3.15A~6.3A SU05026-7001A PSE KTL 3. 结构及尺寸 Structure and Size (unit: mm) 4. 原材料明细 Material Details 编号 No. 零件名称 Part Name 材质 Material ① 端帽 End cap 黄铜表面镀镍 Nickel plated brass ② 玻璃管 Glass tube 玻璃 Glass ③ 熔丝 Fuse element 合金线 Alloy SHENZHEN LANSON ELECTRONICS CO.,LTD. PRODUCT EDITION NO. A/8 SPECIFICATION FILE NO. LS/C- 005-17 MODEL:5J PAGE PAGE 2 OF 4 5. 标示 Marking 保险丝两端铜帽上应印有下列标示:The fuse shall have the following marking : A 帽:良胜型号+快断型符号+额定电流+低分断符号+额定电压 A Cap:Lanson’s model +Electrical characteristics +Ampere rating + Low-breaking Capacity Symbol +Voltage rating 5J F 10A L 250V B 帽:良胜标志+认证符号 B Cap:Lanson’s logo + Approved Symbol 6. 外观 Appearance 6.1 外观不应有显著的污点、裂纹。 There shall not be any remarkable stain,rust or crack on the appearances. 6.2 标示应该很容易辨识。 Marking shall be easily legible. 7. 机械特性 Mechanical characteristics 拉力强度试验 Tensile test 将保险丝固定好后,对保险丝两端引线施加 10N 的轴向拉力,持续 1 分钟。试验过后,保险丝 没有任何破损现象。 Exert the axial pulling force of 10N to the both ends of lead wire for 1 minute. After the test the fuse shall be no damage and loosening. 8. 电气特性 Electrical characteristics 8.1 实验条件 Test condition 所有测试环境温度为 25±5℃。 All electrical characteristics tests are conducted at an ambient temperature of 25±5℃. 8.2 分断能力 Interrupting rating test 保险丝能承受的分断能力:35A 或 10 倍的额定电流当中较大的。分断能力测试后测得保险 丝的绝缘阻抗值大于 0.1ΜΩ。 The fuse interrupting capacity:35A or 10 times the rated current whichever is greater. After interrupting, the insulation resistance between the fuse terminations shall be not less than 0.1ΜΩ. SHENZHEN LANSON ELECTRONICS CO.,LTD. PRODUCT EDITION NO. A/8 SPECIFICATION FILE NO. LS/C- 005-17 MODEL:5J PAGE PAGE 3 OF 4 8.3 时间-电流特性 Time-Current Characteristics 额定电流的% % of ampere rating 熔断时间 Opening time (200mA~6.3A) 熔断时间 Opening time (8A~10A) 210% 30 min Max 30 min Max 275% 50 ms~2 s 50 ms~2 s 400% 10 ms~300 ms 10 ms~400 ms 1000% 20 ms Max 40 ms Max 8.4 耐久性测试 Endurance test 对保险丝通过相关标准规格单规定的 1.2 倍额定电流 1 小时,然后截断电流 15 分钟,将该循环 重复 100 次。试验过后保险丝没有任何破损现象。 A 1.2 times the ampere rating specified in the relevant standard sheet is passed through the fuse for a period of 1h.The current is then switched off for a period of 15 minutes. This cycle is repeated 100 times. After the test the fuse shall be no damage and loosening. 8.5 焊接参数 Soldering parameters 8.5.1 波峰焊 260℃,最大10秒, Wave soldering 260 ℃,10 sec. Maximum 8.5.2 手工焊 350℃,最大5秒, Manual soldering 350℃, 5 sec. Maximum 8.6 时间电流曲线图见附页 Time- current curve see attachment 9 环境特性 Environmental characteristics 9.1 使用温度范围 Operating Temperature -55℃~125℃。 9.2 保存条件 Storage Conditions 相对湿度≤75%,可存放 3 年。 Relative humidity≤75%, store 3 years . 10. 包裝 Packing 10.1 500PCS/小袋、4 小袋/内盒、10 内盒/外箱(实际装箱依客户订单)。 500 fuses per plastic bag, 4 plastic bags per inner box, 10 inner boxes per external carton. (The actual case in accordance with the customer order) 10.2 产品符合 RoHS 环保指令 The product is compliant with RoHS Directive 附:承认书后附安规证书及环保报告 Appendix: The pecification attached safety certificate and RoHS directive test report. SHENZHEN LANSON ELECTRONICS CO.,LTD. 附页 attachment PRODUCT EDITION NO. A/8 SPECIFICATION FILE NO. LS/C- 005-17 MODEL:5J PAGE PAGE 4 OF 4
5J2100A 价格&库存
很抱歉,暂时无法提供与“5J2100A”相匹配的价格&库存,您可以联系我们找货
