15HCL-40E
15HCL-40E
    EATON(伊顿)
    Cartridge,Non-Standard
    15.5KV 40E HCL FUSE
15HCL-40E 数据手册
Technical Data 10353 Effective November 2019 Supersedes October 2019 BUSSMANN SERIES 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Features and benefits • Current-limiting E-Rated medium voltage fuses are defined by their melting time-current characteristic that permit their electrical interchangeability with other fuses of the same E Rating. • E-Rated fuses must have a defined current response time specified by ANSI C37.46. E-Rated fuses of 100 amps and below must melt in 300 seconds at an RMS current within the range of 200% to 240% of the fuse’s nameplate current rating. E-Rated fuses greater than 100 amps must melt within 600 seconds at an RMS current in the range of 220% to 264% of the fuse’s nameplate current rating. • E-Rated fuses are physically dimensioned for easy installation in existing hardware. • Current-limiting fuses provide positive interruption even on low fault currents. The fuse limits the magnitude of electromechanical stresses in the protected apparatus. • Constructions available in ferrule, bolt-on and clip-lock, and specialty mount fuses for AMPGARD motor starters. • Outdoor rating available on select catalog numbers (requires installation in a suitable enclosure). • Open fuse indicator speeds troubleshooting by providing a positive visual indication of fuse operation. • 50/60 Hz operating frequency for worldwide application. • Mountings are available in disconnect and nondisconnect versions with porcelain or glass polyester insulators. • Live parts and end fittings available. Description: • Bussmann™ series of E-Rated, current-limiting, medium voltage fuses are for feeder circuit, switchgear and transformer protection. Typical applications: • Medium voltage transformer primary protection • Medium voltage feeder circuit protection • Medium voltage switches • Medium voltage metal-enclosed switchgear Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 E-Rated medium voltage ferrule fuses Dimensions (see catalog number tables for values) Catalog symbols: • • C General purpose B • 15CLE-_E-D (long construction, 10-25 A) • 15CLE-_E (long construction, 15-300 A) • 15HLE-_E (short construction, 10-250 A) • 15LHLE-_E (intermediate construction, 65-300 A) Full range (per ANSI C37.40) • 3.31 (84.1) MV155F_ B Ratings*: • Volts — 15.5 kV • Amps — 10 to 300 A • Interrupting ratings — 31.5 to 63 kA RMS Sym. A * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information: • E-Rated fuses meet the performance characteristics of ANSI C37.46 • UL® Listed, Guide JEEG, File E240398. See catalog numbers. Recommended fuseclips and holders: Catalog number Amp rating Approximate dimensions - in (mm) Fuse mounting type Mounting (including live parts, end fittings)** Porcelain insulator Glass-polyester insulator Live parts (including end fittings) End fittings (disconnect only) 95 15CLE-PNM-C 15CLE-GNM-C CLE-NL-C — 110 15CLE-HPNM-C — CLE-NL-C — 15CLE-PDM-C 15CLE-GDM-C CLE-DL-C CLE-DF-C 110 15CLE-HPDM-C — CLE-DL-C CLE-DF-C 95 15CLE-PNM-D 15CLE-GNM-D CLE-NL-D — 110 15CLE-HPM-D — CLE-NL-D — 15CLE-PDM-D 15CLE-GNM-D CLE-DL-D CLE-DF-D 110 15CLE-HPDM-D — CLE-DL-D CLE-DF-D Non-disconnect 110 15CLE-PNM-E — CLE-NL-E — Disconnect† 110 15CLE-PDM-E — CLE-DL-E CLE-DF-E 15HLE-PNM-D 15HLE-GNM-D CLE-NL-D 15HLE-PDM-D 15HLE-GDM-D CLE-DL-D 15HLE-PNM-E — CLE-NL-E 15HLE-PDM-E — CLE-DL-E CLE-DF-E Not available Not available CLE-NL-D — Not available Not available CLE-DL-D Not available Not available CLE-NL-E Not available Not available CLE-DL-E CLE-DF-D — CLE-DF-E Voltage BIL (kV) Diameter Clip center Length CLE 15E–25E Single barrel 10E-D–25E-D 30E–100E Single barrel 125E–300E Double barrel Non-disconnect Disconnect † Non-disconnect Disconnect † 95 95 2 (51) 3 (76) 3 (76) 20 (508) 20 (508) 20 (508) 21.5 (546) 23.9 (607) 23.9 (607) HLE 10E-80E Single barrel Non-disconnect 95 Disconnect† 95 100E–250E Double barrel Non-disconnect 95 Disconnect† 95 65E–100E Single barrel Non-disconnect — Disconnect† — 125E–300E Double barrel Non-disconnect — Disconnect† — 3 (76) 15 (381) 18.9 (480) 3 (76) 15 (381) 18.9 (480) — CLE-DF-D — LHLE 3 (76) 3 (76) 18 (457) 18 (457) 20.53 (521) 20.53 (521) ** End fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. 2 Eaton.com/bussmannseries 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 CLE, HLE and LHLE Type general purpose fuses Dimensions — in (mm) Amps Length A Diameter B CLE Long construction 10 23.9 (607) 3 (76) 15 21.5 (546) 2 (51) 15 23.9 (607) 3 (76) 20 21.5 (546) 2 (51) 20 23.9 (607) 3 (76) 25 21.5 (546) 2 (51) 25 30 40 50 65 80 100 23.9 (607) 3 (76) 125 150 175 200 250 300 HLE Short construction 10 15 20 25 30 40 50 65 18.9 (480) 3 (76) 80 100 125 150 175 200 250 LHLE 65 80 100 125 150 20.5 (521) 3 (76) 175 200 250 300 Clip centers C IR RMS Sym. (kA) No. of barrels 63 31.5 63 31.5 63 31.5 Installation location Indoor/outdoor Indoor Indoor/outdoor Indoor Indoor/outdoor Indoor 1 20 (508) 63 Indoor/outdoor 2 63 Indoor/outdoor Indoor/outdoor 15LHLE-65E 15LHLE-80E 15LHLE-100E 15LHLE-125E-D 15LHLE-150E-D 15LHLE-175E 15LHLE-200E 15LHLE-250E 15LHLE-300E 2 1 18 (457) 50 2 15CLE-10E-D 15CLE-15E* 15CLE-15E-D 15CLE-20E* 15CLE-20E-D 15CLE-25E* 15CLE-25E-D 15CLE-30E 15CLE-40E† 15CLE-50E† 15CLE-65E† 15CLE-80E† 15CLE-100E† 15CLE-125E-D† 15CLE-150E-D† 15CLE-175E† 15CLE-200E† 15CLE-250E† 15CLE-300E† 15HLE-10E 15HLE-15E 15HLE-20E 15HLE-25E 15HLE-30E 15HLE-40E† 15HLE-50E† 15HLE-65E† 15HLE-80E† 15HLE-100E-D† 15HLE-125E-D† 15HLE-150E† 15HLE-175E† 15HLE-200E† 15HLE-250E† 1 15 (381) Catalog no. * Fuses conform to dimensional standards established by Westinghouse. † UL Listed, Guide JEEG, File E240398. Eaton.com/bussmannseries 3 Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 MV155F_ Full range Dimensions — in (mm) Length A Diameter B Amps 5 7 10 10 15 15 20 20 25 25 30 30 40 50 65 65 80 Clip centers C IR RMS Sym. (kA) No. of barrels Installation location 21.7 (551) 18.7 (475) 18 (457) 15 (381) Catalog no. MV155F1CBX5E MV155F1CBX7E MV155F1CBX10E MV155F1DBX10E MV155F1CBX15E MV155F1DBX15E MV155F1CBX20E MV155F1DBX20E MV155F1CBX25E MV155F1DBX25E MV155F1CBX30E MV155F1DBX30E MV155F1DBX40E MV155F1DBX50E MV155F1DBX65E MV155F1DCX65E MV155F1DBX80E 80 21.7 (551) 18 (457) MV155F1DCX80E 100 100 125 125 150 150 175 175 200 200 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) MV155F1DBX100E MV155F1DCX100E MV155F2DBX125E MV155F2DCX125E MV155F2DBX150E MV155F2DCX150E MV155F2DBX175E MV155F2DCX175E MV155F2DBX200E MV155F2DCX200E 2 (51) 18.7 (475) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 15 (381) 1 50 3 (76) Indoor 2 Recommended CLE, HLE and MV155 fuseclips Clip dimensions - in (mm) Fuse diameter in (mm) 2 (51) Description Enclosed fuseclip Enclosed fuseclip Open fuseclip Spring loaded open fuseclip Figure 1 3 (76) A 3.75 (95) 4.14 (105) B 1.98 (50) 2.45 (62) 2 3 C 2.01 (51) 3.01 (76) D 1.19 (30) 1.19 (30) E F 4.54 (115) 1.51 (38) 5.64 (143) 1.51 (38) See dimensions drawing *For single barrel applications only. Not sold in pairs. Figure 1 Figure 2 ØC A D B G F E 4 Eaton.com/bussmannseries Figure 3 Catalog G number 0.4 (10) A3354710* 0.4 (10) A3354730* 1A0065 9078A67G04 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 AMPERE RATING 15A 20A 25A 30A 100 5A 7A 10A 15.5 kV time-current curves — minimum melt for MV155 2 inch diameter fuses TIME IN SECONDS 10 1 7,000 1,000 10 .01 100 .1 CURRENT IN AMPERES MV155_ (2 inch diameter) Eaton.com/bussmannseries 5 Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 AMPERE RATING 15A 20A 25A 30A 100 5A 7A 10A 15.5 kV time-current curves — total clear for MV155_ 2 inch diameter fuses TIME IN SECONDS 10 1 CURRENT IN AMPERES MV155_ (2 inch diameter) 6 Eaton.com/bussmannseries 7,000 1,000 10 .01 100 .1 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV time-current curves — minimum melt for MV155_ 3 inch diameter fuses 200A 125A 150A 175A 15A 20A 25A 30A 40A 50A 65A 80A 100A 10A 1000 100 TIME IN SECONDS 10 1 .1 MV155_ (3 inch diameter) 20000 10000 1000 100 10 .01 CURRENT IN AMPERES Eaton.com/bussmannseries 7 Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 15.5 kV time-current curves — total clear for MV155_ 3 inch diameter fuses 200A 125A 150A 175A 10A 15A 20A 25A 30A 40A 50A 65A 80A 100A 1000 100 TIME IN SECONDS 10 1 MV155_ (3 inch diameter) 8 Eaton.com/bussmannseries 20000 CURRENT IN AMPERES 10000 10 1000 .01 100 .1 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV peak let-through for MV155_ 2 and 3 inch diameter fuses B 100 200A 175A 150A 125A 100A 80A 65A 50A 30&40A 25A 20A 15A 07&10A 05A 1 A .1 .1 1 10 AVAILABLE CURRENT IN KILOAMPERES (RMS Symmetrical) 100 MAXIMUM LET-THROUGH (Peak Kiloamperes) 10 MV155_ (2 and 3 inch diameter) Eaton.com/bussmannseries 9 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection TIME IN SECONDS 15.5 kV time-current curves — minimum melt for 15LHLE_ 3 inch diameter fuses CURRENT IN AMPERES 15LHLE_ (3 inch diameter) 10 Eaton.com/bussmannseries Curve TC66703203 April 2011 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 TIME IN SECONDS 15.5 kV time-current curves — total clear for 15LHLE_ 3 inch diameter fuses CURRENT IN AMPERES 15LHLE_ (3 inch diameter) Curve TC66703303 April 2011 Eaton.com/bussmannseries 11 Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 Peak Instantaneous Let-Through Current in Kilo-amperies 15.5 kV peak let-through for 15LHLE_ 3 inch diameter fuses CURRENT IN AMPERES 15LHLE_ (3 inch diameter) 12 Eaton.com/bussmannseries Curve TC70547404 April 2011 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 CLE and HLE type mountings - in (mm) Hole centers Catalog number A B 15CLE-GDM-C 15CLE-GDM-D 15CLE-PDM-C 15CLE-PDM-D 15CLE-HPDM-C 15CLE-HPDM-D 15HLE-GDM-D 15HLE-PDM-D 21.24 (539.5) 21.15 (537.2) 21.24 (539.5) 21.15 (537.2) 21.24 (539.5) 21.15 (537.2) 16.25 (412.8) 16.25 (412.8) 6 6 6 6 6 6 6 6 (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) 15CLE-PDM-E 15HLE-GDM-E 15HLE-PDM-E 21.15 (537.2) 16.25 (412.8) 16.25 (412.8) 6 (152.4) 6 (152.4) 6 (152.4) 15CLE-GNM-C 15CLE-PNM-C 15CLE-HPNM-C 15CLE-GNM-D 15CLE-PNM-D 15CLE-HPNM-D 15HLE-GNM-D 15HLE-PNM-D 21.25 (539.7) 21.25 (539.7) 21.25 (539.7) 21.15 (539.7) 21.15 (539.7) 21.15 (539.7) 16.25 (412.7) 16.25 (412.7) 6 6 6 6 6 6 6 6 15CLE-PNM-E 15HLE-GNM-E 15HLE-PNM-E 21.15 (539.7) 16.25 (412.7) 16.25 (412.7) 6 (152.4) 6 (152.4) 6 (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) (152.4) Overall length Hole inset Hole centers C D E Disconnect single barrel† 34 (863.6) 0.75 (19.0) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 34 (863.6) 0.75 (19.0) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 34 (863.6) 0.75 (19.0) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 25 (647.7) 0.62 (15.7) 1.75 (44.4) 25 (647.7) 0.62 (15.7) 1.75 (44.4) Disconnect double barrel† 31 (787.4) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) Non-disconnect single barrel 30.5 (774.7) 0.75 (19.0) 1.75 (44.4) 30.5 (774.7) 0.75 (19.0) 1.75 (44.4) 30.5 (774.7) 0.75 (19.0) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 31 (787.4) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) Non-disconnect double barrel 31 (787.4) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) 25 (635) 0.62 (15.7) 1.75 (44.4) CLE and HLE Type disconnect mounting† Contact height F BIL kV 7 (177.8) 7 (177.8) 7 (177.8) 7 (177.8) 8.5 (215.9) 8.5 (215.9) 7 (177.8) 7 (177.8) 12.25 14.22 12.25 14.22 13.75 15.72 14.22 14.22 (311.1) (361.2) (311.1) (361.2) (349.2) (399.3) (361.2) (361.2) 95 95 95 95 110 110 95 95 8.5 (215.9) 7 (177.8) 7 (177.8) 19.28 (489.7) 17.78 (451.6) 17.78 (451.6) 95 95 95 7 (177.8) 7 (177.8) 8.5 (215.9) 7 (177.8) 7 (177.8) 8.5 (215.9) 7 (177.8) 7 (177.8) 9.75 (247.6) 9.75 (247.6) 11.25 (285.7) 11.29 (286.7) 11.29 (286.7) 12.79 (286.7) 11.29 (286.7) 11.29 (286.7) 95 95 110 95 95 110 95 95 8.5 (215.9) 7 (177.8) 7 (177.8) 14.98 (380.5) 14.98 (380.5) 14.98 (380.5) 95 95 95 CLE and HLE Type non-disconnect mounting G G F D F D Overall height G E E C A A C E E D B † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. D B Eaton.com/bussmannseries 13 Technical Data 10353 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Effective November 2019 X.XX (XX.X) A voltage specialty mount fuses E-Rated medium HCL B Catalog symbols: • • 15BHLE-_E 0.44(bolt-on x 0.91 version) Slots 15HCL-_E (clip-lock (11.2 x 23.1) version) Ratings*: Volts — 15.5 kV • Amps — 10 to 300 A Indicator 0.5 (12.7) C • • A 0.44 (11.2) Dia. Hole 0.25 4.31 (109.5) 4.31 (109.5) Interrupting ratings — 50 to 63 kA RMS Sym * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. 1.25 1.25 (31.8) (31.8) B Agency information: • E-Rated fuses meet the performance characteristics of ANSI C37.46 Recommended live parts for clip-lock fuses • 7.94 (201.7) 7.94 (201.7) Catalog number HCL-NL-1 Dimensions - in (mm) 0.5 (12.7) BHLE 2.12 (53.8) 11.62 (295.1) 0.38 (9.7) Indicator B 3.00 C A * Flush with surface in untripped position, trip force is 2 lb (0.9kg) (76.2) Indicator to be located here 3.31 (84.1) B 2.12 (53.8) C A Indicator to be located here 3.31 (84.1) 3.31 (84.1) B 14 2.12 (53.8) Eaton.com/bussmannseries C A (6.4) 11.62 (295.1) 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 BHCL, BHLE and HCL type fuses Dimensions — in (mm) Amps Length A BHCL and BHLE bolt-on 10 15 20 25 30 40 50 65 22.2 (563) 80 100 125 150 175 200 250 300 25.1 (637) 400 HCL clip-lock Diameter B Hole centers C IR RMS Sym. (kA) No. of barrels Installation location 1 20.9 (531) 63 Indoor/outdoor 3 (76) 2 23.7 (602) 50 3 Indoor Indoor Catalog no. 15BHLE-10E 15BHLE-15E 15BHLE-20E 15BHLE-25E 15BHLE-30E 15BHLE-40E† 15BHLE-50E† 15BHLE-65E† 15BHLE-80E† 15BHLE-100E-D† 15BHLE-125E-D† 15BHLE-150E† 15BHLE-175E† 15BHLE-200E† 15BHLE-250E† 15BHCL-300E 15BHCL-400E 10 15HCL-10E 15 20 25 30 40 50 15HCL-15E 15HCL-20E 15HCL-25E 15HCL-30E 15HCL-40E† 15HCL-50E† 65 80 1 22.8 (579) 3 (76) N/A 63 Indoor 15HCL-65E† 15HCL-80E† 100 15HCL-100E† 125 15HCL-125E-D† 150 15HCL-150E† 175 200 2 15HCL-175E† 15HCL-200E† 250 15HCL-250E† 300 15HCL-300E† † UL Listed, Guide JEEG, File E240398. Eaton.com/bussmannseries 15 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection 15.5 kV time-current curves — minimum melt for 15CLE-_E and 15CLE-_-D 15CLE-_ 16 Eaton.com/bussmannseries Curve 70548501 April 16, 1999 Reference # 563532 Curve 70546801 Curve 70547001 April 1999 April 1999 Reference # 705468 Reference # 705470 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV time-current curves — total clear for 15CLE-_E and 15CLE-_-D 15CLE-_ Curve 70548601 April 16, 1999 Reference # 563533 Curve 70546901 April 1999 Reference # 705469 Curve 70547101 April 1999 Reference # 705471 Eaton.com/bussmannseries 17 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection 15.5 kV peak let-through for 15CLE-_E and 15CLE-_-D 15CLE-_ 18 Eaton.com/bussmannseries Curve 70548802 September 1999 Reference # 705488 Curve 70547501 September 1999 Reference # 705475 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV time-current curves — minimum melt for 15HLE-_E and 15BHLE-_E 15HLE-_, 15BHLE-_ Curve 70548507 April 16, 1999 Reference # 563532 Curve 70546601 April 1999 Reference # 705466 Eaton.com/bussmannseries 19 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection 15.5 kV time-current curves — total clear for 15HLE-_E and 15BHLE-_E 15HLE-_, 15BHLE-_ 20 Eaton.com/bussmannseries Curve 70548607 April 16, 1999 Reference # 563533 Curve 70546701 April 1999 Reference # 705467 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV peak let-through for 15HLE-_E and 15BHLE-_E 15HLE-_, 15BHLE-_ Curve 70548805 September 1999 Reference # 705488 Curve 70547401 September 1999 Reference # 705474 Eaton.com/bussmannseries 21 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection 15.5 kV time-current curves — minimum melt for 15HCL-_E 15HCL-_ 22 Eaton.com/bussmannseries Curve 70548503 Curve 66703201 Janaury 2001 January 2001 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection Technical Data 10353 Effective November 2019 15.5 kV time-current curves — total clear for 15HCL-_E 15HCL-_ Curve 70548603 Janaury 2001 Curve 66703301 January 2001 Eaton.com/bussmannseries 23 Technical Data 10353 Effective November 2019 15.5 kV E-Rated medium voltage fuses for feeder circuit, switchgear and transformer protection 15.5 kV peak let-through for 15HCL-_E 15HCL-_ 24 Eaton.com/bussmannseries Curve 70548803 Janaury 2001 Curve 70547402 Janaury 2001 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries ANSI is a registered trademark of the American National Standards Association IEEE is a registered trademark of the Institute of Electrical and Electronics Engineers NEMA is a registered trademark of the National Electrical Mfgrs. Association NFPA is a registered trademark of the National Fire Protection Association UL is a registered trademark of the Underwriters Laboratories, Inc. © 2019 Eaton All Rights Reserved Publication No. 10353 November 2019 25 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
15HCL-40E 价格&库存
很抱歉,暂时无法提供与“15HCL-40E”相匹配的价格&库存,您可以联系我们找货
