DS1030-02-2x10P8BVA-A5.2B2.8C16.5-K8L
    CONNFLY(晨翔)
    插件,P=2mm
    排针 P=2.00mm 20Pin(2x10) 直插
DS1030-02-2x10P8BVA-A5.2B2.8C16.5-K8L 数据手册
2.0*N±0.5 4.00 Notes: Specifications: 1. Contact Resistance: 20mΩ Max. 2. Insulation Resistance: 1000MΩ Min. 3. Dielectric Withstanding Voltage: 500V AC(rms) For 1 Minute. 4. Current Rating:1.5A. 5. Voltage Rating:250V AC rms. 6. Temperature: -40°C~+105°C. Materials: 1. Contact Material: Copper Alloy. 2. Contact Plating: Gold Plating Over Nickel. 3. Insulator Materials: PA-9T,Black,UL94-V0. Product Number Code: N=No.of contacts/2 2.0*(N-1)±0.25 2.00 2.00 Plating level 3A: Level 3A B: Level B C±0.2 C±0.2 2.00 A±0.2 2.00±0.10 A±0.2 □0.50±0.05 2.00 Ø 80 0. B±0.2 2.0*(N-1) B±0.2 2.00 DIM.A B C type 1: Type 1 ...... or A*.*-B*.*-C*.* V1 type Bend type A: V1 type B: V2 type V2 type Mounting type V: Vertical type 2.00 Table A: Dimension Type Recommend PCB layout (Tolerance:±0.05) A Dimension Type A C B C B 1 3.20 9.60 2.20 9 4.60 8.20 3.60 2 4.00 5.70 2.80 10 3.50 13.50 3.00 3 3.00 22.00 3.00 11 3.50 21.40 2.80 4 6.00 10.40 3.00 12 3.70 21.70 3.70 5 3.20 9.60 2.20 13 6.00 12.00 3.00 6 3.20 15.75 2.20 14 3.50 6.00 2.50 7 4.00 9.00 3.00 15 6.50 8.50 3.00 8 3.60 7.50 2.50 16 4.25 19.70 4.30 Housing color B:Black Contact plating 8: Full gold flash Connector type P:Plug No.of contacts 2x1-2x40 2.00mm Pin Header Double Row Straight Type 晨翔电子有限公司 (Series Image-Reference Only) CONNFLY ELECTRONIC CO. LTD
DS1030-02-2x10P8BVA-A5.2B2.8C16.5-K8L 价格&库存
很抱歉,暂时无法提供与“DS1030-02-2x10P8BVA-A5.2B2.8C16.5-K8L”相匹配的价格&库存,您可以联系我们找货
  • 1+1.05841
  • 30+1.02061
  • 100+0.98281
  • 500+0.90720
  • 1000+0.86940
  • 2000+0.84672
