RS3N50C
RS3N50C
    REASUNOS(瑞森半导体)
    SOT-223
    耐压:500V 电流:3A
RS3N50C 数据手册
RS3N50C N Channel MOSFET ID RDS(ON)(Typ ) VDSS 3A 2.5Ω 500V Applications: • Switch Mode Power Supply(SMPS) • Uninterruptible Power Supply (UPS) • Power Factor Correction (PFC) Features: • Fast switching speed • 100% avalanche tested • Improved dv/dt capability Ordering Information Part Number Package Marking Packing Qty. RS3N50C SOT-223 RS3N50C Tape&reel 4000 PCS Absolute Maximun Ratings Tc= 2 5℃ unless otherwise specified Symbol Parameter RS3N50C Units 500 V VDSS Drain-to-Source Voltage ID Continuous Drain Current 3 IDM Pulsed Drain Current (Note*1) 12 PD Power Dissipation 5.56 W VGS Gate- to- Source Voltage ±30 V 28.8 mJ EAS Single Pulse Avalanche Engergy L = 10.0mH, VDD = 50V, RG = 25 Ω A IAS Avalanche Current (Note*1) 2.4 A EAR Repetitive Avalanche Energy (Note*1) 0.12 mJ Maximum Temperature for Soldering TL TPKG Leads at 0.063in(1.6mm)from Case for 10 seconds Package Body for 10 seconds TJ and Operating Junction and Storage TSTG Temperature Range 300 260 ℃ -55 to 150 * Drain Current Limited by Maximum Junction Temperature Caution: Stresses greater than those listed in the“ Absolute Maximum Ratings” Table may cause permanent www.reasunos.com 1 /8 damage to the device. Copyright Reasunos RS3N50C N Channel MOSFET Thermal Resistance Symbol Parameter RS3N50C Units Test Conditions Drain lead soldered to water cooled RθJC Junction-to-Case 22.5 heatsink, PD adjusted for a peak junction temperature of + 1 5 0 ℃ ℃/ W RθJA Junction-toAmbient 62.5 1 cubic foot chamber,free air. OFF Characteristics TJ= 25℃ unless otherwise specified Symbol BVDSS IDSS IGSS Parameter Min. Typ. Max. Units Test Conditions 500 -- -- V VGS=0V,ID=250µA Drain- to- Source Leakage Current -- -- 1 µA Gate- to- Source Forward Leakage -- -- 100 Drain- to- source Breakdown Voltage Gate- to- Source Reverse Leakage -- VDS=500V,VGS=0 V VGS=30V ,VDS=0V nA VGS=-30V ,VDS=0 -- -100 Min. Typ. Max. Units Test Conditions -- 2.5 3 Ω VGS=10V,ID=1.5A 3 -- 4 V V ON Characteristics TJ=25℃ unless otherwise specified Symbol RDS(on) VGS(TH) Parameter Static Drain- to- Source OnResistance(Note*2) Gate Threshold Voltage VGS=VDS,ID=250µ A Resistive Switching Characteristics Essentially independent of operating temperature Symbol Parameter Min. Typ. Max. td(ON) Turn- on Delay Time -- 33 -- trise Rise Time -- 5.5 -- td(OFF) Turn- OFF Delay Time -- 57 -- tfall Fall Time -- 34 -- www.reasunos.com 2 /8 Units Test Conditions VDS=250V nS ID=3A RG=25Ω Copyright Reasunos RS3N50C N Channel MOSFET Dynamic Characteristics Essentially independent of operating temperature Symbol Parameter Min. Typ. Max. Units Ciss Input Capacitance -- 267 -- Coss Output Capacitance -- 35 -- Crss Reverse Transfer Capacitance -- 7 -- Qg Total Gate Charge -- 9 -- Qgs Gate- to- Source Charge -- 1.3 -- Qgd Gate-to-Drain(" Miller") Charge -- 5.1 -- Min. Typ. Max. Units Test Conditions VGS=0V pF VDS=25V f=1.0MHz VDS=400V nC ID=3A VGS=10V Source- Drain Diode Characteristics Symbol Parameter Test Conditions IS Continuous Source Current -- -- 2 A ISM Maximum Pulsed Current -- -- 8 A VSD Diode Forward Voltage -- -- 1.4 V IS=1.5A,VGS=0V trr Reverse Recovery Time -- 325 -- nS VGS=0V Qrr Reverse Recovery Charge -- 0.78 -- µC Integral pn- diode in MOSFET IS=3A,di/dt=100A/ µs Notes: * 1. Repetitive rating, pulse width limited by maximum junction temperature. * 2. Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 1% www.reasunos.com 3 /8 Copyright Reasunos RS3N50C N Channel MOSFET Typical Feature Curve www.reasunos.com 4 /8 Copyright Reasunos RS3N50C N Channel MOSFET www.reasunos.com 5 /8 Copyright Reasunos RS3N50C N Channel MOSFET Test Circuits and Waveforms www.reasunos.com 6 /8 Copyright Reasunos RS3N50C N Channel MOSFET Package outline drawing www.reasunos.com 7 /8 Copyright Reasunos RS3N50C N Channel MOSFET Disclaimers: Reasunos Semiconductor Technology Co.Ltd (Reasunos) reserves the right to make changes without notice in order to improve reliability,function or design and to discontinue any product or service without notice .Customers should obtain the latest relevant information before orders and should verify that such information in current and complete.All products are sold subject to Reasunos's terms and conditions supplied at the time of orderacknowledgement. Reasunos Semiconductor Technology Co.Ltd warrants performance of its hardware products to the speciffications at the time of sale.Testing,reliability and quality control are used to the extene Reasunos deems necessary to support this warrantee. Except where agreed upon by contr- actual agreement,testing of all parameters of each product is not necessarily performed. Reasunos Semiconductor Technology Co.Ltd does not assume any liability arising from the use of any product or circuit designs described herein.Customers are responsible for their products and applications using Reasunos's components.To minimize risk,customers must provide adequate design and operating safeguards. Reasunos Semiconductor Technology Co.Ltd does not warrant or convey any license eith- er expressed or implied under its patent rights,nor the rights of others.Reproduction of inform- ation in Reasunos's data sheeets or data books is permissible only if reproduction is without modification oralteration.Reproduction of this information with any alteration is an unfair and deceptive business practice. Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such altered documentation. Resale of Reasunos's products with statements different from or beyond the parameters stated by Reasunos Semiconductor Technology Co.Ltd for that product or service voids all exp- ress or implied warrantees for the associated Reasunos's product or service and is unfair and deceptive business practice. Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such statements. Life Support Policy: Reasunos Semiconductor Technology Co.Ltd's Products are not authorized for use as cri- tical components in life support devices or systems without the expressed written approval of Reasunos Semiconductor Technology Co.Ltd. As used herein: 1. Life support devices or systems are devices or systems which: a.are intended for surgical implant into the human body, b.support or sustain life, c.whose failuer to when properly used in accordance with instructions for used provided in the laeling,can be reasonably expected to result in significant injury to the user. 2.A critical component is any component of a life support device or system whose failure to system whose failure to perform can be reasonably expected to cause the failure of the life support device or system,or to affect its safety or effectiveness. www.reasunos.com 8 /8 Copyright Reasunos
RS3N50C 价格&库存
很抱歉,暂时无法提供与“RS3N50C”相匹配的价格&库存,您可以联系我们找货
RS3N50C
  • 5+0.75227
  • 50+0.59467
  • 150+0.51588
  • 500+0.45678
  • 2500+0.40949
  • 4000+0.38578
库存:160
