乐
瓦
上
海
LW Silicon P-Channel Power MOSFET
V
ID
-4.0
A
PD
3.0
W
RDS(ON) TYPE
90
mΩ
公
司
provide excellent RDS(ON) with low gate charge. It can be used in
-60
a wide variety of applications. The package form is SOT-223,
Marking and Pin Assignment
限
which accords with the ROHS standard and Halogen Free
科
技
Features:
上
海
有
standard.
电
The LWS60110A23 uses SGT technology and design to
VDSS
乐
瓦
微
General Description:
LWS60110A23
l Fast Switching
l Low Gate Charge and RDS(ON)
子
l Low Reverse transfer capacitances
Inner Equivalent Principium Chart
电
Applications:
瓦
公
司
微
l DC-DC Converter
l Portable Equipment
子
科
技
上
有
限
海
乐
l Power Management
Package Marking and Ordering Information:
2500 Pcs
Parameter
Drain-to-Source Voltage
Value
Units
-60
V
TC=25℃
-4.0
A
Continuous Drain Current
TC=100℃
-2.5
A
海
上
ID
Reel
Pulsed Drain Current
-16
A
VGS
Gate-to-Source Voltage
±20
V
PD
Power Dissipation
Operating Junction and Storage Temperature Range
3.0
W
Maximum Temperature for Soldering
260
RθJA
Parameter
Value
瓦
Symbol
Thermal Resistance, Junction-to-Ambient
41.6
Units
℃/W
上
子
海
科
乐
技
有
限
Thermal Characteristics:
微
电
公
TL
150, -55 to 150
子
司
TJ, TSTG
科
IDMa1
公
Symbol
VDSS
SOT-223
乐
瓦
Absolute Maximum Ratings:
Qty.
限
LWS60110A23
Packing
有
S60110
Package
技
Part Number
微
电
Marking
上海乐瓦微电子科技有限公司
司
http://lewa-micro.com
Page 1/10
乐
瓦
上
海
LWS60110A23
Electrical Characteristic (TA = 25 °C, unless otherwise specified):
Static Characteristics
VDSS
Drain to Source Breakdown Voltage
IDSS
IGSS(F)
Value
Units
Max.
VGS=0V, ID=-250µA
-60
Drain to Source Leakage Current
VDS=-60V, VGS=0V
1.0
μA
Gate to Source Forward Leakage
VGS=-20V, VDS=0V
-100
nA
IGSS(R) Gate to Source Reverse Leakage
VGS=+20V, VDS=0V
100
nA
VGS(TH) Gate Threshold Voltage
RDS(ON)1 Drain-to-Source On-Resistance
VDS=VGS, ID=-250µA
-1.2
-1.6
-2.0
V
VGS=-10V, ID=-3.0A
90
110
mΩ
RDS(ON)2 Drain-to-Source On-Resistance
VGS=-4.5V, ID=-2.0A
110
150
mΩ
上
海
有
V
电
子
乐
瓦
微
Typ.
限
Min.
科
技
Test Conditions
电
Parameter
公
司
Symbol
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Resistive Switching Characteristics
Rise Time
Turn-Off Delay Time
Fall Time
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
上
海
tf
315
59
2.98
Test Conditions
Units
pF
Value
Min.
Typ.
Max.
ID =-2.0A
VDS =-30V
VGS =-10V
RG =5.0Ω
6.8
8.0
16
4.0
VGS =-10V
VDS = -30V
ID =-5.0A
6.01
1.27
0.72
Units
ns
nC
有
td(OFF)
Turn-on Delay Time
Max.
微
电
tr
Parameter
乐
瓦
td(ON)
VGS = 0V
VDS =-30V
f = 1.0MHz
Typ.
Test Conditions
Value
Min.
Typ.
Max.
TC =25 °C
-4.0
VSD
Diode Forward Voltage
IS=-2.0A, VGS=0V
-1.2
V
微
电
A
上
子
海
科
乐
技
瓦
有
限
a1:Repetitive rating; pulse width limited by maximum junction temperature
子
Diode Forward Current
公
IS
Units
科
司
Parameter
技
Source-Drain Diode Characteristics
Symbol
公
Input Capacitance
Min.
限
Test Conditions
Ciss
Symbol
Value
公
司
Parameter
子
科
技
上
海
乐
瓦
Symbol
有
限
微
Dynamic Characteristics
上海乐瓦微电子科技有限公司
司
Page 2/10
乐
瓦
上
海
General
Description:
Characteristics
Curve:
有
限
RDS(on)=f(ID), Tj=25 °C; parameter: VGS
微
电
ID=f(VDS), Tj=25 °C; parameter: VGS
子
科
技
上
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
电
Figure 2: Typ. drain-source on resistance
公
司
Figure 1: Typ. output characteristics
LWS60110A23
Figure 4: drain-source on resistance
乐
RDS(on)=f(Tj), ID=-3.0A, VGS=-10V;
海
ID=f(VGS), |VDS|>2|ID|RDS(on)max;
上
子
科
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 3: Typ. transfer characteristics
上海乐瓦微电子科技有限公司
司
Page 3/10
乐
瓦
上
海
Figure 6: Drain-source breakdown voltage
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
Figure 5: Typ. gate threshold voltage
LWS60110A23
VBR(DSS)=f(Tj); ID=-250μA;
微
电
子
科
技
上
VGS=f(Tj),I VGS=VDS,ID=-250μA;
Figure 8: Typ. Capacitances
瓦
乐
C=f(VDS); VGS=0V; f=1.0 MHz;
海
VGS=f(Qg), ID=-5.0A, Tj=25 °C; parameter: VDS
上
子
科
技
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 7: Typ. gate charge
上海乐瓦微电子科技有限公司
司
Page 4/10
乐
瓦
上
海
4
3.5
有
2.5
子
1.5
电
1
1
瓦
微
0.5
0.5
海
乐
2
25
50
75
100
125
150
50
100
125
150
ID=f(TA);
微
电
子
科
技
上
Ptot=f(TA);
75
TA[℃]
有
限
TA[℃]
公
司
1.5
-ID [A]
科
技
2
3
上
海
2.5
乐
瓦
微
4.5
限
3
PTOT [W]
Figure 10:Drain current
公
司
3.5
电
Figure 9: Power dissipation
LWS60110A23
上
100uS
有
1.00
10uS
1mS
技
-ID[A]
海
10.00
限
乐
瓦
100.00
Figure 12: Typ. forward characteristics
公
Figure 11: Safe operating area
科
10mS
子
司
0.10
电
1
100
乐
-VDS[V]
ID=f(VDS); TC=25 °C; D=0; parameter: tp
IF=f(VSD);
上
子
海
科
技
10
瓦
0.1
微
0.01
有
限
公
DC
上海乐瓦微电子科技有限公司
司
Page 5/10
乐
瓦
上
海
LWS60110A23
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
Figure 13: Max. Transient Thermal Impedance
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
ZthJA=f(tp); parameter: D
上海乐瓦微电子科技有限公司
司
Page 6/10
乐
瓦
上
海
公
司
Figure 14: Gate Charge Test Circuit & Waveform
微
电
子
科
技
上
有
限
海
乐
瓦
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
General
Description:
Test Circuit
& Waveform:
LWS60110A23
微
瓦
Figure 16: Unclamped Inductive Switching Test Circuit & Waveforms
上
子
海
科
乐
技
有
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 15: Resistive Switching Test Circuit & Waveforms
上海乐瓦微电子科技有限公司
司
Page 7/10
乐
瓦
上
海
COMMON DIMENSION (MM)
PKG
SOT-223
MIN
MON
MAX
A
1.520
1.580
1.720
A1
0.010
0.060
0.150
A2
1.470
1.520
1.570
b
0.660
0.710
0.800
c
0.250
0.280
0.350
D
6.500
6.600
6.750
D1
2.900
3.000
3.100
E
6.700
7.000
7.300
E1
3.300
3.500
e
2.300 REF
瓦
0.750 REF
0°
4°
限
有
技
10°
上
子
海
科
科
子
电
微
3.700
L
Q
公
Symbol
乐
技
有
限
公
司
上
海
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
General
Package Description:
Outline:
LWS60110A23
上海乐瓦微电子科技有限公司
司
Page 8/10
乐
瓦
上
海
General History:
Description:
Revision
Descriptions
Rev 1.0
Feb.2024
Initial Version
电
Date
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
Revison
LWS60110A23
上海乐瓦微电子科技有限公司
司
Page 9/10
乐
瓦
上
海
Disclaimer:
LWS60110A23
The information in this document is believed to be accurate and reliable. However, no responsibility is assumed by
电
公
司
LW-Micro for its use. All operating parameters must be designed, validated and tested to ensure they meet the
乐
瓦
微
requirements of your application. LW-Micro reserves the right to make any specification and/or circuitry changes
without prior notification. Before starting a brand-new project, please contact LW-Micro Sales to get the most
科
技
上
海
有
限
recent relevant information.
Mailing Address: Room 301, Building 2, No.1690 CaiLun Road, China (Shanghai) Pilot Free Trade Zone
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
Shanghai Lewa Micro-electronics Technology Co., Ltd
上海乐瓦微电子科技有限公司
司
Page 10/10
很抱歉,暂时无法提供与“LWS60110A23”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61096
- 50+0.48298
- 150+0.41894
- 500+0.37098
