乐
瓦
上
海
LW Silicon P-Channel Power MOSFET
V
ID
-4.0
A
PD
5.0
W
RDS(ON) TYPE
115
mΩ
公
司
design to provide excellent RDS(ON) with low gate charge. It can
-100
be used in a wide variety of applications. The package form is
Marking and Pin Assignment
限
SOT-223, which accords with the ROHS standard and Halogen
科
技
Features:
上
海
有
Free standard.
电
The LWS1H150A23 uses advanced SGT technology and
VDSS
乐
瓦
微
General Description:
LWS1H150A23
l Fast Switching
l Low Gate Charge and RDS(ON)
子
l Low Reverse transfer capacitances
Inner Equivalent Principium Chart
电
Applications:
瓦
公
司
微
l DC-DC Converter
l Portable Equipment
子
科
技
上
有
限
海
乐
l Power Management
Package Marking and Ordering Information:
Reel
2500 Pcs
Parameter
Drain-to-Source Voltage
Units
-100
V
TC=25℃
-4.0
A
Continuous Drain Current
TC=100℃
-2.5
A
海
上
ID
Value
Pulsed Drain Current
-16
A
VGS
Gate-to-Source Voltage
±20
V
Single pulse avalanche energy
72
mJ
Power Dissipation
Operating Junction and Storage Temperature Range
5.0
TL
Maximum Temperature for Soldering
260
微
瓦
Units
25
乐
℃/W
70
℃/W
Value
RθJC
Thermal Resistance, Junction-to-Case
RθJA
Thermal Resistance, Junction-to-Ambient
上
海
Parameter
子
科
技
有
Thermal Characteristics:
Symbol
150, -55 to 150
限
公
TJ, TSTG
W
子
司
EAS
PD
电
a2
科
IDMa1
公
Symbol
VDSS
SOT-223
乐
瓦
Absolute Maximum Ratings:
Qty.
限
LWS1H150A23
Packing
有
S1H150/D.C.
Package
技
Part Number
微
电
Marking
上海乐瓦微电子科技有限公司
司
http://lewa-micro.com
Page 1/10
乐
瓦
上
海
LWS1H150A23
Electrical Characteristic (TA = 25 °C, unless otherwise specified):
Static Characteristics
VDSS
Drain to Source Breakdown Voltage
IDSS
IGSS(F)
Value
Units
Max.
VGS=0V, ID=-250µA
-100
Drain to Source Leakage Current
VDS=-100V, VGS=0V
1.0
μA
Gate to Source Forward Leakage
VGS=-20V, VDS=0V
100
nA
IGSS(R) Gate to Source Reverse Leakage
VGS=+20V, VDS=0V
-100
nA
VGS(TH) Gate Threshold Voltage
RDS(ON)1 Drain-to-Source On-Resistance
VDS=VGS, ID=-250µA
-1.2
-1.7
-2.2
V
VGS=-10V, ID=-5.0A
115
150
mΩ
RDS(ON)2 Drain-to-Source On-Resistance
VGS=-4.5V, ID=-5.0A
130
165
mΩ
上
海
有
V
电
子
乐
瓦
微
Typ.
限
Min.
科
技
Test Conditions
电
Parameter
公
司
Symbol
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
677
53.6
6.6
18
Turn-on Delay Time
Rise Time
Test Conditions
Turn-Off Delay Time
Fall Time
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
上
海
tf
Units
pF
Ω
Value
Min.
Typ.
Max.
ID =-5.0A
VDS =-50V
VGS =-10V
RG =5.0Ω
5.9
3.7
39.5
24.6
VGS =-10V
VDS = -50V
ID =-5.0A
12.2
2.3
1.9
Units
ns
nC
技
td(OFF)
微
电
tr
Parameter
乐
瓦
td(ON)
Max.
VGS = 0V, VDS Open
Resistive Switching Characteristics
Symbol
Typ.
公
Coss
VGS = 0V
VDS =-50V
f = 1.0MHz
Min.
Units
Typ.
Max.
-4.0
A
-1.2
V
TC =25 °C
VSD
Diode Forward Voltage
IS=-5.0A, VGS=0V
trr
Reverse Recovery time
66
ns
Qrr
Reverse Recovery Charge
IS=-5.0A, VDD=-50V
dI/dt=100A/μs
nC
微
电
Diode Forward Current
瓦
子
Min.
公
司
Value
IS
214
乐
限
a1:Repetitive rating; pulse width limited by maximum junction temperature
a2:VDD=50V,L=1mH, Rg=25Ω, Starting TJ=25 ℃
海
有
技
Test Conditions
上
子
科
Parameter
科
Source-Drain Diode Characteristics
Symbol
限
Input Capacitance
Test Conditions
有
Ciss
Value
公
司
Parameter
子
科
技
上
海
乐
瓦
Symbol
有
限
微
Dynamic Characteristics
上海乐瓦微电子科技有限公司
司
Page 2/10
乐
瓦
上
海
General
Description:
Characteristics
Curve:
有
限
RDS(on)=f(ID), Tj=25 °C; parameter: VGS
微
电
ID=f(VDS), Tj=25 °C; parameter: VGS
子
科
技
上
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
电
Figure 2: Typ. drain-source on resistance
公
司
Figure 1: Typ. output characteristics
LWS1H150A23
Figure 4: drain-source on resistance
乐
RDS(on)=f(Tj), ID=-5.0A, VGS=-10V;
海
ID=f(VGS), |VDS|>2|ID|RDS(on)max;
上
子
科
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 3: Typ. transfer characteristics
上海乐瓦微电子科技有限公司
司
Page 3/10
乐
瓦
上
海
Figure 6: Drain-source breakdown voltage
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
Figure 5: Typ. gate threshold voltage
LWS1H150A23
VBR(DSS)=f(Tj); ID=-250μA;
微
电
子
科
技
上
VGS=f(Tj),I VGS=VDS,ID=-250μA;
Figure 8: Typ. Capacitances
瓦
乐
C=f(VDS); VGS=0V; f=1.0 MHz;
海
VGS=f(Qg), ID=-5.0A, Tj=25 °C; parameter: VDS
上
子
科
技
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 7: Typ. gate charge
上海乐瓦微电子科技有限公司
司
Page 4/10
乐
瓦
上
海
4
3.5
子
3
2.5
2
1.5
电
2
上
海
-ID [A]
有
3
科
技
4
乐
瓦
微
4.5
限
5
PTOT [W]
Figure 10:Drain current
公
司
6
电
Figure 9: Power dissipation
LWS1H150A23
1
50
75
100
125
150
25
50
100
125
150
ID=f(TC);
微
电
子
科
技
上
Ptot=f(TC);
75
TC[℃]
有
限
TC[℃]
公
司
0.5
海
乐
瓦
微
1
Figure 11: Safe operating area
1
限
10uS
100uS
有
上
-ID[A]
海
10
公
乐
瓦
100
Figure 12: Typ. forward characteristics
1mS
技
10mS
科
DC
电
1
100
1000
乐
-VDS[V]
ID=f(VDS); TC=25 °C; D=0; parameter: tp
IF=f(VSD);
上
子
海
科
技
10
瓦
0.1
微
0.01
有
限
公
子
司
0.1
上海乐瓦微电子科技有限公司
司
Page 5/10
乐
瓦
上
海
LWS1H150A23
D=1
科
技
ZthJC (˚C/W)
0.1
上
海
0.2
有
限
0.5
乐
瓦
微
公
司
100
10
电
Figure 13: Max. Transient Thermal Impedance
0.05
1
0.02
电
0.1
子
0.01
Duty factor D=t1/t2
TJM-TC=PDM*ZthJC(t)
1E-05
0.0001
公
司
0.01
1E-06
0.001
0.01
tp (sec)
0.1
1
有
限
海
乐
瓦
微
Single pulse
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
ZthJC=f(tp); parameter: D
上海乐瓦微电子科技有限公司
司
Page 6/10
乐
瓦
上
海
公
司
Figure 14: Gate Charge Test Circuit & Waveform
微
电
子
科
技
上
有
限
海
乐
瓦
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
General
Description:
Test Circuit
& Waveform:
LWS1H150A23
微
瓦
Figure 16: Unclamped Inductive Switching Test Circuit & Waveforms
上
子
海
科
乐
技
有
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
Figure 15: Resistive Switching Test Circuit & Waveforms
上海乐瓦微电子科技有限公司
司
Page 7/10
乐
瓦
上
海
COMMON DIMENSION (MM)
PKG
SOT-223
MIN
MON
MAX
A
1.520
1.580
1.720
A1
0.010
0.060
0.150
A2
1.470
1.520
1.570
b
0.660
0.710
0.800
c
0.250
0.280
0.350
D
6.500
6.600
6.750
D1
2.900
3.000
3.100
E
6.700
7.000
7.300
E1
3.300
3.500
e
2.300 REF
瓦
0.750 REF
0°
4°
限
有
技
10°
上
子
海
科
科
子
电
微
3.700
L
Q
公
Symbol
乐
技
有
限
公
司
上
海
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
电
General
Package Description:
Outline:
LWS1H150A23
上海乐瓦微电子科技有限公司
司
Page 8/10
乐
瓦
上
海
General History:
Description:
Revision
Descriptions
Rev 1.0
Feb.2024
Initial Version
电
Date
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
科
技
上
海
有
限
乐
瓦
微
公
司
Revison
LWS1H150A23
上海乐瓦微电子科技有限公司
司
Page 9/10
乐
瓦
上
海
Disclaimer:
LWS1H150A23
The information in this document is believed to be accurate and reliable. However, no responsibility is assumed by
电
公
司
LW-Micro for its use. All operating parameters must be designed, validated and tested to ensure they meet the
乐
瓦
微
requirements of your application. LW-Micro reserves the right to make any specification and/or circuitry changes
without prior notification. Before starting a brand-new project, please contact LW-Micro Sales to get the most
科
技
上
海
有
限
recent relevant information.
Mailing Address: Room 301, Building 2, No.1690 CaiLun Road, China (Shanghai) Pilot Free Trade Zone
上
子
海
科
乐
技
瓦
有
微
限
电
公
子
司
科
技
有
上
限
海
公
乐
瓦
微
电
子
科
技
上
有
限
海
乐
瓦
公
司
微
电
子
Shanghai Lewa Micro-electronics Technology Co., Ltd
上海乐瓦微电子科技有限公司
司
Page 10/10
很抱歉,暂时无法提供与“LWS1H150A23”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.77350
- 50+0.67544
- 150+0.63342
- 500+0.58104
