1N65G
1N65G
    HXY(华轩阳)
    SOT-223
    1个N沟道 耐压:600V 电流:1A
1N65G 数据手册
HXY 1N65G ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Description The 1N65G uses advanced trench technology to provide excellent RDS(ON), low gate charge and D operation with gate voltages as low as 4.5V. This D G device is suitable for use as a Battery protection or in other Switching application. S SOT-223 General Features VDS = 650V ID =1A RDS(ON) < 12Ω @ VGS=10V PIN2 D ! Application " Battery protection PIN1 G ! Load switch ! " " " ! PIN3 S Uninterruptible power supply N-Channel MOSFET Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) 1N65G SOT-223 1N65 XXXX 4000 Absolute Maximum Ratings (TC=25℃ unless otherwise specified) Symbol Parameter Rating Units VDS Drain-Source Voltage 650 V VGS Gate-Source Voltage ±20 V ID@TA=25℃ Continuous Drain Current, VGS @ 10V1 1 A IDM Pulsed Drain Current2 4.8 A PD@TA=25℃ Total Power Dissipation4 1 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ RθJA Thermal Resistance Junction-ambient (Steady State)1 62.5 ℃/W Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY 1N65G ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Electrical Characteristics (TJ=25℃ unless otherwise specified) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage △VGS(th) VGS(th) Temperature Coefficient Conditions Min. Typ. Max. Unit 650 --- --- V Reference to 25℃ , ID=1mA --- 0.057 --- V/℃ VGS=10V , ID=0.6A --- 9.5 12 Ω 2 --- 4 V ----- -5.68 --- --1 mV/℃ VDS=650V , VGS=0V , TJ=25℃ VDS=650V , VGS=0V , TJ=55℃ --- --- 5 VGS=±30V , V DS=0V --- --- ±100 uA nA VGS=0V , ID=250uA VGS=VDS , ID =250uA IDSS IGSS Drain-Source Leakage Current Gate-Source Leakage Current gfs Forward Transconductance VDS=5V , ID=0.5A --- 35 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.7 --- Ω Qg Total Gate Charge (4.5V) --- 4 --- Qgs Gate-Source Charge --- 0.9 --- Qgd Gate-Drain Charge --- 2.5 --- Td(on) Turn-On Delay Time --- 4 --- --- 24 --- --- 6 --- --- 24 --- --- 119 --- --- 19 --- --- 2 --- --- --- 1 A --- --- 4.8 A --- --- 1.4 V --- 160 --- nS --- 0.3 --- nC Tr Td(off) Tf Rise Time Turn-Off Delay Time Fall Time Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance IS ISM VSD Continuous Source Current1,5 Pulsed Source Current2,5 Diode Forward Voltage2 trr Reverse Recovery Time Qrr Reverse Recovery Charge VDS=520V , VGS=10V , ID=1A VDD=325V , VGS=10V , RG=50 Ω , ID=1A VDS=15V , VGS=0V , f=1MHz VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ IF=15A , TJ=25℃ dI/dt=100A/µs , nC ns pF Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=28A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY 1N65G ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Typical Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY 1N65G ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG SOT-223 Package Outline Dimensions Symbol A A1 A2 b b1 c D E E1 e L θ Dimensions In Millimeters Min. Max. —— 1.800 0.020 0.100 1.500 1.700 0.660 0.840 2.900 3.100 0.230 0.350 6.300 6.700 6.700 7.300 3.300 3.700 2.300(BSC) 0.750 —— 0° 10° Shenzhen HuaXuanYang Electronics CO.,LTD Dimensions In Inches Min. Max. —— 0.071 0.001 0.004 0.059 0.067 0.026 0.033 0.114 0.122 0.009 0.014 0.248 0.264 0.264 0.287 0.130 0.146 0.091(BSC) 0.030 —— 0° 10° www.hxymos.com HXY 1N65G ELECTRONICS CO.,LTD N-Channel Enhancement Mode MOSFET HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
1N65G 价格&库存
很抱歉,暂时无法提供与“1N65G”相匹配的价格&库存,您可以联系我们找货
