IRLL2703TRPBF
www.VBsemi.com
N-Channel 30 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
• TrenchFET® Power MOSFET
30
RDS(on) () at VGS = 10 V
0.019
RDS(on) () at VGS = 4.5 V
0.021
ID (A)
• 100 % Rg and UIS Tested
7
Configuration
Single
D
SOT-223
G
D
G
D
S
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
VDS
LIMIT
Drain-Source Voltage
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
TC = 25 °C
TC = 125 °C
Continuous Source Current (Diode Conduction)
Pulsed Drain Currenta
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipationa
L = 0.1 mH
TC = 25 °C
TC = 125 °C
Operating Junction and Storage Temperature Range
ID
30
V
7
4.5
IS
5
IDM
31
IAS
10
EAS
5
PD
UNIT
4
1.3
A
mJ
W
TJ, Tstg
- 55 to + 175
°C
SYMBOL
LIMIT
UNIT
RthJA
110
RthJF
38
THERMAL RESISTANCE RATINGS
PARAMETER
Junction-to-Ambient
Junction-to-Foot (Drain)
PCB
Mountb
°C/W
Notes
a. Pulse test; pulse width 300 μs, duty cycle 2 %.
b. When mounted on 1" square PCB (FR-4 material).
c. Parametric verification ongoing.
服务热线:400-655-8788
1
IRLL2703TRPBF
www.VBsemi.com
SPECIFICATIONS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
Gate-Source Threshold Voltage
30
0.5
1.5
IDSS
Zero Gate Voltage Drain Current
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward
VGS = 0 V, ID = 250 μA
VDS = VGS, ID = 250 μA
IGSS
Gate-Source Leakage
Transconductanceb
VDS
VGS(th)
RDS(on)
gfs
VDS = 0 V, VGS = ± 20 V
± 100
VGS = 0 V
VDS = 30 V
1
VGS = 0 V
VDS = 30 V, TJ = 125 °C
50
VGS = 0 V
VDS = 30 V, TJ = 175 °C
150
VGS = 10 V
VDS5 V
10
VGS = 10 V
ID = 6 A
0.019
V
nA
μA
A
VGS = 4.5 V
ID = 4.9 A
0.021
VGS = 10 V
ID = 6 A, TJ = 125 °C
0.054
VGS = 10 V
ID = 6 A, TJ = 175 °C
0.064
21
S
295
pF
VDS = 15 V, ID = 5 A
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
67
Reverse Transfer Capacitance
Crss
25
Total Gate Chargec
Qg
6
Gate-Source
Chargec
Qgs
Gate-Drain Chargec
Qgd
Gate Resistance
Rg
Turn-On Delay
Timec
Rise Timec
Turn-Off Delay Timec
Fall Timec
Source-Drain Diode Ratings and
VGS = 0 V
VDS = 15 V, f = 1 MHz
VGS = 10 V
VDS = 15 V, ID = 6 A
1.2
1
f = 1 MHz
3.0
6.65
11
6
9
VDD = 15 V, RL = 2.5
ID 6 A, VGEN = 10 V, Rg = 1
12
18
13
12
td(on)
tr
td(off)
tf
nC
ns
Characteristicsb
Pulsed Currenta
ISM
Forward Voltage
VSD
IF = 3 A, VGS = 0 V
31
A
0.8
1.1
V
Notes
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRLL2703TRPBF
www.VBsemi.com
TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted)
40
40
VGS = 10 V thru 4 V
32
ID - Drain Current (A)
32
24
VGS = 3 V
16
24
16
TC = 25 °C
8
8
TC = 125 °C
VGS = 2 V
TC = - 55 °C
4
6
8
2
4
6
8
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
30
10
0.10
TC = - 55 °C
0.08
TC = 25 °C
RDS(on) - On-Resistance (Ω)
gfs - Transconductance (S)
24
18
TC = 125 °C
12
0.06
VGS = 4.5 V
0.04
0.02
6
VGS = 10 V
0.00
1.2
2.4
3.6
4.8
8
16
24
32
40
On-Resistance vs. Drain Current
Transconductance
500
10
400
8
C - Capacitance (pF)
ID = 6 A
Ciss
300
200
100
Coss
6
VDS = 15 V
4
2
Crss
12
18
24
30
4
6
Qg - Total Gate Charge (nC)
Capacitance
Gate Charge
8
10
服务热线:400-655-8788
3
IRLL2703TRPBF
www.VBsemi.com
100
2.0
1.7
1.4
VGS = 4.5 V
1.1
TJ = 150 °C
1
0.1
TJ = 25 °C
0.01
0.8
0.5
- 50 - 25
0.001
50
75
100
125
150
0.0
175
0.2
0.4
0.6
0.8
1.0
TJ - Junction Temperature (°C)
VSD - Source-to-Drain Voltage (V)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
0.25
0.5
0.20
0.2
VGS(th) Variance (V)
10
VGS = 10 V
IS - Source Current (A)
RDS(on) - On-Resistance (Normalized)
ID = 6 A
0.15
0.10
- 0.1
ID = 5 mA
- 0.4
ID = 250 μA
TJ = 150 °C
0.05
1.2
- 0.7
TJ = 25 °C
- 1.0
- 50 - 25
0.00
4
6
8
10
50
75
100
TJ - Temperature (°C)
On-Resistance vs. Gate-to-Source Voltage
Threshold Voltage
125
150
175
40
ID = 1 mA
38
36
34
32
30
- 50 - 25
50
75
100
125
150
175
Drain Source Breakdown vs. Junction Temperature
服务热线:400-655-8788
4
IRLL2703TRPBF
www.VBsemi.com
THERMAL RATINGS (TA = 25 °C, unless otherwise noted)
100
IDM Limited
10
100 μs
1
1 ms
Limited by RDS(on)*
10 ms
0.1
100 ms
1s, 10s, DC
TC = 25 °C
Single Pulse
BVDSS Limited
0.01
0.01
0.1
1
10
* VGS > minimum VGS at which RDS(on) is specified
100
Safe Operating Area
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
Single Pulse
t1
t2
2. Per Unit Base = R thJA = 110 °C/W
3. T JM - TA = PDMZthJA(t)
4. Surface Mounted
0.01
0.0001
0.001
0.01
0.1
1
10
100
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
服务热线:400-655-8788
5
IRLL2703TRPBF
www.VBsemi.com
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
Single Pulse
0.05
0.02
0.01
0.0001
0.001
0.01
0.1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
Note
• The characteristics shown in the two graphs
- Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C)
- Normalized Transient Thermal Impedance Junction-to-Foot (25 °C)
are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single
pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part
mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities
can widely vary depending on actual application parameters and operating conditions.
服务热线:400-655-8788
6
IRLL2703TRPBF
www.VBsemi.com
SOT-223 (HIGH VOLTAGE)
B
D
A
3
0.08 (0.003)
B1
C
0.10 (0.004) M C B M
A
4
3
H
E
0.20 (0.008) M C A M
L1
1
2
3
4xL
3xB
e
θ
e1
4xC
MILLIMETERS
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
1.55
1.80
0.061
0.071
0.033
B
0.65
0.85
0.026
B1
2.95
3.15
0.116
0.124
C
0.25
0.35
0.010
0.014
D
6.30
6.70
0.248
0.264
E
3.30
3.70
0.130
e
2.30 BSC
e1
4.60 BSC
0.181 BSC
H
6.71
7.29
0.264
L
0.91
0.036
L1
θ
0.061 BSC
0.146
0.0905 BSC
0.287
0.0024 BSC
10'
10'
ECN: S-82109-Rev. A, 15-Sep-08
DWG: 5969
Notes
1. Dimensioning and tolerancing per ASME Y14.5M-1994.
2. Dimensions are shown in millimeters (inches).
3. Dimension do not include mold flash.
4. Outline conforms to JEDEC outline TO-261AA.
服务热线:400-655-8788
7
IRLL2703TRPBF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
