BCP56-16
BCP56-16
    YONGYUTAI(永裕泰)
    SOT-223
    NPN 电流:1A 电压:80V
BCP56-16 数据手册
BCP54/55/56 Features • For AF driver and output stages • High collector current • Low collector-emitter saturation voltage D1 S1 D2 • Complementary types: BCP51/BCP52/BCP53 (PNP) E C B SOT-223 top view Schematic diagram Maximum Ratings(Ta=25℃ unless otherwise noted) Symbol Parameter BCP54 BCP55 BCP56 Unit VCBO Collector-Base Voltage 45 60 100 V VCEO Collector-Emitter Voltage 45 60 80 V VEBO Emitter-Base Voltage 5 V IC Collector Current -Continuous 1 A ICM Peak Pulse Collector Current 2 A IB Base Current-Continuous 100 mA IBM Peak Pulse Base Current 200 mA PC Collector Power Dissipation 1.5 W 83.3 °C/W -55~+150 °C RΘJA TJ,Tstg Thermal Resistance From Junction To Ambient Operation Junction and Storage Temperature Range www.yongyutai.com PAGE 1 BCP54/55/56 Electrical Characteristics (TJ=25℃ unless otherwise noted) Parameter Symbol Condition V(BR)CBO Collector-base breakdown voltage Min Typ Max Unit BCP54 45 -- -- BCP55 IC=100μA, IE=0 60 -- -- BCP56 100 -- -- BCP54 45 -- -- 60 -- -- 80 -- -- V(BR)CEO Collector-emitter breakdown voltage BCP55 IC=10mA, IB=0 BCP56 V V V(BR)EBO Emitter-base breakdown voltage IE=10μA, IC=0 5 -- -- V ICBO VCB=30V , IE=0 -- -- 100 nA VCE=2V, IC= 5mA 25 -- -- VCE=2V, IC= 150mA 63 -- 250 VCE=2V, IC= 500mA 25 -- -- -- -- 0.5 V 100 -- -- MHz -- -- 1 V Collector cut-off current hFE1 hFE2 DC current gain hFE3 VCE(sat) Collector-emitter saturation voltage IC=500 mA, IB= 50mA fT Transition frequency VCE=10V, IC= 50mA,f=100MHz VBE Base-emitter voltage VCE=2V, IC= 500mA -- Ordering Information (Example) Type Hfe Marking 63-160 BCP54-10 100-250 BCP54-16 63-160 BCP55-10 100-250 BCP55-16 63-160 BCP56-10 BCP54 BCP55 BCP56 100-250 www.yongyutai.com Minimum Package(pcs) Inner Box Quantity(pcs) Outer Carton Delivery Mode Quantity(pcs) 2,500 5,000 35,000 13"reel 2,500 5,000 35,000 13"reel 2,500 5,000 35,000 13"reel BCP56-16 PAGE 2 BCP54/55/56 Typical Operating Characteristics www.yongyutai.com PAGE 3 BCP54/55/56 SOT-223 Package information Symbol A A1 A2 b1 b2 c D E E1 e e1 L L1 θ www.yongyutai.com Dimensions in Millimeters(mm) Min Max 0.700 0.900 0.000 0.100 0.700 0.800 0.150 0.250 0.250 0.350 0.100 0.200 1.500 1.700 0.700 0.900 1.450 1.750 0.500TYP 0.900 1.100 0.400REF 0.260 0.460 0° 8° Dimensions In Inches Min Max 0.028 0.035 0.000 0.004 0.028 0.031 0.006 0.010 0.010 0.014 0.004 0.008 0.059 0.067 0.028 0.035 0.057 0.069 0.020TYP 0.035 0.043 0.016REF 0.010 0.018 0° 8° PAGE 4
BCP56-16 价格&库存
很抱歉,暂时无法提供与“BCP56-16”相匹配的价格&库存,您可以联系我们找货
BCP56-16
    • 10+0.35068
    • 100+0.28018
    • 300+0.24493
    • 2500+0.21849
    • 5000+0.19734
    • 10000+0.18669
    库存:1275
