AGM60P20R
● General Description
Product Summary
The AGM60P20R combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON)
BVDSS
RDSON
ID
-60V
65mΩ
-10A
This device is ideal for load switch and battery
protection applications.
SOT-223 Pin Configuration
● Features
■ Advance high cell density Trench technology
■ Low RDS(ON) to minimize conductive loss
■ Low Gate Charge for fast switching
■ Low Thermal resistance
● Application
■ MB/VGA Vcore
■ SMPS 2nd Synchronous Rectifier
■ POL application
■ BLDC Motor driver
Package Marking and Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
AGM60P20R
AGM60P20R
SOT223
330mm
12mm
3000
Table 1.
Absolute Maximum Ratings (TA=25℃)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
-60
V
VGS
Gate-Source Voltage (VDS=0V)
±20
V
-10
A
Drain Current-Continuous(TA=100℃)
-6.3
A
Drain Current-Continuous@ Current-Pulsed (Note 2)
-32
A
Maximum Power Dissipation(TA=25℃)
3.0
w
60
mJ
-55 To 150
Typ
Max
Unit
42
℃/W
Drain Current-Continuous(TA=25℃) (Note 1)
ID
IDM (pluse)
PD
EAS
TJ,TSTG
Table 2.
Avalanche energy (Note 3)
Operating Junction and Storage Temperature Range
Thermal Characteristic
Symbol
RθJA
www.agm-mos.com
Parameter
Thermal Resistance Junction-ambient (Steady State)1
1
VER2.6
AGM60P20R
Table 3.
Electrical Characteristics (TA=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=-250μA
-60
V
IDSS
Zero Gate Voltage Drain Current
VDS=-60V,VGS=0V
-1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=-250μA
-1.3
-1.8
-2.5
V
gFS
Forward Transconductance
VDS=5V,ID=-5A
7.0
S
RDS(on)
Drain-Source On-State Resistance
VGS=-10V, ID=-5A
65
89
mΩ
VGS=-4.5V, ID=-4A
95
120
mΩ
525
pF
80
pF
3.9
pF
3.5
Ω
10
nS
6.0
nS
40
nS
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VDS=-30V,VGS=0V,
F=1MHZ
f=1.0MHz
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
13
nS
Qg
Total Gate Charge
8.5
nC
Qgs
Gate-Source Charge
1.8
nC
Qgd
Gate-Drain Charge
1.5
nC
-10
A
VGS=-10V,VDS=-30V,
ID=-5A,RGEN=3Ω
VGS=-10V,
VDS=-30V, ID=-5A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VSD
Forward on Voltage
VGS=0V,IS=-5A
-1.2
V
trr
Reverse Recovery Time
Isd=-5A , dI/dt=100A/µs ,
50
ns
Qrr
Reverse Recovery Charge
TJ=25℃
105
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃
www.agm-mos.com
2
VER2.6
AGM60P20R
Typ. output characteristics
-ID =f(-VDS )
Typ. drain-source on resistance
RDS(on) =f(-ID )
200
30
-10V
-4.0V
25
-4.5V
-5.0V
150
Ron[mohm]
-ID[A]
-4.5V
15
10
-5.0V
100
-4.0V
5
-10V
2
3
4
50
5
-VDS[V]
15
10
5
10
-ID[A]
15
Typ. forward transconductance
gfs =f(-ID )
gfs[S]
-ID[A]
Typ. transfer characteristics
-ID =f(-VGS )
5
2
3
4
www.agm-mos.com
-ID[A]
-Vgs[V]
3
VER2.6
AGM60P20R
Drain-source on-state resistance
RDS(on) =f(T j ); ID =-5.0A; VGS =-10V
Typ. capacitances
C =f(-VDS ); VGS =0V; f =1MHz
200
1,000
150
C[pF]
Ron[mohm]
100
100
10
50
-20
100
1
140
Tj[℃]
Typ. gate charge
-VGS =f(Qgate ) ; ID =-5A
10
40
50
60
Drain-source breakdown voltage
-VBR(DSS) =f(Tj ); ID =-250uA
70
Vd=-30.0V
9
30
-VDS[V]
Vd=-60.0V
8
7
65
-VBR(DSS) [V]
-Vgs[V]
6
5
4
60
3
2
1
4
6
8
Qg[nC]
www.agm-mos.com
-60
-20
100
140
Tj[℃]
4
VER2.6
AGM60P20R
Power Dissipation
Ptot =f(TA )
Safe operating area
-ID =f(-VDS )
100
10us
3.00
10
100us
-ID[A]
Ptot[W]
4.00
2.00
1ms
1
10ms
1.00
DC
0.00
50
75
TA[℃]
100
125
0.1
150
0.1
1
-VDS[V]
10
100
Max. transient thermal impedance
ZthJC =f(tp )
www.agm-mos.com
5
VER2.6
AGM60P20R
Test Circuit and Waveform:
Gate Charge Test Circuit & Waveform
Resistive Switching Test Circuit & Waveforms
Unclamped Inductive Switching Test Circuit & Waveforms
www.agm-mos.com
6
VER2.6
AGM60P20R
SOT-223 Package Dimensions
www.agm-mos.com
7
VER2.6
AGM60P20R
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequences.Do not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the second version issued on February 20, 2023. This document
replaces and Replace all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
8
VER2.6
很抱歉,暂时无法提供与“AGM60P20R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.08227
- 50+0.87491
- 150+0.77123
- 500+0.69347
- 3000+0.59465
- 6000+0.56355
