ZVN2120GTA-VB
ZVN2120GTA-VB
    VBSEMI(微碧)
    SOT-223
    20Vgs(±V);2~4Vth(V)
ZVN2120GTA-VB 数据手册
ZVN2120GTA www.VBsemi.com N-Channel 200 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) • • • • • • 200 RDS(on) () VGS = 10 V 1.2 Qg (Max.) (nC) 8.2 Qgs (nC) 1.8 Qgd (nC) 4.5 Configuration Available in tape and reel Dynamic dV/dt rating Repetitive avalanche rated Fast switching Ease of paralleling Simple drive requirements Available Single D SOT-223 D G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL LIMIT Drain-Source Voltage VDS 200 Gate-Source Voltage VGS ± 20 Continuous Drain Current VGS at 10 V TC = 25 °C TC = 100 °C Pulsed Drain Current a ID IDM UNIT V 1.0 0.8 A 5.0 Linear Derating Factor 0.025 Linear Derating Factor (PCB Mount) e 0.017 W/°C Single Pulse Avalanche Energy b EAS 50 Repetitive Avalanche Current a IAR 0.96 A Repetitive Avalanche Energy a EAR 0.31 mJ TC = 25 °C Maximum Power Dissipation Maximum Power Dissipation (PCB Mount) e TA = 25 °C Peak Diode Recovery dV/dt c Operating Junction and Storage Temperature Range for 10 s Soldering Recommendations (Peak Temperature) d Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. VDD = 50 V, starting TJ = 25 °C, L = 81 mH, RG = 25 , IAS = 0.96 A (see fig. 12). c. ISD  3.3 A, dI/dt  70 A/μs, VDD  VDS, TJ  150 °C. d. 1.6 mm from case. e. When mounted on 1" square PCB (FR-4 or G-10 material). PD 3.1 2.0 dV/dt 5.0 TJ, Tstg -55 to +150 300 mJ W V/ns °C 服务热线:400-655-8788 1 ZVN2120GTA www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL MIN. TYP. MAX. Maximum Junction-to-Ambient  (PCB Mount) a PARAMETER RthJA - - 40 Maximum Junction-to-Case (Drain) RthJC - - 60 UNIT °C/W Note a. When mounted on 1" square PCB (FR-4 or G-10 material). SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VDS Temperature Coefficient VDS VGS = 0 V, ID = 250 μA 200 - - V VDS/TJ Reference to 25 °C, ID = 1 mA - 0.30 - V/°C VGS(th) VDS = VGS, ID = 250 μA 2.0 - 4.0 V Gate-Source Leakage IGSS VGS = ± 20 V - - ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 200 V, VGS = 0 V - - 25 VDS = 160 V, VGS = 0 V, TJ = 125 °C - - 250 Gate-Source Threshold Voltage Drain-Source On-State Resistance Forward Transconductance μA - 1.2 -  gfs VDS = 50 V, ID = 0.58 A 0.51 - - S VGS = 0 V, VDS = 25 V, f = 1.0 MHz, see fig. 5 - 140 - - 53 - - 15 - - - 8.2 - - 1.8 RDS(on) ID = 0.58 A b VGS = 10 V Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss pF Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd - - 4.5 Turn-On Delay Time td(on) - 8.2 - tr - 17 - - 14 - - 8.9 - - 4.0 - - 6.0 - - - 0.96 S - - 7.7 TJ = 25 °C, IS = 0.96 A, VGS = 0 V b - - 2.0 V - 150 310 ns - 0.60 1.4 μC Rise Time Turn-Off Delay Time Fall Time Internal Drain Inductance Internal Source Inductance td(off) VGS = 10 V ID = 3.3 A, VDS = 160 V, see fig. 6 and 13 b VDD = 100 V, ID = 3.3 A, Rg = 24 , RD = 30 , see fig. 10 b tf LD LS Between lead, 6 mm (0.25") from package and center of die contact nC ns D nH G S Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulsed Diode Forward Current a ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the  integral reverse p - n junction diode D A G TJ = 25 °C, IF = 3.3 A, dI/dt = 100 A/μs b Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width  300 μs; duty cycle  2 %. 服务热线:400-655-8788 2 - ZVN2120GTA www.VBsemi.com 101 VGS ID, Drain Current (A) Top 15 V 10 V 8.0 V 7.0 V 6.0 V 5.5 V 5.0 V Bottom 4.5 V 100 10-1 4.5 V 20 µs Pulse Width TC = 25 °C 100 10-1 101 VDS, Drain-to-Source Voltage (V) 91193_01 RDS(on), Drain-to-Source On Resistance (Normalized) TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 3.5 ID = 3.3 A 3.0 VGS = 10 V 2.5 2.0 1.5 1.0 0.5 0.0 - 60 - 40 - 20 20 40 60 80 100 120 140 160 TJ, Junction Temperature (°C) 91193_04 Fig. 1 - Typical Output Characteristics, TC = 25 °C 0 Fig. 4 - Normalized On-Resistance vs. Temperature 300 VGS 15 V 10 V 8.0 V 7.0 V 6.0 V 5.5 V 5.0 V Bottom 4.5 V VGS = 0 V, f = 1 MHz Ciss = Cgs + Cgd, Cds Shorted Crss = Cgd Coss = Cds + Cgd 100 250 4.5 V 10-1 Capacitance (pF) ID, Drain Current (A) Top 100 Coss 100 Crss 0 101 100 VDS, Drain-to-Source Voltage (V) 91193_02 Ciss 150 50 20 µs Pulse Width TC = 150 °C 10-1 200 VDS, Drain-to-Source Voltage (V) 91193_05 Fig. 2 - Typical Output Characteristics, TC = 150 °C Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage 150 °C 25 °C 10-1 10-2 20 µs Pulse Width VDS = 50 V 4 5 6 7 8 9 VGS, Gate-to-Source Voltage (V) 91193_03 Fig. 3 - Typical Transfer Characteristics VGS, Gate-to-Source Voltage (V) ID, Drain Current (A) 20 100 101 ID = 3.3 A VDS = 160 V 16 VDS = 100 V VDS = 40 V 12 8 4 For test circuit see figure 13 0 10 0 91193_06 2 4 6 8 10 QG, Total Gate Charge (nC) Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage 服务热线:400-655-8788 3 ZVN2120GTA www.VBsemi.com 1.0 ID, Drain Current (A) ISD, Reverse Drain Current (A) 101 150 °C 100 25 °C 0.6 0.4 0.2 VGS = 0 V 10-1 0.4 0.8 1.2 1.6 0.0 2.0 25 VSD, Source-to-Drain Voltage (V) 91193_07 102 50 100 125 150 Fig. 9 - Maximum Drain Current vs. Case Temperature RD VDS Operation in this area limited by RDS(on) 5 75 TC, Case Temperature (°C) 91193_09 Fig. 7 - Typical Source-Drain Diode Forward Voltage ID, Drain Current (A) 0.8 VGS 2 D.U.T. Rg + - VDD 10 5 10 V 100 µs 2 1 Pulse width ≤ 1 µs Duty factor ≤ 0.1 % 1 ms Fig. 10a - Switching Time Test Circuit 5 TC = 25 °C TJ = 150 °C Single Pulse 2 0.1 1 2 5 10 ms VDS 10 5 2 102 2 5 90 % 103 VDS, Drain-to-Source Voltage (V) 91193_08 Fig. 8 - Maximum Safe Operating Area 10 % VGS td(on) td(off) tf tr Fig. 10b - Switching Time Waveforms Thermal Response (ZthJC) 102 0 - 0.5 10 1 0.2 0.1 0.05 0.02 Single Pulse (Thermal Response) t1 0.1 10-2 10-5 91193_11 PDM 0.01 t2 Notes: 1. Duty Factor, D = t1/t2 2. Peak Tj = PDM x ZthJC + TC 10-4 10-3 10-2 0.1 1 10 102 103 t1, Rectangular Pulse Duration (S) Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case 服务热线:400-655-8788 4 ZVN2120GTA www.VBsemi.com L Vary tp to obtain required IAS VDS VDS tp VDD D.U.T Rg + - I AS V DD VDS 10 V 0.01 Ω tp IAS Fig. 12b - Unclamped Inductive Waveforms Fig. 12a - Unclamped Inductive Test Circuit EAS, Single Pulse Energy (mJ) 120 ID 0.43 A 0.61 A Bottom 0.90 A Top 100 80 60 40 20 0 VDD = 50 V 25 91193_12C 50 75 100 125 150 Starting TJ, Junction Temperature (°C) Fig. 12c - Maximum Avalanche Energy vs. Drain Current Current regulator Same type as D.U.T. 50 kΩ QG VGS 12 V 0.2 µF 0.3 µF QGS QGD + D.U.T. VG - VDS VGS 3 mA Charge IG ID Current sampling resistors Fig. 13a - Basic Gate Charge Waveform Fig. 13b - Gate Charge Test Circuit 服务热线:400-655-8788 5 ZVN2120GTA www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit + D.U.T. Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + + - - Rg • • • • dV/dt controlled by Rg Driver same type as D.U.T. ISD controlled by duty factor “D” D.U.T. - device under test + - VDD Driver gate drive P.W. Period D= P.W. Period VGS = 10 Va D.U.T. lSD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage Inductor current VDD Body diode forward drop Ripple ≤ 5 % ISD Note a. VGS = 5 V for logic level devices Fig. 14 - For N-Channel        服务热线:400-655-8788 6 ZVN2120GTA www.VBsemi.com SOT-223 B D A 3 0.08 (0.003) B1 C 0.10 (0.004) M C B M A 4 3 H E 0.20 (0.008) M C A M L1 1 2 3 4xL 3xB e θ 0.10 (0.004) M C B M e1 4xC MILLIMETERS INCHES DIM. MIN. MAX. MIN. MAX. A 1.55 1.80 0.061 0.071 0.033 B 0.65 0.85 0.026 B1 2.95 3.15 0.116 0.124 C 0.25 0.35 0.010 0.014 D 6.30 6.70 0.248 0.264 E 3.30 3.70 0.130 e 2.30 BSC e1 4.60 BSC 0.181 BSC H 6.71 7.29 0.264 L 0.91 - 0.036 L1 θ 0.061 BSC - 0.146 0.0905 BSC 0.287 0.0024 BSC 10' - 10' ECN: S-82109-Rev. A, 15-Sep-08 DWG: 5969 Notes 1. Dimensioning and tolerancing per ASME Y14.5M-1994. 2. Dimensions are shown in millimeters (inches). 3. Dimension do not include mold flash. 4. Outline conforms to JEDEC outline TO-261AA. 服务热线:400-655-8788 7 ZVN2120GTA www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
