BT134W
FSSeries
2A 4quadrants TRIACs
Product Summary
Symbol
Value
Unit
IT(RMS)
2
A
VDRM VRRM
600 / 800
V
VTM
1.55
V
Feature
Application
With high ability to withstand the shock loading of
large current,With high commutation performances,
4 quadrants products especially recommended for
use on inductive load.
Heating controller; Motor speed controller;
Mahjong machine; Blender;
Hair straightener; Household appliances like
toasters...
Package
Circuit diagram
SOT-223-3L
Marking
BT134
XXXX
www.fuxinsemi.com
Page 1
Ver2.1
BT134W
FSSeries
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Repetitive peak off-state voltage
VDRM
600 / 800
V
Repetitive peak reverse voltage
VRRM
600 / 800
V
RMS on-state current
IT(RMS)
2
A
ITSM
A
I2t
0.72
A2s
dIT/dt
A/μs
IGM
2
A
PG(AV)
0.5
W
Junction Temperature
TJ
-40 ~ +125
Storage Temperature
TSTG
-40 ~ +150
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current (IG =2×IGT)
Peak gate current
Average gate power dissipation
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Gate trigger current
Symbol
IGT
Gate trigger voltage
VGT
Gate non-trigger voltage
VGD
latching current
IL
Holding current
IH
Critical-rate of rise
of commutation voltage
dVD/dt
Value
Test Condition
VD=12V, RL=30Ω,
Tj=25℃
Ⅰ-Ⅱ-Ⅲ
≤5
IV
≤10
ALL
≤1.3
V
≥0.2
V
mA
VD =VDRM Tj =125℃
IG=1.2IGT
Unit
E
Ⅰ-Ⅲ
≤5
Ⅱ-IV
≤10
IT=200mA
VD=2/3VDRM Gate Open Tj
=125℃
mA
≤5
mA
≥15
V/μs
STATIC CHARACTERISTICS
Forward "on" voltage
VTM
Repetitive Peak Off-State Current
IDRM
Repetitive Peak Reverse Current
IRRM
ITM =1.4A tp=380μs
VD =VDRM VR =VRRM
MAX.
1.55
V
Tj=25℃
MAX.
5
μA
Tj=125℃
MAX.
0.5
mA
TYP.
31
℃/W
THERMAL RESISTANCES
Thermal resistance
www.fuxinsemi.com
Rth(j-c)
Junction to case(AC)
Page 2
Ver2.1
BT134W
FSSeries
Typical Characteristics
FIG.1: Maximum power dissipation versus RMS
on-state current
3
FIG.2: RMS on-state current versus case
temperature
P(W)
IT(RMS)(A)
2.5
2.0
2
1.5
1.0
1
0.5
IT(RMS)(A)
0.5
1.0
1.5
2.0
FIG.3: Surge peak on-state current versus
number of cycles
ITSM(A)
TC(℃)
0.0
-50
100
150
FIG.4: On-state characteristics (maximum
values)
24
10
ITM(A)
8
16
Tj=125ºC
6
12
4
8
Tj=25ºC
2
4
Number of cycles
1
10
100
VTM(V)
1000
1.0
1.5
2.0
2.5
3.0
FIG.6: Relative variations of gate trigger current,
holding current and latching current versus
junction temperature
FIG.5: Non-repetitive surge peak on-state current
for a sinusoidal pulse with width tp
很抱歉,暂时无法提供与“BT134W-600E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.86109
- 50+0.70557
- 150+0.62781
- 500+0.56949
- 2500+0.52283
- 4000+0.49940
- 国内价格
- 1+0.57530
- 200+0.37180
- 2000+0.32340
- 4000+0.28600
