UMW
R
ZXMN6A25
60V N-Channel
Product Summary
VDS (V) = 60V
RDS(ON)
50m
(V
GS
= 10V)
RDS(ON)
70m
(V
GS
= 4.5V)
Description
This new generation MOSFET is designed to minimize the on-state
resistance (RDS(ON)) and yet maintain superior switching performance,
making it ideal for high-efficiency power management applications.
Equivalent Circuit
Applications
DC-DC Converters
Power Management Functions
Backlighting
Features and Benefits
Low Input Capacitance
Low On-Resistance
Fast Switching Speed
Lead-Free Finish;
Halogen and Antimony Free.
View
Maximum Ratings (@TA = +25°C, unless otherwise specified.)
Characteristic
Symbol
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current, VGS = 10V
Steady
State
TA = +25°C (Note 6)
TA = +70°C (Note 6)
TA = +25°C (Note 5)
Maximum Body Diode Forward Current (Note 6)
Pulsed Drain Current (Note 7)
Value
60
Units
V
VGSS
±20
V
ID
6.7
5.4
4.8
A
5.7
28.5
A
A
28.5
A
IS
IDM
ISM
Pulsed Source Current (Note 7)
www.umw-ic.com
VDSS
1
UTD Semiconductor Co.,Limited
UMW
R
ZXMN6A25
60V N-Channel
Thermal Characteristics (@TA = +25°C, unless otherwise specified.)
Characteristic
Symbol
Total Power Dissipation
Linear Derating Factor
TA = +25°C (Note 5)
PD
TA = +25°C (Note 6)
PD
Thermal Resistance, Junction to Ambient
Steady state (Note 5)
Steady state (Note 6)
RθJA
Operating and Storage Temperature Range
Electrical Characteristics
TJ, TSTG
Value
2
16
3.9
31
62.5
32
-55 to +150
Symbol
Min
BVDSS
60
Typ
Max
Unit
V
VGS = 0V, ID = 250µA
IDSS
1.0
µA
VDS = 60V, VGS = 0V
Gate-Source Leakage
ON CHARACTERISTICS (Note 9)
Gate Threshold Voltage
IGSS
100
nA
VGS = 20V, VDS = 0V
V
VDS = VGS, ID = 250µA
Static Drain-Source On-Resistance (Note 8)
Diode Forward Voltage (Note 8)
Forward Transconductance (Note 8 & 10)
DYNAMIC CHARACTERISTICS (Note 10)
Input Capacitance
VGS(th)
RDS(ON)
1.0
VSD
gfs
0.85
10.2
Ciss
1,063
Output Capacitance
Coss
104
Reverse Transfer Capacitance
Crss
Total Gate Charge (VGS = 5.0V)
Qg
64
11
20.4
4.1
Qg
50
70
mΩ
0.95
V
S
VGS = 10V, ID = 3.6A
VGS = 4.5V, ID = 3.0A
VGS = 0V, IS = 5.5A
VDS = 15V, ID = 4.5A
VDS = 30V, VGS = 0V
f = 1.0MHz
nC
VDS = 30V, ID = 1.4A,
nS
VGS = 10V, VDD = 30V, RG = 6.0Ω,
ID= 1.0A
Gate-Drain Charge
Turn-On Delay Time
tD(on)
Turn-On Rise Time
tr
4.0
Turn-Off Delay Time
Turn-Off Fall Time
tD(off)
tf
26.2
10.6
trr
Qrr
22
nS
21.4
nC
Notes:
°C/W
°C/W
°C
pF
Qgs
Qgd
Body Diode Reverse Recovery Charge
W
mW/°C
Test Condition
Zero Gate Voltage Drain Current
Body Diode Reverse Recovery Time
W
mW/°C
Characteristic
OFF CHARACTERISTICS (Note 9)
Drain-Source Breakdown Voltage
Total Gate Charge (VGS = 10V)
Gate-Source Charge
Units
5.1
3.8
IF = 2.2A, dI/dt = 100A/μs
5. For a device surface mounted on 25mm x 25mm FR4 PCB with high coverage of single sided 1oz copper, in still air conditions
6. For a device surface mounted on FR4 PCB measured at t 10 secs.
7. Repetitive rating 25mm x 25mm FR4 PCB, D = 0.02, pulse width 300μs - pulse width limited by maximum junction temperature.
8. Measured under pulsed conditions. Width=300μs. Duty cycle ≤ 2%.
9. Short duration pulse test used to minimize self-heating effect.
www.umw-ic.com
2
UMW
R
ZXMN6A25
60V N-Channel
ADVANCE INFORMATION
ADVANCED INFORMATION
Typical Characteristics
www.umw-ic.com
3
UMW
R
ZXMN6A25
60V N-Channel
ADVANCE INFORMATION
Typical Characteristics (continued)
www.umw-ic.com
4
UMW
R
ZXMN6A25
60V N-Channel
ADVANCE INFORMATION
Typical Characteristics (cont.)
www.umw-ic.com
5
UMW
R
ZXMN6A25
60V N-Channel
SOT-223
www.umw-ic.com
6
UMW
R
ZXMN6A25
60V N-Channel
ZXMN
6A25
YWW
Marking
Ordering information
Order code
UMW ZXMN6A25GTA
www.umw-ic.com
Package
Baseqty
2500
SOT-223
7
Deliverymode
Tape and reel
很抱歉,暂时无法提供与“ZXMN6A25GTA(UMW)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.18034
- 50+0.91703
- 150+0.80417
- 500+0.66334
- 2500+0.60070
- 5000+0.56312
