BCP55
BCP55
    HXY(华轩阳)
    SOT-223
    NPN 电流:1A 电压:60V
BCP55 数据手册
HXY BCP54,55,56 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG FEATURES z z Collector Current: IC=1A Power Dissipation of 1.5w E B C SOT-223 Package Marking and Ordering Information Product ID Pack Marking BCP54 SOT-223 BCP54 1000 BCP55 SOT-223 BCP55 1000 BCP56 SOT-223 BCP56 1000 C Qty(PCS) B E MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol BCP55 Unit 45 BCP54 Collector-Base Voltage Limit VCBO 60 BCP56 100 BCP54 45 V VCEO 60 80 V VEBO 5 V Collector Current IC 1 A Collector Power Dissipation PC 1.5 W Thermal Resistance From Junction To Ambient RΘJA 83.3 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg Collector-Emitter Voltage Emitter-Base Voltage Shenzhen HuaXuanYang Electronics CO.,LTD BCP55 BCP56 -55~+150 ℃ www.hxymos.com HXY BCP54,55,56 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG        Ta =25  unless otherwise specified Symbol Parameter Collector-base breakdown voltage Min V(BR)CBO IC= 0.1mA,IE=0 60 BCP56 100 BCP54 45 BCP55 V(BR)CEO IC= 10mA,IB=0 Unit V V 60 80 BCP56 Base-emitter breakdown voltage Max 45 BCP54 BCP55 Collector-emitter breakdown voltage Test conditions V(BR)EBO IE = 10μA,IC=0 5 V ICBO VCB= 30 V, IE=0 hFE(1) VCE= 2V, IC=5mA 25 hFE(2) VCE= 2V, IC=150m A 63 hFE(3) VCE= 2V, IC=500m A 25 VCE(sat) IC=500mA,IB=50mA 0.5 V Base-emitter voltage VBE VCE=2V, IC=500m A 1 V Transition frequency fT Collector cut-off current DC current gain Collector-emitter saturation voltage VCE=10V,IC=50mA,f=100MHz 100 100 nA 250 MHz Typical Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY BCP54,55,56 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY BCP54,55,56 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG SOT-223 Package Outline Dimensions Symbol A A1 A2 b b1 c D E E1 e L θ Dimensions In Millimeters Min. Max. —— 1.800 0.020 0.100 1.500 1.700 0.660 0.840 2.900 3.100 0.230 0.350 6.300 6.700 6.700 7.300 3.300 3.700 2.300(BSC) 0.750 —— 0° 10° Shenzhen HuaXuanYang Electronics CO.,LTD Dimensions In Inches Min. Max. —— 0.071 0.001 0.004 0.059 0.067 0.026 0.033 0.114 0.122 0.009 0.014 0.248 0.264 0.264 0.287 0.130 0.146 0.091(BSC) 0.030 —— 0° 10° www.hxymos.com HXY BCP54,55,56 ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
BCP55 价格&库存
很抱歉,暂时无法提供与“BCP55”相匹配的价格&库存,您可以联系我们找货
