BCP53
BCP53
    HXY(华轩阳)
    SOT-223
    PNP 电流:1A 电压:80V
BCP53 数据手册
HUAXUANYANG HXY BCP51,52,53 ELECTRONICS CO.,LTD PNP Plastic-Encapsulate Transistors FEATURES z z Collector Current: IC=-1A Power Dissipation of 1.5w E B C SOT-223 Package Marking and Ordering Information Product ID Pack Marking BCP51 SOT-223 BCP51 1000 BCP52 SOT-223 BCP52 1000 BCP5 BCP53 SOT-223 BCP53 1000 C Qty(PCS) B E MAXIMUM X RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol BCP52 Unit -45 BCP51 Collector-Base Voltage Limit VCBO -60 BCP53 -100 BCP51 -45 V VCEO -60 -80 V VEBO -5 V Collector Current IC -1 A Collector Power Dissipation PC 1.5 W Thermal Resistance From Junction To Ambient RΘJA 94 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg Collector-Emitter Voltage Emitter-Base Voltage Shenzhen HuaXuanYang Electronics CO.,LTD BCP52 BCP53 -55~+150 ℃ www.hxymos.com HUAXUANYANG HXY BCP51,52,53 ELECTRONICS CO.,LTD PNP Plastic-Encapsulate Transistors        Ta =25  unless otherwise specified Symbol Parameter Collector-base breakdown voltage Min V(BR)CBO IC=- 0.1mA,IE=0 -60 BCP53 -100 BCP51 -45 BCP52 V(BR)CEO IC= -10mA,IB=0 Collector cut-off current = IE = -10μA,IC 0 V(BR)EBO Collector-emitter saturation voltage V -60 V -5 VCB= -30 V, IE 0 ICBO= hFE(1)= VCE=-2V, IC -5mA DC current gain Unit -80 BCP53 Base-emitter breakdown voltage Max -45 BCP51 BCP52 Collector-emitter breakdown voltage Test conditions -100 VCE= -2V, IC=-150m A 63 hFE(3) VCE= -2V, IC=-500m A 25 VCE(sat) = IC=-500mA,IB -50mA VBE Transition frequency fT VCE=-2V, IC=-500m A = 100MHz VCE=-10V,I =C -50mA,f nA 25 hFE(2) Base-emitter voltage V 100 250 -0.5 V -1 V MHz Typical Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD Shenzhen HuaXuanYang Electronics CO.,LTD BCP51,52,53 PNP Plastic-Encapsulate Transistors www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD SOT-223 Package Outline Dimensions Symbol A A1 A2 b b1 c D E E1 e L θ BCP51,52,53 PNP Plastic-Encapsulate Transistors Dimensions In Millimeters Min. Max. —— 1.800 0.020 0.100 1.500 1.700 0.660 0.840 2.900 3.100 0.230 0.350 6.300 6.700 6.700 7.300 3.300 3.700 2.300(BSC) 0.750 —— 0° 10° Shenzhen HuaXuanYang Electronics CO.,LTD Dimensions In Inches Min. Max. —— 0.071 0.001 0.004 0.059 0.067 0.026 0.033 0.114 0.122 0.009 0.014 0.248 0.264 0.264 0.287 0.130 0.146 0.091(BSC) 0.030 —— 0° 10° www.hxymos.com HUAXUANYANG HXY BCP51,52,53 ELECTRONICS CO.,LTD PNP Plastic-Encapsulate Transistors Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
BCP53 价格&库存
很抱歉,暂时无法提供与“BCP53”相匹配的价格&库存,您可以联系我们找货
