MT59211118GWA3D1Y1027
    MINTRON(明硕)
    插件
    RJ11/RJ45连接器 网口90°单口不带灯带屏蔽
MT59211118GWA3D1Y1027 数据手册
2 1 H 5 4 3 7 6 REACH & RoHS COMPLIANT REV. ECN / DESCRIPTION NEW A0 8 BY DATE MQ.Qu 2018.05.11 H MATERIAL: HOUSING: PA46,UL94V-0, BLACK . TERMINAL: PHOSPHOR BRONZE Ø=0.46MM,G/FU" GOLD PLATING. SHIELD: C2680,T=0.20MM,20 ~50U" MIN NICKEL PLATING ON ALL AREA. G MACHANICAL: DURABILITY: 750 CYCLES MIN,12.5MM/MINUTE. INSERTION FORCE : 2.2KG.F MAX. RETENTION STRENGTH : 7.7KG.F BETWEEN JACK AND PLUG . OPERATING TEMPERATURE: -40 ℃~+85 ℃. STORAGE TEMPERATURE: -40°C~+85°C. ALL CRITICAL DIMENSIONS WITH "*" TOP VIEW F J1 ELECTRICAL: VOLTAGE: 125 VOLTS AC. CURRENT RATING : 1.5AMP . DIELECTRIC STRENGTH : 1000 VAC RMS 50HZ OR 60HZ,1 MIN. INSULATION RESISTANCE: 500 MEGA OHMS MIN. INITIAL AFTER 500V DC FOR 1 MINUTE. CONTACT RESISTANCE: SINGLE TERMINAL 30 MILLIOHMS MAX. INITIAL 50 MILLIOHMS MAX. AFTER DURABILITY TEST. J8 E F E LEFT SIDE VIEW FRONT VIEW RIGHT SIDE VIEW BACK VIEW D 2 3 8 6 4 5 7 PCB SIDE TO PHY 1 C 1 3 2 5 4 7 6 8 BOTTOM VIEW B TITLE: MINTRON 1 2 J1 J2 J3 J4 J5 J6 J7 8 J8 RECOMMENDED PCB LAYOUT VIEWED FROM COMPONENT SIDE RJ45 5921 1*1 PART NO.: MT59211118GWA3D1Y1027 REMARK: 3 1 2 3 4 5 6 7 CABLE SIDE D A G 4 SIZE UNITS A4 MM[INCH] SACLE REV 1:1 A0 SHEET 1/1 5 C B GENERAL TOLERANCES APPROVED BY: JP.Gong UNLESS SPECIFIED CHECKED BY: x±0.35 x°±3.0° TW.Xu .x±0.30 .x°±2.0° DESIGND BY: .xx±0.25 .xx°±1.5° .xxx±0.10 .xxx°±1.0° MQ.Qu 6 7 8 A
MT59211118GWA3D1Y1027 价格&库存
很抱歉,暂时无法提供与“MT59211118GWA3D1Y1027”相匹配的价格&库存,您可以联系我们找货
