QCL Series
HC-49/U-S (Short)
Features
• High reliability and Low Cost
• Tight stability and extended temperature
• Proven resistance welded metal package
Applications
• Computers, modems and communications
• Microprocessors
General Specifications
Frequency Range
Equivalent Series Resistance (ESR)
max.
3.200 to 70.000MHz
Frequency Range - MHz
Fundamental
3.200 to 32.768MHz
3.200
to 3.500
300
Third Overtone
24.576 to 70.000MHz
3.510
to 3.999
200
±10 to ±30ppm (±30ppm standard)
4.000
to 5.999
120
Frequency Stability over Temperature Range
See Stability vs. Temperature Table
6.000
to 7.999
80
Storage Temperature
-55 to +125°C
8.000
to 9.999
60
Aging per Year
±3ppm max.
10.000 to 15.999
50
Load Capacticance CL
10 to 32pF and Series Resonance
16.000 to 32.768
40
Shunt Capacticance C0
7.0pF
24.576 to 70.000
80
See ESR Table
Drive Level
1.0mW max.
Insulation Resistance (M)
500 at 100Vdc ±15Vdc
Mode of Oscillation
Frenquency Tolerance at 25°C
Mode of Operation
Fundamental
Fundamental - Third Overtone
Frequency Stability vs. Temperature
Operating Temperature
±10ppm
±20ppm
±30ppm
±50ppm
±100ppm
-20 to +70°C
-40 to +85°C
standard
*Operating Temperature -30 to +85°C
available
Mechanical Dimensions
Part Numbering Guide
Q = Qantek
Package
CL = HC-49/U-S
= (Short)
Example: QCL12.0000F18B35B
Nominal
Frequency
(in MHz)
7 digits including
the decimal point
(f.ie. 12.0000)
Vibration
Mode
Load
Capacitance
F = AT-Fund
S = Series
08 = 8pF
12 = 12pF
18 = 18pF
20 = 20pF etc.
Operating
Temperature
Range
A = -20 to +70°C
B = -40 to +85°C
Frequency
Tolerance
Frequency
Stability
Automotive
Indicator
1 = ±10ppm
2 = ±20ppm
3 = ±30ppm
5 = ±50ppm
0 = ±100ppm
1 = ±10ppm
2 = ±20ppm
3 = ±30ppm
5 = ±50ppm
0 = ±100ppm
not available
Packaging
B = bulk
R = 1000pcs Tape&Reel
bold letters = recommended standard specification
QANTEK Technology Corporation
Phone: +1 877-227-0440 (tollfree)
Fax:
www.qantek.com
info@qantek.com
QCL Rev. 0.2
Qantek
Code
QCL Series
HC-49/U-S (Short)
Tape Dimensions
Marking Code Guide
Contains frequency, Qantek manufacturing code, production code (month and year) and load capacitance.
Year Codes
Month Codes
January
A
July
Load Capacitance Code in pF
G
2010
1
2012
2
pF
PN Code
pF
PN Code
2013
3
2014
4
2015
5
12
A
F
18
B
22
G
February
B
August
H
March
C
September
I
April
D
October
J
8
C
30
H
May
E
November
K
10
D
32
I
June
F
December
L
16
E
S
S
Example: First Line: 12.000 (Frequency) Second Line: QA1A (Qantek - January - 2011 - 12 pF)
Solder Reflow Profile
Environmental Specifications
Mechanical Shock
MIL-STD-202, Method 213, C
Vibration
MIL-STD-202, Method 201 & 204
Thermal Cycle
MIL-STD, Method 1010, B
Gross Leak
MIL-STD-202, Method 112
Fine Leak
All specifications are subject to change without notice.
www.qantek.com
info@qantek.com
QCL Rev. 0.2
Fax:
很抱歉,暂时无法提供与“QCL11.0592F18B23B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.27778
- 50+1.27049
- 100+1.25904
- 200+1.20176
