RTL8213B-CG
RTL8213B-CG
    REALTEK(瑞昱)
    QFN-40-EP(5x5)
    10/100/1000M铜到100Base FX/1000Base-X光纤介质转换器
RTL8213B-CG 数据手册
RTL8213B-CG 10/100/1000M Copper to 100Base-FX/1000Base-X Fiber Media Converter DRAFT DATASHEET (CONFIDENTIAL: Development Partners Only) Rev. 1.0 30 Dec. 2018 Track ID: xxxx-xxxx-xx Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com RTL8213B DRAFT Datasheet COPYRIGHT ©2018 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document ‘as is’, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document is intended for the hardware and software engineer’s general information on the Realtek RTL8213B IC. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. ELECTROSTATIC DISCHARGE (ESD) WARNING This product can be damaged by Electrostatic Discharge (ESD). When handling, care must be taken. Damage due to inappropriate handling is not covered by warranty. Do not open the protective conductive packaging until you have read the following, and are at an approved anti-static workstation.    Use an approved anti-static mat to cover your work surface. Use a conductive wrist strap attached to a good earth ground Always discharge yourself by touching a grounded bare metal surface or approved anti-static mat before picking up an ESD-sensitive electronic component  If working on a prototyping board, use a soldering iron or station that is marked as ESD-safe  Always disconnect the microcontroller from the prototyping board when it is being worked on REVISION HISTORY Revision 1.0 Release Date 2018/12/30 Summary First Release. Unmanaged Gigabit Media Converter ii Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Table of Contents 1. GENERAL DESCRIPTION .................................................................................................................................................... 1 2. FEATURES ................................................................................................................................................................................. 3 3. SYSTEM APPLICATIONS ...................................................................................................................................................... 5 4. APPLICATION EXAMPLES .................................................................................................................................................. 5 4.1. UNMANAGED MEDIA CONVERTER ......................................................................................................................................................... 5 5. BLOCK DIAGRAM .................................................................................................................................................................. 6 6. PIN ASSIGNMENTS ................................................................................................................................................................ 7 6.1. 6.2. 7. PIN DESCRIPTIONS ............................................................................................................................................................... 9 7.1. 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. 7.8. 7.9. 8. MEDIA DEPENDENT INTERFACE PINS ................................................................................................................................................ 9 HIGH SPEED SERIAL INTERFACE PINS ............................................................................................................................................... 9 GENERAL PURPOSE INTERFACES ........................................................................................................................................................ 9 LED PINS ................................................................................................................................................................................................ 9 CONFIGURATION STRAPPING PINS .................................................................................................................................................. 10 MANAGEMENT INTERFACE PINS ..................................................................................................................................................... 11 MISCELLANEOUS PINS ...................................................................................................................................................................... 11 EMBEDDED SWITCH REGULATOR PINS .......................................................................................................................................... 12 POWER AND GND PINS ..................................................................................................................................................................... 12 PHYSICAL LAYER FUNCTIONAL OVERVIEW ........................................................................................................... 13 8.1. 8.2. 8.3. 8.4. 8.5. 8.6. 8.7. 8.8. 8.9. 8.10. 9. PACKAGE IDENTIFICATION .................................................................................................................................................................. 7 PIN ASSIGNMENTS TABLE ................................................................................................................................................................... 8 MDI INTERFACE ................................................................................................................................................................................. 13 1000BASE-T TRANSMIT FUNCTION ............................................................................................................................................... 13 1000BASE-T RECEIVE FUNCTION................................................................................................................................................... 13 100BASE-TX TRANSMIT FUNCTION .............................................................................................................................................. 13 100BASE-TX RECEIVE FUNCTION.................................................................................................................................................. 14 10BASE-T TRANSMIT FUNCTION .................................................................................................................................................... 14 10BASE-T RECEIVE FUNCTION ....................................................................................................................................................... 14 AUTO-NEGOTIATION FOR UTP ........................................................................................................................................................ 14 CROSSOVER DETECTION AND AUTO CORRECTION ..................................................................................................................... 15 POLARITY CORRECTION .................................................................................................................................................................... 15 GENERAL FUNCTION DESCRIPTIONS ......................................................................................................................... 16 9.1. RESET.................................................................................................................................................................................................... 16 9.1.1. Hardware Reset ............................................................................................................................................................................ 16 9.1.2. Software Reset............................................................................................................................................................................... 16 9.2. IEEE 802.3X FULL DUPLEX FLOW CONTROL .............................................................................................................................. 17 9.3. HALF DUPLEX FLOW CONTROL ...................................................................................................................................................... 17 9.3.1. Back-Pressure Mode ................................................................................................................................................................... 17 9.4. SEARCH AND LEARNING ................................................................................................................................................................... 18 9.5. SVL AND IVL/SVL ........................................................................................................................................................................... 18 Unmanaged Gigabit Media Converter iii Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.6. ILLEGAL FRAME FILTERING ............................................................................................................................................................. 18 9.7. IEEE 802.3 RESERVED GROUP ADDRESSES FILTERING CONTROL .......................................................................................... 19 9.8. BROADCAST/MULTICAST/UNKNOWN DA STORM CONTROL ................................................................................................... 20 9.9. PORT SECURITY FUNCTION .............................................................................................................................................................. 20 9.10. MIB COUNTERS .................................................................................................................................................................................. 20 9.11. PORT MIRRORING ............................................................................................................................................................................... 20 9.12. VLAN FUNCTION............................................................................................................................................................................... 21 9.12.1. Port-Based VLAN ................................................................................................................................................................... 21 9.12.2. IEEE 802.1Q Tag-Based VLAN .......................................................................................................................................... 21 9.12.3. Protocol-Based VLAN ........................................................................................................................................................... 21 9.13. QOS FUNCTION ................................................................................................................................................................................... 22 9.13.1. Input Bandwidth Control ...................................................................................................................................................... 22 9.13.2. Priority Assignment ............................................................................................................................................................... 22 9.13.3. Priority Queue Scheduling ................................................................................................................................................... 23 9.13.4. IEEE 802.1p/Q and DSCP Remarking .............................................................................................................................. 23 9.13.5. ACL-Based Priority ............................................................................................................................................................... 23 9.14. IEEE 802.1X FUNCTION ................................................................................................................................................................... 24 9.14.1. Port-Based Access Control .................................................................................................................................................. 24 9.14.2. Authorized Port-Based Access Control ............................................................................................................................. 24 9.14.3. Port-Based Access Control Direction ................................................................................................................................ 24 9.14.4. MAC-Based Access Control ................................................................................................................................................. 24 9.14.5. MAC-Based Access Control Direction .............................................................................................................................. 24 9.14.6. Optional Unauthorized Behavior ....................................................................................................................................... 24 9.15. IEEE 802.1D FUNCTION ................................................................................................................................................................... 25 9.16. REALTEK CABLE TEST (RTCT) ....................................................................................................................................................... 25 9.17. LED INDICATORS ............................................................................................................................................................................... 26 9.18. GREEN ETHERNET .............................................................................................................................................................................. 28 9.18.1. Link-On and Cable Length Power Saving ........................................................................................................................ 28 9.18.2. Link-Down Power Saving..................................................................................................................................................... 28 9.19. REGULATOR ......................................................................................................................................................................................... 28 10. INTERFACE DESCRIPTIONS ............................................................................................................................................ 29 10.1. 10.2. 10.3. 11. MASTER I2C FOR EEPROM AUTO-LOAD .................................................................................................................................... 29 REALTEK SLAVE I2C-LIKE INTERFACE FOR EXTERNAL CPU TO ACCESS THE RTL8213B ................................................ 30 SLAVE MII MANAGEMENT SMI INTERFACE FOR EXTERNAL CPU TO ACCESS RTL8213B .............................................. 31 ELECTRICAL CHARACTERISTICS ................................................................................................................................ 32 11.1. ABSOLUTE MAXIMUM RATINGS...................................................................................................................................................... 32 11.2. RECOMMENDED OPERATING RANGE ............................................................................................................................................. 32 11.3. THERMAL CHARACTERISTICS .......................................................................................................................................................... 33 11.3.1. Assembly Description ............................................................................................................................................................ 33 11.3.2. Material Properties ................................................................................................................................................................ 33 11.3.3. Simulation Conditions ........................................................................................................................................................... 33 11.3.4. Thermal Performance of QFN-56 on PCB Under Still Air Convection.................................................................... 34 11.4. DC CHARACTERISTICS ...................................................................................................................................................................... 34 11.5. SWITCH REGULATOR ......................................................................................................................................................................... 34 11.6. AC CHARACTERISTICS ...................................................................................................................................................................... 35 Unmanaged Gigabit Media Converter iv Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11.6.1. 11.6.2. 11.6.3. 11.6.4. 11.6.5. Master I2C for EEPROM Auto-load Interface Timing Characteristics .................................................................... 35 Slave I2C-like Mode Timing Characteristics ................................................................................................................... 36 Slave MII Management SMI for External CPU Access Interface Timing Characteristics ................................... 37 SGMII/1000Base-X Characteristics .................................................................................................................................. 38 Power and Reset Characteristics ....................................................................................................................................... 40 12. MECHANICAL DIMENSIONS ............................................................................................................................................ 41 13. ORDERING INFORMATION .............................................................................................................................................. 42 Unmanaged Gigabit Media Converter v Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet List of Tables TABLE 1. PIN ASSIGNMENTS TABLE ................................................................................................................................................................... 8 TABLE 2. MEDIA DEPENDENT INTERFACE PINS ............................................................................................................................................... 9 TABLE 3. HIGH SPEED SERIAL INTERFACE PINS............................................................................................................................................... 9 TABLE 4. GENERAL PURPOSE INTERFACES PINS .............................................................................................................................................. 9 TABLE 5. LED PINS ............................................................................................................................................................................................. 10 TABLE 6. CONFIGURATION STRAPPING PINS .................................................................................................................................................. 10 TABLE 7. MANAGEMENT INTERFACE PINS ..................................................................................................................................................... 11 TABLE 8. MISCELLANEOUS PINS ........................................................................................................................................................................... 11 TABLE 9. EMBEDDED SWITCH REGULATOR PINS .............................................................................................................................................. 12 TABLE 10. POWER AND GND PINS ....................................................................................................................................................................... 12 TABLE 11. MEDIA DEPENDENT INTERFACE PIN MAPPING .............................................................................................................................. 15 TABLE 12. RESERVED MULTICAST ADDRESS CONFIGURATION TABLE ........................................................................................................ 19 TABLE 13. LED DEFINITIONS ................................................................................................................................................................................ 26 TABLE 14. SLAVE MII MANAGEMENT SMI ACCESS FORMAT ........................................................................................................................ 31 TABLE 15. ABSOLUTE MAXIMUM RATINGS........................................................................................................................................................ 32 TABLE 16. RECOMMENDED OPERATING RANGE................................................................................................................................................ 32 TABLE 17. ASSEMBLY DESCRIPTION .................................................................................................................................................................... 33 TABLE 18. MATERIAL PROPERTIES ....................................................................................................................................................................... 33 TABLE 19. SIMULATION CONDITIONS .................................................................................................................................................................. 33 TABLE 20. THERMAL PERFORMANCE OF QFN-56 ON PCB UNDER STILL AIR CONVECTION ................................................................. 34 TABLE 21. DC CHARACTERISTICS ........................................................................................................................................................................ 34 TABLE 22. SWITCH REGULATOR ........................................................................................................................................................................... 34 TABLE 23. MASTER I2C FOR EEPROM AUTO-LOAD TIMING CHARACTERISTICS .................................................................................... 35 TABLE 24. SLAVE I2C-LIKE MODE TIMING CHARACTERISTICS ..................................................................................................................... 36 TABLE 25. MDIO TIMING CHARACTERISTICS AND REQUIREMENT .............................................................................................................. 37 TABLE 26. SGMII/1000BASE-X DIFFERENTIAL TRANSMITTER CHARACTERISTICS ................................................................................. 38 TABLE 27. SGMII/1000BASE-X DIFFERENTIAL RECEIVER CHARACTERISTICS ........................................................................................ 39 TABLE 28. POWER AND RESET CHARACTERISTICS ........................................................................................................................................... 40 TABLE 29. ORDERING INFORMATION ................................................................................................................................................................... 42 Unmanaged Gigabit Media Converter vi Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet List of Figures FIGURE 1. UNMANAGED MEDIA CONVERTER ................................................................................................................................................... 5 FIGURE 2. BLOCK DIAGRAM ................................................................................................................................................................................ 6 FIGURE 3. PIN ASSIGNMENTS (QFN-40)............................................................................................................................................................ 7 FIGURE 4. CONCEPTUAL EXAMPLE OF POLARITY CORRECTION................................................................................................................ 15 FIGURE 5. PROTOCOL-BASED VLAN FRAME FORMAT AND FLOW CHART ............................................................................................. 22 FIGURE 6. PULL-UP AND PULL-DOWN OF LED PINS FOR SINGLE-COLOR LED .................................................................................... 27 FIGURE 7. PULL-UP AND PULL-DOWN OF LED PINS FOR BI-COLOR LED ............................................................................................. 27 FIGURE 8. SMI START AND STOP COMMAND ................................................................................................................................................. 29 FIGURE 9. MASTER I2C FOR EEPROM AUTO-LOAD INTERFACE CONNECTION EXAMPLE ................................................................. 29 FIGURE 10. 8-BIT EEPROM SEQUENTIAL READ .............................................................................................................................................. 29 FIGURE 11. REALTEK SLAVE I2C-LIKE FOR EXTERNAL CPU ACCESS INTERFACE CONNECTION EXAMPLE........................................ 30 FIGURE 12. REALTEK SLAVE I2C-LIKE INTERFACE WRITE COMMAND ........................................................................................................ 30 FIGURE 13. REALTEK SLAVE I2C-LIKE INTERFACE READ COMMAND.......................................................................................................... 30 FIGURE 14. SLAVE MII MANAGEMENT SMI INTERFACE CONNECTION EXAMPLE ..................................................................................... 31 FIGURE 15. MASTER I2C FOR EEPROM AUTO-LOAD TIMING CHARACTERISTICS ................................................................................... 35 FIGURE 16. SCK/SDA POWER ON TIMING ......................................................................................................................................................... 35 FIGURE 17. SLAVE I2C-LIKE MODE TIMING CHARACTERISTICS.................................................................................................................... 36 FIGURE 18. MDIO SOURCED BY THE MASTER .................................................................................................................................................. 37 FIGURE 19. MDIO SOURCED BY THE RTL8213B (SLAVE) ............................................................................................................................. 37 FIGURE 20. SGMII/1000BASE-X DIFFERENTIAL TRANSMITTER EYE DIAGRAM ....................................................................................... 38 FIGURE 21. SGMII/1000BASE-X DIFFERENTIAL RECEIVER EYE DIAGRAM .............................................................................................. 39 FIGURE 22. POWER AND RESET CHARACTERISTICS .......................................................................................................................................... 40 Unmanaged Gigabit Media Converter vii Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 1. General Description The RTL8213B-CG is a QFN40, high-performance media converter featuring low-power integrated 1-port Giga-PHY that support 1000Base-T, 100Base-TX, and 10Base-T. For specific applications, the RTL8213B supports one SerDes interface that could be configured as a SGMII/1000Base-X/100FX interface. The RTL8213B integrates a SRAM for packet buffering, nonblocking switch fabric, and internal register management into a single CMOS device. Only a 25MHz crystal is required; an optional EEPROM is offered for internal register configuration. The embedded packet storage SRAM in the RTL8213B features superior memory management technology to efficiently utilize memory space. The RTL8213B integrates a 2048-entry look-up table with a 4-way XOR Hashing algorithm for address searching and learning. The table provides read/write access from the Slave I2C-like serial Interface, or Slave Media Independent Interface Management (MIIM) Interface. Each of the entries can be configured as a static entry. Normal entry aging time is between 200 and 400 seconds. Sixteen Filtering Databases are used to provide Independent VLAN Learning and Shared VLAN Learning (IVL/SVL) functions. The Extension GMAC1 of the RTL8213B implements a 1000Base-X/100Base-FX interface. The RTL8213B supports standard 802.3x flow control frames for full duplex, and optional backpressure for half duplex. It determines when to invoke the flow control mechanism by checking the availability of system resources, including the packet buffers and transmitting queues. The RTL8213B supports broadcast/multicast output dropping, and will forward broadcast/multicast packets to non-blocked ports only. For IP multicast applications, the RTL8213B can forward IPv4 IGMPv1/v2/v3 and IPv6 MLDv1/v2 snooping protocol packets. In order to support flexible traffic classification, the RTL8213B supports 48-entry ACL rule check and multiple actions options. Each port can optionally enable or disable the ACL rule check function. The ACL rule key can be based on packet physical port, Layer2, Layer3, and Layer4 information. When an ACL rule matches, the action taken is configurable to Drop/Permit/Redirect/Mirror, change priority value in 802.1q/Q tag, force output tag format and rate policing. The rate policing mechanism supports from 8Kbps to 1Gbps (in 8Kbps steps). In Bridge operation the RTL8213B supports 16 sets of port configurations: disable, block, learning, and forwarding for Spanning Tree Protocol and Multiple Spanning Tree Protocol. To meet security and management application requirements, the RTL8213B supports IEEE 802.1x Port-based/MAC-based Access Control. A 1-set Port Mirroring function is configured to mirror traffic (RX, TX, or both) appearing on one of the switch’s ports. Support is provided on each port for multiple RFC MIB Counters, for easy debug and diagnostics. To improve real-time and multimedia networking applications, the RTL8213B supports eight priority assignments for each received packet. These are based on (1) Port-based priority; (2) 802.1p/Q VLAN tag priority; (3) DSCP field in IPv4/IPv6 header; and (4) ACL-assigned priority. Each output port supports a weighted ratio of eight priority queues to fit bandwidth requirements in different applications. The input bandwidth control function helps limit per-port traffic utilization. There is one leaky bucket for average packet rate control for each queue of all ports. Queue scheduling algorithm can use Strict Priority (SP) or Weighted Fair Queue (WFQ) or Weighted Round Robin (WRR) or mixed. Unmanaged Gigabit Media Converter 1 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet The RTL8213B provides a 4096-entry VLAN table for 802.1Q port-based, tag-based, and protocol-based VLAN operation to separate logical connectivity from physical connectivity. The RTL8213B supports four Protocol-based VLAN configurations that can optionally select EtherType, LLC, and RFC1042 as the search key. Each port may be set to any topology via EEPROM upon reset, or Slave I2C-like serial Interface, or Slave Media Independent Interface Management (MIIM) Interface after reset. Unmanaged Gigabit Media Converter 2 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 2. Features  Embedded single-port 10/100/1000Base-T PHY  Each port supports full duplex 10/100/1000M connectivity (half duplex only supported in 10/100M mode)   2048-entry MAC address table with 4-way hash algorithm  Up to 2048-entry L2/L3 Filtering Database  Per-port MAC learning limitation  System base MAC learning limitation Extra Interface (Extension GMAC1) supports   SGMII (1.25Gbps) Interface  1000Base-X Interface Supports Spanning configuration  Full-duplex and half-duplex operation with IEEE 802.3x flow control and backpressure  Supports 9216-byte jumbo forwarding at wire speed  Realtek Cable Test (RTCT) function  Supports 48-entry ACL Rules packet length Layer3, and Layer4 information  Actions include mirror, redirect, dropping,  IEEE 802.1s Multiple Spanning Tree with up to 16 Spanning Tree instances  Supports IEEE 802.1x Access Control Protocol  Port-Based Access Control  Supports Auto protection from Denial-of-Service attacks  Supports trap IGMP/MLD packets to external CPU  Supports Quality of Service (QoS) priority adjustment, traffic policing, CVLAN decision, and SVLAN assignment  Supports per port Input Bandwidth Control  Traffic classification based on IEEE 802.1p/Q  Supports five types of user defined ACL rule priority definition, physical Port, IP DSCP field, ACL definition, VLAN based priority, MAC based priority and SVLAN based priority format for 48 ACL rules  Optional per-port enable/disable of ACL function  Eight Priority Queues per port  Optional setting of per-port action to take when ACL mismatch  Per queue flow control Supports IEEE 802.1Q VLAN  Min-Max Scheduling  Supports 4096 VLANs and 32 Extra Enhanced  Strict Priority and Weighted Fair Queue (WFQ), VLANs Weighted Round scheduling  Supports Un-tag definition in each VLAN Protocol-based  Per-port and per-VLAN egress VLAN tagging and un-tagging  Supports IVL, SVL, and IVL/SVL Unmanaged Gigabit Media Converter packet  Supports rate limiting (12 shared meters, with 8kbps granulation)  Supports RFC MIB Counter VLAN  Up to 4 Protocol-based VLAN entries (WRR) rate of each queue decision and Robin  One leaky bucket to constrain the average packet  Supports VLAN policing and VLAN forwarding Tag-based, Behavior  MAC-Based Access Control  Search keys support physical port, Layer2,  Port-based, Port  IEEE 802.1w Rapid Spanning Tree  100FX Interface  Tree  MIB-II (RFC 1213)  Ethernet-Like MIB (RFC 3635)  Interface Group MIB (RFC 2863) 3 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet  RMON (RFC 2819)  Bridge MIB (RFC 1493) protects system from attack by hackers   Bridge MIB Extension (RFC 2674)  Supports Stacking VLAN and Port Isolation with eight Enhanced Filtering Databases  Supports IEEE 802.1ad Stacking VLAN  Supports 64 SVLANs  Supports MAC-based 1:N VLAN   Supports Port Mirror function for one monitor port for multiple mirroring ports  Link-On Cable Length Power Saving  Link-Down Power Saving  Port 3 supports 3 parallel LED outputs  Port 6 supports 2 parallel LED outputs  Supports Slave I2C-like interface or Slave MII Management interface to access configuration register  Supports 2K-byte configuration  Build in 3.3V to 1.1V switch regulator with power MOS  25MHz crystal or 3.3V OSC input  5x5 QFN 40-pin package Security Filtering  Disable learning for each port  Disable learning-table aging for each port  Drop unknown DA for each port  Broadcast/Multicast/Unknown DA storm control Unmanaged Gigabit Media Converter Supports Realtek Green Ethernet features 4 EEPROM space Track ID: xxxx-xxxx-xx for Rev. 1.0 RTL8213B Datasheet 3.  4. System Applications Unmanaged Media converter Application Examples 4.1. Unmanaged Media Converter CPU Address Table MIB Counter Packet Buffer Queue Manager ALE Configuration Slave SMI/ I2C-Like ACL Giga MAC 3 Extension GMAC 1 EEPROM Giga PHY 3 1000Base-X/100Base-FX RJ-45 Jack SFP Figure 1. Unmanaged Gigabit Media Converter Unmanaged Media Converter 5 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 5. Block Diagram RTL8213B Block Diagram UTP Giga-PHY PCS SRAM Controller Queue Managment SGMII (1.25Gbps) Extension GMAC 1 SerDes 1000Base-X/ 100Base-FX SWR P3 GMAC Lookup Engine 3.3V to 1.1V SWR Packet Buffer SRAM Linking Lists 2048 MAC Address Table 4096 VLAN Table LED LED PLL I2C Host SCK/SDA MDC/MDIO 25MHz Crystal Figure 2. Unmanaged Gigabit Media Converter Management Interface Control Registers + MIB Counter Block Diagram 6 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet XTALI XTALO AVDDH GPO52/P3LED0/SMI_SEL GPIO51/P3LED1 GPO50/P3LED2/EN_PHY GPIO48/P6LED0/MID29 GPO45/P6LED1/DISAUTOLOAD DVDDL DVDDIO 30 29 28 27 26 25 24 23 22 21 Pin Assignments GND_SWR P3MDIAP 36 EN_SWR P3MDIAN 37 RTL8213B 15 14 AVDDH P3MDIBP 38 13 HSIN P3MDIBN 39 XXXXXXX GXXXB 12 HSIP AVDDL 40 11 SVDDL QFN40 E-PAD: GND EPAD Size 3.7mm x 3.7mm Figure 3. 10 16 HSOP 35 9 AVDDH HSON LX 8 17 DVDDL 34 7 PLLVDDL AVDDH LX 6 18 AVDDL 33 5 nRESET MDIREF HV_SWR 4 19 P3MDIDN 32 3 SCK P3MDIDP HV_SWR 2 20 P3MDICN 31 1 SDA P3MDICP 6. Package Size 5mm x 5mm Pin Assignments (QFN-40) 6.1. Package Identification Green package is indicated by the ‘G’ in GXXX (Figure 3). Unmanaged Gigabit Media Converter 7 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 6.2. Pin Assignments Table Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; OPU: Output Pin With Pull-Up Resistor; (Typical Value = 75K Ohm) (Typical Value = 75K Ohm) Name P3MDICP P3MDICN P3MDIDP P3MDIDN MDIREF AVDDL AVDDH DVDDL HSON HSOP SVDDL HSIP HSIN AVDDH EN_SWR GND_SWR LX LX HV_SWR HV_SWR Unmanaged Gigabit Media Converter Table 1. Pin Assignments Table Pin Type Name No. 1 AI/O DVDDIO 2 AI/O DVDDL 3 AI/O GPO45/P6LED1/DISAUTOLOAD 4 AI/O GPO48/P6LED0/MID29 5 AO GPO50/P3LED2/EN_PHY 6 AP GPIO51/P3LED1 7 AP GPO52/P3LED0 /SMI_SEL 8 P AVDDH 9 AO XTALO 10 AO XTALI 11 AP SDA/MDIO 12 AI SCK/MDC 13 AI nRESET 14 AP PLLVDDL 15 AI AVDDH 16 AG P3MDIAP 17 AO P3MDIAN 18 AO P3MDIBP 19 AP P3MDIBN 20 AP AVDDL 8 Pin No. 21 22 Type 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 I/OPU I/OPU I/OPU I/OPU I/OPU AP AO AI I/O I/O IPU AP AP AI/O AI/O AI/O AI/O AP Track ID: xxxx-xxxx-xx P P Rev. 1.0 RTL8213B DRAFT Datasheet 7. Pin Descriptions 7.1. Media Dependent Interface Pins Pin Name P3MDIAP/N P3MDIBP/N P3MDICP/N P3MDIDP/N 7.2. High Speed Serial Interface Pins Pin Name HSOP/N HSIP/N Table 2. Media Dependent Interface Pins Drive Pin No. Type Description (mA) 36 AI/O 10 Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted 37 and received on all four pairs. For 100Base-TX and 10Base-T operation, 38 only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs 39 MDIAP/N and MDIBP/N. 1 2 Each of the differential pairs has an internal 100-ohm termination resistor. 3 4 Table 3. High Speed Serial Interface Pins Drive Pin No. Type Description (mA) 10 AO 10 High Speed Serial Output Pins: 125MHz/1.25GHz Differential serial interface to transmit data. Keep floating when unused. 9 12 AI 10 High Speed Serial Input Pins: 125MHz/1.25GHz Differential serial interface to receive data. Keep floating when unused. 13 7.3. General Purpose Interfaces Table 4. Pin No. 23 24 25 26 27 General Purpose Interfaces Pins Other Configuration GPIO Function Strapping GPO45 P6LED1 DISAUTOLOAD GPO48 P6LED0 MID29 GPO50 P3LED2 EN_PHY GPIO51 P3LED1 GPO52 P3LED0 SMI_SEL 7.4. LED Pins The RTL8213B LED Pins work in parallel mode. LED0, LED1, LED2 of Port 3 and LED0, LED1 of Port 6 indicate information that can be defined via register or EEPROM. When the LED pin is pulled low, the LED output polarity will be high active. When the LED pin is pulled high, the LED output polarity will change from high active to low active. See section 9.17 LED Indicators, page 26 for more details. Unmanaged Gigabit Media Converter 9 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Table 5. Pin Name Pin No. Type P3LED2/ GPO50/ EN_PHY P3LED1/ GPIO51 25 I/OPU 26 I/OPU P3LED0/ GPO52/ SMI_SEL P6LED1/ GPO45/ DISAUTOLOAD P6LED0/ GPO48/ MID29 27 I/OPU 23 I/OPU 24 I/OPU LED Pins Drive Description (mA) P3LED2 Output Signal. P3LED2 indicates information is defined by register or EEPROM. See section 9.17 LED Indicators, page 26 for more details. P3LED1 Output Signal. P3LED1 indicates information is defined by register or EEPROM. See section 9.17 LED Indicators, page 26 for more details. P3LED0 Output Signal. P3LED0 indicates information is defined by register or EEPROM. See section 9.17 LED Indicators, page 26 for more details. P6LED1 Output Signal. P6LED1 indicates information is defined by register or EEPROM. See section 9.17 LED Indicators, page 26 for more details. P6LED0 Output Signal. P6LED0 indicates information is defined by register or EEPROM. See section 9.17 LED Indicators, page 26 for more details. 7.5. Configuration Strapping Pins Pin Name DISAUTOLOAD/ GPO45/ P6LED1 MID29/ GPO48/ P6LED0 EN_PHY/ GPO50/ P3LED2 Table 6. Configuration Strapping Pins Pin No. Type Description 23 I/OPU Disable EEPROM Autoload. Pull Up: Disable EEPROM autoload Pull Down: Enable EEPROM autoload Note 1: This pin must be kept floating, or pulled high or low via an external 4.7k ohm resistor upon power on or reset. When this pin is pulled low, the LED output polarity will be high active. When this pin is pulled high, the LED output polarity will change from high active to low active. See section 9.17 LED Indicators, page 26 for more details. 24 I/OPU Slave SMI (MDC/MDIO) Device Address. Pull Up: Slave SMI (MDC/MDIO) Device Address is d’29 Pull Down: Slave SMI (MDC/MDIO) Device Address is 0 Note: This pin must be kept floating, or pulled high or low via an external 4.7k ohm resistor upon power on or reset. 25 I/OPU Enable Embedded PHY. Pull Up: Enable embedded PHY Pull Down: Disable embedded PHY Note: This pin must be kept floating, or pulled high or low via an external 4.7k ohm resistor upon power on or reset. When this pin is pulled low, the LED output polarity will be high active. When this pin is pulled high, the LED output polarity will change from high active to low active. See section 9.17 LED Indicators, page 26 for more details. Unmanaged Gigabit Media Converter 10 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Pin Name SMI_SEL/ GPO52/ P3LED0 Pin No. Type Description 27 I/OPU Slave I2C-like/Slave MII Management Interface Selection. Pull Up: Slave I2C-like interface Pull Down: Slave MII Management interface Note: This pin must be kept floating, or pulled high or low via an external 4.7k ohm resistor upon power on or reset. When this pin is pulled low, the LED output polarity will be high active. When this pin is pulled high, the LED output polarity will change from high active to low active. See section 9.17 LED Indicators, page 26 for more details. 7.6. Management Interface Pins Pin Name SCK/ MDC SDA/ MDIO Table 7. Management Interface Pins Pin No. Type Description 32 I/O Master I2C Interface Clock for EEPROM auto-download. Slave I2C Interface Clock for external CPU to access DUT. Slave MII Management Interface Clock (selected via the hardware strapping SMI_SEL). 31 I/O Master I2C Interface Data for EEPROM auto-download. Slave I2C Interface Data for external CPU to access DUT. Slave MII Management Interface Data (selected via the hardware strapping SMI_SEL). 7.7. Miscellaneous Pins Pin Name MDIREF GPO45/ P6LED1/ DISAUTOLOAD GPO48/ P6LED0/ MID29 GPO50/ P3LED2/ EN_PHY GPIO51/ P3LED1 GPO52/ P3LED0/ SMI_SEL XTALO 23 Table 8. Miscellaneous Pins Type Description AO Reference Resistor. A 2.49K ohm (1%) resistor must be connected between MDIREF and GND. I/OPU General Purpose Output Interface IO45. 24 I/OPU General Purpose Output Interface IO48. 25 I/OPU General Purpose Output Interface IO50. 26 I/OPU General Purpose Input/Output Interface IO51. 27 I/OPU General Purpose Output Interface IO52. Pin No. 5 29 AO Unmanaged Gigabit Media Converter 25MHz Crystal Clock Output Pin. 11 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Pin Name XTALI nRESET Pin No. 30 33 Type Description AI 25MHz Crystal Clock Input Pin. 25MHz +/-50ppm tolerance crystal reference. When using a crystal, connect a loading capacitor between crystal pin and ground. When either using an oscillator or driving an external 25MHz clock from another device, XTALO should kept floating. IPU System Reset Input Pin. When low active will reset the RTL8213B-CG. 7.8. Embedded Switch Regulator Pins Pin Name EN_SWR GND_SWR Pin No. 15 16 Table 9. Embedded Switch Regulator Pins Type Description AI Enable embedded switch regulator. Pull Up: Enable embedded switch regulator. Pull Down: Disable embedded switch regulator. Note: pulled high or low via an external 4.7k ohm resistor to enable or disable embedded switch regulator. AG Regulator Ground. LX 17, 18 AO Regulator output. It should connect to the external inductor. HV_SWR 19, 20 AP Regulator Power Supply Input. 7.9. Power and GND Pins Pin Name DVDDIO Pin No. 21 DVDDL AVDDH AVDDL SVDDL PLLVDDL GND 8, 22 7, 14, 28, 35 6, 40 11 34 E-PAD Unmanaged Gigabit Media Converter Table 10. Power and GND Pins Type Description P Digital I/O High Voltage Power for LED, Management Interface, and nRESET. P Digital Low Voltage Power. AP Analog High Voltage Power. AP Analog Low Voltage Power. AP SerDes Low Voltage Power. AP PLL Low Voltage Power. G GND. 12 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 8. Physical Layer Functional Overview 8.1. MDI Interface The RTL8213B embeds Single10/100/1000M Ethernet PHYs in one chip. Each port uses a single common MDI interface to support 1000Base-T, 100Base-TX, and 10Base-T. This interface consists of four signal pairs-A, B, C, and D. Each signal pair consists of two bi-directional pins that can transmit and receive at the same time. The MDI interface has internal termination resistors, and therefore reduces BOM cost and PCB complexity. For 1000Base-T, all four pairs are used in both directions at the same time. For 10/100 links and during auto-negotiation, only pairs A and B are used. 8.2. 1000Base-T Transmit Function The 1000Base-TX transmit function performs 8B/10B coding, scrambling, and 4D-PAM5 encoding. These code groups are passed through a waveform-shaping filter to minimize EMI effects, and are transmitted onto 4-pair CAT5 cable at 125MBaud/s through a D/A converter. 8.3. 1000Base-T Receive Function Input signals from the media pass through the sophisticated on-chip hybrid circuit to subtract the transmitted signal from the input signal for effective reduction of near-end echo. The received signal is then processed with state-of-the-art technology, e.g., adaptive equalization, BLW (Baseline Wander) correction, cross-talk cancellation, echo cancellation, timing recovery, error correction, and 4D-PAM5 decoding. The 8-bit-wide data is recovered and is sent to the GMII interface at a clock speed of 125MHz. The RX MAC retrieves the packet data from the internal receive MII/GMII interface and sends it to the packet buffer manager. 8.4. 100Base-TX Transmit Function The 100Base-TX transmit function performs parallel to serial conversion, 4B/5B coding, scrambling, NRZ/NRZI conversion, and MLT-3 encoding. The 5-bit serial data stream after 4B/5B coding is then scrambled as defined by the TP-PMD Stream Cipher function to flatten the power spectrum energy such that EMI effects can be reduced significantly. The scrambled seed is based on PHY addresses and is unique for each port. After scrambling, the bit stream is driven onto the network media in the form of MLT-3 signaling. The MLT-3 multi-level signaling technology moves the power spectrum energy from high frequency to low frequency, which also reduces EMI emissions. Unmanaged Gigabit Media Converter 13 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 8.5. 100Base-TX Receive Function The receive path includes a receiver composed of an adaptive equalizer and DC restoration circuits (to compensate for an incoming distorted MLT-3 signal), an MLT-3 to NRZI and NRZI to NRZ converter to convert analog signals to digital bit-stream, and a PLL circuit to clock data bits with minimum bit error rate. A de-scrambler, 5B/4B decoder, and serial-to-parallel conversion circuits are followed by the PLL circuit. Finally, the converted parallel data is fed into the MAC. 8.6. 10Base-T Transmit Function The output 10Base-T waveform is Manchester-encoded before it is driven onto the network media. The internal filter shapes the driven signals to reduce EMI emissions, eliminating the need for an external filter. 8.7. 10Base-T Receive Function The Manchester decoder converts the incoming serial stream to NRZ data when the squelch circuit detects the signal level is above squelch level. 8.8. Auto-Negotiation for UTP The RTL8213B obtains the states of duplex, speed, and flow control ability for each port in UTP mode through the auto-negotiation mechanism defined in the IEEE 802.3 specifications. During auto-negotiation, each port advertises its ability to its link partner and compares its ability with advertisements received from its link partner. By default, the RTL8213B advertises full capabilities (1000Full, 100Full, 100Half, 10Full, 10Half) together with flow control ability. Unmanaged Gigabit Media Converter 14 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 8.9. Crossover Detection and Auto Correction The RTL8213B automatically determines whether or not it needs to crossover between pairs (see Table 11) so that an external crossover cable is not required. When connecting to another device that does not perform MDI crossover, when necessary, the RTL8213B automatically switches its pin pairs to communicate with the remote device. When connecting to another device that does have MDI crossover capability, an algorithm determines which end performs the crossover function. The crossover detection and auto correction function can be disabled via register configuration. The pin mapping in MDI and MDI Crossover mode is given below. Pairs A B C D 1000Base-T A B C D Table 11. Media Dependent Interface Pin Mapping MDI MDI Crossover 100Base-TX 10Base-T 1000Base-T 100Base-TX TX TX B RX RX RX A TX Unused Unused D Unused Unused Unused C Unused 10Base-T RX TX Unused Unused 8.10. Polarity Correction The RTL8213B automatically corrects polarity errors on the receiver pairs in 1000Base-T and 10Base-T modes. In 100Base-TX mode, the polarity is irrelevant. In 1000Base-T mode, receive polarity errors are automatically corrected based on the sequence of idle symbols. Once the de-scrambler is locked, the polarity is also locked on all pairs. The polarity becomes unlocked only when the receiver loses lock. In 10Base-T mode, polarity errors are corrected based on the detection of valid spaced link pulses. The detection begins during the MDI crossover detection phase and locks when the 10Base-T link is up. The polarity becomes unlocked when the link is down. RTL8213B Link Partner + RX _ + _ TX + TX _ _ + Figure 4. Unmanaged Gigabit Media Converter + _ RX Conceptual Example of Polarity Correction 15 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9. General Function Descriptions 9.1. Reset 9.1.1. Hardware Reset In a power-on reset, an internal power-on reset pulse is generated and the RTL8213B will start the reset initialization procedures. These are:  Determine various default settings via the hardware strap pins at the end of the nRESET signal  Auto-load the configuration from EEPROM if EEPROM is detected  Complete the embedded SRAM BIST process  Initialize the packet buffer descriptor allocation  Initialize the internal registers and prepare them to be accessed by the external CPU 9.1.2. Software Reset The RTL8213B supports two software resets; a chip reset and a soft reset. 9.1.2.1 CHIP_RESET When CHIP_RESET is set to 0b1 (write and self-clear), the chip will take the following steps: 1. Download configuration from strap pin and EEPROM 2. Start embedded SRAM BIST (Built-In Self Test) 3. Clear all the Lookup and VLAN tables 4. Reset all registers to default values 5. Restart the auto-negotiation process 9.1.2.2 SOFT_RESET When SOFT_RESET is set to 0b1 (write and self-clear), the chip will take the following steps: 1. Clear the FIFO and re-start the packet buffer link list 2. Restart the auto-negotiation process Unmanaged Gigabit Media Converter 16 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.2. IEEE 802.3x Full Duplex Flow Control The RTL8213B supports IEEE 802.3x flow control in 10/100/1000M modes. Flow control can be decided in two ways:  When Auto-Negotiation is enabled, flow control depends on the result of NWay  When Auto-Negotiation is disabled, flow control depends on register definition 9.3. Half Duplex Flow Control In half duplex mode, the CSMA/CD media access method is the means by which two or more stations share a common transmission medium. To transmit, a station waits (defers) for a quiet period on the medium (that is, no other station is transmitting) and then sends the intended message in bit-serial form. If the message collides with that of another station, then each transmitting station intentionally transmits for an additional predefined period to ensure propagation of the collision throughout the system. The station remains silent for a random amount of time (backoff) before attempting to transmit again. When a transmission attempt has terminated due to a collision, it is retried until it is successful. The scheduling of the retransmissions is determined by a controlled randomization process called ‘Truncated Binary Exponential Backoff’. At the end of enforcing a collision (jamming), the switch delays before attempting to retransmit the frame. The delay is an integer multiple of slot time (512 bit times). The number of slot times to delay before the nth retransmission attempt is chosen as a uniformly distributed random integer ‘r’ in the range: 0 ≤ r < 2k where: k = min (n, backoffLimit). The backoffLimit for the RTL8213B is 9. The half duplex back-off algorithm in the RTL8213B does not have the maximum retry count limitation of 16 (as defined in IEEE 802.3). This means packets in the switch will not be dropped if the back-off retry count is over 16. 9.3.1. Back-Pressure Mode In Back-Pressure mode, the RTL8213B sends a 4-byte jam pattern (data=0xAA) to collide with incoming packets when congestion control is activated. The Jam pattern collides at the fourth byte counted from the preamble. The RTL8213B supports 48PASS1, which receives one packet after 48 consecutive jam collisions (data collisions are not included in the 48). Enable this function to prevent port partition after 63 consecutive collisions (data collisions + consecutive jam collisions). Unmanaged Gigabit Media Converter 17 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.4. Search and Learning Search When a packet is received, the RTL8213B uses the destination MAC address, Filtering Identifier (FID) and Enhanced Filtering Identifier (EFID) to search the 2048-entry look-up table. The 48-bit MAC address, 4bit FID and 3-bit EFID use a hash algorithm, to calculate an 11-bit index value. The RTL8213B uses the index to compare the packet MAC address with the entries (MAC addresses) in the look-up table. This is the ‘Address Search’. If the destination MAC address is not found, the switch will broadcast the packet according to VLAN configuration. Learning The RTL8213B uses the source MAC address, FID, and EFID of the incoming packet to hash into a 9-bit index (4-entry). It then compares the source MAC address with the data (MAC addresses) in this index. If there is a match with one of the entries, the RTL8213B will update the entry with new information. If there is no match and the 4 entries are not all occupied by other MAC addresses, the RTL8213B will record the source MAC address and ingress port number into an empty entry. This process is called ‘Learning’. Address aging is used to keep the contents of the address table correct in a dynamic network topology. The look-up engine will update the time stamp information of an entry whenever the corresponding source MAC address appears. An entry will be invalid (aged out) if its time stamp information is not refreshed by the address learning process during the aging time period. The aging time of the RTL8213B is between 200 and 400 seconds (typical is 300 seconds). 9.5. SVL and IVL/SVL The RTL8213B supports a 16-group Filtering Identifier (FID) for L2 search and learning. In default operation, all VLAN entries belong to the same FID. This is called Shared VLAN Learning (SVL). If VLAN entries are configured to different FIDs, then the same source MAC address with multiple FIDs can be learned into different look-up table entries. This is called Independent VLAN Learning and Shared VLAN Learning (IVL/SVL). 9.6. Illegal Frame Filtering Illegal frames such as CRC error packets, runt packets (length maximum length) will be discarded by the RTL8213B. The maximum packet length may be set from 1518 bytes to 16K bytes. Unmanaged Gigabit Media Converter 18 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.7. IEEE 802.3 Reserved Group Addresses Filtering Control The RTL8213B supports the ability to drop/forward IEEE 802.3 specified reserved group MAC addresses: 01-80-C2-00-00-00 to 01-80-C2-00-00-2F. The default setting enables forwarding of these reserved group MAC address control frames. Frames with group MAC address 01-80-C2-00-00-01 (802.3x Pause) will always be filtered. Table 12 shows the Reserved Multicast Address (RMA) configuration mode from 0180-C2-00-00-00 to 01-80-C2-00-00-2F. Table 12. Reserved Multicast Address Configuration Table Assignment Value Bridge Group Address 01-80-C2-00-00-00 IEEE Std 802.3, 1988 Edition, Full Duplex PAUSE Operation 01-80-C2-00-00-01 IEEE Std 802.3ad Slow Protocols-Multicast Address 01-80-C2-00-00-02 IEEE Std 802.1X PAE Address 01-80-C2-00-00-03 Provider Bridge Group Address 01-80-C2-00-00-08 Undefined 802.1 Address 01-80-C2-00-00-04 ~ 01-80-C2-00-00-07 & 01-80-C2-00-00-09 ~ 01-80-C2-00-00-0C & 01-80-C2-00-00-0F Provider Bridge MVRP Address 01-80-C2-00-00-0D IEEE Std 802.1AB Link Layer Discovery Protocol Address 01-80-C2-00-00-0E All LANs Bridge Management Group Address 01-80-C2-00-00-10 Load Server Generic Address Loadable Device Generic Address Undefined 802.1 Address 01-80-C2-00-00-11 01-80-C2-00-00-12 01-80-C2-00-00-13 ~ 01-80-C2-00-00-17 & 01-80-C2-00-00-19 & 01-80-C2-00-00-1B ~ 01-80-C2-00-00-1F 01-80-C2-00-00-18 01-80-C2-00-00-1a 01-80-C2-00-00-20 01-80-C2-00-00-21 01-80-C2-00-00-22 | 01-80-C2-00-00-2F 01-00-0C-CC-CC-CC 01-00-0C-CC-CC-CD (01:80:c2:00:00:0e or 01:80:c2:00:00:03 or 01:80:c2:00:00:00) && ethertype = 0x88CC Generic Address for All Manager Stations Generic Address for All Agent Stations GMRP Address GVRP Address Undefined GARP Address CDP (Cisco Discovery Protocol) CSSTP (Cisco Shared Spanning Tree Protocol) LLDP Unmanaged Gigabit Media Converter 19 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.8. Broadcast/Multicast/Unknown DA Storm Control The RTL8213B enables or disables per-port broadcast/multicast/unknown DA storm control by setting registers (default is disabled). After the receiving rate of broadcast/multicast/unknown DA packets exceeds a reference rate (number of Kbps per second or number of packets per second), all other broadcast/multicast/unknown DA packets will be dropped. The reference rate is set via register configuration. 9.9. Port Security Function The RTL8213B supports three types of security function to prevent malicious attacks:    Per-port enable/disable SA auto-learning for an ingress packet Per-port enable/disable look-up table aging update function for an ingress packet Per-port enable/disable drop all unknown DA packets 9.10. MIB Counters The RTL8213B supports a set of counters to support management functions.   MIB-II (RFC 1213) Ethernet-Like MIB (RFC 3635)    Interface Group MIB (RFC 2863) RMON (RFC 2819) Bridge MIB (RFC 1493)  Bridge MIB Extension (RFC 2674) 9.11. Port Mirroring The RTL8213B supports one set of port mirroring functions for all ports. The TX, or RX, or both TX/RX packets from multiple mirrored port can be mirrored to one monitor port. Unmanaged Gigabit Media Converter 20 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.12. VLAN Function The RTL8213B supports 4096 VLAN groups. These can be configured as port-based VLANs, IEEE 802.1Q tag-based VLANs, and Protocol-based VLANs. Two ingress-filtering and egress-filtering options provide flexible VLAN configuration: Ingress Filtering   The acceptable frame type of the ingress process can be set to ‘Admit All’, ‘Admit only Untagged’ or ‘Admit only Tagged’ ‘Admit’ or ‘Discard’ frames associated with a VLAN for which that port is not in the member set Egress Filtering   ‘Forward’ or ‘Discard’ Leaky VLAN frames between different VLAN domains ‘Forward’ or ‘Discard’ Multicast VLAN frames between different VLAN domains The VLAN tag can be inserted or removed at the output port. The RTL8213B will insert a Port VID (PVID) for untagged frames, or remove the tag from tagged frames. The RTL8213B also supports a special insert VLAN tag function to separate traffic from the WAN and LAN sides in Router and Gateway applications. 9.12.1. Port-Based VLAN This default configuration of the VLAN function can be modified via an attached Slave I2C-like serial Interface, or Slave Media Independent Interface Management (MIIM) Interface. The 4096-entry VLAN Table designed into the RTL8213B provides full flexibility for users to configure the input ports to associate with different VLAN groups. Each input port can join with more than one VLAN group. Port-based VLAN mapping is the simplest implicit mapping rule. Each ingress packet is assigned to a VLAN group based on the input port. It is not necessary to parse and inspect frames in real-time to determine their VLAN association. All the packets received on a given input port will be forwarded to this port’s VLAN members. 9.12.2. IEEE 802.1Q Tag-Based VLAN The RTL8213B supports 4096 VLAN entries to perform 802.1Q tag-based VLAN mapping. In 802.1Q VLAN mapping, the RTL8213B uses a 12-bit explicit identifier in the VLAN tag to associate received packets with a VLAN. The RTL8213B compares the explicit identifier in the VLAN tag with the 4096 VLAN Table to determine the VLAN association of this packet, and then forwards this packet to the member set of that VLAN. Two VIDs are reserved for special purposes. One of them is all 1’s, which is reserved and currently unused. The other is all 0’s, which indicates a priority tag. A priority-tagged frame should be treated as an untagged frame. Two VLAN ingress filtering functions are supported in registers by the RTL8213B. One is the ‘VLAN tag admit control, which provides the ability to receive VLAN-tagged frames only. Untagged or priority tagged (VID=0) frames will be dropped. The other is ‘VLAN member set ingress filtering’, which will drop frames if the ingress port is not in the member set. 9.12.3. Protocol-Based VLAN The RTL8213B supports a 4-group Protocol-based VLAN configuration. The packet format can be RFC 1042, LLC, or Ethernet, as shown in Figure 5. There are 4 configuration tables to assign the frame type and Unmanaged Gigabit Media Converter 21 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet corresponding field value. Taking IP packet configuration as an example, the user can configure the frame type to be ‘Ethernet’, and value to be ‘0x0800’. Each table will index to one of the entries in the 4096-entry VLAN table. The packet stream will match the protocol type and the value will follow the VLAN member configuration of the indexed entry to forward the packets. Ethernet DA/SA TYPE …… RFC_1042 DA/SA Length AA- AA-03 00-00-00 LLC_Other DA/SA Length DSAP/SSAP …… TYPE …… Frame Input Type/Length is 00-00~05-FF? No 6 bytes after Type/Length are AA-AA-03-00-00-00? No Frame Type = Ethernet Frame Type = LLC_ Other Frame Type = RFC_1042 Figure 5. Protocol-Based VLAN Frame Format and Flow Chart 9.13. QoS Function The RTL8213B supports 8 priority queues and input bandwidth control. Packet priority selection can depend on Port-based priority, 802.1p/Q Tag-based priority, IPv4/IPv6 DSCP-based priority, and ACLbased priority. When multiple priorities are enabled in the RTL8213B, the packet’s priority will be assigned based on the priority selection table. Each queue has one leaky bucket for Average Packet Rate. Per-queue in each output port can be set as Strict Priority (SP) or Weighted Round Robin (WRR), or Weighted Fair Queue (WFQ) for packet scheduling algorithm. 9.13.1. Input Bandwidth Control Input bandwidth control limits the input bandwidth. When input traffic is more than the RX Bandwidth parameter, this port will either send out a ‘pause ON’ frame, or drop the input packet depending on register setup. Per-port input bandwidth control rates can be set from 8Kbps to 1Gbps (in 8Kbps steps). 9.13.2. Priority Assignment Priority assignment specifies the priority of a received packet according to various rules. The RTL8213B can recognize the QoS priority information of incoming packets to give a different egress service priority. Unmanaged Gigabit Media Converter 22 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet The RTL8213B identifies the priority of packets based on several types of QoS priority information:  Port-based priority  802.1p/Q-based priority   IPv4/IPv6 DSCP-based priority ACL-based priority   VLAN-based priority MAC-based priority  SVLAN-based priority 9.13.3. Priority Queue Scheduling The RTL8213B supports MAX-MIN packet scheduling. Packet scheduling offers two modes:  Average Packet Rate (APR) leaky bucket, which specifies the average rate of one queue  Weighted Fair Queue (WFQ), which decides which queue is selected in one slot time to guarantee the minimal packet rate of one queue Weighted Round Robin (WRR)  In addition, each queue of each port can select Strict Priority or WFQ or WRR packet scheduling according to packet scheduling mode. 9.13.4. IEEE 802.1p/Q and DSCP Remarking The RTL8213B supports the IEEE 802.1p/Q and IP DSCP (Differentiated Services Code Point) remarking function. When packets egress from one of the 8 queues, the packet’s 802.1p/Q priority and IP DSCP can optionally be remarked to a configured value. 802.1p/Q priority & IP DSCP value can be remarked based on internal priority or original 802.1p/Q priority & IP DSCP value in packets. 9.13.5. ACL-Based Priority The RTL8213B supports 48-entry ACL (Access Control List) rules. When a packet is received, its physical port, Layer2, Layer3, and Layer4 information are recorded and compared to ACL entries. If a received packet matches multiple entries, the entry with the lowest address is valid. If the entry is valid, the action bit will be applied to which related action bit is enable. If a packet hits an ACL rule and the priority action bit is ‘enable’, then this packet gets a 3-bit ACL-priority from the ACL module. Unmanaged Gigabit Media Converter 23 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.14. IEEE 802.1x Function The RTL8213B supports IEEE 802.1x Port-based/MAC-based Access Control.  Port-Based Access Control for each port  Authorized Port-Based Access Control for each port    Port-Based Access Control Direction for each port MAC-Based Access Control for each port MAC-Based Access Control Direction  Optional Unauthorized Behavior 9.14.1. Port-Based Access Control Each port of the RTL8213B can be set to 802.1x port-based authenticated checking function usage and authorized status. Ports with 802.1X unauthorized status will drop received/transmitted frames. 9.14.2. Authorized Port-Based Access Control If a dedicated port is set to 802.1x port-based access control, and passes the 802.1x authorization, then its port authorization status can be set to authorized. 9.14.3. Port-Based Access Control Direction Ports with 802.1X unauthorized status will drop received/transmitted frames only when port authorization direction is ‘BOTH’. If the authorization direction of an 802.1X unauthorized port is IN, incoming frames to that port will be dropped, but outgoing frames will be transmitted. 9.14.4. MAC-Based Access Control MAC-Based Access Control provides authentication for multiple logical ports. Each logical port represents a source MAC address. There are multiple logical ports for a physical port. When a logical port or a MAC address is authenticated, the relevant source MAC address has the authorization to access the network. A frame with a source MAC address that is not authenticated by the 802.1x function will be dropped or trapped to the CPU. 9.14.5. MAC-Based Access Control Direction Unidirectional and Bi-directional control are two methods used to process frames in 802.1x. As the system cannot predict which port the DA is on, a system-wide MAC-based access control direction setup is provided for determining whether receiving or bi-direction should be authorized. If MAC-based access control direction is BOTH, then received frames with unauthenticated SA or unauthenticated DA will be dropped. When MAC-based access control direction is IN, only received frames with unauthenticated SA will be dropped. 9.14.6. Optional Unauthorized Behavior Port-Based Network Access Control and MAC-Based Access Control offer a whole system control to determine unauthorized frame dropping, or trapping to CPU. Unmanaged Gigabit Media Converter 24 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.15. IEEE 802.1D Function When using IEEE 802.1D, the RTL8213B supports 16 sets and four status’ for each port for CPU implementation 802.1D (STP) and 802.1s (MSTP) function:   Disabled: The port will not transmit/receive packets, and will not perform learning Blocking: The port will only receive BPDU spanning tree protocol packets, but will not transmit any packets, and will not perform learning  Learning: The port will receive any packet, including BPDU spanning tree protocol packets, and will perform learning, but will only transmit BPDU spanning tree protocol packets Forwarding: The port will transmit/receive all packets, and will perform learning  The RTL8213B also supports a per-port transmission/reception enable/disable function. Users can control the port state via register. 9.16. Realtek Cable Test (RTCT) The RTL8213B physical layer transceivers use DSP technology to implement the Realtek Cable Test (RTCT) feature. The RTCT function can be used to detect short, open or impedance mismatch in each differential pair. The RTL8213B also provides LED support to indicate test status and results. Unmanaged Gigabit Media Converter 25 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.17. LED Indicators The RTL8213B supports parallel LEDs for each port. Port 3 has three LED indicator pins, LED0, LED1, LED2, and Port 6 has two LED indicator pins, LED0, LED1. Each pin may have different indicator information (defined in Table 13). Refer to section 7.4 LED Pins, page 9 for pin details. LED Status LED_Off Dup/Col Link/Act Spd1000 Spd100 Spd10 Spd1000/Act Spd100/Act Spd10/Act Spd100 (10)/Act Act Table 13. LED Definitions Description LED Output off. Duplex/Collision Indicator. Blinking when collision occurs. Low for full duplex, and high for half duplex mode. Link, Activity Indicator. Low for link established. Link/Act Blinking when the corresponding port is transmitting or receiving. 1000Mbps Speed Indicator. Low for 1000Mbps. 100Mbps Speed Indicator. Low for 100Mbps. 10Mbps Speed Indicator. Low for 10Mbps. 1000Mbps Speed/Activity Indicator. Low for 1000Mbps. Blinking when the corresponding port is transmitting or receiving. 100Mbps Speed/Activity Indicator. Low for 100Mbps. Blinking when the corresponding port is transmitting or receiving. 10Mbps Speed/Activity Indicator. Low for 10Mbps. Blinking when the corresponding port is transmitting or receiving. 10/100Mbps Speed/Activity Indicator. Low for 10/100Mbps. Blinking when the corresponding port is transmitting or receiving. Activity Indicator. Act blinking when the corresponding port is transmitting or receiving. The LED pin also supports pin strapping configuration functions. The PnLED0, PnLED1, and PnLED2 pins are dual-function pins: input operation for configuration upon reset, and output operation for LED after reset. When the pin input is pulled high upon reset, the pin output is active low after reset. When the pin input is pulled down upon reset, the pin output is active high after reset (see Figure 6 and Figure 7). Typical values for pull-up/pull-down resistors are 4.7K. The PnLED1 can be combined with PnLED0 or PnLED2 as a Bi-color LED. The PnLED1 should operate with the same polarity as other Bi-color LED pins. For example:  P3LED1 should pull up upon reset if P3LED1 is combined with P3LED2 as a Bi-color LED, and P3LED2 input is pulled high upon reset. In this configuration, the output of these pins is active low after reset  P3LED1 should be pulled down upon reset if P3LED1 is combined with P3LED2 as a Bi-color LED, and P3LED2 input is pulled down upon reset. In this configuration, the output of these pins is active high after reset Unmanaged Gigabit Media Converter 26 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Pull-Up Pull-Down DVDDIO 4.7K ohm 470 ohm RTL8213B LED Pin 470 ohm 4.7K ohm RTL8213B LED Pin LED Pins Output Active High LED Pins Output Active Low Figure 6. Pull-Up SPD 1000 Pull-Up and Pull-Down of LED Pins for Single-Color LED 4.7K ohm Pull-Down DVDDIO SPD 100 470ohm 470ohm RTL8213B Yellow SPD100 Green RTL8213B Unmanaged Gigabit Media Converter Yellow SPD1000 4.7K ohm Green 4.7K ohm LED Pins Output Active High LED Pins Output Active Low Figure 7. 4.7K ohm Pull-Up and Pull-Down of LED Pins for Bi-Color LED 27 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 9.18. Green Ethernet 9.18.1. Link-On and Cable Length Power Saving The RTL8213B provides link-on and dynamic detection of cable length and dynamic adjustment of power required for the detected cable length. This feature provides high performance with minimum power consumption. 9.18.2. Link-Down Power Saving The RTL8213B implements link-down power saving on a per-port basis, greatly cutting power consumption when the network cable is disconnected. After it detects an incoming signal, it wakes up from link-down power saving and operates in normal mode. 9.19. Regulator The RTL8213B embeds a 3.3V-1.1V switch regulator to simplify the power solution. The 1.1V output power is used for the digital core and analog circuits. Do not use the regulator for other chips, even if the rating is enough. Unmanaged Gigabit Media Converter 28 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet Interface Descriptions 10. 10.1. Master I2C for EEPROM Auto-load The EEPROM interface of the RTL8213B uses the serial I2C bus to read the serial EEPROM. When the RTL8213B is powered up, it drives SCK and SDA to read the configuration data from the EEPROM by strapping configuration. SDA SCK START Figure 8. STOP SMI Start and Stop Command 3.3V NC-1.5K ohm I2C Master SCK EERPOM EEPROM_SCL 3.3V 1.5K ohm SDA EEPROM_SDA 4.7K ohm DISAUTOLOAD Figure 9. 1 CONTROL BYTE S 1 0 1 0 0 0 R/ A 0 W# C (0) K Master I2C for EEPROM Auto-load Interface Connection Example 1 ADDRESS BYTE A C K ADDR[7:0] The 1st DATA BYTE 1 CONTROL BYTE S 1 0 1 0 0 0 R/ A 0 W# C (1) K A C K MSB to LSB ACK by Slave(EEPROM) The 2nd DATA BYTE MSB to LSB ACK by Slave(EEPROM) ACK by Slave(EEPROM) N O A C P K MSB to LSB ACK by Master NOACK by Master Figure 10. 8-Bit EEPROM Sequential Read Unmanaged Gigabit Media Converter 29 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 10.2. Realtek Slave I2C-Like Interface for External CPU to Access the RTL8213B When EEPROM auto-load is complete, the RTL8213B registers can be accessed through SCK and SDA via an external CPU. The device address of the RTL8213B is 0x4. For the start and end of a write/read command, SCK needs one extra clock before/after the start/stop signals. 3.3V 1.5K ohm I2C Slave External CPU S_SCK M_SCL 3.3V 1.5K ohm S_SDA M_SDA 3.3V 4.7K ohm* SMI_SEL Figure 11. Realtek Slave I2C-Like for External CPU Access Interface Connection Example 1 CONTROL BYTE S 1 0 1 1 1 0 R/ A 0 W# C (0) K The 1st ADDRESS BYTE (reg_addr[7:0]) The 2nd ADDRESS BYTE (reg_addr[15:8]) A C K ADDR[7:0] MSB to LSB ACK by Slave The 1st DATA BYTE (write_data[7:0]) A C K ADDR[15:8] MSB to LSB ACK by Slave The 2nd DATA BYTE (write_data[15:8]) MSB to LSB ACK by Slave A C P K A C K MSB to LSB ACK by Slave ACK by Slave Figure 12. Realtek Slave I2C-Like Interface Write Command 1 CONTROL BYTE S 1 0 1 1 1 0 R/ A 0 W# C (1) K The 1st ADDRESS BYTE (reg_addr[7:0]) ADDR[7:0] MSB to LSB ACK by Slave ACK by Slave The 2nd ADDRESS BYTE (reg_addr[15:8]) A C K ADDR[15:8] The 1st DATA BYTE (read_data[7:0]) A C K The 2nd DATA BYTE (read_data[15:8]) A C K MSB to LSB MSB to LSB MSB to LSB ACK by Master ACK by Slave N O A C P K NOACK by Master Figure 13. Realtek Slave I2C-Like Interface Read Command Unmanaged Gigabit Media Converter 30 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 10.3. Slave MII Management SMI Interface for External CPU to Access RTL8213B The RTL8213B registers can be accessed via Slave MDC and MDIO via an external CPU (Decided by Strapping Configuration). SMI Slave 33 ohm S_MDC External CPU M_MDC 3.3V 1.5K ohm S_MDIO M_MDIO 4.7K ohm SMI_SEL Figure 14. Slave MII Management SMI Interface Connection Example Table 14. Slave MII Management SMI Access Format Management Frame Fields PRE ST OP DEVAD REGAD TA DATA IDLE 1…1 01 10 AAAAA RRRRR Z0 DDDDDDDDDDDDDDDD Z Read 1…1 01 01 AAAAA RRRRR 10 DDDDDDDDDDDDDDDD Z Write Note: By default the Slave needs no less than 32bit Preambles (PRE) before accessing the slave via the Slave SMI interface. An external CPU can configure the Slave to enable the preamble suppression function. When preamble suppression is enabled the Slave does not need preamble before accessing the slave. Unmanaged Gigabit Media Converter 31 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11. Electrical Characteristics 11.1. Absolute Maximum Ratings WARNING: Absolute maximum ratings are limits beyond which permanent damage may be caused to the device, or device reliability will be affected. All voltages are specified reference to GND unless otherwise specified. Table 15. Absolute Maximum Ratings Parameter Min Junction Temperature (Tj) Storage Temperature -45 DVDDIO, AVDDH, HV_SWR Supply Referenced to GND, GND-0.3 AGND, and GND_SWR DVDDL, AVDDL, SVDDL, PLLVDDL Supply Referenced to GND-0.3 GND, AGND, and GND_SWR Digital Input Voltage GND-0.3 Max +125 +125 Units C C +3.63 V +1.21 V VDDIO+0.3 V 11.2. Recommended Operating Range Table 16. Recommended Operating Range Parameter Min Typical Ambient Operating Temperature (Ta) 0 DVDDIO Supply Voltage Range 3.135 3.3 AVDDH and HV_SWR Supply Voltage Range 3.135 3.3 DVDDL, AVDDL, SVDDL, and PLLVDDL Supply Voltage Range 1.045 1.1 Unmanaged Gigabit Media Converter 32 Max 70 3.465 3.465 1.155 Track ID: xxxx-xxxx-xx Units C V V V Rev. 1.0 RTL8213B DRAFT Datasheet 11.3. Thermal Characteristics 11.3.1. Assembly Description Package PCB Table 17. Assembly Description Type QFN-40 Dimension (L×W) 5×5 mm2 Thickness 0.85 mm PCB Dimension (L×W) 78.1×61.4 mm2 PCB Thickness 1.6 mm 4-Layer: - 1st layer (1oz): 20% coverage of Cu Number of Cu Layer-PCB - 2nd layer (1oz): 80% coverage of Cu - 3rd layer (1oz): 80% coverage of Cu - 4th layer (1oz): 75% coverage of Cu 11.3.2. Material Properties Item Package Die Silver Paste Lead Frame Mold Compound PCB Table 18. Material Properties Material Thermal Conductivity K (W/m-k) Si 147 1033BF 2.5 CDA7025 168 7372 0.9 Cu 400 FR4 0.2 11.3.3. Simulation Conditions Table 19. Simulation Conditions 0.52W 4L (2S2P) / 2L (1S1P) Air Flow = 0m/s Input Power Test Board (PCB) Control Condition Unmanaged Gigabit Media Converter 33 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11.3.4. Thermal Performance of QFN-56 on PCB Under Still Air Convection 4L PCB 2L PCB Table 20. Thermal Performance of QFN-56 on PCB Under Still Air Convection θJA θJB θJC 30.9 6.59 15.4 42.2 7.93 17.6 ΨJT 0.30 0.42 Note: θJA: Junction to ambient thermal resistance θJB: Junction to board thermal resistance θJC: Junction to case thermal resistance ΨJT: Junction-to-top-center thermal characterization parameter 11.4. DC Characteristics Table 21. DC Characteristics SYM Min Typical Max System Idle (All UTP Ports Link Down, and Extension Port Link Down, without LEDs) 13 Power Supply Current for VDDH IDVDDIO, IAVDDH Parameter Units mA Power Supply Current for VDDL IDVDDL, IAVDDL, ISVDDL, 132 mA IPLLVDDL 1000M Active (All UTP Ports 1000M Link/Active, and Extension Port Link/Active as 1000Base-X, without LEDs) 70 Power Supply Current for VDDH IDVDDIO, IAVDDH mA Power Supply Current for VDDL IDVDDL, IAVDDL, ISVDDL, 218 mA IPLLVDDL VDDIO=3.3V TTL Input High Voltage Vih 2.0 V TTL Input Low Voltage Vil 0.7 V Output High Voltage Voh 2.7 V Output Low Voltage Vol 0.6 V Note: Power Consumption test condition, DVDDIO=3.3V, AVDDH=3.3V, DVDDL=1.1V, AVDDL=1.1V, SVDDL=1.1V, and PLLVDDL=1.1V. Embedded Switch Regulator disabled. 11.5. Switch Regulator Symbol FSW TSS Parameter Oscillator Frequency Soft-Start Time Unmanaged Gigabit Media Converter Table 22. Switch Regulator Min - 34 Typ 2 1.5 Max - Units MHz ms Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11.6. AC Characteristics 11.6.1. Master I2C Characteristics for EEPROM Auto-load Interface Timing Tsck t1 t2 SCK t3 t4 t5 t6 t7 Data Output SDA Data Output Data Input t8 Data Input t11 Figure 15. Master I2C for EEPROM Auto-load Timing Characteristics t9 nRESET SCK SDA Figure 16. SCK/SDA Power on Timing Symbol Tsck t1 t2 t3 t4 t5 t6 t7 t8 t9 Table 23. Master I2C for EEPROM Auto-load Timing Characteristics Description Type Min Typical SCK Clock Period O 9 SCK High Time O 4.05 4.5 SCK Low Time O 4.05 4.5 START Condition Setup Time O 2 START Condition Hold Time O 2 Data Input Hold Time O 0 Data Input Setup Time O 10 Data output delay O 2.15 STOP Condition Setup Time O 2 SCK/SDA Active from Reset Ready O 76.8 Unmanaged Gigabit Media Converter 35 Max 2.35 - Track ID: xxxx-xxxx-xx Units µs µs µs µs µs µs µs µs µs ms Rev. 1.0 RTL8213B DRAFT Datasheet Symbol t11 - Description Time the bus free before new START SCK Rise Time (10% to 90%) SCK Fall Time (90% to 10%) Duty Cycle Type O O O O Min 10 40 Typical 50 Max 100 100 60 Units µs ns ns % 11.6.2. Slave I2C-like Mode Timing Characteristics t1 t2 SCK t3 SDA t4 t5 Data Input t6 Data Input t7 t8 Data Output Figure 17. Slave I2C-like Mode Timing Characteristics Symbol t1 t2 t3 t4 t5 t6 t7 t8 Table 24. Slave I2C-like Mode Timing Characteristics Description Type Min Typical SCK High Time I 250 SCK Low Time I 250 START Condition Setup Time I 150 START Condition Hold Time I 150 Data Hold Time I 150 Data Setup Time I 150 Clock to Data Output Delay O 10 STOP Condition Setup Time I 150 - Unmanaged Gigabit Media Converter 36 Max 100 - Track ID: xxxx-xxxx-xx Units ns ns ns ns ns ns ns ns Rev. 1.0 RTL8213B DRAFT Datasheet 11.6.3. Slave MII Management SMI for External CPU Access Interface Timing Characteristics The RTL8213B supports MDIO slave mode. The Master (CPU) can access the Slave (RTL8213B) registers via the MDIO interface. The MDIO is a bi-directional signal that can be sourced by the Master or the Slave. In a write command, the master sources the MDIO signal. In a read command, the slave sources the MDIO signal.  The timing characteristics t1, t2, and t3 (Table 25) of the Master (the RTL8213B link partner CPU) are provided by the Master when the Master sources the MDIO signal (Write command)  The timing characteristics t4 (Table 25) of the Slave (RTL8213B) are provided by the RTL8213B when the RTL8213B sources the MDIO signal (Read command) t1 VIH MDC VIL VIH MDIO VIL t2 t3 Figure 18. MDIO Sourced by the Master VIH MDC VIL VIH MDIO VIL t4 Figure 19. MDIO Sourced by the RTL8213B (Slave) Table 25. MDIO Timing Characteristics and Requirement Parameter SYM Description/Condition Type Min MDC Clock Period t1 Clock Period I 125 MDIO to MDC Rising Setup Time t2 Input Setup Time I 8 (Write Data) MDIO to MDC Rising Hold Time t3 Input Hold Time I 8 (Write Data) MDC to MDIO Delay Time (Read t4 Clock (Rising Edge) to Data O 0 Data) Delay Time Unmanaged Gigabit Media Converter 37 Typical - Max - Units ns ns - - ns - 80 ns Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11.6.4. SGMII/1000Base-X Characteristics Table 26. SGMII/1000Base-X Differential Transmitter Characteristics Parameter SYM Min Typ Max Units Notes Unit Interval UI 799.92 800 800.08 ps 800ps ± 100ppm Eye Mask T_X1 0.15 UI Eye Mask T_X2 0.4 UI Eye Mask T_Y1 150 mV Eye Mask T_Y2 600 mV Output Differential Voltage VTX-DIFFp-p 300 700 800 mV Minimum TX Eye Width TTX-EYE 0.7 UI Output Jitter TTX-JITTER 0.3 UI TTX-JITTER-MAX = 1 - TTX-EYE-MIN = 0.30UI Data dependent jitter 0.0875 UI Output Rise Time TTX-RISE 0.125 0.25 UI 20% ~ 80% Output Fall Time TTX-FALL 0.125 0.25 UI 20% ~ 80% Output impedance RTX 40 140 ohm single-end AC Coupling Capacitor CTX 80 100 120 nF Transmit Length in PCB LTX 10 inch - Figure 20. SGMII/1000Base-X Differential Transmitter Eye Diagram Unmanaged Gigabit Media Converter 38 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B Draft Datasheet Table 27. SGMII/1000Base-X Differential Receiver Characteristics Parameter SYM Min Typ Max Units Notes Unit Interval UI 799.92 800 800.08 ps 800ps ± 100ppm Eye Mask R_X1 0.15 UI Eye Mask R_Y1 100 mV Eye Mask R_Y2 600 mV Input Differential Voltage VRX-DIFFp-p 200 1200 mV Minimum RX Eye Width TRX-EYE 0.4 UI Input Jitter Tolerance TRX-JITTER 0.6 UI TRX-JITTER-MAX = 1 - TRX-EYE-MIN = 0.6UI Differential Resistance RRX 80 100 120 ohm - Figure 21. SGMII/1000Base-X Differential Receiver Eye Diagram Unmanaged Gigabit Media Converter 39 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 11.6.5. Power and Reset Characteristics t1 AVDDH Power t2 t4 DVDDIO/ HV_SWR Power 0V 2.7V(+-5%) t5 0.8V(+-5%) LV Power 0V t3 t6 t7 nRESET pin 0V Figure 22. Power and Reset Characteristics Table 28. Power and Reset Characteristics Parameter SYM Description/Condition Type Min Typical AVDDH Rising Time t1 AVDDH power rise settling time I 0.5 HV Power Rising Time t2 DVDDIO, HV_SWR(If embedded I 0.5 SWR be used) power rise settling time LV Power Rising Time t3 DVDDL and AVDDL power rise settling I 0.1 time HV Power Ready Time after t4 The duration from HV power more than I more than HV POR threshold HV POR threshold to HV power ready LV Power Ready Time after t5 The duration from LV power more than I more than LV POR threshold LV POR threshold to LV power ready Reset Delay Time t6 The duration from ‘all power steady’ to I 10 the reset signal released to high Reset Low Time t7 The duration of reset signal remaining I 10 low time before issuing a reset to RTL8213B Note 1: If the powers supply voltage of the RTL8213B lower than normal operation condition happened, Reset (POR) or Pin Reset is needed for normal operation of the RTL8213B. Note 2: DVDDIO power must be ready no later than HV_SWR power if embedded SWR be used. Note 3: AVDDH power must be ready no later than DVDDIO power. Unmanaged Gigabit Media Converter 40 Max - Units ms ms - ms 10 ms 10 ms - ms - ms the Power On Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 12. Mechanical Dimensions Plastic Quad Flat No Lead Package 40 Leads 5x5mm2 Outline Symbol A A1 A3 b D/E D2/E2 e L Min 0.80 0.00 0.15 3.45 0.30 Dimension in mm Nom 0.85 0.02 0.20 REF 0.20 5.00 BSC 3.70 0.40 BSC 0.40 Max 0.90 0.05 Min 0.031 0.000 0.25 0.006 3.75 0.136 0.50 0.012 Dimension in inch Nom 0.033 0.001 0.008 REF 0.008 0.197 BSC 0.146 0.016 BSC 0.016 Max 0.035 0.002 0.010 0.147 0.020 Notes: 1. CONTROLLING DIMENSION:MILLIMETER(mm). 2. REFERENCE DOCUMENTL:JEDEC MO-220. Unmanaged Gigabit Media Converter 41 Track ID: xxxx-xxxx-xx Rev. 1.0 RTL8213B DRAFT Datasheet 13. Ordering Information Table 29. Ordering Information Part Number Package RTL8213B-CG QFN 40-Pin ‘Green’ Package Note: See page 7 for package identification. Status Mass Production Realtek Semiconductor Corp. Headquarters No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan, R.O.C. Tel: 886-3-5780211 Fax: 886-3-5776047 www.realtek.com Unmanaged Gigabit Media Converter 42 Track ID: xxxx-xxxx-xx Rev. 1.0
RTL8213B-CG 价格&库存
很抱歉,暂时无法提供与“RTL8213B-CG”相匹配的价格&库存,您可以联系我们找货
RTL8213B-CG
    • 1+10.62380
    • 10+9.02660
    • 30+8.15540
    • 100+6.81230
    • 490+6.37670
    • 980+6.18310
    库存:10580
    RTL8213B-CG
    • 1+6.95475
    • 10+5.33775
    • 490+5.18100
    库存:600
    RTL8213B-CG
    • 1+9.40940
    • 10+7.98930
    • 30+7.21690
    • 100+6.02130
    • 490+5.63500
    • 980+5.46390
    库存:559
    RTL8213B-CG
    • 1+9.48240
    • 10+8.05680
    • 30+7.27920
    • 100+6.08040
    • 490+5.69160
    • 980+5.51880
    库存:49266
    RTL8213B-CG
    • 1+8.60440
    • 10+7.31080
    • 30+6.60520
    • 100+5.51740
    库存:304
