HTU7G06S0P5P
HTU7G06S0P5P
    WATECH(华太电子)
    SOT89-3
    RF放大器 3.6V SOT89-3
HTU7G06S0P5P 数据手册
Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics LDMOS RF Power Transistor HTU7G06S0P5P 1. Description HTU7G06S0P5P is a MOSFET type transistor specifically designed for VHF/UHF RF Power Amplifier applications. This device has an internal monolithic Zener diode from gate to source for ESD protection. 100-600MHz, 0.5W, 3.6V WIDE BAND RF POWER LDMOS TRANSISTOR 2. Features OUTLINE DRAWING  High power: Mark: H06P5A 4.4 +/-0.1 Pout=0.7W @VDD=4V, f=430MHz 1.6 +/-0.1  High Efficiency: 1.5 +/-0.1 2  Integrated gate protection diode 4.1 +/-0.15 2.5 +/-0.1 ηd=70% @VDD=4V, f=430MHz 1 1 +/-0.1 3. Application  For output stage of high power amplifiers in 2 3 0.4 +0.04 -0.05 1.5 +/-0.1 0.42 +/-0.1 VHF/UHF Band mobile radio sets.  For drive stage of high power amplifiers in Terminal No. 1 : Gate 2 : Source 3 : Drain UNIT:mm Universal Broadband. 4. Absolute Maximum Rarings Parameter Symbol Conditions Ratings Unit Drain to source voltage VDSS Vgs=0V 17 V Gate to source voltage VGSS Vds=0V -5 ~ 10 V Operating Voltage VDD - 8.5 V Storage temperature Tstg - -55 ~ 150 ℃ Operating Junction Temperature TJ - -40 ~ 150 ℃ Thermal resistance Zth(j-c) Junction to case 25 ℃/W © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 1 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 5. Electrical Characteristics Parameter Symbol Conditions Min Typ Max Unit Breakdown Voltage V(BR)DDS VGG=0V, ID=8uA 17 - - V Zero Gate Voltage Drain Leakage Current IDSS VDD=17V, VGG=0V 1 - - uA Gate-Source Leakage Current IGSS VDD=0V, VGG=10V 1 - - uA Gate Threshold Voltage Vth VDD=VGG, Id=8uA 0.5 1.0 1.5 V Output Power Pout - 0.7 - W Drain Efficiency ηd VDD=4V, Pin=0.1W f=430MHz,IDQ=50mA - 70 - % Output Power Pout - 1.5 - W Drain Efficiency ηd VDD=7.2V, Pin=31mW f=530MHz,IDQ=50mA - 73 - % 6. ESD Protection Characteristics Test Methodology Class Human Body Model (per JESD22-A114) 1B Machine Model (per EIA/JESD22-A115) A Charge Device Model (per JESD22-C101) III 7. Load Mismatch(in Huatai Test Fixture) Test Methodology VSWR = 20:1 at all Phase Angles CW: VDD=8.4Vdc, IDQ=50mA, f=435MHz, Pout =32dBm. Results No Device Degradation © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 2 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 8. Typical Characteristics CHANNEL DISSIPATION VS. IDS VS. VGS AMBIENT TEMPERATURE 1.50 On PCB with Heat-sink Ta=+25℃ VDS=4V 1.25 8 1.00 6 IDS (A) CHANNEL DISSIPATION (W) 10 0.75 4 0.50 2 0.25 0.00 0.0 0 0 1.0 20 40 60 80 100 120 140 160 0.5 1.0 1.5 2.0 2.5 AMBIENT TEMPERATURE (℃) VGS (V) IDS VS. VDS Ciss VS.VGS 20 Ta=+25℃ VGS=2.9V 3.0 3.5 4.0 Ta=+25℃ f=1MHz VGS=2.6V 0.8 0.6 Ciss (pF) IDS (A) 15 VGS=2.3V 0.4 10 VGS=2.0V 5 0.2 VGS=1.7V VGS=1.4V 0.0 0 0 5 2 4 6 8 10 0 1 2 3 VDS (V) VGS (V) Crss VS. VDG Coss VS. VDS 15 Ta=+25℃ f=1MHz 4 5 Ta=+25℃ f=1MHz Coss (pF) Crss (pF) 4 3 2 10 5 1 0 0 0 5 10 VDG (V) 15 20 0 5 10 15 20 VDS (V) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 3 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 9. Typical Characteristics @VDD=4V, 400-470MHz 25 70 Pout Gain IDS ηd 20 Ta=+25℃ 15 VDD=4V Pin=20dBm IDQ=50mA 50 10 40 5 30 410 420 430 440 450 0.6 Ta=+25℃ 0.4 Pout IDS ηd VDD=4V Pin=0.1W IDQ=50mA 1.0 80 70 50 ηd (%) Ta=+25℃ f=430MHz Pin=0.1W IDQ=50mA 40 Pout (W), IDS (A) 0.8 60 450 460 4 5 6 7 100 80 0.6 Pout IDS ηd 0.4 8 0.5 1.0 1.5 2.0 2.5 VDD (V) VGG (V) Pout VS. Pin @ f = 400MHz Pout VS. Pin @ f = 400MHz 80 Ta=+25℃ f=400MHz VDD=4V IDQ=50mA 1.0 70 60 Pout Gain IDS ηd 20 15 50 40 10 30 5 20 Pout (W), IDS(A) 0.8 25 10 -5 0 5 10 Pin (dBm) 15 20 40 80 0.6 60 Pout IDS ηd 0.4 0.0 0.00 0 3.0 100 Ta=+25℃ f=400MHz VDD=4V IDQ=50mA 0.2 0 60 20 0.0 0.0 20 3 40 0 470 Ta=+25℃ f=430MHz Pin=0.1W VDD=4V 0.2 30 0.0 30 440 Pout VS. VGG @ f = 430MHz 0.5 35 430 Pout VS. VDD @ f = 430MHz 2.0 1.0 420 f (MHz) 2.5 1.5 410 f (MHz) Pout IDS ηd 60 20 0.0 400 20 470 460 3.0 Pout (dBm), Gain (dB), IDS(A) 80 0.2 0 400 Pout (W), IDS (A) 60 0.8 ηd (%) 80 100 ηd (%) 30 1.0 40 ηd (%) 90 Pout (W), IDS(A) 35 ηd (%) Pout VS. f @ VDD=4V ηd (%) Pout (dBm), Gain (dB), IDS(A) Pout VS. f @ VDD=4V 20 0.02 0.04 0.06 0.08 0 0.10 Pin (W) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 4 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics Pout VS. Pin @ f = 430MHz 60 Pout Gain IDS ηd 20 15 50 40 10 30 5 20 80 0.6 60 Pout IDS ηd 0.4 0.2 0 30 5 10 15 20 0.02 0.04 0.06 Pin (W) Pout VS. Pin @ f = 470MHz Pout VS. Pin @ f = 470MHz 1.0 80 Ta=+25℃ f=470MHz VDD=4V IDQ=50mA 70 0.8 25 60 Pout Gain IDS ηd 20 15 50 40 10 30 5 20 100 Ta=+25℃ f=470MHz VDD=4V IDQ=50mA 80 0.6 60 Pout IDS ηd 0.4 0.2 0 10 -5 0 5 10 Pin (dBm) 15 20 0 0.10 0.08 Pin (dBm) Pout (W), IDS(A) 35 0 40 20 0.0 0.00 10 -5 Pout (dBm), Gain (dB), IDS(A) Pout (W), IDS(A) 0.8 25 ηd (%) 70 100 Ta=+25℃ f=430MHz VDD=4V IDQ=50mA 0.0 0.00 40 ηd (%) Ta=+25℃ f=430MHz VDD=4V IDQ=50mA ηd (%) 30 Pout VS. Pin @ f = 430MHz 1.0 80 ηd (%) Pout (dBm), Gain (dB), IDS(A) 35 20 0.02 0.04 0.06 0.08 0 0.10 Pin (W) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 5 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 10.Test Circuit @VDD=4V, 400-470MHz 400-470MHz (@VDD=4.0V, Idq = 50mA) VDD 8mm VGG C8 C9 C10 L3 C7 C6 C5 8mm 4mm 7mm L2 C4 4mm RF-out R1 C1 5mm 5mm L1 3mm C3 3mm RF-in Q1 C2 Note: The characteristic impedance of all microstrip lines: 50ohm No. Description P/N Manufacturer C1 220pF Chip Ceramic Capacitors GRM1885C1H221JA01 muRata C2 15pF Chip Ceramic Capacitors GRM1885C1H150JA01 muRata C3 15pF Chip Ceramic Capacitors GRM1885C1H150JA01 muRata C4 220pF Chip Ceramic Capacitors GRM1885C1H221JA01 muRata C5 220pF Chip Ceramic Capacitors GRM1885C1H220JA01 muRata C6 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C7 4.7uF Chip Ceramic Capacitors GRM32ER61H474KA12L muRata C8 220pF Chip Ceramic Capacitors GRM1885C1H221JA01 muRata C9 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C10 10uF Chip Ceramic Capacitors GRM32ER61H105KA12L muRata L1 6.8nH Chip Ceramic inductance - - L2 D: 0.31mm, Inside: 1.5mm, 2 Turns Enameled wire - L3 D: 0.3mm, Inside: 1.5mm, 8 Turns Enameled wire - R1 100Ω Chip Resistors - - Q1 RF LDMOS HTU7G06S0P5P Suzhou Huatai Electronics Ltd. PCB Er=4.5 FR4 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 6 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 11.Input/Output Impedance Characteristics @VDD=4V, 400-470MHz Termination 50 ohm Input Matching Network of Test Circuit Output Matching Network of Test Circuit Zsource Termination 50 ohm Zload @Pin=0.1W,VDD=4V,IDQ=50mA f(MHz) Zsource (ohm) 400 11.88 + j 28.26 435 13.56 + j 33.71 470 15.93 + j 38.83 @Pin=0.1W,VDD=4V,IDQ=50mA f(MHz) Zload (ohm) 400 12.25 + j 10.64 435 11.03 + j 14.55 470 10.14 + j 18.41 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 7 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 12.Typical Characteristics @VDD=7.2V, 500-560MHz Pout VS. VGG @ f = 530MHz 1.6 80 2.4 1.4 70 2.1 1.2 Ta=+25℃ Pout IDS ηd Gain VDD=7.2V 1.0 IDQ=50mA 50 40 70 1.8 60 1.5 Pout IDS ηd Gain 1.2 0.9 50 40 0.6 30 0.4 20 0.6 20 0.2 10 0.3 10 0.0 500 510 520 530 540 550 VGG (V) Pout VS. Pin @ f = 530MHz Ta=+25℃ f=530MHz VDD=7.2V IDQ=50mA 4.0 70 3.5 Ta=+25℃ 30 60 25 50 20 40 15 30 Pout Gain IDS ηd 10 5 0 0 3.0 5 10 Pout (W), IDS (A) 35 Pout VS. VDD @ f = 530MHz 80 ηd (%) 40 30 0.0 0 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 0 560 f (MHz) Pout (dBm), Gain (dB), IDS (A) 80 80 70 f=530MHz IDQ=50mA Pin=15dBm(31mW) 2.5 60 50 Pout IDS ηd Gain 2.0 1.5 40 30 20 1.0 20 10 0.5 10 0 0.0 0 3 15 Pin (dBm) ηd (%), Gain (dB) 0.8 Pin=15dBm(31mW) 60 90 Ta=+25℃ f=530MHz VDD=7.2V Pin=15dBm(31mW) ηd (%), Gain (dB) 2.7 Pout (W), IDS (A) 90 ηd (%), Gain (dB) Pout (W), IDS (A) Pout VS. f @ VDD=7.2V 1.8 4 5 6 7 8 9 10 VDD (V) 80 2.1 70 1.8 60 1.5 50 1.2 Ta=+25℃ f=530MHz VDD=7.2V IDQ=50mA 0.9 40 Pout IDS ηd ηd (%) Pout (W), IDS (A) Pout VS. Pin @ f = 530MHz 2.4 30 0.6 20 0.3 10 0.0 0 0 10 20 30 40 50 60 70 Pin (mW) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 8 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 13.Test Circuit @VDD=7.2V, 500-560MHz 500-560MHz (@VDD=7.2V, Idq = 50mA) VDD 8mm VGG C8 C9 C10 L3 C7 C6 C5 8mm 4mm L2 C4 3mm 7mm RF-out R1 C1 5mm 7mm L1 3mm C3 3mm RF-in C2 Note: The characteristic impedance of all microstrip lines: 50ohm No. Description P/N Manufacturer C1 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C2 10pF Chip Ceramic Capacitors GRM1885C1H100JA01 muRata C3 6pF Chip Ceramic Capacitors GRM1885C1H060JA01 muRata C4 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C5 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C6 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C7 4.7uF Chip Ceramic Capacitors GRM32ER61H474KA12L muRata C8 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C9 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C10 10uF Chip Ceramic Capacitors GRM32ER61H105KA12L muRata L1 6.8nH Chip Ceramic inductance - - L2 D: 0.35mm, Inside: 1.5mm, 2 Turns Enameled wire - L3 D: 0.3mm, Inside: 1.5mm, 8 Turns Enameled wire - R1 100Ω Chip Resistors - - Q1 RF LDMOS HTU7G06S0P5P Suzhou Huatai Electronics Ltd. PCB Er=4.5 FR4 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 9 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 14.Input/Output Impedance Characteristics @VDD=7.2V, 500-560MHz Termination 50 ohm Input Matching Network of Test Circuit Output Matching Network of Test Circuit Zsource Termination 50 ohm Zload @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zsource (ohm) 500 70.45 + j 20.79 530 76.29 + j 16.66 560 74.05 + j 16.43 @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zload (ohm) 500 20.66 + j 27.01 530 20.16 + j 31.00 560 20.08 + j 35.28 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 10 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 15. Typical Characteristics @VDD=7.2V, 135-175MHz 90 2.7 1.4 80 2.4 f=135/155/175MHz 1.2 70 IDQ=50mA 0.6 Pin=15dBm(31mW) 50 40 0.4 30 0.2 20 35 150 160 60 1.5 50 1.2 40 Pout IDS ηd Gain 0.9 30 20 10 0.0 0 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 f (MHz) VGG (V) Pout VS. Pin @ f = 135/155/175MHz Pout VS. VDD @ f = 135/155/175MHz Ta=+25℃ f=135/155/175MHz VDD=7.2V IDQ=50mA 30 80 2.7 70 2.4 60 25 50 20 40 15 10 5 30 —— f=135MHz - - - f=155MHz ····· f=175MHz Pout Gain IDS ηd 20 0 2 70 0.3 10 180 170 80 1.8 0.6 4 6 8 10 12 14 16 18 Pout (W), IDS (A) 40 140 VDD=7.2V Pin=15dBm(31mW) 90 —— f=135MHz - - - f=155MHz ····· f=175MHz 80 2.1 70 1.8 60 1.5 Ta=+25℃ f=135/155/175MHz Pout IDS ηd Gain 1.2 IDQ=50mA 0.9 Pin=15dBm(31mW) 50 40 30 0.6 20 10 0.3 10 0 0.0 0 3 20 ηd (%), Gain (dB) Ta=+25℃ 0.8 VDD=7.2V Pout (W), IDS (A) 60 Pout IDS ηd Gain ηd (%), Gain (dB) 1.0 2.1 90 —— f=135MHz - - - f=155MHz - ·- f=175MHz Ta=+25℃ ηd (%), Gain (dB) 1.6 0.0 130 Pout (dBm), Gain (dB), IDS (A) Pout VS. VGG @ f = 135/155/175MHz ηd (%) Pout (W), IDS (A) Pout VS. f @ VDD=7.2V 4 5 6 7 8 9 10 VDD (V) Pin (dBm) 2.4 80 2.1 70 1.8 60 1.5 50 1.2 40 0.9 Ta=+25℃ f=135/155/175MHz VDD=7.2V IDQ=50mA 0.6 —— f=135MHz - - - f=155MHz ····· f=175MHz 0.3 Pout IDS ηd ηd (%) Pout (W), IDS (A) Pout VS. Pin @ f = 135/155/175MHz 30 20 10 0.0 0 10 20 30 40 50 60 70 80 0 90 100 Pin (mW) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 11 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 16.Test Circuit @VDD=7.2V, 135-175MHz 135-175MHz (@VDD=7.2V, Idq = 50mA) VDD 8mm VGG C8 C9 C10 L3 C7 C6 C5 8mm 4mm R1 C1 13mm L1 L2 3mm 2mm 2mm 6mm C4 RF-out C2 C3 3mm RF-in Note: The characteristic impedance of all microstrip lines: 50ohm No. Description P/N Manufacturer C1 470pF Chip Ceramic Capacitors GRM1885C1H471JA01 muRata C2 10pF Chip Ceramic Capacitors GRM1885C1H100JA01 muRata C3 15pF Chip Ceramic Capacitors GRM1885C1H150JA01 muRata C4 470pF Chip Ceramic Capacitors GRM1885C1H471JA01 muRata C5 470pF Chip Ceramic Capacitors GRM1885C1H471JA01 muRata C6 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C7 4.7uF Chip Ceramic Capacitors GRM32ER61H474KA12L muRata C8 470pF Chip Ceramic Capacitors GRM1885C1H471JA01 muRata C9 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C10 10uF Chip Ceramic Capacitors GRM32ER61H105KA12L muRata L1 47nH Chip Ceramic inductance - - L2 D: 0.35mm, Inside: 1.5mm, 3 Turns Enameled wire - L3 D: 0.3mm, Inside: 1.5mm, 8 Turns Enameled wire - R1 100Ω Chip Resistors - - Q1 RF LDMOS HTU7G06S0P5P Suzhou Huatai Electronics Ltd. PCB Er=4.5 FR4 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 12 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 17.Input/Output Impedance Characteristics @VDD=7.2V, 135-175MHz Termination 50 ohm Input Matching Network of Test Circuit Output Matching Network of Test Circuit Zsource Termination 50 ohm Zload @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zsource (ohm) 135 38.34 + j 17.95 155 40.96 + j 21.88 175 42.73 + j 22.86 @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zload (ohm) 135 27.70 + j 5.53 155 24.01 + j 1.02 175 18.70 + j 2.03 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 13 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 18.Typical Characteristics @VDD=7.2V, 880-950MHz 80 2.1 70 2.1 70 1.8 60 1.8 60 1.5 50 1.2 Ta=+25℃ VDD=7.2V IDQ=50mA Pin=15dBm(31mW) 50 Pout IDS ηd Gain 0.9 40 30 1.2 0.9 0.6 20 0.6 0.3 10 0.3 0.0 880 890 900 910 920 930 940 0 2.1 2.4 70 25 60 20 50 15 40 Ta=+25℃ —— f=890MHz f=890/920/940MHz - - - f=920MHz VDD=7.2V ····· f=940MHz IDQ=50mA Pout Gain IDS ηd 0 30 20 6 8 10 12 14 16 80 2.1 70 1.8 60 1.5 1.2 0.9 Ta=+25℃ f=890/920/940MHz IDQ=50mA Pin=15dBm(31mW) Pout IDS ηd Gain Pin (dBm) 40 30 20 0.3 10 0 3 18 50 0.6 0.0 10 4 90 —— f=890MHz - - - f=920MHz ····· f=940MHz 2.4 Pout (W), IDS (A) 30 2.7 ηd (%) Pout (dBm), Gain (dB), IDS (A) Pout VS. VDD @ f = 890/920/940MHz 80 2 2.7 VGG (V) Pout VS. Pin @ f = 890/920/940MHz 0 20 0.0 0 950 35 5 30 10 f (MHz) 10 40 Pout IDS ηd Gain Ta=+25℃ —— f=890MHz f=890/920/940MHz - - - f=920MHz VDD=7.2V - ·- f=940MHz Pin=15dBm(31mW) ηd (%), Gain (dB) 1.5 Pout (W), IDS (A) 2.4 ηd (%), Gain (dB) Pout VS. VGG @ f = 890/920/940MHz 80 ηd (%), Gain (dB) Pout (W), IDS (A) Pout VS. f @ VDD=7.2V 2.4 4 5 6 7 8 9 10 VDD (V) Pout VS. Pin @ f = 890/920/940MHz Pout (W), IDS (A) 1.8 100 Ta=+25℃ f=890/920/940MHz VDD=7.2V IDQ=50mA 90 1.5 80 1.2 70 0.9 —— f=890MHz - - - f=920MHz ····· f=940MHz 0.6 Pout IDS ηd 0.3 60 ηd (%) 2.1 50 40 0.0 30 0 10 20 30 40 50 60 70 Pin (mW) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 14 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 19.Test Circuit @VDD=7.2V, 880-950MHz 880-950MHz (@VDD=7.2V, Idq = 50mA) VDD 8mm VGG C9 C10 C11 5mm C5 L1 C8 C7 C6 8mm 4mm 5mm 15mm RF-out R1 C1 10mm 2mm 3mm C3 C4 3mm RF-in C2 Note: The characteristic impedance of all microstrip lines: 50ohm No. Description P/N Manufacturer C1 47pF Chip Ceramic Capacitors GRM1885C1H470JA01 muRata C2 15pF Chip Ceramic Capacitors GRM1885C1H150JA01 muRata C3 6pF Chip Ceramic Capacitors GRM1885C1H060JA01 muRata C4 2pF Chip Ceramic Capacitors GRM1885C1H020JA01 muRata C5 47pF Chip Ceramic Capacitors GRM1885C1H470JA01 muRata C6 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C7 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C8 4.7uF Chip Ceramic Capacitors GRM32ER61H474KA12L muRata C9 100pF Chip Ceramic Capacitors GRM1885C1H101JA01 muRata C10 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C11 10uF Chip Ceramic Capacitors GRM32ER61H105KA12L muRata L1 D: 0.35mm, Inside: 1.5mm, 2 Turns Enameled wire - R1 51Ω Chip Resistors - - Q1 RF LDMOS HTU7G06S0P5P Suzhou Huatai Electronics Ltd. PCB Er=4.5 FR4 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 15 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 20.Input/Output Impedance Characteristics @VDD=7.2V, 880-950MHz Termination 50 ohm Input Matching Network of Test Circuit Output Matching Network of Test Circuit Zsource Termination 50 ohm Zload @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zsource (ohm) 890 5.09 + j 47.15 920 5.02 + j 50.19 940 5.00 + j 52.41 @Pin=31mW,VDD=7.2V,IDQ=50mA f(MHz) Zload (ohm) 890 18.87 + j 41.11 920 20.17 + j 43.18 940 20.86 + j 44.49 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 16 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 21.Typical Characteristics @VDD=4V, 400-470MHz The Test Circuit is Absolutely Stable in the UHF-band with Feedback Pout VS. f @ VDD=4V Pout VS. f @ VDD=4V 70 30 60 1.0 IDS 25 50 Pout Ta=+25℃ VDD=4V Pin=20dBm IDQ=50mA 20 15 40 Gain d 30 IDS 10 Pout(W),IDS(A) 0.8 d(%) d 64 0.6 Ta=+25℃ VDD=4V Pin=0.1W IDQ=50mA 0.4 60 56 20 0.2 10 410 420 430 440 450 460 52 0.0 0 470 400 460 0.8 0.7 70 65 d 1 60 Pout(W),IDS(A) 0.6 d(%) Pout(W),IDS(A) 450 Pout VS. VGG @ f = 430MHz IDS 55 0 50 4 5 6 7 0.5 IDS d 0.4 Ta=+25℃ f=400MHz VDD=4V IDQ=50mA 45 0.2 40 0.1 35 0.5 30 1.5 1.0 0.8 0.7 60 Gain 15 IDS 40 d 30 d(%) 20 Pout(W),IDS(A) 0.6 50 Pout Pout IDS d 50 40 30 0.2 20 0.1 10 10 0 0.0 0.00 20 60 0.3 5 15 70 0.4 20 0 80 Ta=+25℃ f=400MHz VDD=4V IDQ=50mA 0.5 10 Pin(dBm) 50 Pout VS. Pin @ f = 400MHz 70 10 55 0.3 Pout VS. Pin @ f = 400MHz 5 60 Pout VGG(V) 35 0 65 Ta=+25℃ f=430MHz Pin=0.1W VDD=4V 0.0 0.0 8 470 70 VDD(V) 25 440 Pout VS. VDD @ f = 430MHz Pout 30 430 f (MHz) 75 3 420 f (MHz) Ta=+25℃ f=430MHz Pin=0.1W IDQ=50mA 2 410 d(%) 5 0 400 Pout(dBm),Gain(dB),IDS(A) 68 0.02 0.04 0.06 0.08 d(%) Pout(dBm),Gain(dB),IDS(A) Pout d(%) 35 0 0.10 Pin(W) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 17 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics Pout VS. Pin @ f = 430MHz Ta=+25℃ f=430MHz VDD=4V IDQ=50mA 0.6 50 Pout Gain 20 40 d IDS 15 30 0.1 10 0.02 Pin(dBm) Pout VS. Pin @ f = 470MHz Pout Gain d 0.8 60 0.7 0.6 50 IDS Pout(W),IDS(A) 25 40 15 30 10 20 5 10 0 0.0 0.00 0 5 10 0.08 0 0.10 15 20 80 70 Ta=+25℃ f=470MHz VDD=4V IDQ=50mA 60 0.5 20 0 0.06 Pout VS. Pin @ f = 470MHz 70 d(%) Pout(dBm),Gain(dB),IDS(A) 30 0.04 Pin(W) 35 Ta=+25℃ f=470MHz VDD=4V IDQ=50mA 40 20 0.0 0.00 20 d 50 0.2 0 15 IDS 30 10 10 Pout 0.3 5 5 60 0.4 20 0 70 0.5 10 0 80 Ta=+25℃ f=430MHz VDD=4V IDQ=50mA Pout IDS 0.4 50 40 d 0.3 30 0.2 20 0.1 10 0.02 0.04 0.06 0.08 d(%) 25 0.7 60 Pout(W),IDS(A) 30 d(%) Pout(dBm),Gain(dB),IDS(A) 0.8 70 d(%) Pout VS. Pin @ f = 430MHz 35 0 0.10 Pin(W) Pin(dBm) Stabfact-K VS. Freq 0 200 400 600 800 10 Ta=+25℃ VDD=4V IDQ=50mA 9 Stabfact-K 8 1000 10 9 8 7 7 6 6 5 5 4 4 3 3 2 2 Stabfact-K 1 1 0 0 200 400 600 800 0 1000 f (MHz) © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 18 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 22.Test Circuit @VDD=4V, 400-470MHz 400-470MHz (@VDD=4.0V, Idq = 50mA,with feedback) VDD 8mm VGG C9 C10 C11 L2 C8 C7 C6 8mm 4mm C3 R2 3mm L3 7mm 4mm 5mm 5mm L1 C5 RF-out R1 C4 3mm RF-in Q1 C1 C2 Note: The characteristic impedance of all microstrip lines: 50ohm No. Description P/N Manufacturer C1,C5 220pF Chip Ceramic Capacitors GRM1885C1H221JA01 muRata C2,C4 15pF Chip Ceramic Capacitors GRM1885C1H150JA01 muRata C3 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C6,C9 220pF Chip Ceramic Capacitors GRM1885C1H221JA01 muRata C7,C10 1nF Chip Ceramic Capacitors GRM1885C1H102JA01 muRata C8 4.7uF Chip Ceramic Capacitors GRM32ER61H474KA12L muRata C11 10uF Chip Ceramic Capacitors GRM32ER61H105KA12L muRata L1 6.8nH Chip Ceramic inductance - - L2 D: 0.31mm, Inside: 1.5mm, 2 Turns Enameled wire - L3 D: 0.3mm, Inside: 1.5mm, 8 Turns Enameled wire - R1 100Ω Chip Resistors - - R2 150 Ω Chip Resistors - - Q1 RF LDMOS HTU7G06S0P5P Suzhou Huatai Electronics Ltd. PCB Er=4.5 FR4 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 19 / 22 Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 Suzhou Huatai Electronics 23.HTU7G06S0P5P S-Parameter Data (VDD=4V, Idq=50mA) S11 S21 S12 S22 Freq (MHz) (mag) (ang) (mag) (ang) (mag) (ang) (mag) (ang) 300 350 400 430 470 500 550 600 650 700 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 0.954 0.890 0.846 0.829 0.810 0.803 0.793 0.783 0.773 0.764 0.759 0.757 0.758 0.754 0.753 0.749 0.743 0.740 0.743 0.747 0.751 0.753 0.754 0.754 0.756 0.756 -165.3 -176.8 173.7 168.6 162.5 158.1 151.0 144.0 137.5 131.4 125.7 120.1 114.5 109.0 103.6 98.2 93.2 88.5 84.0 79.2 74.2 69.2 64.2 59.3 54.6 49.6 9.687 8.132 6.981 6.440 5.840 5.465 4.922 4.473 4.069 3.726 3.448 3.217 3.017 2.830 2.657 2.493 2.342 2.217 2.123 2.040 1.963 1.889 1.816 1.745 1.697 1.655 -74.5 -113.8 -151.1 -172.8 158.7 137.4 102.3 67.4 32.9 -1.1 -34.7 -68.3 -102.0 -135.6 -169.2 157.4 124.4 91.8 59.3 26.3 -6.7 -39.8 -72.8 -105.7 -138.1 -171.2 0.088 0.086 0.083 0.082 0.082 0.081 0.080 0.079 0.077 0.076 0.075 0.074 0.074 0.072 0.071 0.070 0.068 0.068 0.068 0.067 0.066 0.066 0.065 0.064 0.064 0.064 -164.6 157.0 120.5 99.2 71.2 50.2 15.8 -18.9 -52.6 -86.3 -119.1 -152.0 174.3 141.3 108.2 75.6 43.2 11.0 -21.2 -54.0 -86.7 -119.2 -151.8 175.5 144.2 111.4 0.515 0.531 0.539 0.545 0.552 0.557 0.561 0.564 0.569 0.574 0.580 0.584 0.584 0.577 0.575 0.575 0.579 0.581 0.581 0.578 0.577 0.579 0.580 0.580 0.578 0.571 -96.1 -167.5 126.5 88.2 38.1 0.3 -61.5 -122.8 177.1 117.4 59.1 1.0 -57.4 -116.9 -176.5 124.3 66.8 10.2 -47.1 -105.2 -163.5 137.7 79.7 21.6 -34.9 -92.9 © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 20 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 24.Recommended PCB Pad Layout Symbol Dimesions in Milimeters Dimesions in Inches Min. Max. Min. Max. A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF. 0.061 REF. D2 1.750 REF. 0.069 REF. E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 E2 1.900 REF. 0.075 REF. e 1.500 TYP. 0.060 TYP. e1 3.000 TYP. 0.118 TYP. L θ 0.900 1.200 45° 0.035 0.047 45° © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 21 / 22 Suzhou Huatai Electronics Document Number: HTU7G06S0P5P Rev. 2.4, 05/2019 25. Disclaimer Information in this document is believed to be accurate and reliable. However, Huatai Electronics does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Huatai Electronics takes no responsibility for the content in this document if provided by an information source outside of Huatai Electronics or an authorized Huatai Electronics distributor In no event shall Huatai Electronics be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Huatai Electronics products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Huatai Electronics product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Huatai Electronics and its distributors accept no liability for inclusion and/or use of Huatai Electronics products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Huatai Electronics reserves the right to make changes without further notice to any products herein. “Typical” parameters that may be provided in Huatai Electronics data sheets and/or specifications can and do vary in different applications, and actual performance may vary over time. All operating parameters, including “typicals,” must be validated for each customer application by customer’s technical experts. Huatai Electronics does not convey any license under its patent rights nor the rights of others. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance. For the full Terms and conditions of commercial sale or further details of the products contained therein, please contact Huatai Electronics or an authorized Huatai Electronics distributor. How to reach us: http://www.huatai-elec.com/ © 2019 SUZHOU HUATAI ELETRONICS LTD. ALL RIGHTS RESERVED. © 2019 Suzhou Huatai Electronics Ltd. All rights reserved. Product Data Sheet 22 / 22
HTU7G06S0P5P 价格&库存
很抱歉,暂时无法提供与“HTU7G06S0P5P”相匹配的价格&库存,您可以联系我们找货
