30BQ040
SCHOTTKY BARRIER DIODE
FEATURES
• Small foot print, surface mountable
• Very low forward voltage drop
• High frequency operation
• Guard ring for enhanced ruggedness and long
term reliability
• Lead (Pb)-free (“PbF” suffix)
• Designed and qualified for industrial level
SMC
MECHANICAL DATA
Case: SMC(DO-214AB)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.21 grams (approximate)
MAJOR RATINGS AND CHARACTERISTICS
SYMBOL
IF(AV)
CHARACTERISTICS
VALUES
UNITS
3.0
A
40
V
Rectangular waveform
VRRM /VR
IFSM
tp = 5 µs sine
2000
A
VF
3.0 Apk, TJ = 125 °C
0.43
V
TJ
Range
- 55 to 150
°C
VOLTAGE RATINGS
PARAMETER
SYMBOL
Maximum DC reverse voltage
30BQ040
VR
Maximum working peak reverse voltage
UNITS
40
VRWM
V
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Maximum average forward current
SYMBOL
IF(AV)
TEST CONDITIONS
VALUES
50 % duty cycle at TL = 118 °C, rectangular waveform
3.0
50 % duty cycle at TL = 110 °C, rectangular waveform
4.0
5 µs sine or 3 µs rect. pulse
Following any rated
load condition and with
rated VRRM applied
2000
UNITS
A
Maximum peak one cycle
non-repetitive surge current
IFSM
Non-repetitive avalanche energy
EAS
TJ = 25 °C, IAS = 1.0 A, L = 12 mH
6.0
mJ
IAR
Current decaying linearly to zero in 1 µs
Frequency limited by TJ maximum VA = 1.5 x VR typical
1.0
A
Repetitive avalanche current
10 ms sine or 6 ms rect. pulse
110
ELECTRICAL SPECIFICATIONS
PARAMETER
SYMBOL
TEST CONDITIONS
3A
Maximum forward voltage drop
VFM (1)
6A
3A
6A
Maximum reverse leakage current
IRM (1)
TJ = 25 °C
TJ = 125 °C
TJ = 25 °C
TJ = 125 °C
VR = Rated VR
VALUES
UNITS
0.53
0.68
0.43
V
0.57
0.5
30
mA
Maximum junction capacitance
CT
VR = 5 VDC (test signal range 100 kHz to 1 MHz) 25 °C
230
pF
Typical series inductance
LS
Measured lead to lead 5 mm from package body
3.0
nH
10 000
V/µs
Maximum voltage rate of change
dV/dt
Rated VR
Note
(1) Pulse width < 300 µs, duty cycle < 2 %
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/ 5
30BQ040
THERMAL - MECHANICAL SPECIFICATIONS
PARAMETER
SYMBOL
Maximum junction and storage
temperature range
TJ (1), TStg
Maximum thermal resistance,
junction to lead
RthJL (2)
junction to ambient
RthJA
TEST CONDITIONS
VALUES
UNITS
- 55 to 150
°C
12
DC operation
°C/W
46
0.24
Approximate weight
g
0.008
Marking device
Case style SMC (similar to DO-214AB)
oz.
V3F
Notes
(1)
(2)
dP tot
1
------------- < -------------- thermal runaway condition for a diode on its own heatsink
dT J R thJA
Mounted 1" square PCB
10
100 000
TJ = 150 °C
IR - Reverse Current (µA)
IF - Instantaneous Forward Current (A)
Typical Characteristics
TJ = 150 °C
TJ = 125 °C
TJ = 25 °C
1
10 000
TJ = 125 °C
TJ = 100 °C
1000
TJ = 75 °C
100
TJ = 50 °C
10
0.1
TJ = 25 °C
1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
40
VFM - Forward Voltage Drop (V)
VR - Reverse Voltage (V)
Fig. 1 - Maximum Forward Voltage Drop Characteristics
(Per Leg)
Fig. 2 - Typical Values of Reverse Current vs.
Reverse Voltage (Per Leg)
CT - Junction Capacitance (pF)
1000
TJ = 25 °C
100
10
10
15
30
35
40
45
Fig. 3 - Typical Junction Capacitance vs. Reverse Voltage (Per Leg)
2/ 5
30BQ040
ZthJC - Thermal Impedance (°C/W)
100
10
PDM
1
Single pulse
(thermal resistance)
0.1
0.00001
0.0001
t1
D = 0.75
D = 0.50
D = 0.33
D = 0.25
D = 0.20
0.001
0.01
t2
Notes:
1. Duty factor D = t1/t2
2. Peak TJ = PDM x ZthJC + TC
0.1
1
10
100
t1 - Rectangular Pulse Duration (s)
160
DC
150
2.0
D = 0.20
D = 0.25
D = 0.33
D = 0.50
D = 0.75
140
130
Average Power Loss (W)
Allowable Lead Temperature (°C)
Fig. 4 - Maximum Thermal Impedance ZthJC Characteristics (Per Leg)
120
110
100
Square wave (D = 0.50)
80 % rated VR applied
90
80
D = 0.75
D = 0.50
D = 0.33
D = 0.25
D = 0.20
1.5
1.0
RMS limit
0.5
DC
See note (1)
2
3
5
4
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
IF(AV) - Average Forward Current (A)
Fig. 5 - Maximum Average Forward Current vs.
Fig. 6 - Maximum Average Forward Dissipation vs.
IFSM - Non-Repetitive Surge Current (A)
10 000
1000
100
At any rated load condition
and with rated VRRM applied
following surge
10
10
100
1000
10 000
tp - Square Pulse Duration (µs)
Fig. 7 - Maximum Peak Surge Forward Current vs. Pulse Duration
Note
Formula used: TC = TJ - (Pd + PdREV) x RthJC;
Pd = Forward power loss = IF(AV) x VFM at (IF(AV)/D) (see fig. 6);
PdREV = Inverse power loss = VR1 x IR (1 - D); IR at VR1 = 80 % rated VR
(1)
3/ 5
30BQ040
SMC Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
7.75
8.13
0.305
0.320
B
5.59
6.22
0.220
0.245
C
6.60
7.11
0.260
0.280
D
2.75
3.25
0.108
0.128
E
2.25
2.82
0.089
0.111
G
2.00
2.62
0.079
0.103
H
1.26
1.56
0.050
0.061
I
0.05
0.15
0.002
0.006
K
4.30
6.00
0.169
0.236
L
1.25
1.75
0.049
0.069
N
0.10
0.30
0.004
0.012
SMC Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
4/ 5
30BQ040
SMC Tape and Reel
SMC Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMC
6.3
8.25
2.90
Ø1.55
1.75
7.50
4.00
8.00
2.00
16.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMC Tape Leader and Trailer
SMC Reel
REEL OPTION
13’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø330
100
21
R165
R50
R6.50
16.4
21.00
±2
±1
±1
±1
±1
±1
±1
±1
5/ 5
很抱歉,暂时无法提供与“30BQ040”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68306
- 20+0.62279
- 100+0.56252
- 500+0.50225
- 1000+0.47412
- 2000+0.45403
- 国内价格
- 1+0.52970
- 100+0.48460
- 1000+0.46210
