GR8762KG
GR8762KG
    GRENERGY(南京绿芯)
    SOP-8
    GR8762KG
GR8762KG 数据手册
GR8762 Power Factor Controller IC for High Power Factor Features LHDTHDprotections Description  Low Startup Current The GR8762 is a current-mode PFC controller  Low Quiescent Current operating  Under-Voltage Lockout with Hysteresis sinusoidal current is taken from the single phase line  Zero Current Detector for Critical Conduction supply and stabilized DC voltage is available at the Mode output. The IC includes a highly liner multiplier  Dynamic and Static Output Over-Voltage in critical conduction mode. The which can reduce AC input current distortion, that Protection allows wide-range-mains operation with an  Gate Output Maximum Voltage Clamped extremely low THD, even over a large load range.  Internal Restart Timer The output voltage is controlled by an error amplifier  1% Internal Reference Voltage and an internal voltage reference. An effective  Internal Leading-Edge Blanking two-step (dynamic and static) OVP enables to safely  +/-500mA Totem Pole Output with Active Shut handle over voltages either occurring at start-up or Down resulting from load disconnection. The totem-pole output stage capable of ±500mA driving capability is suitable for big MOSFET or IGBT. It is available in Applications both 8-pin DIP and 8-pin SOP package.  Power Supply PFC Pre-Regulator  LED Lighting Application  Desktop PC  Electronics Ballast for Fluorescent Lamp Ordering and Marking Information GR8762 Package Code RoHS Code J: DIP-8 K: SOP-8 G: Green (Halogen Free) Device L: PB Free Device DIP-8/SOP-8 GR8762 X X XXX Serial No. Code 1 Code 2 Code 1 Year 8 9 A B 2008 2009 2010 2011 Code 2 1 Month Jan. 2 Feb. 3 Mar. 4 Apr. ● ● ● G H I J 2016 2017 2018 2019 9 Sep. A Oct. B Nov. C Dec. Grenergy OPTO Inc. reserves the right to make changes to improve reliability or manufacture ability without notice, and advise customers to obtain the latest version of relevant information to verify before placing orders. 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 1 GR8762 Pin Configuration TOP VIEW VSEN 1 8 VCC COMP 2 7 DRV MUL 3 6 GND 4 5 ZCD CS Pin Description Pin Symbol Description Voltage error amplifier Inverting Input. VSEN is connected via a resistive divider to 1 VSEN the boost converter output, With a capacitor connected to COMP, The internal error amplifier acts as an integrator. Voltage error amplifier output. This is the first multiplier input. If the current flowing 2 COMP into this pin is exceeding an internal threshold, the multiplier output voltage is reduced to prevent the MOSFET from over-voltage damage. 3 MUL Multiplier input, which is the second multiplier input and is connected via a resistive divider to the rectifier output voltage. Current sense input, which is connected to a sense resistor controlling the 4 CS MOSFET source current .A leading edge blanking circuitry, suppresses voltage spits when turning the MOSFET on. 5 ZCD 6 GND 7 DRV Zero current detector input, which is connected to an auxiliary winding monitoring the zero crossing of the inductor current. Ground Gate drive output, which is the output of a totem-pole circuitry for direct driving a MOSFET. Positive voltage supply. If VCC exceeds the UVLO (on) threshold, the IC is 8 VCC switched on. When VCC falls below the UVLO (off) threshold, it is switched off and power consumption is very low. VCC is internally clamped to 28V. 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 2 GR8762 Absolute Maximum Ratings VCC supply + zener current ----------------------------------------------------------------------------------------------Voltage at Pin VSEN, MUL, CS, ZCD ------------------------------------------------------------------------ 20mA -0.3V~6.5V Junction temperature -----------------------------------------------------------------------------------------------------Operating ambient temperature ----------------------------------------------------------------------------------Storage temperature range ------------------------------------------------------------------------------------ 150℃ -20℃ ~ 85℃ -65℃ ~ 150℃ SOP-8 package thermal resistance --------------------------------------------------------------------------------- 160℃/W DIP-8 package thermal resistance -------------------------------------------------------------------------------- 100℃/W Power dissipation (SOP-8, at ambient temperature = 85℃) --------------------------------------------------- 400mW Power dissipation (DIP-8, at ambient temperature = 85℃) -------------------------------------------------- 650mW Lead temperature (All Pb free packages, soldering, 10sec) ------------------------------------------------------ 260℃ ESD voltage protection (Human body model) ---------------------------------------------------------------------------- 2 KV ESD voltage protection (Machine model)--------------------------------------------------------------------------------- 200 V Block Diagram VCC GND ZCD 25V + 9.5V Internal Supply UVLO 12V Reference Voltage Clamp Current 5.7V + Detector - 1.7V 0.2V - Enable + 1.3V Restart Timer Inhibit time delay 2.25V 2.5V Inhibit + + Voltage Amp - 200ns LEB Current Comp + 1.7V Multiplier RS Flip-Flop Gate Drive DRV 15V OVR VSEN COMP MUL CS 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 3 GR8762 Electrical Characteristics (Ta = 25℃, Vcc = 12V, CO=1nf, unless otherwise specified.) Parameter Test Conditions Symbol Min Typ Max Unit 22 V SUPPLY VOLTAGE VCC 10.5 Zener Voltage ICC+IZ=20mA VZ 22 25 28 V UVLO on Voltage VCC-ON 11 12 13 V UVLO off Voltage VCC-OFF 8.5 9.5 10.5 V VCC Hysteresis VCC-HY 2.5 ICCL 40 70 uA 2.5 3.8 mA 3.5 5.0 mA 1.7 2.2 mA 2.5 2.535 V 2 5 mV -1 uA V SUPPLY CURRENT Startup Current Quiescent Current 1 ICCH after turn on Operating Supply Current ICC During OVP(either Quiescent Current 2 static or dynamic or Vinv≦150mV) VOLTAGE ERROR AMPLIFIER Voltage Feedback Input Theshold VFB Line Regulation Vcc = 10.3V~22V Input Bias Current VINV=0 to 3V Voltage Gain Source Current Sink Current VFBLR GV Gain Bandwidth 2.465 60 GBW VCOMP= 4V VSEN=2.4V VCOMP= 4V VSEN=2.6V 80 dB 1 MHz ICOMPsrc -2 -3.5 -5 mA ICOMPsnk 2.5 4.5 5.5 mA Upper Clamp Voltage ISOURCE= 0.5mA VCOMP_H 4.5 5.0 5.5 V Lower Clamp Voltage ISINK= 0.5mA VCOMP_L 2.0 2.2 2.4 V VVFF= 0 to 4V IMUL -1 uA MULTIPLIER INPUT Input Bias Current Dynamic Voltage Range of MUL V V CS MUL K Gain VMUL VMUL=0 to 0.5V 3.0 1.65 VCOMP=Upper Clamp VMUL=1V V 1.9 V/V 0.6 1/V 30 uA VCOMP=4V OVER-VOLTAGE REGULATOR Threshold Current 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com IOVR 4 GR8762 Hysteresis 20 Static OVP Threshold 2.15 uA 2.25 2.35 V 200 350 nS 1.7 1.8 V CURRENT SENSE COMPARATOR Delay to Output TD(H-L) Current Sense Reference Clamp VCOMP= Upper Clamp Current Sense Offset VMUL= 0 Leading Edge Blanking 1.6 VCSoffset 30 mV TLEB 200 nS ZERO CURRENT DETECTOR Upper Clamp Voltage IZCD= 2.5mA 5.0 5.7 6.5 V Lower Clamp Voltage IZCD= -2.5mA 0.3 0.65 1.0 V Upper Threshold Voltage Arming Voltage (positive-going edge) Lower Threshold Voltage Arming (positive-going edge) Voltage (negative-going edge) VZCDA 1.7 V VZCDT 1.3 V (negative-going edge) Source Current Capability IZCD_src -2.5 Sink Current Capability IZCD_sink 2.5 Disable Threshold VZCD_DIS 150 Restart Threshold VZCD_EN 250 Restart Current after Disable -5.5 mA mA 200 250 mV 350 mV 30 75 uA 75 190 300 uS IGD source = 20mA 2.0 2.6 V IGD source = 200mA 5.5 6.5 V IGD sink=200mA 1.3 2.0 V RESTART TIMER Restart Time TRES GATE DRIVER Dropout voltage Rising Time Load=1nF TRISE 40 80 nS Falling Time Load=1nF TFALL 30 70 nS 12 15 V 3.5 V Clamp UVLO Saturation VCLAMP VCC = 0 to VCC Isink=2mA 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 10 5 GR8762 Typical Performance Characteristics 13.0 UVLO(on) & UVLO(off) (V) Startup Current(uA) 40.0 35.0 30.0 25.0 Fig. 5 12.0 11.0 10.0 20.0 9.0 -40 0 40 80 120 -40 0 40 Temp.(℃) Fig. 1 120 Fig. 2 2.50 32.0 2.00 30.0 VCC Zener Clamp(V) Operating Current(mA) 80 Temp.(℃) 1.50 1.00 0.50 28.0 26.0 24.0 -40 0 40 80 120 -40 0 Tempe.(℃) 40 80 120 Temp.(℃) Fig. 3 Fig. 4 240 2.60 220 Restart Time(us) Vref(V) 2.55 2.50 2.45 200 180 160 140 2.40 -40 0 40 80 120 Temp.(℃) Fig. 5 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com -40 0 40 80 120 Temp.(℃) Fig. 6 6 Typical Performance Characteristics (Cont.) 400 130 120 Shut Down Delay(ns) LEB Time(ns) 350 300 250 110 100 90 200 80 -40 0 40 Fig. 7 80 120 -40 0 40 Tempe.(℃) Tempe.(℃) Fig. 7 Fig. 8 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 80 120 7 Application Information Overview The GR8762 contains an one quadrant multiplier with a wide linear operating range, a voltage amplifier used in a feedback loop, an overvoltage regulator, a current sense comparator, a zero current detector, a PWM and logic circuit, a totem pole MOSFET driver, an internal voltage reference, a restart timer and under voltage lockout circuit. Because of the integrator’s low bandwidth fast changes of the output voltage can’t be regulated within an adequate time. Fast output changes occur during initial start-up, sudden load removal. While the integrator’s differential input voltage remains zero. During this fast changes, a peak current is flowing through the external capacitor into pin COMP. If this Multiplier The one quadrant multiplier has two inputs M1 and M2. The input M1 (MUL Pin) provides the information of the waveform of the input voltage. current exceeds an internal defined margin the overvoltage regulator circuit reduces the multiplier output voltage. As a result the on time of the MOSFET is reduced. Its range is from 0 to 3.5V being referenced to ground. The input M2 (COMP Pin) is the voltage amplifier output, which provides the information of the DC output voltage. Both inputs are designed to achieve good linearity over a wide dynamic range to represent an AC line free from distortion. Current Sense Comparator An external sense resistor transfers the source current of the MOSFET into a sense voltage. The multiplier output is compared with this sense voltage. The switch-on peak current of the MOSFET is blanked out via a leading edge blanking circuit Voltage Error Amplifier with a blanking time of typically 300nS. With an external capacitor between the pins VSEN and COMP the voltage error amplifier forms an integrator. The integrator monitors the average output voltage over several line cycles. Typically the integrator’s bandwidth is set below 20Hz in order to suppress the 100Hz ripple of the rectified line voltage. The non-inverting input is biased internally at 2.5V. The output is directly connected to the multiplier input. The gate drive is disabled when VSEN voltage is less than 0.18V or COMP voltage is less than 2.2V. Zero Current Detector The zero current detector senses the inductor current via an auxiliary winding and ensures that the next on-time of the MOSFET is initiated immediately when the inductor current has reached zero. This diminishes the reverse recovery losses of the boost converter diode. The MOSFET is switched off when the voltage drop of the sense resistor reaches the voltage level of the multiplier output. So the boost current waveform has a triangular shape and there are no dead-time gaps between the cycles. This Overvoltage Regulator 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com leads to a continuous AC line current limiting the 8 peak current to twice of the average current. 130us after the inductor current reaches zero. To prevent false tripping, the zero current detector is designed as a Schmitt-Trigger with a hysteresis of Under-Voltage Lockout 0.5V. An internal 5.7V clamp protects the input from An under voltage lockout circuit switches the IC on overvoltage breakdown. An external resistor has to when VCC reaches the UVLO(ON) threshold and be used in series with the auxiliary winding to limit switches the IC off when VCC is falling below the the current through the clamps. UVLO(OFF) threshold. During start up the supply current is less than 40uA. An internal voltage clamp Restart Timer has been added to protect the IC from VCC The restart timer function eliminates the need of a overvoltage. oscillator. The timer starts or restarts the GR8762 when the drive output has been off for more than Typical Application Circuit Pre-regulator Application GR8762 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 9 BOM List No. Part Description Q’ty. 1 BD1 PBL405 4A 600V 1 2 CN1, CN2 2/3 pin 3.96 180°,white 1 3 C1 474K 400V Pitch=15mm 1 4 C2 47uF 35V 6*12mm 105℃ 1 5 C3 0805 104K 50V 1 6 C4 103K 100V 7 C5, C6 0805 103K 50V X7R 2 8 C7 0805 225K 50V X7R 1 9 C8 47uF/450V 22*26(max) 105℃ 1 10 C9 NC 1 11 CX1 474K/275V 1 12 CR1 FR104 1A 400V 1 13 CR2 ER506 5A/800V DO-201 1 14 CR3 LL4148 DO-80 1 15 F1 4*8mm T3.15A/250V, fuse 1 16 HS1 15*10.5*25mm heat sink, Aluminum 1 17 LF1 T12*10*8c 0.7mH 1 18 LF2 T16*12*8c 1 19 NTC1 SCK2R55A 1 20 Q1 2SK2842 12A/500V TO-220 1 21 R1, R2, R3, R4 1206 22 R5 20K 23 X7R X7R 1 15mH 1M 5% 4 0805 5% 1 R6, R7 1206 240K 5% 2 24 R8 100R 1206 5% 1 25 R9 39K 1206 5% 1 26 R10 33R 1206 5% 1 27 R11 0R 1206 5% 1 28 R12 100K 0805 5% 1 29 R13 4.7K 0805 5% 1 30 R14 0R 5% 1 31 R15 0.27R 2WS 5% 1 32 R16 NC 0 0805 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 10 BOM List (Cont.) No. Part Description Q’ty. 33 R17, R18 330K 1206 1% 2 34 R19 4.3K 0805 1% 1 35 R20 91K 36 T1 PQ2620 0.7mH 1 37 U1 SOP-8 GR8762 1 38 Z1 18V 1W 1 39 PCB CEM-1 2oz 1mm 110*56mm 1 0805 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 1% 1 11 D C B 1 T1B 3rd Layer 0.15*36Ts N 4 3 90~264VAC L 68K R13 0R R2 L2 UU9.8 C5 47u/50V CX1 0.1u BAV103 D3 F1 2A/250V ZD3 16V R23 5.1K 2 C11 12N Q2 2N2222 BD1 1A/600V R24 10K U2B PC817 R30 3K R21 24K C8 100u/25V C3 0.1u/400V DR8*10 L1 5 3 C12 12N R9 1M R12 1M ZCD GND U1 GR8762 MULT GD CS 3 FB COMP R10 150K R3 150K VCC 8 6 R25 100K 1 2 7 4 R6 200K C9 1u NC R20 R5 200K C13 NC C10 470P R17 510R R15 10R 2200P/1KV C4 R22 1.1R/1W R11 10K 2A/600V Q1 D4 1N4007 1st Layer 0.2*132Ts 1.15mH 2 1 T1A EE-16V 8PIN 4 R19 5.1K 7 12V ZD2 R14 0R Q3 2N2222 C6 0.1u R27 5.1K R1 47R CY1 1KP D1 ER304 2nd Layer 0.3 Triple*48Ts 8 C1 470P/500V 5 4 VCTRL OUT 1K R16 U3 TSM1052 VSENSE ICTRL C2 220u/35V ZD1 0R 6 VCC GND 2 A 5 1 3 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com Date: File: B Size Title C14 0.47u R28 15K R29 1K R18 2K R26 2K C15 0.1u R4 40.2K GND 6 2011/3/14 Sheet of C:\Documents and Settings\..\Single stage using Drawn GR8763.Sch By : Number U2A PC817 R8 1R2 R7 1R2 D2 US1M VOUT 22V/0.33A Revision LED Lighting Application 12 D C B A Package Information DIP-8 SYMBOL MILLIMETERS MIN. INCHES MAX. A MIN. MAX. 5.33 0.210 A1 0.38 0.015 A2 2.92 4.95 0.115 0.195 b 0.36 0.56 0.014 0.022 b2 1.14 1.78 0.045 0.070 c 0.20 0.35 0.008 0.014 D 9.01 10.16 0.355 0.400 D1 0.13 E 7.62 8.26 0.300 0.325 E1 6.10 7.11 0.240 0.280 0.005 e 2.54 BSC 0.100 BSC eA 7.62 BSC 0.300 BSC eB L 10.92 2.92 3.81 0.430 0.115 0.150 Note: 1. Followed from JEDEC MS-001 BA. 2. Dimension D, D1 and E1 do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 10 mil. 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 13 Package Information SOP-8 SYMBOL INCHES MILLIMETERS MIN. MAX. A MIN. MAX. 1.75 A1 0.10 A2 1.25 b 0.31 0.51 0.012 0.020 c 0.17 0.25 0.007 0.010 D 4.80 5.00 0.189 0.197 E 5.80 6.20 0.228 0.244 E1 3.80 4.00 0.150 0.157 e 0.25 0.069 0.004 0.010 0.049 1.27 BSC 0.050 BSC h 0.25 0.50 0.010 0.020 L 0.40 1.27 0.016 0.050 θ o 0 o 8 o 0 o 8 Note: 1. Followed from JEDEC MS-012 AA. 2. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion or gate burrs shall not exceed 6 mil per side. 3. Dimension “E1” does not include inter-lead flash or protrusions. Inter-lead flash and protrusions shall not exceed 10 mil per side. 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 14 Carrier Tape & Reel Dimensions Application A H 330.0±2.0 50 MIN. P0 P1 P2 D0 D1 4.0±0.10 8.0±0.10 2.0±0.05 1.5+0.10 -0.00 1.5 MIN. SOP-8 T1 C d 12.4+2.00 13.0+0.50 -0.00 -0.20 D 1.5 MIN. W E1 20.2 MIN. 12.0±0.30 1.75±0.10 T A0 B0 F 5.5±0.05 K0 0.6+0.00 -0.40 6.40±0.20 5.20±0.20 2.10±0.20 (mm) Devices Per Unit Application Carrier Width Cover Tape Width Devices Per Reel SOP- 8 12 - 2500 2012.04 Ver.1. 0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 15 Taping Direction Information SOP-8 Direction of feed Direction of feed ________________________________________________________________________ Grenergy OPTO, Inc. reserves the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. 2012.04 Ver.1.0 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 16
GR8762KG 价格&库存
很抱歉,暂时无法提供与“GR8762KG”相匹配的价格&库存,您可以联系我们找货
