BCT4157EXT-TR
BCT4157EXT-TR
    BROADCHIP(广芯)
    SC-70-6
    BCT4157/4157B是一款高带宽、快速单刀双掷(SPDT)CMOS开关。它可用作模拟开关或低延迟总线开关。BCT4157/4157B在1.65V至5.5V的宽工作电源电压范围内使用,在1.65V...
BCT4157EXT-TR 数据手册
April, 2008, REV1.2 BCT4157/4157B Low-Voltage, 2.8Ω SPDT Analog Switch General Description Features The BCT4157/4157B is a high-bandwidth, fast single-pole double-throw (SPDT) CMOS switch. It can be used as an analog switch or as a low-delay bus switch. Specified over a wide operating power supply voltage range, 1.65V to 5.5V, the BCT4157/4157B has a maximum ON resistance of 5.1-ohms at 1.65V, 3.9-ohms at 2.3V & 2.85-ohms at 4.5V. ♦CMOS Technology for Bus and Analog Applications ♦ Low ON Resistance: 3-ohms @ 2.7V ♦ Wide VCC Range: 1.65V to 5.5V ♦ Rail-to-Rail Signal Range ♦ Control Input Overvoltage Tolerance: 5.5V min. ♦ High Off Isolation: 57dB at 10MHz ♦ 54dB (10MHz) Crosstalk Rejection Reduces Signal Distortion ♦ Break-Before-Make Switching ♦ High Bandwidth: 300 MHz ♦ Extended Industrial Temperature Range: –40°C to 85°C ♦ Improved Direct Replacement for NC7SB4157 ♦ Packaging (Pb-free & Green available): Break-before-make switching prevents both switches being enabled simultaneously. This eliminates signal disruption during switching. The control input, S, tolerates input drive signals up to 5.5V, independent of supply voltage. BCT4157/4157B is an improved direct replacement for the FSA4157/NC7SB4157 Pin Description Applications Name Cell Phones PDAs Portable Instrumentation Battery Powered Communications Computer Peripherals S Description Logic Control Vcc Positive Power Supply Connection Diagram(Top View) A Common Output/Data Port SC70-6 B0 Data Port (Normally Closed) GND B1 Ground Data Port Logic Function Table TDFN-6 S 1 6 B1 VCC 2 5 GND A 3 4 B0 Logic Input (S) Function 0 B0 Connected to A 1 B1 Connected to A ORDERING INFORMATION Ordering Code Package Description Temp Range Top Marking BCT4157EXT-TR 6-pin SC70 –40°C to +85°C ABG BCT4157BEXT-TR 6-pin TDFN 1.45X1 –40°C to +85°C ABG www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage VCC.........................................–0.5V to +7V DC Switch Voltage (VS) (2).…….......…..–0.5V to VCC +0.5V (2) DC Input Voltage (VIN) .…..…….....….......–0.5V to +7.0V DC VCC or Ground Current (ICC/IGND)..................±100mA DC Output Current (VOUT) .......................................128mA Storage Temperature Range (TSTG) ....... –65°C to +150°C Junction Temperature under Bias (TJ) .......…............ 150°C Junction Lead Temperature (TL) (Soldering, 10 seconds) .................................... 260°C Power Dissipation (PD) @ +85°C .............................180mW RECOMMENDED OPERATING CONDITIONS (3) Supply Voltage Operating (VCC)………………1.65V to 5.5V Control Input Voltage (VIN)………………………..0V to VCC Switch Input Voltage (VIN)…………………………0V to VCC Output Voltage (VOUT)…………………………….0V to VCC Operating Temperature (TA)………………...–40°C to +85°C Thermal Resistance (θJA)…………………………..350°C/W Note 1:Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Note 2:The input and output negative voltage ratings may be exceeded if the input and output diode current ratings are observed. Note 3:Control input must be held HIGH or LOW; it must not float. DC ELECTRICAL CHARACTERISTICS (TA = - 40°C to +85°C) Parameter Description VIAR Analog Input Signal Range Test Conditions Supply Voltage Temp (ºC) Min. VCC TA = 25°C & –40°C to 85°C 0 Typ Max. Unit s VCC V 4.5 Ω RON ON Resistance(4) Iout = 100mA, B0 or B1=1.5V 2.7V TA = 25°C RON ON Resistance(4) Iout = 100mA, B0 or B1=3.5V 4.5V TA = 25°C Iout = 100mA, B0=B1=1.5V 2.7V TA = 25°C 0.75 Ω I(A) = -100mA; B0 or B1= 0V, 1.5V, 1.5V 2.7V TA = 25°C 1.5 Ω I(A) = -100mA; B0 or B1= 0V, 1.5V, 3.0V, 4.5V TA = 25°C 0.5 Ω ∆RON RONF ON Resistance Match Between Channels(4,5,6) ON Resistance(4,5, 7) Flatness RONF ON Resistance(4,5, 7) Flatness VIH VIL Input High Voltage Input Low Voltage Logic High Level Logic Low Level VCC = 1.65V to 1.95V VCC = 2.3V to 5.5V VCC = 1.65V to 1.95V VCC = 2.3V to 5.5V 3 3 1.5 TA = 25°C & –40°C to 85°C V 1.7 0.5 V 0.8 www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch DC ELECTRICAL CHARACTERISTICS (TA = - 40°C to +85°C) IIN Input Leakage Current IOFF OFF State Leakage Current ICC Quiescent Supply Current VCC = 0V to 5.5V 0 ≤VIN ≤5.5V VCC = 5.5V A=1V,4.5V, B0 or B1=4.5V, 1V All channels ON or OFF, VIN = VCC or GND, IOUT = 0 VCC = 5.5V TA = 25°C ±0.1 TA = –40°C to 85°C ±1.0 TA = 25°C -2.0 2.0 TA = 25°C µA 1 TA = –40°C to 85°C 10 Note 4: Measured by voltage drop between A and B pins at the indicated current through the device. ON resistance is determined by the lower of the voltages on two ports (A or B) Note 5: Parameter is characterized but not tested in production. Note 6: DRON = RON max – RON min. measured at identical VCC, temperature and voltage levels. Note 7: Flatness is defined as difference between maximum and minimum value of ON resistance over the specified range of conditions.. Note 8: Guaranteed by design. CAPACITANCE Parameter CIN CIO-B (12) Test Conditions Description Supply Voltage Temp (ºC) Min. Control Input Typ Max. Units 2.3 VCC = 5.0V For B Port,Switch OFF TA = 25°C pF 6.5 f= 1 MHz(12) CIOA-ON For A Port, Switch ON 18.5 SWITCH AND AC CHARACTERISTICS Parameter Description Test Conditions tPLH tPHL Propagation Delay: A to Bn See test circuit diagrams 1 and 2. VI Open (10) Supply Voltage Temp (ºC) Min. VCC= 2.3V to 2.7V VCC = 3.0V to 3.6V TA = 25°C & –40 to 85°C tPZL tPZH 0.8 7 23 3.5 13 VCC= 3.0V to 3.6V 2.5 6.9 VCC= 4.5V to 5.5V 1.7 5.2 VCC= 2.3V to 2.7V TA = 25°C VCC = 2.5V tPZL tPZH OUTPUT ENABLE TURN NOTIME: A TO BN See test circuit diagrams 1 and 2. VI = 2VCC for TPZL, VI = 0V for tPZH VCC = 3.3V VCC = 3.0V to 3.6V VCC = 4.5V to 5.5V Units 0.3 VCC= 1.65V to 1.95V diagrams 1 & 2. See test circuit VI = 2VCC for TPZL, VI = 0V for tPZH Max. 1.2 VCC= 4.5V to 5.5V Output Enable Turn ON Time: A to Bn Typ ns 24 TA = 25°C & –40 to 85°C 14 7.6 5.7 www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch tPLZ tPHZ Output Disable Turn OFF Time: A to Bn VCC = 1.65V to 1.95V See test circuit diagrams 1 and 2. VI = 2VCC for TPZL, VI = 0V for tPZH 3 12.5 2 7 VCC = 3.0V to 3.6V 1.5 5 VCC = 4.5V to 5.5V 0.8 3.5 VCC = 2.3V to 2.7V TA = 25°C VCC = 2.5V tPLZ tPHZ Output Disable Turn OFF Time: A to Bn See test circuit diagrams 1 and 2. VI = 2VCC for TPZL, VI = 0V for tPZH VCC = 3.3V VCC = 3.0V to 3.6V 13 7.5 TA = –40 to 85°C 5.3 VCC = 4.5V to 5.5V 3.8 VCC = 2.5V tBM Break Before Make Time See test circuit diagram 9.(9) VCC = 3.3V VCC = 3.0V to 3.6V 0.5 TA = 25°C & –40 to 85°C VCC = 4.5V to 5.5V Q OIRR Charge Injection CL = 0.1nF, VGEN = 0V, RGEN = 0Ω. See test circuit 4. Off Isolation RL = 50Ω, VGEN = 0V, RGEN = 0Ω. See test circuit 5. (11) VCC = 1.65V to 5.5V 0.5 0.5 0.5 VCC = 5.0V 7 TA = 25°C VCC = 3.3V pC 3 TA = 25°C –57 dB XTALK Crosstalk Isolation See test circuit 6. VCC = 1.65V to 5.5V TA = 25°C –54 f3dB –3dB Bandwidth See test circuit 9 VCC = 1.65V to 5.5V TA = 25°C 300 MHz Note 6: Guaranteed by design Note 7: Guaranteed by design but not production tested. The device contributes no other propagation delay other than the RC delay of the switch ON resistance and the 50pF load capacitance, whne driven by an ideal voltage source with zero output impedance. Note 8: Off Isolation = 20 Log10 [ VA / VBn ] and is measured in dB. Note 9: TA = 25°C, f = 1MHz. Capacitance is characterized but not tested in production. www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch TEST CIRCUITS AND TIMING DIAGRAMS www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch www.broadchip.com April, 2008, REV1.2 Low-Voltage, 2.8Ω SPDT Analog Switch Packaging Mechanical: 6-Pin SC70 (C) Packaging Mechanical: 6-Pin TDFN www.broadchip.com
BCT4157EXT-TR 价格&库存
很抱歉,暂时无法提供与“BCT4157EXT-TR”相匹配的价格&库存,您可以联系我们找货
