RTCS0300
Precision DC Ammeter Shunt
Precision Shunt, Rated Current 300A, Standard Tolerance 0.1%
Low Thermal EMF, TCR ±20ppm/℃
Shunt works at very high current, so the temperature of surface rises sharply which will
cause the change of resistance. For precision measurement, we must choose shunts
which are with low TCR, low PCR and low Thermal EMF.
Resi launched the precision shunt series which can reach 0.1% 10% to 100% of rated
current. The maximum TCR is ±20ppm/℃ in the range of -20℃ to +120℃. Besides, the
shunt has extreme stability with low PCR and low Thermal EMF.
Dimensions(mm)
102±0.5
39.5±0.5
29.5±0.5
61±0.5
300A / 50mV
230101001
2-M3
125±1
2-M10
Model
Resistance
Tolerance
TCR
Output Voltage
Rated Current
Max. Current
Weight
RTCS0300B050Z00
166.6μΩ
±0.1%
±20ppm/℃
50mV
300A
360A
711±10g
104±0.5
29.5±0.5
29.5±0.5
61±0.5
300A / 75mV
230101001
2-M3
125±1
2-M10
Model
Resistance
Tolerance
TCR
Output Voltage
Rated Current
Max. Current
Weight
RTCS0300B075Z00
250μΩ
±0.1%
±20ppm/℃
75mV
300A
360A
531±10g
Performance
Test
Test Method
Standard
Optimum Surface Temperature
Measured at the center of metal strip
+30℃~+90℃
Operating Temperature Range
- 40℃~+140℃
Maximum Surface Temperature
+140℃
Thermal EMF
When reach heat balance, disconnect the circuit and test EMF
<0.05 μV/℃
TCR
Measured temperature range of -25℃ to +120℃, +25℃ Ref.
≤±20ppm/℃
Current Coefficient
10%-100% Rated Current Test
≤±5ppm/A
Short Time Overload
2.25 rated voltage for 5 seconds
△R≤±0.05%
Long Time Overload
1.2 rated voltage for 2 hours, +25°C
△R≤±0.1%
Thermal Equilibrium Time
Measured at the center of metal strip when resistance won‘ t change
<5min
C&B Electronics Shenzhen Co.,Ltd| www.resistor.today | resi@cbeureka.com | Tel:0755-83981080/83981010
No.: E18020Version:
E18018Version: V4
V3
Date: 2022/12/26
RTCS0300
Custom Service for Your Application (CTS Service)
Each shunt requires precise trimming of value. The main challenge in the trimming process is to reach tight tolerance both at 10% of rated current and
100% rated current. It is known that the temperature curve of Manganin material is not linear, so to adjust the surface temperature of metal strip to the
optimum surface temperature is the only way to achieve tight tolerance .
CTS is a free customized trimming service. It will estimate customer's working condition and the average surface temperature of the shunt, and then
provides the best resistance for precision measurement. CTS can significantly improve the tolerance. Each CTS product will be assigned with a
unique identification code.
We will provide test reports for every CTS product for free.
If you are interested in CTS service, please contact our sales engineers with below required information.
Minimum Operating Current
Minimum Ambient Temperature
Maximum Operating Current
Maximum Ambient Temperature
Working Current Curve
Ambient Temperature Curve
Final Product
Installation Method
Final Product Working Condition
Heat Dissipation Condition
Design Lifetime
Installation Notes or Picture
Note
Reverse Installation Advice
(1) During the installation of the shunt, it shall be ensured that the copper head is in close contact with the bus bar, and the contact area between the
copper head and the bus bar shall be as large as possible. If conditions permit, the size of the bus bar shall be as large as possible and the bus bar
shall be clean.
Reverse Installation Example
电压采样接入口
Voltage Terminal
电流接入口
Current
(2) According to the IEEE standards, the operating current should not be higher than 2/3 of the rated current under the normal conditions.
(3) Derating is required when the ambient temperature is higher than 40 °C to avoid damaging the shunt.
(4) Air cooling, water cooling, increased physical size, and installation of heat sinks can be used to reduce operating temperature.
(5) It is recommended to wear gloves when installing the shunt to prevent oil contamination.
(6) The surface of the copper bar used for installing the shunt shall be smooth and clean. It is recommended that the surface be plated with nickel or tin to reduce the contact resistance.
(7) Recommended Installation Torque
No.
Bolt Size
Recommended Torque (N.m)
1
M3
0.4~0.8
2
M10
15~25
No.: E18020Version:
E18018Version: V4
V3
Date: 2022/12/26
RTCS0300
Storage Instructions
(1) The shunt shall be stored at a temperature of 5 to 35 ° C, humidity
很抱歉,暂时无法提供与“RTCS0300B050Z00”相匹配的价格&库存,您可以联系我们找货
