WAN5010FD25N07
WAN5010FD25N07
    ONEWAVE(万诚)
    SMD,5x1mm
    芯片天线5010 M-Ant 2.45G+5G 07型
WAN5010FD25N07 数据手册
承 認 書 SPECIFICATION FOR APPROVAL 客戶名稱 CUSTOMER : 客戶料號 CUSTOMER’S P/N : 料號 PART NUMBER : WAN5010FD25N07 規格 DESCRIPTION : Chip Antenna 5010 M-Ant 2.45G + 5G Type 07 版本 VERSION : V1.1 日期 ISSUE DATE : 2023/06/14 客 戶 承 認 CUSTOMER APPROVED 工 程 部 R&D CENTER 承 認 APPROVAL 確 認 CHECKED 製 作 DRAWN Ray Tennyson Snow 萬誠科技股份有限公司 OneWave Electronic Co., Ltd. 112 台北市北投區立功街 151 號 1 樓 1F, No. 151, Li Gong Street, Beitou District, Taipei City 112, Taiwan TEL: +886 2 2898-2220 FAX: +886 2 2898-5055 電話: (02) 2898-2220 傳真: (02) 2898-5055 5010 Chip antenna For WLAN Dual-Band Applications P/N: WAN5010FD25N07 Dimension (mm) L 5.02 ± 0.20 W 1.12 ± 0.20 T 1.25 ± 0.20 ONEWAVE TECHNOLOGY CO., LTD. 2/12 Part Number Information WAN 5010 A A B C D E F B FD 25 N 07 C D E F Product Series Dimension L x W Material Working Frequency Feeding mode Antenna type Antenna 5.0X1.0mm (+-0.2mm) High K material 2.4 ~ 2.5GHz & 5.15~5.85GHz Monopole & Single Feeding Type = 07 1. Electrical Specification Specification Part Number WAN5010FD25N07 Central Frequency 2450 / 5500 MHz Bandwidth 100 / 800 (Min.) MHz Return Loss -10 (Max) dB Peak Gain 4.00 / 5.47 dBi Impedance 50 Ohm Operating Temperature -40~+110 ℃ Maximum Power 4 W Resistance to Soldering Heats 10 ( @ 260℃) sec. Polarization Linear Azimuth Beamwidth Omni-directional Termination Cu / Sn (Leadless) Remark : Bandwidth & Peak Gain was measured under evaluation board of next page ONEWAVE TECHNOLOGY CO., LTD. 3/12 2. Recommended PCB Pattern Evaluation Board Dimension Suggested Matching Circuit 重要資訊 : 匹配元件建議使用精準度高的電感±0.1~0.3nH、電容±0.1pF 1.5nH 1.9pF ONEWAVE TECHNOLOGY CO., LTD. 4/12 ◆ Layout Dimensions in Clearance area( Size=10.0*3.5mm) 50 ohm transmission Line Matching circuit FootPrint (Unit : mm) ONEWAVE TECHNOLOGY CO., LTD. 5/12 3. Measurement Results Return Loss ONEWAVE TECHNOLOGY CO., LTD. 6/12 Radiation Pattern Y Z X Efficiency Peak Gain Directivity 2400MHz 49.58 % 3.55 dBi 6.60 dBi 2450MHz 57.08 % 4.00 dBi 6.43 dBi 2500MHz 50.89 % 3.35 dBi 6.29 dBi Efficiency Peak Gain Directivity 5150MHz 61.26 % 5.35 dBi 7.48 dBi 5500MHz 57.08 % 5.47 dBi 7.31 dBi 5850MHz 68.48 % 5.64 dBi 7.28 dBi Y Z X ONEWAVE TECHNOLOGY CO., LTD. 7/12 Chamber Coordinate System ONEWAVE TECHNOLOGY CO., LTD. 8/12 4.Reliability and Test Condictions ITEM REQUIREMENTS TEST CONDITION Solderability 1. Wetting shall exceed 90% coverage 2. No visible mechanical damage Pre-heating temperature:150℃/60sec. Solder temperature:230±5℃ Duration:4±1sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin TEMP (℃) 4±1 sec. 230℃ 150℃ 60sec Solder heat Resistance 1. No visible mechanical damage 2. Central Freq. change :within ± 6% TEMP (℃) 10±0.5 sec. 260℃ Pre-heating temperature:150℃/60sec. Solder temperature:260±5℃ Duration:10±0.5sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin 150℃ 60sec Component Adhesion (Push test) .. 1. No visible mechanical damage Component Adhesion (Pull test) 1. No visible mechanical damage Thermal shock 1. No visible mechanical damage 2. Central Freq. change :within ±6% Phase Temperature(℃) Time(min) 1 +110±5℃ Room Temperature 30±3 Within 3sec -40±2℃ Room Temperature 30±3 Within 3sec 2 3 4 Resistance to High Temperature 1. No visible mechanical damage Resistance to Low Temperature 1. No visible mechanical damage Humidity 1. No visible mechanical damage 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. The device should be reflow soldered(230±5℃ for 10sec.) to a tinned copper substrate A dynometer force gauge should be applied the side of the component. The device must with-ST-F 0.5 Kg without failure of the termination attached to component. Insert 10cm wire into the remaining open eye bend ,the ends of even wire lengths upward and wind together. Terminal shall not be remarkably damaged. +110℃=>30±3min -40℃=>30±3min Test cycle:10 cycles The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature: +110±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature:-40±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Temperature: 40±2℃ Humidity: 90% to 95% RH Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. ONEWAVE TECHNOLOGY CO., LTD. 9/12 5.Soldering and Mounting Mildly activated rosin fluxes are preferred. The minimum amount of solder can lead to damage from the stresses caused by the difference in coefficients of expansion between solder, chip and substrate. The terminations are suitable for all wave and re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. Iron Soldering Reflow Soldering PRE-HEATING SOLDERING TEMPERATURE(°C) 10s max. 250~260 230 180 150 60~120 s SOLDERING NATURAL COOLING 30~60s within 3s TEMPERATURE(°C) PRE-HEATING NATURAL COOLING 350 300 150 Gradual cooling Over 60s TIME(sec.) TIME(sec.) Recommended temperature profiles for re-flow soldering in Figure 1. Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. ‧Preheat circuit and products to 150℃ ‧Never contact the ceramic with the iron tip ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧280℃ tip temperature (max) ‧1.0mm tip diameter (max) ‧Limit soldering time to 3 sec. ONEWAVE TECHNOLOGY CO., LTD. 10/12 6.Packaging Information ◆ W 12.0 ±0.30 ◆ Tape Specification: Ao 1.30 ±0.10 Bo 5.50 ±0.10 Ko 1.50 ±0.10 P 4.00 ±0.10 F 5.50 ±0.05 E 1.75 ±0.10 D 1.50 ±0.10 D1 0.50 ±0.10 Po 4.00 ±0.10 P2 2.00 ±0.10 t 0.25 ±0.05 Reel Specification: (7’’, Φ180 mm) Tape Width(mm) A(mm) 12 12±1.0 B(mm) 60±2 C(mm) D(mm) Chip/Reel(pcs) 13.5±0.5 178±2 ONEWAVE TECHNOLOGY CO., LTD. 3000 11/12 7.Storage and Transportation Information Storage Conditions To maintain the solderability of terminal electrodes: 1. Temperature and humidity conditions: -10~ 40℃ and 30~70% RH. 2. Recommended products should be used within 6 months from the time of delivery. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. Transportation Conditions 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. ONEWAVE TECHNOLOGY CO., LTD. 12/12
WAN5010FD25N07 价格&库存
很抱歉,暂时无法提供与“WAN5010FD25N07”相匹配的价格&库存,您可以联系我们找货
