PCX2347J35474
PCX2347J35474
    PILKOR(飞尔)
    插件,P=22.5mm
    薄膜电容 插件,P=22.5mm 0.47μF ±10% 310V 26.00 x 8.50mm
PCX2347J35474 数据手册
规 格 承 认 书 SPECIFICATIONS FOR APPROVAL 客户名称 CUSTOMER 产品名称 PRODUCTS 规格描述 DESCRIPTION 型号编码 OUR 'S P/N 日 期 ISSUED DATE : 深圳华秋电子有限公司 : PILKOR电容 : X2 0.47uF K 310VAC P=22.5mm L=25mm : PCX2 347J35474 : 2024年8月1日 客户确认(CUSTOMER'S APPROVAL ): 深圳市润德福电子有限公司 Tel:0755-88251887 Fax:0755-88251897 PILKOR Electronics Series Impedance Film capacitors PCX2 347 MKT RADIAL POTTED CAPACITORS Pitch 10.0/15.0/22.5/27.5mm 10.0 and 15.0mm 22.5 and 27.5mm QUICK REFERENCE DATA Capacitance range (E6 series) * 0.01㎌ ㎌ to 2.2㎌ ㎌ Capacitance tolerance ± 10 %, ± 20 % Rated (AC) voltage 50 to 60 Hz 310 V~ Climatic category 55/110/56 Temperature range -55℃ ℃ ~ +110℃ ℃ Reference IEC, UL specification IEC 60384-14(3rd edition) and UL60384-14 Safety approvals ENEC, KC, CQC UL60384-14 Potting & Encapsulation material Qualified in accordance with UL 94V-0 Safety class X2 * Intermediate values of the E12 series are available to special order FEATURES . 10.0 to 27.5 mm lead pitch . Supplied loose in box and taped on reel . Consist of a low-inductive wound cell of Metallized Polyester film, potted in a flame retardant case APPLICATIONS . For X2-electromagnetic interference suppression . Specially designed to meet the NEW REQUIREMENTS in new IEC 60384-14 specification(3rd edition)/UL 60384-14 requiring for X2 a 2.5kV peak pulse voltage test . Energy meter . Stable capacitance in damp environment 85℃ ℃85%RH, 240Vac, 1000hours • Please refer to caution and warning at http://www.pilkor.co.kr/sub/download/introductions.pdf before using these products. Main application _ In series with the powerline ( capacitive power supply ) Ordering Information 149 Aug 2020 PILKOR Electronics Series Impedance Film capacitors PCX2 347 l b l h h H lt P dt P0 PCX2 347 X X X XXX Capacitance Code 3 Voltage 310V Code D F J L Original Pitch 10.0 mm 15.0 mm 22.5 mm 27.5 mm Available versions Product (lmax) Hole to hole ( Po) 12.5 18.0 26.0 31.0 code Packing method C – tol. Lead length & Height 0 Loose in box ±20% lt = 5.0±1.0mm - 10.0 15.0 22.5 27.5 1 Loose in box ±10% lt = 5.0±1.0mm - 10.0 15.0 22.5 27.5 4 Loose in box ±20% lt =25.0±2.0mm - 10.0 15.0 22.5 27.5 5 Loose in box ±10% lt =25.0±2.0mm - 10.0 15.0 22.5 27.5 6 Ammopack ±20% H = 18.5mm* 12.7mm 10.0 15.0 22.5 27.5 7 Ammopack ±10% H = 18.5mm* 12.7mm 10.0 15.0 22.5 27.5 Pitch (P) * H ; intape height ; for detailed specifications refer to chapter PACKAGING ** Some values is not following the coding rule. SAFETY APPROVALS 150 Aug 2020 PILKOR Electronics Series Impedance Film capacitors PCX2 347 SAFETY APPROVALS Voltage Value File Number UL60384-14 310V(AC) 0.01㎌ to 2.2㎌ E165646 ENEC(SEMKO) * 310V(AC) 0.01㎌ to 2.2㎌ SE-ENEC-2001434R1 EK 310V(AC) C ≤ 0.1㎌ 0.1㎌ < C ≤ 0.33㎌ 0.33㎌ < C ≤ 1.0㎌ SH03001-14001 SH03001-14002 SH03001-14003 CQC 310V(AC) 4.7nF to 2.2㎌ CQC16001153987 * The ENEC-approval together with the CB-Certificate replace all national approval marks of the following countries(they have already signed the ENEC-Agreement): Austria; Belgium; Czech. Republic; Denmark; Finland; France; Germany; Greece; Hungary; Ireland; Italy; Luxembourg; Netherlands; Norway; Portugal; Slovenian; Spain; Sweden; Switzerland and United Kingdom *Approval number (File No.) of safety regulations are subject to revision without notice Packaging Information SMALLEST PACKING QUANTITIES (SPQ) LOOSE IN BOX DIMENSIONS lt = 5.0 ± 1.0 mm lt = 25 ± 2.0 mm 4.0 x 10.0 x 12.5 5.0 x 11.0 x 12.5 6.0 x 12.0 x 12.5 6.0 x 12.0 x 18.0 7.0 x 13.5 x 18.0 8.5 x 13.5 x 18.0 8.5 x 15.0 x 18.0 10.0 x 16.5 x 18.0 11.0 x 18.5 x 18.0 7.0 x 16.5 x 26.0 8.5 x 18.0 x 26.0 10.0 x 19.5 x 26.0 12.0 x 22.0 x 26.0 16.5 x 22.0 x 26.0 2000 1500 1000 1000 1000 1000 1000 1000 1000 1000 500 500 500 250 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 500 500 500 250 9.0 x 19.0 x 31.0 10.0 x 20.0 x 31.0 11.0 x 21.0 x 31.0 13.0 x 23.0 x 31.0 21.0 x 31.0 x 31.0 500 500 500 250 150 500 250 250 250 150 151 Aug 2020 PILKOR Electronics Series Impedance Film capacitors PCX2 347 SPECIFIC REFERENCE DATA FOR 310 VAC Tangent of loss angle C ≤ C> 1 ㎌ 1 ㎌ at 1 khz at 10 khz ≤ 80 x 10 -4 ≤ 80 x 10 –4 ≤ 150 x 10 -4 - Rated voltage pulse slope (dV/dt)R 100 V/㎲ R between leads, for C ≤ 0.33 ㎌ 〉15 000 ㏁ RC between leads, for C > 0.33 ㎌ 〉5 000 s Withstanding(DC) Voltage (cut-off current 10mA) 4.3* VR, 1min Withstanding(AC) Voltage between leads and case 2400V VRac = 310V~ X2 Cap. (㎌ ㎌) 0.01 0.015 0.022 0.033 0.047 0.068 0.082 0.1 0.1 0.15 0.22 0.33 0.47 0.33 0.47 0.68 1.0 1.5 0.47 0.68 1.0 1.5 2.2 1min loose and taped bxhxl (mm) MASS (g) lt = 5 C – tol. ± 20 % Pitch = 10.0 ± 0.4 mm 4.0 x 10.0 x 12.5 0.8 D30103 4.0 x 10.0 x 12.5 0.8 D30153 4.0 x 10.0 x 12.5 0.8 D30223 5.0 x 11.0 x 12.5 0.9 D30333 5.0 x 11.0 x 12.5 0.9 D30473 6.0 x 12.0 x 12.5 1.0 D30683 6.0 x 12.0 x 12.5 1.0 D30823 6.0 x 12.0 x 12.5 1.0 D30104 Pitch = 15.0 ± 0.4 mm 1.4 F30104 6.0 x 12.0 x 18.0 7.0 x 13.5 x 18.0 1.9 F30154 8.5 x 15.0 x 18.0 2.6 F30224 10.0 x 16.5 x 18.0 3.1 F30334 11.0 x 18.5 x 18.0 4.1 F30474 Pitch = 22.5 ± 0.4 mm 7.0 x 16.5 x 26.0 3.2 J30334 8.5 x 18.0 x 26.0 4.4 J30474 10.0 x 19.5 x 26.0 5.5 J30684 12.0 x 22.0 x 26.0 9.0 J30105 16.5 x 22.0 x 26.0 10.0 J30155 Pitch = 27.5 ± 0.4 mm 9.0 x 19.0 x 31.0 5.5 L30474 10.0 x 20.0 x 31.0 6.5 L30684 11.0 x 21.0 x 31.0 7.8 L30105 13.0 x 23.0 x 31.0 10.4 L30155 21.0 x 31.0 x 31.0 20.5 L30225 CATALOGUE NUMBER PCX2 347...... loose in box ± 1.0 mm lt = 25 ± 2.0 mm C – tol. C – tol. C – tol. ± 10 % ± 20 % ± 10 % dt = 0.6 +0.06/-0.05 mm D31103 D34103 D35103 D31153 D34153 D35153 D31223 D34223 D35223 D31333 D34333 D35333 D31473 D34473 D35473 D31683 D34683 D35683 D31823 D34823 D35823 D31104 D34104 D35104 dt = 0.8 +0.08/-0.05 mm F31104 F34104 F35104 F31154 F34154 F35154 F31224 F34224 F35224 F31334 F34334 F35334 F31474 F34474 F35474 dt = 0.8 +0.08/-0.05 mm J31334 J34334 J35334 J31474 J34474 J35474 J31684 J34684 J35684 J31105 J34105 J35105 J31155 J34155 J35155 dt = 0.8 +0.08/-0.05 mm L31474 L34474 L35474 L31684 L34684 L35684 L31105 L34105 L35105 L31155 L34155 L35155 L31225 L34225 L35225 152 Aug 2020 PILKOR Electronics Series Impedance Film capacitors PCX2 347 MOUNTING NORMAL USE The capacitors are designed for mounting on printed-circuit boards. The capacitors packed in bandoliers are designed for mounting on printed-circuit boards by means of automatic insertion machines. For detailed specifications refer to chapter "PACKAGING". SPECIFIC METHOD OF MOUNTING TO WITHSTAND VIBRATION AND SHOCK In order to withstand vibration and shock tests, it must be ensured that the stand-off pips are in good contact with the printed-circuit board. . For pitches of 15mm the capacitors shall be mechanically fixed by leads. . For larger pitches the capacitors shall be mounted in the same way and the body clamped. SPACE REQUIREMENTS ON PRINTED-CIRCUIT BOARD The maximum length and width of film capacitors are shown in the following drawing ; b max = b + 0.3mm Eccentricity Imax = I +0.3 mm - Product height with seating plane as given by IEC 60717 as reference : hmax ≤ h+0.3mm STORAGE TEMPERATURE . Storage temperature : Tstg = -25 to +40 oC with RH maximum 80% without condensation. RATINGS AND CHARACTERISTICS Unless otherwise specified all electrical values apply to an ambient temperature of 23± 1℃, an atmospheric pressure of 86 to 106kPa and a relative humidity 50± 2%. For reference testing, a conditioning period shall be applied of 96± 4 hours by heating the products in a circulating air oven at the rated temperature and a relative humidity not exceeding 20%. Maximum RMS Voltage as a function of frequency 103 AC voltage (V) 102 101 101 102 103 104 f(Hz) 105 AC voltage (RMS value) as a function of frequency at Tamb≤110℃ APPLICATION NOTE To ensure withstanding high humidity requirements in the application it is recommended not to damage the epoxy adhesion at the leads. Therefore the leads may not be damaged or bent before soldering. 153 Aug 2020 PILKOR Electronics Series Impedance Film capacitors PCX2 347 PRODUCT MARKING Capacitors are marked with having following information; 1.Manufacturer (PILKOR) 2.Manufacturer's type designation (PCX2 347 ) 3.Rated capacitance in code according to IEC 60062 4.Rated (AC) voltage (310V~) 5.Sub class (X2) 6.Tolerance on rated capacitance M =± 20 % K = ± 10 % 7.Climatic category (55/110/56) 8.Metallized polyester film (MKT) 9.Year and week of manufacturing (e.g 1401) 10.Safety approvals * white or black color Example of marking 10n M 310V~ X2 347 PILKOR 2030 Marking on the side or top 10n M 310V~ X2 347 PILKOR 2030 Marking on the side or top PILKOR 2030 150n M 310V~ X2 PCX2 347 MKT 55/110/56 Marking on the top Marking on the side 1μ M 310V~ X2 PCX2 347 MKT PILKOR 2030 55/110/56 Marking on the top 154 Aug 2020
PCX2347J35474 价格&库存
很抱歉,暂时无法提供与“PCX2347J35474”相匹配的价格&库存,您可以联系我们找货
PCX2347J35474
  • 1+1.59500
  • 30+1.54000
  • 100+1.43000
  • 500+1.32000
  • 1000+1.26500
  • 2000+1.21000
库存:6
