FFTP-15-D-08.77-01-N-R 数据手册
F-211-1
(1,27mm) .050"
FMTP–10–D–03.85–01
FFTP–20–D–08.77–01–N
FFTP, FMTP SERIES
TIGER EYE TWISTED PAIR IDC CABLES
Mates with:
FTS, FTSH, EHF, SHF
PINS
PER ROW
FFTP
SPECIFICATIONS
END
ASSEMBLY
For complete specifications
see www.samtec.com?FFTP
Insulator Material: PBT
Contact: BeCu
Plating: 10µ" (0,25µm)
Au over 50µ" (1,27µm)
Ni on contact area; Sn over
50µ" (1,27µm) Ni on balance
Wire: 30 AWG 7/40,
Tinned, Twisted Pair
with PVC insulator
Current Rating: 0.5A
Operating Temp Range:
-40°C to +105°C
Lead Size Accepted:
(0,41mm) .016" SQ
Contact Resistance:
15 mΩ max delta from initial
Insertion Depth:
(2,64mm) .104" to
(3,17mm) .125"
Insertion Force:
(Single contact only)
5oz (1,39N) avg.
Withdrawal Force:
3oz (0,83N) avg.
RoHS Compliant: Yes
–D
–05, –08 –10, –13,
–17, –20, –25
= (97,79mm) 3.85"
N
OPTION
–N
= Reverse
Connector
= Notch
Polarization
(Standard)
–08.77
–R
= (222,76mm) 8.77"
ASSEMBLY LENGTH
–18.00
(1,90)
.075
No. of
positions
x
(1,27)
.050
(4,19)
.165
(1,02) .040
= (457,20mm) 18.00"
Other sizes and lengths available.
Contact Samtec.
–R
FFTP
(3,05)
.120
Rated @ 7dB Insertion Loss
Cable
Length
–SE
3.85" (97,8mm)
FMTP
PINS
PER ROW
END
ASSEMBLY
see www.samtec.com?FMTP
Terminal: BeCu
Plating: Sn over 50µ"
(1,27µm) Ni
Wire: 30 AWG 7/40, Tinned,
Twisted Pair with PVC insulator
-40°C to +105°C
RoHS Compliant: Yes
2.0 GHz / 4.00 Gbps
Performance data for other cable lengths and complete test data
available at www.samtec.com?FFTP or contact sig@samtec.com
(5,08)
.200
–D
SPECIFICATIONS
ASSEMBLY
LENGTH
–D
–03.85
–05, –08, –10,
–13, –17, –20, –25
= Double End
= (97,79mm)
3.85"
(Call for other sizes)
= Transfer End
–T
–08.77
= (222,76mm)
8.77"
ASSEMBLY LENGTH
01
Other cable lengths available.
Call Samtec.
(3,05)
.120
–R
–D
(1,27)
.050
(0,41) .016 SQ
WWW.SAMTEC.COM
(3,07)
.121
OPTION
–R
= (457,20mm)
18.00"
Other sizes and
lengths available.
Contact Samtec.
(5,08)
.200
TRANSFER
OPTION
Leave blank for
–D End Assembly.
For –T End Assembly
Specify “–N”
(Socket has notch
polarization)
–18.00
No. of
positions
x
(1,27)
.050
(4,19)
.165
APPLICATION
SPECIFIC
OPTION
APPLICATION
*Note: Standard FMTP callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates wth Pin 1, etc.
Note: This Series is
non-standard, non-returnable.
01
–03.85
= Double
End
Mates with:
FLE*, SFMC*
ASSEMBLY
LENGTH
–T
= Reverse
Connector
