F-215 (Rev 25JUN15)
IPT1–110–04–L–D
IPT1–110–01–L–D
(2,54 mm) .100"
IPT1–125–01–L–D–RA
IPT1–105–01–L–D–VS
IPT1 SERIES
SHROUDED POWER CONNECTOR SET
SPECIFICATIONS
Mates with:
IPS1
Each pin individually
shrouded for electrical
and mechanical protection
For complete specifications
see www.samtec.com?IPT1
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over 50µ" (1.27 µm) Ni
Operating Temp Range:
-55°C to +105°C with Tin;
-55°C to +125°C with Gold
Insertion Depth:
(3.81 mm) .150" to
(6.48 mm) .255"
PINS
Wiping Distance:
(0.38 mm) .015"
1
Insertion Force (SMT):
2
3.0 oz (0.83 N) avg.
3
Withdrawal Force (SMT):
2.6 oz (0.72 N) avg.
4
Insertion Force (T/H):
ALL
6.0 oz (1.67 N) avg.
Withdrawal Force (T/H):
5.0 oz (1.39 N) avg.
Voltage Rating:
775 VAC/1095 VDC
RoHS Compliant: Yes
Processing:
Lead–Free Solderable: Yes
SMT Lead Coplanarity:
(0.13 mm) .005" max (05-10)
(0.15 mm) .006" max (15-25)
(6.35 mm)
.250"
IPT1/IPS1
CURRENT RATING
(PER CONTACT)
5.9 A
4.8 A
4.1 A
3.6 A
2.3 A
Choice of
Through-Hole,
Right Angle or
Surface Mount
• Locking clip
option
IPT1
1
NO. PINS
PER ROW
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
05, 10, 15, 20, 25
(Standard sizes)
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
= 10µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–02
IPS1
–03
No. of positions x (2.54) .100
+ (0.51) .020
IPT1
02
–04
–05
50
(5.08)
.200
(2.54) 01
.100
(MOQ Required)
• Other sizes
• Other platings
• Latching feature
• No. 1 position polarized
Contact Samtec.
Requires –01
Lead Style
(Leave blank for
Through-Hole)
LEAD MATED
B
STYLE HEIGHT A
(11.05) (6.35) (2.16)
–01
.435
.250 .085
(6.35) N/A
-01-VS (13.59)
.535
.250
MATED
HEIGHT
Through-hole
–06
–07
–08
(2.54)
.100
49
–09
Surface Mount
(14.00)
.551
(16.00)
.630
(17.00)
.669
(19.00)
.748
(20.00)
.787
(25.00)
.984
(30.00)
1.181
(35.00)
1.378
(9.30) (2.64)
.366 .104
(11.30) (2.16)
.445 .085
(12.30) (2.69)
.484 .106
(14.30) (2.46)
.563 .097
(15.30) (2.35)
.602 .093
(20.30) (2.31)
.799 .091
(25.30) (2.39)
.996 .094
(30.30) (2.46)
1.193 .097
A (1.27)
.050
(0.51)
.020
–RA
= Right Angle
–VS
= Surface Mount
–A
= Alignment Pin
(–VS only)
(N/A with -LC)
–LC
= Locking Clip
(Manual
placement
required)
(–VS only)
(N/A with -A)
–K
–TR
(1.50)
.060
–VS
(2.54) .100
(0.64) .025 SQ
–RA
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
OTHER
OPTION
= (6.00 mm)
.236" DIA
Polyimide film
Pick & Place Pad
(–VS only)
(2.30)
.090
(7.16)
.282
A
B
TAIL
OPTION
D
–L
APPLICATION
ALSO AVAILABLE
• Individually
shrouded
contacts
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= Tape & Reel
Packaging
(–VS only)
很抱歉,暂时无法提供与“IPT1-115-03-S-D”相匹配的价格&库存,您可以联系我们找货
