F-215
ISDF–07–D–M
SYSTEM
ISDF–10–D–S
(1,27 mm) .050"
CC03R–2830–01–G
ISDF, CC03R, CC03M, TFM SERIES
DISCRETE WIRE COMPONENTS & TOOLING
SPECIFICATIONS
For complete specifications
see www.samtec.com?ISDF,
www.samtec.com?CC03R or
www.samtec.com?CC03M
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
TOOLING
• Hand tool:
CAT-HT-203-2830-12
• Clamp for mounting
hand tool to work table:
CAT-HT-MNT-01
TYPE
ISDF
= Housing
Insulator
Material:
Black LCP
(1,27)
.050
POSITIONS
PER ROW
–03, –04,
–05, –07,
–10, –15,
–20, –25,
–40, –50
OPTION
= Double Row
–S
(5,08)
.200
= Screw
Down
(–D only)
–S
(2,03) .080
–D
–M
NO. PINS
PER ROW
PLATING
= Gold flash
on contact
–G
= 10µ"
(0,25 µm)
Gold on
contact
(0,38)
.015
(1,27)
.050
DIA
(15,37)
.605
(1,78)
.070
Note: Some lengths, styles
and options are non-standard,
non-returnable.
1
= 28 to 30 AWG
= Contact,
Mini Reel
(5,000 Parts
per Reel)
(3,68)
.145
(6,32)
.249
TFM
–2830
= Contact,
Full Reel
(35,000 Parts
per Reel)
(2,00)
.079
DIA
(1,27)
.050
(2,03)
.080
(1,27)
.050
CC03R
CC03M
(11,18)
.440
(6,35)
.250
01
–GF
= Metal
Retention
Latch
–D
No. of Positions
x (1,27) .050
+ (0,38) .015
WIRE
GAUGE
TYPE
–M
–S
= Single Row
(Standard sizes)
• Mini Applicator:
CAT-MA-203-2830-XX-01
Mates with:
SFSD(T), SFSS(T)
ROW
OPTION
(3,81)
.150
(1,91)
.075
–S
LEAD
STYLE
(3,81)
.150
PLATING
OPTION
Contact Material:
BeCu
ROW
OPTION
OPTION
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TFM
03, 04, 05, 07, 10,
15, 20, 25, 40, 50
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
OTHER
Au or Sn over
50µ" (1,27 µm) Ni
SOLUTIONS
Voltage Rating:
250 VAC mated with SFM
• Many other options
Operating Temp Range:
available. See TFM,
-55°C to +125°C
TFML, TFC Series
RoHS Compliant: Yes
Processing:
RECOGNITIONS
For complete scope
of recognitions see
FILE NO: 090871_0_000
–L
–S
= 15µ" (0,38 µm)
Gold on post,
Matte Tin on tail
= Single Row
–02
(1,27) .050 x
No. of Positions + (3,18) .125
(4,45)
.175
= Double Row
(2,79)
.110
01
02
(See website for –DS & –WT OAL)
–REX = (1,27) .050 x
No. of Positions + (6,68) .263
(1,27)
.050
(5,72)
.225
(0,46)
.018 DIA
–DS
–D
= Surface Mount
or contact Samtec.
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (05-25)
(0,15 mm) .006" max (30-50)
–01
= Through-hole
–WT
–WT
01
(1,27) .050
(5,59)
.220
(1,97) .078
(2,35)
.093
(0,64)
.025
(5,72)
.225
(0,36) .014
SURFACE MOUNT
(3,81)
.150
–DS
THROUGH-HOLE
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= Dual Screw
Down for
(1,60 mm)
.062" PCB
(05, 07, 10, 15,
20, 25, 40
positions only)
(Requires –D
row option)
(Mates with
SFSD/SFSDT
–SS and –DS
option only)
(1,99)
.079
= Weld Tab
(Mates to
SFSS/SFSD
–SR and –DR
option only)
(05, 07, 10, 15,
20, 25, 40, 50
positions only)
