MTLW-105-22-G-D-280
MTLW-105-22-G-D-280
    SAMTEC(申泰)
    CONN HEADER VERT 10POS 2.54MM
MTLW-105-22-G-D-280 数据手册
F-218 MTLW–130–05–G–S–110 TLW–118–06–T–D (2.54 mm) .100" TLW, MTLW SERIES LOW-PROFILE .025" SQ POST HEADERS Board Mates: BSW, CES, SLW, HLE 1 TLW Cable Mates: SMSD, SMSS NO. PINS PER ROW PLATING OPTION Specify LEAD STYLE from chart = Gold flash on post, Matte Tin on tail = Single Row –G = Double Row –F FEATURES 01 thru 40 These headers provide = Single Row the ultimate low-profile (0.64 mm) .025" square (2.54) .100 x No. of Positions post board stacking system. The 40 01 high quality (2.54) TLW .100 Phosphor (6.60) TYP CES = .260 Bronze terminals (6.09) SLW = .240 are available with a = Double Row standard short post height 02 72 (TLW Series) for mating (2.54) with low-profile sockets, .100 or the post height can be Modified (MTLW Series) 01 71 to accommodate IDC assemblies and other applications. (1.52) .060 (2.48) .098 01 thru 36 SPECIFICATIONS MTLW For complete specifications see www.samtec.com?TLW or www.samtec.com?MTLW Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (TLW/SLW): 5.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold RoHS Compliant: Yes Lead–Free Solderable: Yes 1 C C (3.05) .120 (1.52) .060 A (0.64) .025 –01 –05 & –06 (5.03) .198 ROW OPTION LEAD STYLE LEAD STYLE A C – 01 N/A – 05 (4.32) .170 (3.43) .135 (5.84) .230 (2.67) .105 (2.67) .105 – 06 = 10 µ" (0.25 µm) Gold on post, Gold flash on tail –S –D OTHER OPTION –RA = Right-angle (–01 Lead Style only) –“XX” = Polarized Position Specify position for omitted pin. –T = Matte Tin ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. NO. PINS PER ROW 01 thru 40 LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = Single Row ROW OPTION POST HEIGHT –S –“XXX” = Single Row –D = Post Height Dimension (In inches) = Double Row (2.54) .100 x No. of Positions POST (0.00) .000 MIN 40 (2.54) .100 TYP 01 (2.48) .098 01 thru 36 RECOGNITIONS 02 72 –06 (5.03) .198 FILE NO. E111594 (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. MTLW Series is non-standard, non-returnable. 01 (0.64) .025 SQ TAIL (0.00) .000 MIN LEAD STYLE – 05 = Double Row For complete scope of recognitions see www.samtec.com/quality (OAL) 71 –07 –08 –09 (1.52) .060 –10 –22 –23 –24 OAL (8.51) .335 (7.62) .300 (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (16.00) .630 (11.30) .445 (12.19) .480 –F = Gold flash on post, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –G = 10 µ" (0.25 µm) Gold on post, Gold flash on tail –T = Matte Tin Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
MTLW-105-22-G-D-280 价格&库存
很抱歉,暂时无法提供与“MTLW-105-22-G-D-280”相匹配的价格&库存,您可以联系我们找货
MTLW-105-22-G-D-280
    • 1+18.610301+2.41069
