MTMS-113-59-G-D-535
MTMS-113-59-G-D-535
    SAMTEC(申泰)
    CONN HDR .050" 26POS
MTMS-113-59-G-D-535 数据手册
F-218 MTMS–130–02–G–D–100 MTMS–110–02–G–D–100 MTMS–125–51–G–S–200 (1.27 mm) .050" MTMS, HMTMS SERIES MODIFIED MICRO TERMINAL Mates with: SMS, SLM, RSM SPECIFICATIONS For complete specifications see www.samtec.com?MTMS or www.samtec.com?HMTMS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold RoHS Compliant: Yes Position anywhere in the body with (3.05 mm) .120" minimum tail PROCESSING Ideal for board stacking applications Single row and double row Lead-Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE 01 thru 50 Specify LEAD STYLE from chart PLATING OPTION ROW OPTION POST HEIGHT OPTION –S –“XXX” –“XXX” FILE NO. E111594 ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail MTMS –G = Modified Standard = Single Row –D = Double Row = 10 µ" (0.25 µm) Gold on post, Gold flash on tail HMTMS = Modified High Temp (1.27) .050 x No. of Positions LEAD STYLE (2.48) .098 50 01 02 100 (2.54) .100 (4.98) .196 01 HMTMS –D BODY DESIGN 99 (1.27) .050 TYP (0.46) .018 SQ B (0.00) .000 MIN (2.54) .100 OAL (3.05) C .120 MIN* (0.51) .020 (0.51) .020 DIA SINGLE ROW Note: This Series is non-standard, non-returnable. DOUBLE ROW –01 –02 –25* –51 –52 –53 –54 –55 –56 –57 –58 –59 –60 = “B” Dimension (Specify Post Height in inches (0.13 mm) .005" increments) B OAL (Maximum when C = (3.05 mm) .120") (11.43) .450 (5.84) .230 (8.13) .320 (2.54) .100 (8.38) .330 (3.18) .125 (10.41) .410 (4.83) .190 (10.80) .425 (5.21) .205 (12.83) .505 (7.24) .285 (14.10) .555 (8.51) .335 (15.49) .610 (9.91) .390 (15.88) .625 (10.29) .405 (16.51) .650 (10.92) .430 (17.91) .705 (12.32) .485 (19.18) .755 (13.59) .535 (20.96) .825 (15.37) .605 *Style -25 tail C = (2.67 mm) .105" min is available. Tail DIA is .020" (0.51 mm) for min .120" (3.05 mm). Balance of tail is .018" (0.46 mm) SQ. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. = Polarized Position (Specify position of omitted pin)
MTMS-113-59-G-D-535 价格&库存
很抱歉,暂时无法提供与“MTMS-113-59-G-D-535”相匹配的价格&库存,您可以联系我们找货
