MTSW-102-09-T-S-485
MTSW-102-09-T-S-485
    SAMTEC(申泰)
    MODIFIED .025 SQUARE POST TERMIN
MTSW-102-09-T-S-485 数据手册
F-217 HMTSW–126–23–L–S–237 MTSW–117–09–G–D–383–RA (2.54 mm) .100" MODIFIED .025" SQ POST HEADERS Board Mates: SSW, SSQ, ESW, ESQ, BCS, BSW CES, SLW, HLE, SSM TYPE STRIP Cable Mates: IDSD, IDSS, SMSD, SMSS Modified .025" strips permit custom post heights. (0.13) .005 Samtec offers the greatest stacking flexibility in the industry. The “M” stands for Modified. You tell us the post height you need and we’ll deliver it. = (5.08 mm) .200" Pitch (2.54) .100 = Hi-Temp Modified Strip LEAD STYLE –2 = (2.54 mm) .100" Pitch HMTSW (5.08) .200 (0.13) .005 SPECIFY “LEAD STYLE” FROM CHART (2.54) .100 x No. of Positions (2.54) .100 50 02 MTSW SPECIFICATIONS For complete specifications see www.samtec.com?MTSW or www.samtec.com?HMTSW Insulator Material: MTSW: Black Glass Filled Polyester HMTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead–Free Solderable: MTSW: No, Wave Only HMTSW: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 –1 MTSW = Modified Strip (0.13) .005 NO. PINS PER ROW PIN PITCH Straight Pin Versions (2.54) .100 01 03 (2.54) (5.02) .100 .198 –D (2.54) .100 (5.08) (7.56) .200 .298 –T 148 150 (5.08) (7.56) .200 .298 (7.62) .300 01 MTSW –Q Right (3.02) (1.78) .119 .070 Angle Versions (8.12) .320 TAIL (0.00).000 MIN = (2.54 mm) .100" Center Version 148 (3.09) (1.78) .120 .070 –S 01 100 02 50 (2.54) .100 (6.10) .240 (1.78) .070 01 99 03 150 (2.54) .100 (5.08) .200 (8.10) .319 –D 02 thru 25 LEAD STYLE OAL –06 (7.62) .300 –07 (10.92) .430 –08 (13.46) .530 –09 (18.54) .730 –10 (21.08) .830 = (5.08 mm) .200" Center Version –T (1.78) .070 (1.78) .070 01 148 03 150 (5.08) .200 (8.12) .320 (8.10) .319 –Q (1.78) .070 (1.78) .070 01 MTSW OVERALL LENGTH (OAL) (2.54) .100 01 thru 50 HMTSW (2.54) .100 x No. of Positions HMTSW –S & –D (5.56) .219 (1.78) = 36 .070 positions maximum POST (0.00) .000 MIN 99 150 01 03 FILE NO: 090871_0_000 Note: These Series are non-standard, non-returnable. –S 100 (5.08) .200 (7.62) .300 (2.48) .098 01 HMTSW 148 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –11 (23.62) .930 –12 (26.16) 1.030 –13 (31.24) 1.230 –21 (36.32) 1.430 –22 (16.00) .630 –23 (11.30) .445 –24 (12.19) .480 –27 (33.78) 1.330 –28 (28.70) 1.130 MTSW–115–09–L–S–229-RE MTSW–126–08–T–S–229–RA MTSW–108–28–G–D–920 HMTSW–110–23–L–S–237 MTSW, HMTSW SERIES ROW OPTION PLATING OPTION –F POST HEIGHT OTHER OPTION POLARIZED OPTION –S = Gold flash on post, Matte Tin on tail –“XXX” = Single –L = Polarized (Specify ‘XXX’ as position number) –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Double (4.19) .165" Contact Area –T –G –RA = Triple = 10 µ" (0.25 µm) Gold on post, Gold flash on balance Tail = Locking Lead (N/A with –RE, N/A in single row 1 or 2 positions. Available on tails from (2.29 mm) .090" to (10.16 mm) .400" only) = Double Row .200" (5.08 mm) row space = Matte Tin –RE = Right-angle –LL –Q –T or ALSO AVAILABLE (MOQ Required) Two leads per strip crimped in opposite directions on or near centerline. See TSW for availability. –RA Option with –LL Option • Other platings Contact Samtec. –LA = (Maximum “C” = (13.46 mm) .530) –“XXXX”= “C” Dimension (Specify post height in INCHES – .005" (0.13 mm) increments) FOR A = (2,29) .090 * * * * * * LEAD STYLE OAL –06 –07 –08 –09 –10 –11 –12 –13 –21 –22 –23 –24 –27 (7.62) .300 (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (23.62) .930 (26.16) 1.030 (31.24) 1.230 (36.32) 1.430 (16.00) .630 (11.30) .445 (12.19) .480 (33.78) 1.330 (28.70) 1.130 –28 C C C (2.79) .110 (6.10) .240 (8.64) .340 (13.72) .540 (16.26) .640 (18.80) .740 (21.34) .840 (26.42) 1.040 (31.50) 1.240 (11.18) .440 (6.48) .255 (7.37) .290 (28.96) 1.140 (23.88) .940 N/A N/A (3.30) .130 (5.84) .230 (10.92) .430 (13.46) .530 (16.00) .630 (18.54) .730 (23.62) .930 (28.70) 1.130 (8.38) .330 (3.68) .145 (4.57) .180 (26.16) 1.030 (21.08) .830 N/A –S MAXIMUM MAXIMUM MAXIMUM STRAIGHT w/RA w/RE (3.30) .130 (8.38) .330 (10.92) .430 (13.46) .530 (16.00) .630 (21.08) .830 (26.16) 1.030 (5.84) .230 Straight Pin Versions A = OAL–C– (2.54) .100 –D C OAL C OAL (2.54) .100 (2.54) .100 A A C OAL C (2.54) .100 (2.54) .100 A A (5.33) Styles –21, –23, –24, –27 N/A with –D Right-Angle Versions (– RA Options) A = OAL–C– .210 Styles –13, –21, –23, –24, –27, –28 N/A with –T or – Q (1.78) .070 (1.78) .070 C A (1.52) .060 (2.54) .100 A (1.52) .060 (1.78) .070 C (2.54) .100 (1.78) .070 C A (1.52) .060 (2.54) .100 (2.54) .100 C (1.52) .060 (2.54) .100 (2.54) .100 N/A (1.78) .070 (23.62) .930 (18.54) .730 * Styles –21, –23, –24, –27 not available with –D Right-Angle Styles –13, –21, –23, –24, –27, –28 not available with –T or – Q Right-Angle OAL –Q –T Right-Angle Versions C A (4.06) .160 (2.54) .100 (– RE Options) Single Row Only (7.87) A = OAL–C– .310 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (5.08) .200 A (2.54) .100
MTSW-102-09-T-S-485 价格&库存
很抱歉,暂时无法提供与“MTSW-102-09-T-S-485”相匹配的价格&库存,您可以联系我们找货
MTSW-102-09-T-S-485
