QTS-075-04-H-D-A-K-TR
    SAMTEC(申泰)
    SMD,P=0.64mm
    板对板连接器 SMT
QTS-075-04-H-D-A-K-TR 数据手册
® (0.635 mm) .025" PITCH • QTS/QSS SERIES QTS QTS Board Mates: QSS - - NO. OF POSITIONS PER ROW QSS –025, –050, –075 Board Mates: QTS D A - OTHER OPTIONS –K = Gold flash on contact, Matte Tin on tail = (7.00 mm) .275" DIA Polyimide film Pick & Place Pad –L –C Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 1.8 A per pin (2 pins powered) Ground Plane: 23.1 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 285 VAC Max Cycles: 100 PROCESSING Lead–Free Solderable: Yes QTS SMT Lead Coplanarity: (0.10 mm) .004" max (025-075) QSS SMT Lead Coplanarity: (0.10 mm) .004" max (025-050) (0.15 mm) .006" max (075)* *(.004" stencil solution may be available; contact ipg@samtec.com) Board Stacking: For applications requiring more than two connectors contact ipg@samtec.com (No. of Positions per Row/25) x (20.00) .7875 (5.97) .235 (7.11) .280 QTS LEAD STYLE (0.76) .030 A Leave blank for Tray Packaging –TR = Tape & Reel = Full Reel Tape & Reel must order max. quantity per reel; contact Samtec for quantity breaks) = 50 µ" (1.27 µm) Electro-Polished Selective Gold on contact, Matte Tin on tail (passes 10 year MFG testing) SPECIFICATIONS “X”R –FR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Cable Mates: SQCD Standoffs: SO MATED HEIGHT WITH QSS A –01 (4.27) .168 (5.00) .197 –02 (7.26) .286 (8.00) .315 *Processing conditions will affect mated height. See SO Series for board space tolerances. View complete specifications at: samtec.com?QTS QSS - - - NO. OF POSITIONS PER ROW PLATING OPTION 01 –025, –050, –075 (50 total positions per bank) - - D –F = Gold flash on contact, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (No. of Positions per Row/25) x (20.00) .7875 + (10.90) .429 10 YEAR MFG (No. of Positions per Row/25) x (20.00) .7875 + (5.72) .225 (No. of Positions per Row/25) x (20.00) .7875 + (10.90) .429 LIFE EXTENDED PRODUCT HIGH MATING CYCLES –C A OTHER OPTIONS - –GP = Guide Holes for mating with QTS-RA –K = (8.25 mm) .325" DIA Polyimide Film Pick & Place Pad = 50 µ" (1.27 µm) Electro-Polished Selective Gold on contact, Matte Tin on tail (passes 10 year MFG testing) (No. of Positions per Row/25) x (20.00) .7875 + (1.27) .050 (No. of Positions per Row/25) x (20.00) .7875 + (5.72) .225 (3.63) .143 (7.24) .285 (0.76) .030 (7.49) .295 “X”R Leave blank for Tray Packaging –TR = Tape & Reel –FR = Full Reel Tape & Reel must order max. quantity per reel; contact Samtec for quantity breaks) (No. of Positions per Row/25) x (20.00) .7875 + (10.90) .429 (7.24) .285 (7.49) .295 (No. of Positions per Row/25) x (20.00) .7875 + (1.27) .050 Note: Some lengths, styles and options are non-standard, non-returnable. - - - PLATING OPTION –F Specify LEAD STYLE from Chart (50 total positions per bank) QTS/QSS - LEAD STYLE 25 (0.76) .030 (No. of Positions per Row/25) x (20.00) .7875 + (5.72) .225 –GP OPTION (No. of Positions per Row/25) x (20.00) .7875 + (1.27) .050 (3.63) .143 View complete specifications at: samtec.com?QSS (7.49) .295 samtec.com/QStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (3.63) .143 F-224
QTS-075-04-H-D-A-K-TR 价格&库存
很抱歉,暂时无法提供与“QTS-075-04-H-D-A-K-TR”相匹配的价格&库存,您可以联系我们找货
