S10B-F31SK-GGXR(LF)(AU)
    JST
    P=3.81mm
    线对板针座 1x10P 间距:3.81mm
S10B-F31SK-GGXR(LF)(AU) 数据手册
JFA CONNECTOR J300 SERIES 3.81, 5.08, 5.4 mm pitch/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ––––––––––––––––––– • Current rating: (AC, DC) Circuits 1 2 3 4 5 6 8 9 10 12 16 20 Connectors for signal circuit or power supply circuit, applicable to the factory automation, heavy electric machinery, and other industrial equipment in general. In spite of the various kinds of housings available, their contacts are designed to be common. The applicable tooling can be standardized. #14 15.0 13.5 12.25 11.25 10.5 9.75 9.0 8.5 8.5 8.25 8.0 8.0 #16 14.0 13.5 12.25 11.25 10.5 9.75 9.0 8.5 8.5 8.25 8.0 8.0 #18 11.5 11.25 10.5 10.0 9.5 9.0 8.25 8.0 8.0 7.75 7.5 7.25 Unit: A Wire size (AWG) #22 #20 8.0 9.5 7.5 9.25 7.0 8.5 6.5 8.0 6.25 7.5 6.0 7.0 5.5 6.5 5.25 6.25 5.25 6.25 5.0 6.0 4.75 6.0 4.5 6.0 #24 6.5 6.25 5.75 5.5 5.25 5.0 4.5 4.5 4.5 4.0 4.0 4.0 #26 5.75 5.5 5.0 4.75 4.5 4.25 3.75 3.75 3.75 3.5 3.5 3.5 #28 4.75 4.5 4.1 4.0 4.0 3.75 3.25 3.25 3.25 3.0 3.0 2.75 • Voltage rating: J310/J340 series (3.81 mm pitch) 250 V AC, DC J320/J350 series (5.08 mm pitch) 600 V AC, DC J330 series (5.4 mm pitch) 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 5 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: J310/J340 series (3.81 mm pitch) 1,500 VAC/minute J320/J350 series (5.08 mm pitch) 2,200 VAC/minute J330 series (5.4 mm pitch) 2,200 VAC/minute • Applicable wire: AWG #28 to #14 • Applicable PC board thickness: 1.6 to 2.4 mm * Refer to the page of each product for the specifications of the common type (J350D, J360T). * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– • Double-spring construction • Housing lances • Clear click feeling 1 0 Recognized E60389 1 Certified LR20812 2 R50133261 JFA CONNECTOR/J300 SERIES List of J300 series products 3.81 mm pitch / Voltage rating 250 V AC, DC Type Wire-to-wire Wire-to-board Top entry type Side entry type Free hanging type Panel mounting type Screw type Housing lock type J310S Single-row type 3, 4, 5, 6, 8,10 3, 4, 5, 6, 8,10 3, 4, 5, 8,10 3, 4, 5, 8,10 B A Circuits J310D Double-row type B B B A A A [line pitch 5.08 mm] B B A A B A A B 6, 8,10,12,16, 20 6, 8,10,12,16, 20 6, 8,10,12,16, 20 6, 8,10,12,16, 20 20 A Circuits B J310M Double-row module type B A [line pitch 7.62 mm] B A J-3 10 A B Circuits 6 6 J-3 40 J340F Four-row type [line pitch 5.08 mm] D C B A Circuits 12, 20 5.4 mm pitch / Voltage rating 600 V AC, DC Type Wire-to-board Top entry type Side entry type Wire-to-wire Free hanging type Panel mounting type Screw type Housing lock type J330 [line pitch 7.7 mm] Circuits 30, 40 2 JFA CONNECTOR/J300 SERIES List of J300 series products 5.08 mm pitch / Voltage rating 600 V AC, DC Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type Panel mounting type Screw type 20 J-3 20 J-3 J-3 J320S Single-row type Housing lock type 20 J-3 20 2, 3, 4, 5, 6 2, 3, 4, 5, 6 1, 2, 3, 4 1, 2, 3, 4 12 12 4 1 Circuits 2 3 4 1 5 6 1 2 7 8 J-3 9 2 3 50 A 3 4 B 3 J- 10 4 A 5 5 B 3 J- J350D Double-row type 1 2 3 4 5 1 [line pitch 5.08 mm] 2 3 10 4 5 9 J-3 8 50 7 6 5 3 A 2 B 1 12, 20 A 20 B J-3 20 [line pitch 7.62 mm] J-3 J320M Double-row module type 4, 12, 20 20 Circuits J-3 4 B B A J-3 B 20 A A A B 6,10,12 6, 8,10,12 20 J320T Triple-row module type 6,12 6,12, 20 J-3 Circuits [line pitch 7.62 mm] Circuits 9 Double-row common type (J350D) Triple-row common type (J360T) Common type (line pitch 5.08 mm) Circuits 3 12 (line pitch 6.5 mm) 9,18, 24 JFA CONNECTOR/J300 SERIES Receptacle contact Model No. Strip contact Loose piece SF3F-002 (*) -P2.0 BF3F-002 (*) -P2.0 SF3F-01 (*) -P2.0 BF3F-01 (*) -P2.0 SF3F-41 (*) -P2.0 LF3F-41 (*) -P2.0 SF3F-71 (*) -P2.0 BF3F-71 (*) -P2.0 17.9 (18.4/2L) Q’ty reel Box(Loose piece) S 0.08∼0.20 28∼24 0.8∼1.4 3,700 1,000 M 0.20∼0.50 24∼20 1.2∼2.6 3,700 1,000 L 0.50∼1.25 20∼16 1.8∼2.8 3,200 1,000 2L 1.25∼2.0 16∼14 2.4∼3.4 3,200 1,000 Material and Finish 17.9 (18.4/2L) (5.3 5.8/2L) Applicable wire Insulation O.D. (mm) Size AWG# mm2 (9.3) Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) (2.5 3.0/2L) RoHS compliance Note: 1. Finish (*):GF...Nickel-undercoated, 0.38 μm selective gold-platad GI....Nickel-undercoated, 0.76 μm selective gold-platad T......Tin-plated (reflow treatment) Tab contact Model No. Strip contact Loose piece SF3M-002 (*) -M2.0N BF3M-002 (*) -M2.0N SF3M-01 (*) -M2.0N BF3M-01 (*) -M2.0N SF3M-41 (*) -M2.0N LF3M-41 (*) -M2.0N SF3M-71 (*) -M2.0N BF3M-71 (*) -M2.0N 24.7 (25.2/2L) Applicable wire Insulation O.D. (mm) Size AWG# mm2 Q’ty reel Box(Loose piece) S 0.08∼0.20 28∼24 0.8∼1.4 3,500 1,000 M 0.20∼0.50 24∼20 1.2∼2.6 3,500 1,000 L 0.50∼1.25 20∼16 1.8∼2.8 3,300 1,000 2L 1.25∼2.0 16∼14 2.4∼3.4 3,200 1,000 24.7 (25.2/2L) Material and Finish (5.3 5.8/2L) (2.5 3.0/2L) Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) (11.4) RoHS compliance Note: 1. Finish (*):GF...Nickel-undercoated, 0.38 μm selective gold-platad GI....Nickel-undercoated, 0.76 μm selective gold-platad T......Tin-plated (reflow treatment) Crimping machine, Applicator Strip contact Model No. Applicator Crimping machine Crimp applicator Dies Crimp applicator with dies SF3F-002 (*) -P2.0 SF3M-002 (*) -M2.0N MK/SF3F/M-002-20 APLMK SF3F/M002-20 SF3F-01 (*) -P2.0 SF3M-01 (*) -M2.0N MK/SF3F/M-01-20 APLMK SF3F/M01-20 YRK-8811 MK/SF3F/M-41-20 APLMK SF3F/M41-20 YRK-8801 SF3F-41 (*) -P2.0 SF3M-41 (*) -M2.0N AP-K2N Loose piece Hand tools YRK-8821 MK/SF3F/M-71-20 YRF-882 BF3F-01 (*) -P2.0 BF3M-01 (*) -M2.0N LF3F-41 (*) -P2.0 MKS-L SF3F-71 (*) -P2.0 SF3M-71 (*) -M2.0N Hand tools BF3F-002 (*) -P2.0 BF3M-002 (*) -M2.0N YRF-881 YRF-880 LF3M-41 (*) -M2.0N BF3F-71 (*) -P2.0 YRF-1070 YRF-1071 Note: Finish (*): GF...Nickel-undercoated, 0.38 μm selective gold-platad GI....Nickel-undercoated, 0.76 μm selective gold-platad T......Tin-plated • Extraction tool for J300 series: EJ-JFAJ3 • Refer to the page of crimping tools for details of YRK series hand crimping tools that uses a strip contact. BF3M-71 (*) -M2.0N APLMK SF3F/M71-20 YRK-1071 Note: Finish (*): GF...Nickel-undercoated, 0.38 μm selective gold-platad GI....Nickel-undercoated, 0.76 μm selective gold-platad T......Tin-plated Recognition mark • Plating of the contact Each contact has a marking on its side so that the type or thickness of the plating is recognized. ex. 2 ... gold-plated 0.38 μm thickness 3 ... gold-plated 0.76 μm thickness 5 ... tin-plated Receptacle contact T Tab contact JST 2 JS 2 Indication of the plating Indication of the plating • Common marking on the contact and its application tools In order to avoid incorrect combination of the hand crimp tools or extraction tools and the contacts, the series name (for example J-3) and wire range mark (S, M, L, 2L) are shown on both the tools and the contacts. For example J-3 S..... AWG #28 ∼ #24 M.... AWG #24 ∼ #20 L..... AWG #20 ∼ #16 2L... AWG #16 ∼ #14 Receptacle contact Tab contact J-3 L Wire range mark J3 L Wire range mark Series name Series name 4 J300 SERIES/J310S Assembly layout (8.6) (28.9) (28.4) (10.1) Wire-to-board (40.6) (8.6) Wire-to-wire Receptacle housing Circuits Keying Model No. A 3.81 3 X 7.15 6.55 Y 4 X Y 5 X Y B 6 X Y 16.4 Series name X JST J-3 1 2 3 Circuit No. 8 22.8 Keying No. X Y 10 X Y 4 5 Q’ty /bag 7.62 16.70 26.62 200 7.62 16.70 26.62 200 11.43 20.51 30.43 200 11.43 20.51 30.43 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 19.05 28.13 38.05 200 19.05 28.13 38.05 200 26.67 35.75 45.67 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 34.29 43.37 53.29 100 Material C Glass-filled PBT, UL94V-0, black RoHS compliance 5 F31FSS-03V-KX F31FSS-03V-KY F31FSS-04V-KX F31FSS-04V-KY F31FSS-05V-KX F31FSS-05V-KY F31FSS-06V-KX F31FSS-06V-KY F31FSS-08V-KX F31FSS-08V-KY F31FSS-10V-KX F31FSS-10V-KY Dimensions (mm) C A B J300 SERIES/J310S Tab housing (Free hanging type) Circuits Keying C 8.78 9.35 12.7 9.35 X X Y X 4 Y 3.81 X Keying No. A 5 5.0 Y X B 8 Y X 33.6 4.0 10 A F31MSF-03V-KX F31MSF-03V-KY F31MSF-04V-KX F31MSF-04V-KY F31MSF-05V-KX F31MSF-05V-KY F31MSF-08V-KX F31MSF-08V-KY F31MSF-10V-KX F31MSF-10V-KY X 3 Model No. Y Dimensions (mm) B C Q’ty /bag 7.62 21.62 25.57 200 7.62 21.62 25.57 200 11.43 25.43 29.38 — 11.43 25.43 29.38 — 15.24 29.24 33.19 200 15.24 29.24 33.19 200 26.67 40.67 44.62 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 34.29 48.29 52.24 100 E Q’ty /bag Material Series name Glass-filled PBT, UL94V-0, black Circuit No. J-310 RoHS compliance 3 2 1 Tab housing (Panel mounting type) Circuits Keying E D X 8.78 9.35 5 . φ3 2- 12.7 9.35 X X 3 Y X 4 Y X 3.81 A 5 Keying No. Y 5.0 X 8 B Y X Y F31MSP-03V-KX F31MSP-03V-KY F31MSP-04V-KX F31MSP-04V-KY F31MSP-05V-KX F31MSP-05V-KY F31MSP-08V-KX F31MSP-08V-KY F31MSP-10V-KX F31MSP-10V-KY 33.6 4.0 10 Model No. Series name A Dimensions (mm) B C D 7.62 21.62 22.60 31.00 40.00 200 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 — 11.43 25.43 26.40 34.50 43.50 — 15.24 29.24 30.20 38.00 47.00 200 15.24 29.24 30.20 38.00 47.00 200 26.67 40.67 41.60 50.00 59.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 34.29 48.29 49.20 58.00 67.00 100 Material φ3.6 ±0.1 Glass-filled PBT, UL94V-0, black Circuit No. 5.15 J-310 RoHS compliance 10.3 3 2 1 D ±0.05 C Connector outline 4-R0.5(MAX) Panel layout 6 J300 SERIES/J310S Header (Top entry type) Circuits Keying Model No. C X X 9.35 X 3 X (1.27) Keying No. 3.81 A Y Series name 4 Y X 5 Y X 6 21.6 Circuit No. J-310 Y X 8 5 4 3 2 1 Y X Y 3.8 10 (3.175) B03B-F31SK-GGXR B03B-F31SK-GGYR B04B-F31SK-GGXR B04B-F31SK-GGYR B05B-F31SK-GGXR B05B-F31SK-GGYR B06B-F31SK-GGXR B06B-F31SK-GGYR B08B-F31SK-GGXR B08B-F31SK-GGYR B10B-F31SK-GGXR B10B-F31SK-GGYR Dimensions (mm) A B C Q’ty/box 7.62 13.97 21.62 220 7.62 13.97 21.62 220 11.43 17.78 25.43 180 11.43 17.78 25.43 180 15.24 21.59 29.24 160 15.24 21.59 29.24 160 19.05 25.40 33.05 140 19.05 25.40 33.05 140 26.67 33.02 40.67 120 26.67 33.02 40.67 120 34.29 40.64 48.29 100 34.29 40.64 48.29 100 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated 1.27 ±0.05 φ1.1 ±0.1 Copper foil land 2-φ3.0 (MIN) Through-hole 2-φ2.0 ±0.1 3.81±0.05 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits Keying (3.81) 3.8 3.34 A 3.81 X 7.62 0.82 3 Y X X Keying No. 9.35 10.85 X 4 Y X 5 Y X Series name 6 Y X Circuit No. J-310 22.1 8 Y X 10 Y Model No. S03B-F31SK-GGXR S03B-F31SK-GGYR S04B-F31SK-GGXR S04B-F31SK-GGYR S05B-F31SK-GGXR S05B-F31SK-GGYR S06B-F31SK-GGXR S06B-F31SK-GGYR S08B-F31SK-GGXR S08B-F31SK-GGYR S10B-F31SK-GGXR S10B-F31SK-GGYR Dimensions (mm) Q’ty/box A B C 7.62 15.24 21.62 165 7.62 15.24 21.62 165 11.43 19.05 25.43 135 11.43 19.05 25.43 135 15.24 22.86 29.24 120 15.24 22.86 29.24 120 19.05 26.67 33.05 105 19.05 26.67 33.05 105 26.67 34.29 40.67 90 26.67 34.29 40.67 90 34.29 41.91 48.29 75 34.29 41.91 48.29 75 5 4 3 2 1 Material and Finish C Connector outline 0.82 7.62±0.05 Copper foil land 2-φ4.0 (MIN) Through-hole 2-φ3.0 ±0.1 3.81±0.05 φ1.1 ±0.1 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 7 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES/J310D Assembly layout (13.7) B A (32.8) B B A (28.4) A B (15.2) Wire-to-board A (40.6) Wire-to-wire B (13.7) B A A Receptacle housing A Line No. 12.23 11.63 5.08 3.81 B A B Circuits Keying 6 — 8 — 10 — 12 — 16 — 20 — Dimensions (mm) Model No. F31FDS-06V-K F31FDS-08V-K F31FDS-10V-K F31FDS-12V-K F31FDS-16V-K F31FDS-20V-K A B C Q’ty/bag 7.62 16.70 26.62 200 11.43 20.51 30.43 100 15.24 24.32 34.24 100 19.05 28.13 38.05 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 16.4 22.8 Material Series name J-3 RoHS compliance JST 1 2 3 Circuit No. Glass-filled PBT, UL94V-0, black 4 5 C Tab housing (Free hanging type) C 3.81 5.0 14.43 A A B 17.78 5.08 Line No. Circuits Keying 6 — 8 — 10 — 12 — 16 — 20 — B Model No. A F31MDF-06V-K F31MDF-08V-K F31MDF-10V-K F31MDF-12V-K F31MDF-16V-K F31MDF-20V-K Dimensions (mm) B C Q’ty/bag 7.62 21.62 25.57 200 11.43 25.43 29.38 100 15.24 29.24 33.19 100 19.05 33.05 37.00 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 Material 4.0 33.6 Glass-filled PBT, UL94V-0, black Series name J-310 RoHS compliance Circuit No. 3 2 1 8 J300 SERIES/J310D Tab housing (Panel mounting type) Circuits Keying E D 6 — 8 — 10 — 12 — 16 — 20 — 17.78 A B .5 φ3 2- 14.43 5.08 Line No. 3.81 Model No. F31MDP-06V-K F31MDP-08V-K F31MDP-10V-K F31MDP-12V-K F31MDP-16V-K F31MDP-20V-K A B C D E Q’ty /bag 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 100 15.24 29.24 30.20 38.00 47.00 100 19.05 33.05 34.00 42.00 51.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 Material Glass-filled PBT, UL94V-0, black B 5.0 Dimensions (mm) A 4.0 33.6 RoHS compliance Series name Circuit No. J-310 3 2 1 7.65 15.3 D ±0.05 C φ3 .6 4R0 Connector outline .5 ± 0.1 (M AX ) Panel layout Tab housing (Panel mounting Housing lock type) Circuits Keying Model No. Q’ty/bag 20 — F31MDPL-20V-K 80 Material 14.43 14.43 17.5 7 B 3.81 A 10.3 5.08 (56.09) 53 Glass-filled PBT, UL94V-0, black RoHS compliance Note: Not CSA/UL/TÜV approved. Line No. 34.29 48.29 12.7 10.5 Series name 53.3 ±0.1 J-310 10 9 8 7 6 5 4 3 2 1 2.25 ±0.1 48.8 ±0.1 1.95 ±0.1 33.6 Circuit No. 14.7 ±0.1 48.29 10.8 ±0.1 4-R 0.3max. 4-R 0.8max. Panel layout (Panel thickness:1.6∼2.5 mm) 9 J300 SERIES/J310D Header (Top entry type) Circuits Keying Line No. (1.27) A 5.08 B 14.43 5.08 C Model No. 3.81 A 6 — 8 — 10 — 12 — 16 — 20 — B06B-F31DK-GGR B08B-F31DK-GGR B10B-F31DK-GGR B12B-F31DK-GGR B16B-F31DK-GGR B20B-F31DK-GGR Dimensions (mm) A C B Q’ty/box 7.62 13.97 21.62 132 11.43 17.78 25.43 108 15.24 21.59 29.24 96 19.05 25.40 33.05 84 26.67 33.02 40.67 72 34.29 40.64 48.29 60 Series name Material and Finish 21.6 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Circuit No. J-310 5 4 3 2 1 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. 3.8 3.81 (3.175) φ1.1 ±0.1 1.27 ±0.05 5.08 ±0.05 Copper foil land 2-φ3.0(MIN) Through-hole 2-φ2.0 ±0.1 3.81±0.05 Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Circuits Keying 5.08 14.43 15.93 3.8 (3.81) Series name 6 — 8 — 10 — 12 — 16 — 20 — Line No. Model No. S06B-F31DK-GGR S08B-F31DK-GGR S10B-F31DK-GGR S12B-F31DK-GGR S16B-F31DK-GGR S20B-F31DK-GGR Dimensions (mm) C A B Q’ty/box 7.62 15.24 21.62 88 11.43 19.05 25.43 72 15.24 22.86 29.24 64 19.05 26.67 33.05 56 26.67 34.29 40.67 48 34.29 41.91 48.29 40 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated J-310 25.91 Circuit No. 7.62 3.81 0.82 B A 3.81 A 3.34 Header (Side entry type) 5 4 3 2 1 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) 0.82 3.81 ±0.05 Through-hole 2-φ3.0 ±0.1 3.81±0.05 3.81±0.05 B ±0.05 φ1.1 ±0.1 PC board layout (viewed from component side) 10 J300 SERIES/J310M Assemby layout When mating with J310M receptacle When mating with J310S receptacle modular (16.2) A B (16.2) (28.4) (28.4) Top entry type B B A A Wire-to-board (32.8) (32.8) A 11 B A B A (17.7) B (17.7) Side entry type J300 SERIES/J310M Receptacle housing Circuits 7.62 Line No. 3.81 6 14.77 14.17 A B 7.62 Keying Model No. Q’ty/bag XX F31FMS-06V-KXX F31FMS-06V-KYY F31FMS-06V-KXY 100 YY XY 100 100 Material Glass-filled PBT, UL94V-0, black (16.7) 16.4 22.8 RoHS compliance Keying No. Series name XX J-3 JST 1 2 3 Circuit No. (21.42) (26.62) Header (Top entry type) 7.62 A B 16.97 X 7.62 X X X 6 Keying Model No. Q’ty/box XX B06B-F31MK-GGXXR B06B-F31MK-GGYYR B06B-F31MK-GGXYR 132 YY XY Line No. 3.81 7.62 1.27 ±0.05 φ1.1 ±0.1 21.6 J-310 Copper foil land 2-φ3.0 (MIN) 3.8 3 2 1 3.81 (3.175) 132 Material and Finish Series name Circuit No. 132 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Through-hole 2-φ2.0 ±0.1 7.62 ±0.05 Keying No. Circuits (1.27) 21.62 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 3.81 ±0.05 3.175 ±0.05 13.97 ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits (3.81) 3.8 3.81 7.62 18.47 16.97 X 7.62 X X Series name Copper foil land 2-φ4.0 (MIN) 7.62 ±0.05 3 2 1 25.91 Connector outline J-310 Q’ty/box XX S06B-F31MK-GGXXR S06B-F31MK-GGYYR S06B-F31MK-GGXYR 88 YY 88 88 Material and Finish Line No. Circuit No. Model No. XY B X A 3.34 6 Keying No. Keying 3.81 0.82 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Through-hole 2-φ3.0 ±0.1 3.81 ±0.05 21.62 3.81 ±0.05 φ1.1 ±0.1 3.81 ±0.05 15.24 ±0.05 PC board layout (viewed from component side) 12 J300 SERIES/J310M Keying J310M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) XX-Keying X X Line A Line B Y Indication of keying Y Line B Y Indication of keying Y X X Indication of keying Line B Key rib Y Line A Y X Line A Key rib X Key rib YY-Keying XY-Keying List of combinations With the combination of the J310M headers and the J310M/J310S (3 circuits) receptacle housings, the following modular combinations are possible. Header Receptacle housing Top entry type F31FSS-03V-KX X X-Keying X Single-row 3 circuits (J310S) Single-row 3 circuits (J310S) X X Y X-Keying S03B-F31SK-GGXR Y-Keying B03B-F31SK-GGYR S03B-F31SK-GGYR Double-row XX-Keying 6 circuits B06B-F31MK-GGXXR (J310M) Double-row XX-Keying 6 circuits S06B-F31MK-GGXXR (J310M) Y X Y F31FMS-06V-KYY B B03B-F31SK-GGXR Single-row 3 circuits (J310S) Y-Keying YY-Keying Y YY-Keying X Double-row XX-Keying 6 circuits F31FMS-06V-KXX (J310M) Y F31FSS-03V-KY Y Y-Keying X-Keying Side entry type B06B-F31MK-GGYYR J-3 10 YY-Keying B S06B-F31MK-GGYYR A A A X XY-Keying X B 13 Y Y F31FMS-06V-KXY XY-Keying XY-Keying B06B-F31MK-GGXYR S06B-F31MK-GGXYR J300 SERIES/J320S Assembly layout • Normal type (8.6) (10.1) (28.9) (28.4) Wire-to-board • Reverse type (9.1) (28.9) • Single circuit • 2 to 4 circuits (40.6) (8.6) (10.2) Wire-to-wire (40.6) 14 J300 SERIES/J320S Receptacle housing • Single circuit Circuits Keying Model No. (C) 1 X 1 JST Circuit No. Keying No. 22.8 2 3 4 B 8.9 5 6 X Y X Y X Y X Y X Y X Y F32FSS-01V-KX F32FSS-01V-KY F32FSS-02V-KX F32FSS-02V-KY F32FSS-03V-KX F32FSS-03V-KY F32FSS-04V-KX F32FSS-04V-KY F32FSS-05V-KX F32FSS-05V-KY F32FSS-06V-KX F32FSS-06V-KY Dimensions (mm) A B C — — Q’ty/bag 9.40 12.00 200 9.40 12.00 200 5.08 14.16 24.08 200 5.08 14.16 24.08 200 10.16 19.24 29.16 200 10.16 19.24 29.16 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 20.32 29.40 39.32 200 20.32 29.40 39.32 200 25.40 34.48 44.40 100 25.40 34.48 44.40 100 Material • 2 to 6 circuits A Glass-filled PBT, UL94V-0, black 5.08 7.15 6.55 RoHS compliance 16.4 Keying No. Series name X J-3 1 Circuit No. 22.8 B JST 2 3 4 5 C Tab housing (Free hanging type) Circuits Keying • Single circuit 7 11.6 1 2 3 5 C B 4 4 J-320 X Y X Y X Y X Y (33.6) Series name RoHS compliance 11.6 • 2 to 4 circuits 5.08 Keying No. A Series name J-320 15 Circuit No. 1 33.6 4 5 B 8.78 9.35 9.35 12.7 X X C Q’ty/bag — 13.60 15.60 150 — 13.60 15.60 150 5.08 19.08 23.03 200 5.08 19.08 23.03 200 10.16 24.16 28.11 200 10.16 24.16 28.11 200 15.24 29.24 33.19 200 15.24 29.24 33.19 200 Glass-filled PBT, UL94V-0, black 6.4 2 F32MSF-01V-KX F32MSF-01V-KY F32MSF-02V-KX F32MSF-02V-KY F32MSF-03V-KX F32MSF-03V-KY F32MSF-04V-KX F32MSF-04V-KY Dimensions (mm) A B C Material Circuit No. 3 Model No. Keying No. J300 SERIES/J320S Tab housing (Panel mounting type) • Single circuit Circuits Keying E D X 7 Y X 2 11.6 15.6 11.6 1 Y X 3 Y Keying No. B X 5 4 Y Model No. F32MSP-01V-KX F32MSP-01V-KY F32MSP-02V-KX F32MSP-02V-KY F32MSP-03V-KX F32MSP-03V-KY F32MSP-04V-KX F32MSP-04V-KY Circuit No. ) AX M 5( . R0 4- 11.6 — 11.60 12.60 21.00 28.60 150 — 11.60 12.60 21.00 28.60 150 5.08 19.08 20.00 28.00 36.83 200 5.08 19.08 20.00 28.00 36.83 200 10.16 24.16 25.00 33.00 41.91 200 10.16 24.16 25.00 33.00 41.91 200 15.24 29.24 30.00 38.00 46.99 200 15.24 29.24 30.00 38.00 46.99 200 RoHS compliance 0.1 ± 3.6 2-φ 1 6.4 Q’ty /bag Glass-filled PBT, UL94V-0, black 12.6 ±0.05 (33.6) J-320 Series name E Material 4 6.3 ±0.05 D ±0.05 C ±0.05 Dimensions (mm) B C D A Connector outline Panel layout • 2 to 4 circuits E 8.78 3.5 2-φ 9.35 12.7 X X D 5.08 Keying No. A 5 B 10.22 33.6 4 5.11 D ±0.05 C Series name J-320 Circuit No. 3 2 .6 φ3 1 0.1 ± ) AX 5 0. (M R 4- Connector outline Panel layout Tab housing (Panel mounting type Housing lock type) Circuits Keying Model No. Q’ty/bag 4 X F32MSPL-04V-KX 90 (37.04) 33.95 Keying No. 8.78 12.4 6 9.35 X X Material RoHS compliance Note: Not CSA/UL/TÜV approved. 5.08 10.5 15.24 34.25 ±0.1 33.6 Series name 9.65 ±0.1 12.7 Glass-filled PBT, UL94V-0, black Circuit No. J-320 4 3 2 22.24 ) AX 1 4- .4 R0 (M Panel layout (Panel thickness:1.6∼2.5 mm) 29.24 16 J300 SERIES/J320S Header (Top entry type) Circuits Keying (1.27) X 9.35 X C Keying No. 2 3 5.08 4 Series name 21.6 5 Circuit No. J-320 5 4 3 2 6 X Y X Y X Y X Y X Y Model No. B02B-F32SK-GGXR B02B-F32SK-GGYR B03B-F32SK-GGXR B03B-F32SK-GGYR B04B-F32SK-GGXR B04B-F32SK-GGYR B05B-F32SK-GGXR B05B-F32SK-GGYR B06B-F32SK-GGXR B06B-F32SK-GGYR A Dimensions (mm) B C Q’ty/box 5.08 11.43 19.08 240 5.08 11.43 19.08 240 10.16 16.51 24.16 200 10.16 16.51 24.16 200 15.24 21.59 29.24 160 15.24 21.59 29.24 160 20.32 26.67 34.32 140 20.32 26.67 34.32 140 25.40 31.75 39.40 120 25.40 31.75 39.40 120 1 Material and Finish 3.8 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated 5.08 φ1.1 ±0.1 Copper foil land 2-φ3.0(MIN) Through-hole 2-φ2.0 ±0.1 3.175 1.27 ±0.05 (3.175) A RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 5.08 ±0.05 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) 3.8 7.62 0.82 2 3 10.85 X Keying No. 9.35 X 3.34 Circuits Keying (3.81) A 5.08 4 5 Series name 6 22.1 Circuit No. J-320 5 4 3 2 X Y X Y X Y X Y X Y Model No. S02B-F32SK-GGXR S02B-F32SK-GGYR S03B-F32SK-GGXR S03B-F32SK-GGYR S04B-F32SK-GGXR S04B-F32SK-GGYR S05B-F32SK-GGXR S05B-F32SK-GGYR S06B-F32SK-GGXR S06B-F32SK-GGYR A Dimensions (mm) C B Q’ty/box 5.08 12.70 19.08 180 5.08 12.70 19.08 180 10.16 17.78 24.16 150 10.16 17.78 24.16 150 15.24 22.86 29.24 120 15.24 22.86 29.24 120 20.32 27.94 34.32 105 20.32 27.94 34.32 105 25.40 33.02 39.40 90 25.40 33.02 39.40 90 Material and Finish 1 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) 0.82 Through-hole 2-φ3.0 ±0.1 5.08 ±0.05 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 17 φ1.1 ±0.1 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES/J320S Header (Side entry type Reverse type) (3.81) Circuits Keying X 9.35 X 3.8 7.62 (0.82) 10.85 3.34 A 5.08 22.1 J-320 3 4 SR05B-F32SK-GGXR SR06B-F32SK-GGXR Q’ty /box 20.32 27.94 34.32 105 25.40 33.02 39.40 90 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. 3. Not TÜV approved. Type Connector outline 5 C 7.62±0.05 Copper foil land 2-φ4 (MIN) Through-hole 2-φ3 ±0.1 0.82 2 X Dimensions (mm) C B Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Series name R 1 X 6 A Material and Finish Keying No. Circuit No. 5 Model No. 5.08±0.05 φ1.1±0.1 3.81±0.05 B ±0.05 PC board layout (viewed from component side) 18 J300 SERIES/J320M Assembly layout When mating with J320S receptacle modular When mating with J320M receptacle (16.2) A B (16.2) (28.4) (28.2) Top entry type A B (34) (33.8) Wire-to-wire B B A A (40.4) 19 (17.7) (17.7) A A Free hanging type / Panel mounting type B B A (16.2) B Side entry type A B (16.2) B Wire-to-board A (40.6) J300 SERIES/J320M Receptacle housing Circuits Keying A Line No. 5.08 YY 14.77 14.17 A B 7.62 XY XX YY 10 XY B XX YY 12 Keying No. XY 16.4 22.8 Series name XX J-3 1 2 3 F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY F32FMS-10V-KXX F32FMS-10V-KYY F32FMS-10V-KXY F32FMS-12V-KXX F32FMS-12V-KYY F32FMS-12V-KXY F32FMS-20V-KXX XX 6 4 XX 20 Dimensions (mm) A B C Model No. Q’ty /bag 10.16 19.24 29.16 100 10.16 19.24 29.16 100 10.16 19.24 29.16 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 45.72 54.80 64.72 84(box) Material JST 5 Circuit No. Glass-filled PBT, UL94V-0, black C RoHS compliance Tab housing (Free hanging type) Circuits Keying C Dimensions (mm) A B C Model No. Line No. F32MDF-06V-KXX F32MDF-06V-KYY F32MDF-06V-KXY F32MDF-12V-KXX F32MDF-12V-KYY F32MDF-12V-KXY YY 16.4 16.97 20.32 7.62 X X B X A X XX 6 XY XX 12 YY 5.08 XY Q’ty /bag 10.16 24.16 28.11 100 10.16 24.16 28.11 100 10.16 24.16 28.11 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 Keying No. A Material B 4.0 5.0 Glass-filled PBT, UL94V-0, black 33.6 RoHS compliance Series name Circuit No. J-320 3 2 1 Tab housing (Panel mounting type) Circuits Keying E D Line No. XX YY XY 16.4 16.97 20.32 7.62 X X X 5.08 A 3.5 2-φ B X 6 XX 12 YY XY Keying No. 20 A XX Model No. F32MDP-06V-KXX F32MDP-06V-KYY F32MDP-06V-KXY F32MDP-12V-KXX F32MDP-12V-KYY F32MDP-12V-KXY F32MDP-20V-KXX A Dimensions (mm) B C D E Q’ty /bag 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 45.72 59.72 61.00 70.00 78.23 42(box) Material B 4.0 5.0 Glass-filled PBT, UL94V-0, black 33.6 RoHS compliance Series name Circuit No. J-320 2 1 17.9 8.95 3 D ±0.05 C φ3 .6 ±0 .1 4-R Connector outline 0.5 Panel layout (M AX ) 20 J300 SERIES/J320M Header (Top entry type) Line No. (1.27) Circuits Keying XX 6 A 7.62 16.97 YY XY B X 7.62 X X X C XX Keying No. 10 YY XY Series name XX 12 J-320 4 3 2 5.08 7.62 ±0.05 1.27 ±0.05 10.16 16.51 24.16 120 10.16 16.51 24.16 120 10.16 16.51 24.16 120 20.32 26.67 34.32 84 20.32 26.67 34.32 84 20.32 26.67 34.32 84 25.40 31.75 39.40 72 25.40 31.75 39.40 72 25.40 31.75 39.40 72 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. φ1.1±0.1 Copper foil land 2-φ3.0(MIN) Q’ty /box Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated (3.175) A B06B-F32MK-GGXXR B06B-F32MK-GGYYR B06B-F32MK-GGXYR B10B-F32MK-GGXXR B10B-F32MK-GGYYR B10B-F32MK-GGXYR B12B-F32MK-GGXXR B12B-F32MK-GGYYR B12B-F32MK-GGXYR Dimensions (mm) A B C Material and Finish 1 3.8 5 XY 21.6 Circuit No. YY Model No. Through-hole 2-φ2.0 ±0.1 5.08 ±0.05 Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits Keying (3.81) A 7.62 5.08 0.82 3.8 5.08 XX 6 YY 18.47 16.97 X 7.62 X X X 8 10 Line No. YY XY Series name XX 12 YY XY 27.18 Circuit No. J−320 Q’ty /box 10.16 17.78 24.16 80 10.16 17.78 24.16 80 10.16 17.78 24.16 80 15.24 22.86 29.24 64 20.32 27.94 34.32 56 20.32 27.94 34.32 56 20.32 27.94 34.32 56 25.40 33.02 39.40 48 25.40 33.02 39.40 48 25.40 33.02 39.40 48 Material and Finish C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) Through-hole 2-φ3.0 ±0.1 5.08 ±0.05 S06B-F32MK-GGXXR S06B-F32MK-GGYYR S06B-F32MK-GGXYR S08B-F32MK-GGXYR S10B-F32MK-GGXXR S10B-F32MK-GGYYR S10B-F32MK-GGXYR S12B-F32MK-GGXXR S12B-F32MK-GGYYR S12B-F32MK-GGXYR Dimensions (mm) A B C Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated 5 4 3 2 1 φ1.1 ±0.1 5.08 ±0.05 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 21 XY XX B Keying No. A 3.34 XY Model No. RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES/J320M Keying J320M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) XX-Keying X X Line A Y Line B Y Line B Indication of keying Y Indication of keying Y X X Indication of keying Line B Key rib Y Line A Y X Line A Key rib X Key rib YY-Keying XY-Keying List of combinations With the combination of the J320M headers and the J320M/J320S receptacle housings, the following modular combinations are possible. Tab housing Receptacle housing X Single-row 3, 4 circuits (J320S) 20 F32FSS- V-KX X X-Keying J-3 Single-row 3, 4, 5, 6 circuits (J320S) Free hanging type Y-Keying X-Keying Header Single-row X-Keying 3, 4, 5, 6 circuits Free hanging type (J320S) F32MSF- V-KX Panel mounting type J-3 20 F32MSP- V-KX Top entry type B B-F32SK-GGXR Side entry type S B-F32SK-GGXR Y-Keying Y-Keying Top entry type 20 Free hanging type F32MSF- V-KY Panel mounting type Panel mounting type F32MSP- V-KY Y Y J-3 X X XX-Keying X X F32FMS- V-KXX Double-row XX-Keying 6, 8,10,12 circuits Top entry type (J320M) F32MDF- V-KXX Panel mounting type F32MDP- V-KXX 20 J-3 YY-Keying YY-Keying Side entry type Top entry type B B-F32SK-GGYR Side entry type S B-F32SK-GGYR B B-F32MK-GGXXR Side entry type S B-F32MK-GGXXR J-3 20 A YY-Keying Y Y Y B A Top entry type J-3 F32FMS- V-KYY 20 Y B Free hanging type Free hanging type F32MDF- V-KYY Panel mounting type F32MDP- V-KYY 20 XY-Keying X X XY-Keying Y Y F32FMS- V-KXY Free hanging type Panel mounting type F32MDF- V-KXY Panel mounting type F32MDP- V-KXY Top entry type B B-F32MK-GGYYR Side entry type S B-F32MK-GGYYR J-3 Double-row 6,10,12,20 circuits (J320M) Double-row XX-Keying 6,12,20 circuits Free hanging type (J320M) J-3 20 F32FSS- V-KY XY-Keying Side entry type Top entry type B B-F32MK-GGXYR Side entry type S B-F32MK-GGXYR Note: Number of circuits is indicated in ■■. 22 J300 SERIES/J320T Assembly layout When mating with J320S receptacle When mating with J320M receptacle modular (39.1) C Side entry type B A 23 (25.3) Wire-to-board C B A B A (25.3) (39.3) J300 SERIES/J320T Receptacle housing Circuits Single-row type • 3 circuits 3 10.16 Keying Model No. Q’ty/bag X F32FSS-03V-KX F32FSS-03V-KY 200 Y 5.08 200 7.15 6.55 Material Glass-filled PBT, UL94V-0, black RoHS compliance 16.4 Keying No. Series name X J-3 22.8 19.24 JST 1 2 3 Circuit No. 29.16 Circuits Double-row type • 6 circuits 6 10.16 5.08 Keying Model No. Q’ty/bag XX F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY 100 YY XY Line No. 100 100 14.77 14.17 A B 7.62 Material Glass-filled PBT, UL94V-0, black RoHS compliance 16.4 22.8 19.24 Keying No. Series name XX J-3 1 Circuit No. JST 3 2 29.16 Header (Side entry type) (0.82) 3.81±0.5 Circuit No. 5.08 ±0.5 9 φ1.1±0.1 3 2 1 Keying Model No. Q’ty/box XXX S09B-F32TK-GGXAR S09B-F32TK-GGXBR S09B-F32TK-GGXCR S09B-F32TK-GGXDR 42 Copper foil land 2-φ4 (MIN) 7.62 ±0.05 32.26 X X X X 3.34 7.62 5.08 (3.81) 26.09 B 3.8 X 24.59 Keying No. X 7.62 42 24.16 7.62 (0.82) 42 RoHS compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline C A 42 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Series name Line No. XYX Material and Finish Through-hole 2-φ3 ±0.1 PC board layout (viewed from component side) XXY YYX J-320 5.08 ±0.05 Circuits 17.78 ±0.5 5.08 24 J300 SERIES/J320T Keying J320T series have mis-insertion preventive keying. Available in 4 types - XXX-Keying, XXY-Keying, XYX-Keying and YYX-Keying. (Headers viewed from the mating side are shown below.) Line A Line A Line A Line A Line B Indication Line B of keying Indication Line B of keying Indication Line B of keying Line C Line C Line C Line C Key rib XXX-Keying Key rib XXY-Keying Indication of keying Key rib Key rib XYX-Keying YYX-Keying List of combinations With the combination of the J320T headers and the J320S/J320M receptacle housings, the following modular combinations are possible. Receptacle housing Single-row 3 circuits (J320S) X-Keying F32FSS-03V-KX Header Triple-row 9 circuits (J320T) XXX-Keying S09B-F32TK-GGXAR Y-Keying XXY-Keying F32FSS-03V-KY S09B-F32TK-GGXBR XX-Keying 20 J-3 Double-row 6 circuits (J320M) F32FMS-06V-KXX XYX-Keying S09B-F32TK -GGXCR YY-Keying F32FMS-06V-KYY B A YYX-Keying XY-Keying F32FMS-06V-KXY 25 S09B-F32TK-GGXDR J300 SERIES/J330 21 11 (A) 21 Wire-to-board 11 Assembly layout Specifications ––––––––––––––––––– • Current rating: (AC, DC) #16 30 5.0 5.0 27.2 40 5.0 5.0 34.9 1 1 #14 Unit: A Dimensions (mm) A Wire size (AWG) Circuits (47.7) Receptacle housing (Reverse type Panel mounting type) Circuits Keying 85.2 76 Keying No. (B) 7.7 A X 40 (48.6) W 2 3 4 5 6 6 5 4 3 2 1 1 11 40.6 1 7 8 9 10 X 4.4 (18.2) 1 7 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 310 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 11 8 Q’ty /box G Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) Series name 9 Dimensions (mm) C D E F Material J-330 10 B C (D) 21 (66.4) Circuit No. Y Z 5.4 Keying No. Y Z φ3 .5 A F33FRTPA-30V-KX F33FRTPA-30V-SY F33FRTPA-30V-EZ F33FRFPA-40V-KX F33FRFPA-40V-SY F33FRFPA-40V-EZ F33FRFPA-40V-MW X 30 Circuit No. Model No. RoHS compliance Note: Not CSA/UL/TÜV approved. 21 E (F) 54.4 (59.4) φ4 ± G A ±0.1 Connector outline ±0.3 R1MAX − 0.2 0 67.2 ±0.3 76 ±0.1 Panel layout Tab housing (Reverse type) Circuits (69.6) Circuit No. Series name (64.6) 30 Keying Model No. X F33MRTS-30V-KX F33MRTS-30V-SY F33MRTS-30V-EZ F33MRFS-40V-KX F33MRFS-40V-SY F33MRFS-40V-EZ F33MRFS-40V-MW Y Z 1 X 2 3 4 5 6 7 8 9 10 28 JST 9 8 7 6 5 4 3 2 1 Y Z X 10 1 11 21 W Q’ty /box 24.9 15.4 64 24.9 15.4 64 24.9 15.4 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 Material A 56 Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) 7.7 (B) Circuit No. 38.6 J -3 Keying No. 40 Dimensions (mm) A B RoHS compliance Note: Not CSA/UL/TÜV approved. 5.4 (48.6) 26 J300 SERIES/J340F Assembly layout D C C B B A (33.7) D Side entry type J-3 Wire-to-board JST (40.4) A Receptacle housing • 12 circuits Circuits Keying Model No. Q’ty/bag 12 — 100 20 — F34FFC-12V-K F34FFC-20V-K Material Line No. 12.22 100 C J-3 B 5.08 3.81 D RoHS compliance 30.1 (32.71) 15.24 JST Glass-filled PBT, UL94V-0, black A 16.4 7.62 22.8 Series name • 20 circuits Line No. C J-3 B 5.08 3.81 D A 16.4 22.8 15.24 30.1 (32.71) 15.24 JST 19.84 Series name Circuit No. Series name 1 φ1.1±0.1 2 3.81 7.62 ±0.05 Copper foil land φ4 (MIN) J-340 Connector outline PC board layout (viewed from component side) Model No. 12 — 20 — SC12B-F34FK-GGR SC20B-F34FK-GGR B 31.59 5.08 3.34 30.09 C A 3.8 (0.82) 7.62 7.62 15.02 63 15.24 22.64 42 RoHS compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. A 3.81 D B Dimensions (mm) Q’ty/box A B Material and Finish Line No. 27 Keying Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Through-hole φ3 ±0.1 3.81 Circuits ±0.05 33.53 (0.82) A±0.5 3 3.81±0.05 Header (Side entry type) J300 SERIES/J350D Assembly layout (21.4) (34.2) A B J-3 J-3 A B A (22.9) B B A (28.6) Wire-to-board (40.6) A J-3 A B B (21.4) Wire-to-wire *When mating with receptacle housing (2-circuit) 28 J300 SERIES/J350D Receptacle housing • 4 circuits • 6 circuits 22.8 5.08 24.9 (19.98) Line No. 16.4 10.16 Series name 22.8 16.4 22.8 16.4 5.08 22.8 45.72 (19.98) B A J-3 Line No. Series name 17.38 5.08 (19.98) 17.38 A J-3 B 5.08 50.3 Line No. Series name Circuits Keying Model No. Q’ty/bag 2 — — 6 — 10 — 20 — F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K F35FDC-20V-K 200 4 Material Glass-filled PBT, UL94V-0, black RoHS compliance 29 17.38 B 5.08 Series name • 20 circuits • 10 circuits 5.08 J-3 Line No. 16.4 22.8 20.32 5.08 (19.98) B Series name A Line No. 16.4 17.38 5.08 (20.7) 17.38 14.74 J-3 4.88 A B J-3 5.08 9.96 A • 2 circuits 200 200 100 100 J300 SERIES/J350D Tab housing (Free hanging type) Circuit No. 32.48 Circuits Keying Model No. Q’ty/box 12 — F35MDF-12V-K 50 6 5 4 3 2 1 J-350 Material 33.6 Series name 4 Glass-filled PBT, UL94V-0, black 5 RoHS compliance Note: Not TÜV approved. 32.48 25.4 Circuit No. 3 4 5 6 B A 18.17 2 13.78 1 Line No. 21.52 18.17 5.08 5.08 36.43 Tab housing (Panel mounting type) 2-φ3.6 ±0.1 43 Circuit No. ±0.05 ±0.3 Series name 5 4 3 2 1 Q’ty/box F35MDP-12V-K 41 Material 4 19.2 J-350 33.6 Model No. — ±0.3 6 Connector outline 5 Keying 12 9.6 33.4 ±0.3 Circuits 32.48 Glass-filled PBT, UL94V-0, black RoHS compliance Note: Not TÜV approved. 4-R0.5 (MAX) Panel layout 25.4 5.08 3 4 5 6 43 B A 18.17 2 13.78 1 2-φ3.5 21.52 18.17 5.08 Circuit No. Line No. 52 30 J300 SERIES/J350D Header (Top entry type) Circuits Keying Model No. Connectoroutline 12 — Copper foil land φ3(MIN) 20 — BC12B-F35DK-GGR BC20B-F35DK-GGR 5 3.81 ±0.05 4 3 2 1 21.6 6 5.08 ±0.05 7 25.4 32.48 56 45.72 52.8 32 7 8 9 10 RoHS compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. J-350 (3.54) A ±0.05 Q’ty/box Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Series name 8 5.08 ±0.05 Dimensions (mm) A B Material and Finish Circuit No. 9 ±0.1 10 φ1.1 (4.78) Through-hole φ2 ±0.1 PC board layout (viewed from component side) B A 5.08 B 18.17 5.08 3.81 3.8 2 3 4 5 6 A 5.08 1 3.8 Line No. Header (Side entry type) Circuit No. Series name 10 9 8 7 27.18 Circuits Keying Model No. 4 — 12 — 20 — SC04B-F35DK-GGR SC12B-F35DK-GGR SC20B-F35DK-GGR Dimensions (mm) A B 5.08 Q’ty/box 12.16 152 25.4 32.48 56 45.72 52.8 32 6 5 4 3 2 1 J-350 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated B A A 4 5 6 7 8 B 7.62 5.08 1 3.8 (0.82) 10 3.34 A 9 12, 20 circuits (3.54) A ±0.05 (3.54) 7.62 ±0.05 Through-hole 2-φ3 ±0.1 2.54 ±0.05 Copper foil land φ4 (MIN) (0.82) φ1.1 ±0.1 Copper foil land 2-φ4 (MIN) Through-hole φ3 ±0.1 Connector outline Connector outline PC board layout (viewed from component side) 12, 20 circuits 31 4 circuits 5.08 ±0.05 (0.82) 5.08 ±0.05 A±0.05 2 3.34 3 3.8 2 18.17 19.67 1 5.08 5.08 5.08 18.17 19.67 Line No. PC board layout (viewed from component side) 4 circuits RoHS compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES COMMON TYPE/J350D Double-row Connector type (J350D) Direct mounting type Circuit figure Common type • Rationalization of wiring is realized by the common connection inside the connector Specifications ––––––––––––––––––– • Current rating: (AC, DC) / (Total input current on single-row) Unit: A Circuits 12 #14 Wire size (AWG) #16 #18 #20 13.0 11.5 7.5 9.5 • Voltage rating: 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 2,200 VAC/minute • Applicable wire: AWG #28 to #14 * Contact JST for details. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. 32 J300 SERIES COMMON TYPE/J350D Assembly layout A A J-3 B B (21.4) Direct mounting type (37) *When mating with receptacle housing (2-circuit) Receptacle housing • 4 circuits • 6 circuits B J-3 (19.98) 5.08 (19.98) A J-3 B 17.38 5.08 (20.7) 17.38 A B J- 3 5.08 4.88 17.38 14.74 9.96 A • 2 circuits Line No. 16.4 Line No. 16.4 5.08 Series name 22.8 Series name 22.8 • 10 circuits 16.4 10.16 22.8 Line No. Series name Circuits Keying Model No. Q’ty/bag 2 — 200 4 — 6 — 10 — F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K (19.98) A J-3 B 17.38 5.08 24.9 5.08 200 200 100 Material Glass-filled PBT, UL94V-0, black 5.08 16.4 Line No. 22.8 20.32 RoHS compliance Series name J-350 Series name Circuit No. 1 2 3 5 3 4 5 5.08 25.4 ±0.05 44.6 ±0.1 10.8 2 -φ4.6 Connector outline Panel layout 33 196 RoHS compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. Refer to the top page of 350D (Common) for circuit figure. 6 5.08 A 2 Q’ty/box P12B-F35DK-GFAR Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 18.17 21.6 1 Model No. — 6 57.0 44.6 Circuit No. B Keying 12 Material and Finish 4 33.08 Line No. Circuits 30 4 Tab housing Assembly J300 SERIES COMMON TYPE/J360T Triple-row Commin type (360T) Panel mounting type Direct mounting type Circuit figure Contact for common connection Tab side When mating with receptacle housing Contact for common connection Tab side When mating with receptacle housing assembly with common connection Contact for common connection Receptacle side • Rationalization of wiring is realized by the common connection inside the connector Specifications ––––––––––––––––––– • Current rating: (AC, DC) Unit: A Wire size (AWG) #14 #16 #18 #20 Receptacle housing (Total input current on sinle-row) 12.0 10.5 8.5 6.5 Receptacle housing assembly with common connection (Total input current on all circuits) 15.0 13.5 11.5 9.5 • Voltage rating: 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. (When using receptacle housing) • Withstanding voltage: 2,200 VAC/minute (When using receptacle housing) • Applicable wire: AWG #28 to #14 * Contact JST for details. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. 34 J300 SERIES COMMON TYPE/J360T Assemby layout Panel mounting type Direct mounting type C (28.6) A A A B J-3 C B B B J-3 C C (28.6) (36.8) A (36.8) *When mating with receptacle housing (3-circuit) Receptacle housing 4.9 Circuits Keying Model No. Q’ty/bag 3 — F36FTC-03V-K 200 Material Glass-filled PBT, UL94V-0, black 25.3 (28) A J-3 6.5 B C RoHS compliance 16.4 22.8 Line No. Series name Receptacle housing assembly with common connection 41.2 Circuits Model No. Q’ty/bag 21 F36FTC-21(24-C8T)V-KC 60 Material Contact for common connection: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 5.08 16.4 22.8 35.56 Cross-section of receptacle housing assembly with common connection 25.3 (28) A J -3 6.5 B 6.5 C RoHS compliance Note: 1. Contact JST about 0.76 μm gold-plated product. 2. Not CSA/UL/TÜV approved Line No. Series name Illustration when using Circuit figure Contact for common connection Tab side 1 2 3 4 5 6 7 Inserted the contact common to the right side of receptacle housing 35 Contact for common connection Receptacle side J300 SERIES COMMON TYPE/J360T Tab housing Assembly • Panel mounting type Circuits Keying Circuit No. B ±0.05 E ±0.3 2-φ3.6 9 — 18 — Model No. A P09B-F36TK-GFR P18B-F36TK-GFR Dimensions (mm) B C D E Q’ty /box 35.0 26.1 17.8 10.16 18.8 364 50.2 41.3 33.1 25.40 34.1 224 Series name ±0.1 2 13.55 ±0.3 3 1 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 5 4 30 J-360 27.1±0.3 Material and Finish Connector outline 4-R0.5 (MAX) RoHS compliance Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. Refer to the top page of 360T (Common type) for circuit figure. C Panel layout A B Circuit No. Line No. 2 2-φ3.5 3 6.5 26.09 B 26.09 C 29.44 1 A 5.08 D Circuits Keying • Direct mounting type 2-φ3.6±0.1 14.72 30 J-360 Series name 2 1 Panel layout 3 Connector outline Circuit No. C 9 — 18 — 24 — P09B-F36TK-GFAR P18B-F36TK-GFAR P24B-F36TK-GFAR A Dimensions (mm) B C D Q’ty /box 35.0 26.1 17.8 10.16 364 50.2 41.3 33.1 25.40 224 60.4 51.5 43.2 35.56 168 Material and Finish 4 B ±0.05 Model No. A B Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black RoHS compliance Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. 24-circuit product without housing cover type is also available. 3. The directions such as series names of 24-circuit product are different from 9 and 18-circuit products. 4. 24-circuit product is not approved by UL standard. 5. Refer to the top page of 360T (Common type) for circuit figure. Circuit No. Line No. 1 2 3 2-φ3.5 6.5 26.09 B 29.44 C A 5.08 D 36 JFA CONNECTOR/J300 SERIES Model number identification Receptacle contact Tab contact S F3 F - 41 GF - P 2.0 S F3 M - 41 GF - M 2.0 N Form: S...Strip form, B...Loose piece L...Loose piece with curled barrels Form: S...Strip form, B...Loose piece, L...Loose piece with curled barrels Series name Series name Kind of terminal: M...Tab contact Kind of terminal: F...Receptacle contact Applicable wire: 002...AWG #28 ∼ #24, 01...AWG #24 ∼ #20 41...AWG #20 ∼ #16, 71...AWG #16 ∼ #14 Applicable wire: 002...AWG #28 ∼ #24, 01...AWG #24 ∼ #20, 41...AWG #20 ∼ #16, 71...AWG #16 ∼ #14 Surface finish: GF...Nickel-undercoated, 0.38μm selective gold-plated GI...Nickel-undercoated, 0.76μm selective gold-plated T...Tin-plated (reflow treatment) Surface finish: GF...Nickel-undercoated, 0.38μm selective gold-plated GI...Nickel-undercoated, 0.76μm selective gold-plated T...Tin-plated (reflow treatment) Meterial: M...Copper alloy Meterial: P...Copper alloy Terminal size Sub model No. Sub model No. Receptacle housing Tab housing F31 M S F - 03 V - K X F31 F S S - 03 V - K X Series name Type of connector: F...Receptacle housing, FR...Receptacle housing Reverse type Rows: S...Single-row, D....Double-row with 5.08 mm line pitch M...Double-row with 7.62 mm line pitch T...Triple-row, F....Quadruple-row Series name Type of connector: M...Tab housing, MR...Tab housing Reverse type  Rows: S...Single-row, D...Double-row, D...Double-row, F...Quadruple-row Mounting arrangement: S...Side locking, C...Center locking, PA...Panel mounting type Mounting arrangement: F...Free hanging, P...Panel mounting S...Side locking, PL...Panel mounting Housing lock Circuits: 1 ∼ 6, 8, 10, 12, 16, 20, 30, 40 Circuits: 1 ∼ 6, 8, 10, 12, 16, 20, 30, 40 Flammability: V...UL94V-0 Flammability: V...UL94V-0 Color indication: K...Black, S...White, E...Blue, M...Green Color indication: K...Black, S...White, E...Blue, M...Green Keying: X...X-Keying, Y...Y-Keying, Z...Z-Keying, W...W-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, Blank...Without Keying No. Keying: X...X-Keying, Y...Y-Keying, Z...Z-Keying, W...W-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, Blank...Without Keying No. Header Receptacle housing assembly F36 F T C -21 (24-C8T) V - K C B 05 B - F31 S K - GG X R Series name Type of connector: F...Receptacle housing Rows: T...Triple-row Mounting arrangement: C...Center locking Circuits: 21 Indication of Common : Common circuit is set to No. 8 circuit at each row of A, B, and C. Flammability: V...UL94V-0 PC board mounting direction: B...Top entry type S...Side entry type BC...Top & center locking SR...Side reverse SC...Side & center locking Circuits: 2 ∼ 6, 8 ∼ 10, 12, 16, 20 Product name: Header Color indication: K...Black Surface finish of assembled short circuit terminal : C...Nickel-undercoated, 0.38 μm selective gold-plated : D...Nickel-undercoated, 0.76 μm selective gold-plated Tab housing assembly Series name Rows: S...Single-row D...Double-row with 5.08 mm line pitch M...Double-row with 7.62 mm line pitch T...Triple-row F...Quadruple-row Color indication: K...Black, S...White, E...Blue Surface finish: GG...Nickel-undercoated, 0.38μm selective gold-plated GK...Nickel-undercoated, 0.76μm selective gold-plated T...Tin-plated (reflow treatment) Keying: X...X-Keying, Y...Y-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, XA...XXX-Keying, XB...XXY-Keying, XC...XYX-Keying, XD...YYX-Keying, Blank...Without Keying No. Packaging form: R...Tray, M...Magazine stick 37 P 18B - F36T K - GF A R PC board mounting direction: Panel mounting type Circuits • Assembly: 9, 12, 18, 24 Series name: F35D...J350D, F36T...J360T Color indication: K...Black Surface finish: GF...Nickel-undercoated, 0.38μm selective gold-plated G I ...Nickel-undercoated, 0.76μm selective gold-plated Mounting arrangement: A...Direct mounting type, AN...Direct mounting without housing cover type Blank...Panel mounting type Packaging form: R...Tray JFA CONNECTOR J300 SERIES PROTECTOR 0 B A J-31 J-31 10 9 0 8 7 6 5 4 3 2 1 When applying a current to the connector, the protector prevents foreign substances being inserted into mating part from the wiring side. However it has no function of holding the wire securely. B A Note: Protector is not approved by UL/CSA/TÜV standards. J300 Series J310D series for 20 circuits (50.3) 16.08 Model No. Color Q’ty/box 1 F31PFD-20VK F31PFD-20SC Black 112 Transparent 112 1 Material Black: Glass-filled PBT Transparent: Polycarbonate RoHS compliance Note: Two protectors of the same color are used. (42.9) 26.2 1 No. F31FDS-20V-K (11.63) (43.37) (53.29) J310D series / Embedding-type prottector for 8, 10 circuits (53.29) 1 (12.23) No. Model No. Color Q’ty/box 1 F31PFS-10KU Black 1,000 Material 1 Glass-filled, PBT (22.8) 0.8 RoHS compliance Note: This protector is cut and used for each number of the circuits. (11.63) (43.37) No. J340F series for 20 circuits 23.04 1 (32.3) 1 2 2 Model No. Color Q ty/box F34PFF-20VKA F34PFF-20SCA F34PFF-20VKB F34PFF-20SCB Black 80 Transparent 80 Black 80 Transparent 80 21.2 Material (37.9) Black: Glass-filled PBT Transparent: Polycarbonate RoHS compliance Note: Both 1 and 2 protectors in the same color are used. F34FFC-20V-K (19.84) 1 25.77
S10B-F31SK-GGXR(LF)(AU) 价格&库存
很抱歉,暂时无法提供与“S10B-F31SK-GGXR(LF)(AU)”相匹配的价格&库存,您可以联系我们找货
库存:75
    • 1+29.177021+3.77872
    • 10+19.2390410+2.49165
    • 50+15.6791650+2.03061
    • 100+14.96370100+1.93795
    • 500+14.43146500+1.86902
    • 1000+14.073731000+1.82269
    • 2000+14.003922000+1.81365
    库存:27
      • 1+21.518051+2.78681
      • 10+18.2605110+2.36492
      • 30+14.8786230+1.92694
      • 50+14.1989350+1.83891
      • 100+13.69331100+1.77343
      • 300+13.35346300+1.72941
      • 500+13.28715500+1.72082
      库存:75
