SEAM-20-02.0-STL-10-1-A-K-TR
    SAMTEC(申泰)
SEAM-20-02.0-STL-10-1-A-K-TR 数据手册
REVISION CI DO NOT SCALE FROM THIS PRINT DESIGNED & DIMENSIONED IN INCHES[MILLIMETERS] PATENT NUMBER 7172438 "A" REF (SEE TABLE 6, SHT 2) "C" SPCS. @ .0500 = "D" (SEE TABLE 6, SHT 2) .123 3.12 REF .0500 1.270 (TYP) CL .352 8.94 REF .478 12.14 REF C "A" -10, -15,**-19 -20, -25, -30, -40, -50 A1 .200 5.08 REF VOIDED AT SAMTEC'S DISCRETION H1 "B" REF (SEE TABLE 6, SHT 2) SEAM-XX-XX.X-08-A "J" REF C "H" REF .040 1.02 REF .050 1.27 (TYP) C "E" (TYP) (SEE TABLE 6, SHT 2) .044 1.12 REF (SEE FIG 11, SHT 7) DOT APPLICATOR-KAPTON TAPE. LEAD STYLE -02.0 (SEE TABLE 1) -03.0 (SEE TABLE 1) -03.5 (SEE TABLE 1) ***-05.5 (SEE TABLE 1) ****-06.5 (SEE TABLE 8, SHT 3) -07.0 (SEE TABLE 8, SHT 3) -09.0 (SEE TABLE 8, SHT 3) -11.0 (SEE TABLE 8, SHT 3) *-13.0 (SEE TABLE 8, SHT 3) .100 2.54 REF (TYP) 'B' TAPE & REEL (SEE NOTES 9 & 10) K DOT (PER ROW) C CL "A" SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR No OF POSITIONS OPTION -GP: GUIDE POST (SEE FIG. 9, SHT 6) (ONLY AVAILABLE WITH -02.0 LEAD STYLE, 20, 30, 40, & 50 POSITION) -EP: EXTENDED GUIDE POST (SEE FIG. 10, SHT 6) (ONLY AVAILABLE WITH -02.0& -03.5* LEAD STYLE 20, 30, 40, & 50 POSITION) PLATING SPECIFICATION ALIGNMENT PIN -L: 10µ" LIGHT GOLD IN CONTACT AREA, MATTE TIN ON TAIL -(LEAD STYLE -02.0 THRU-05.5: .060 1.52 USE NEW-SUB-T-1M36-XX.X-L-X) REF -(LEAD STYLE -06.5 THRU-13.0: USE NEW-SUB-T-1M38-XX.X-L-X) 30µ" SELECTIVE GOLD IN CONTACT .035 0.89 REF -SM:AREA, MATTE TIN ON TAIL -(LEAD STYLE -02.0 THRU-05.5: USE NEW-SUB-T-1M36-XX.X-S-X) -(LEAD STYLE -06.5 THRU-13.0: USE NEW-SUB-T-1M38-XX.X-S-X) -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -(LEAD STYLE -02.0 THRU-05.5: .040 1.02 USE NEW-SUB-T-1M36-XX.X-S-X) REF -(LEAD STYLE -06.5 THRU-13.0: USE NEW-SUB-T-1M38-XX.X-S-X) -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD(90/10 5%) ON TAIL .050 1.27 -(LEAD STYLE -02.0 THRU-05.5: USE NEW-SUB-T-1M36-XX.X-STL-X) REF -(LEAD STYLE -06.5 THRU-13.0: USE NEW-SUB-T-1M38-XX.X-STL-X) (SEE NOTE 6) SOLDER COMPOSITION & STYLE C -1: 63% TIN / 37% LEAD CHARGE TAIL (USE NEW-T-1M3X-XX.X-XXX-1) -2: 95.5% TIN / 3.8% SILVER / .7% COPPER CHARGE TAIL (USE NEW-T-1M3X-XX.X-XXX-2) ROW -04: 4 ROWS (SEE FIG 3, SHT 4) (NOT AVAILABLE IN -13.0 LEAD STYLE) -05: 5 ROWS (SEE FIG 7, SHT 5)(SEE NOTE 14) -06: 6 ROWS (SEE FIG 6, SHT 5) -08: 8 ROWS (SEE FIG 1) -10: 10 ROWS (SEE FIG 4, SHT 4) ■-14: 14 ROWS (SEE FIG 5, SHT 4) * = NOT TOOLED = 10 POSITION ONLY AVAILABLE IN -04 ROW LEAD STYLES -02.0, -03.0, -03.5, -07.0, -09.0, -11.0. AVAILABLE IN -06 ROW LEAD STYLES -02.0, -03.0, -03.5 = ONLY AVAILABLE IN A 10 ROW; 4 ROW, -02.0 LEAD STYLE AVAILABLE = ONLY AVAILABLE WITH -02.0 OR -03.5 LEAD STYLE & 4 ROW; -03.0 AVAILABLE ** = ONLY AVAILABLE IN 6 ROW WITH -03.5 OR -05.5 LEAD STYLE *** = ONLY AVAILABLE WITH 19 POSITION, 6 ROWS **** = ONLY AVAILABLE IN 8 & 10 ROW ■ = 14 ROW ONLY AVAILABLE IN -40 POSITION, -02.0 AND -03.5 BODY HEIGHTS. .034 0.86 REF "G" REF .044 1.12 REF "F" REF (SEE TABLE 6, SHT 2) FIG 1 -08: 8 ROW (SEAM-30-02.0-XXX-08-1-A-XX-K-TR SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 0.50 LBS. 3. NOTE DELETED. 4. 5 ROW SOLDER TAILS ARE NOT SYMMETRICAL WITH BODY WIDTH (.378[9.60] SEE FIG. 7, SHEET 5). 5. WHEN APPLICABLE, DIMENSION C8 MUST BE MEASURED USING INSPECTION FIXTURE AT-1817-836-1 FOR 4 ROW OR AT-1817-836-2 FOR 6, 8 & 10 ROW, USE CO-AU-WI-2003-M FOR PROCESS. 6. WITHOUT -A AVAILABLE FOR EXISTING CUSTOMERS ONLY AS OF REVISION AD. 7. NOTE DELETED. 8. NOTE DELETED. 9. FOR QUANTITIES UP TO 49 PIECES, NO LEADER, TRAILER, OR REEL WILL BE SUPPLIED. FOR QUANTITIES 50 - 124, NO LEADER OR TRAILER WILL BE SUPPLIED. 10. ATTACH LABEL "SEAX-0001" TO EACH TAPE & REEL PACKAGE. 11. SOLDER CHARGE VOLUME IS 0.891 x 10^-5 IN ^3 REF. 12. NOTE DELETED. 13. MEASURED FIRST AND LAST POSITIONS ONLY, ALL ROWS. 14. THESE OPTIONS AVAILABLE AS ASO (APPLICATION SPECIFIC OPTIONS) ONLY. PLEASE CONTACT SAMTEC FOR MORE INFORMATION. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK, UL 94 V-0 TERMINAL: COPPER ALLOY F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 1 OF 7 REVISION CI +.002 +0.05 C .056 - .007 1.42 - 0.16 (TYP) .011 0.28 REF CL .028 0.72 REF (SEE TABLE 7) C C .011 0.27 REF .002±.003 0.05±0.08 (SEE NOTE 5 AND 13) NEW-SUB-T-1M36-XX.X-XXX-X SOLDER CHARGE .050 1.27 REF DETAIL 'B' SCALE 7 : 1 C .0175±.0030 0.445±0.076 "L" (TYP) C C "K" SECTION "A"-"A" SCALE 4 : 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 2 OF 7 REVISION CI FIG 2 -06.5 THRU -13.0 LEAD STYLES (SEAM-20-09.0-XXX-08-1-A SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) "A" REF (SEE TABLE 6, SHT 2) "D" (SEE TABLE 6, SHT 2) C .050 1.27 A1 -07.0 LEAD STYLE (SEAM-XX-07.0-XXX-08-X-A SHOWN) "Q" C REF CL CL H1 "B" REF (SEE TABLE 6, SHT 2) SEAM-XX-00.1-XX "P" REF SEAM-S-XX-XX.X-XX-A .050 1.27 (TYP) NEW-SUB-T-1M38-XX.X-XXX-X "E" (TYP) (SEE TABLE 6, SHT 2) C +0.05 .053+-.002 .003 1.35 - 0.08 C 'D' "N" C * C .056±.003 1.42±0.08 DETAIL 'D' SCALE 8 : 1 CL CL .050 1.27 .044 1.12 (TYP) C .0175±.0030 0.445±0.076 SCALE 3.5:1 C F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 3 OF 7 REVISION CI FIG 4 FIG 3 -10: 10 ROW (SEAM-20-02.0-XXX-10-1-A SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) -04: 4 ROW (SEAM-20-02.0-XXX-04-1-A SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) .050 1.27 REF A1 .578 14.68 REF .152 3.86 REF .452 11.48 REF .150 3.81 REF .300 7.62 REF CL .100 2.54 REF D1 .278 7.06 REF A1 CL .063 1.60 REF J1 FIG 5 -14: 14 ROW (SEAM-40-03.5-S-14-2-A-K-TR SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) (ONLY AVAILABLE IN 40 POSITION, -02.0 AND -03.5 BODY HEIGHTS) CL A1 .778 19.76 REF .652 16.56 REF .250 6.35 REF .500 12.70 REF N1 * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE:2:1 F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 4 OF 7 REVISION CI FIG 8 CL .378 9.60 REF .252 6.40 REF -19: 19 POSITIONS (SEAM-19-05.5-XXX-06-1 SHOWN) (ONLY AVAILABLE IN -06 ROW WITH -03.5 OR -05.5 LEAD STYLE) (SAME AS FIG 6, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) .050 1.27 REF (TYP) A1 CL .100 2.54 REF F1 SEAM-XX-XX.X-06-X CL A1 .030 0.76 REF .040 1.02 REF CL F1 SEAM-19-XX.X-06-X FIG 6 -06: 6 ROWS (SEAM-20-03.0-XXX-06-1-A SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) CL A1 CL E1 .378 9.60 REF (SEE NOTE 4) SEAM-XX-XX.X-05-X "G" .068 1.73 REF .002 0.05 REF .072 1.83 (SEE NOTE 4) "G" C .128 3.25 (SEE NOTE 4) SECTION "G"-"G" FIG 7 -05: 5 ROWS (SEAM-20-03.5-XXX-05-1-A SHOWN) (SAME AS FIG 6, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) (SEE NOTE 4) F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 5 OF 7 FIG 9 REVISION CI -GP: GUIDE POST OPTION (ONLY AVAILABLE WITH -02.0 LEAD STYLE, 20, 30, 40, & 50 POSITIONS) (MATES WITH SEAF RIGHT ANGLE ONLY) (SEAM-20-02.0-XXX-06-1-A-GP SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) FIG 10 -EP: EXTENDED GUIDE POST OPTION (ONLY AVAILABLE WITH -02.0 & -03.5 LEAD STYLES, 20, 30, 40, & 50 POSITIONS) (SEAM-20-03.5-XXX-06-1-A-EP SHOWN) (SAME AS FIG 9, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) "V" REF .218 5.54 REF WT-58-XX-X +.005 "W" - .008 +.005 C 2 MAX SWAY (EITHER DIRECTION) WT-42-01-T "W" - .008 C C .120 3.05 REF SEAM-XX-02.0-XX-A-GP .285 7.24 REF R.060 1.52 REF 2 MAX SWAY (EITHER DIRECTION) C .320 8.13 .438 11.13 REF .010 0.25 REF C "Y" "X" REF .070 1.78 REF C SEAM-XX-03.5-XX-A-GP .020 0.51 SQ REF (TYP) .117 2.97 SQ REF (TYP) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 6 OF 7 REVISION CI C "T" .020[0.51] CL CL "S" .020[0.51] "U" (INCL. K DOT) "R" C C FIG 11 -K: K DOT (SEAM-20-02.0-XXX-08-1-A-K SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (SOME CENTER FEATURES REMOVED FOR CLARITY) F:\DWG\MISC\MKTG\SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 PITCH TERMINAL ARRAY ASSEMBLY DWG. NO. SEAM-XX-XX.X-XXX-XX-X-A-XX-K-TR BY: BRATCHER 08-09-2010 SHEET 7 OF 7
SEAM-20-02.0-STL-10-1-A-K-TR 价格&库存
很抱歉,暂时无法提供与“SEAM-20-02.0-STL-10-1-A-K-TR”相匹配的价格&库存,您可以联系我们找货
